strength of 2k2 auto tranny?
Old Sep 9, 2003 | 12:45 PM
  #81
bigdo26's Avatar
i threw an SES the 2nd time I started the car after unhooking the plug. And its still on after re-connecting the plug. Oh well... gotta install a switch.
Old Sep 9, 2003 | 09:09 PM
  #82
][ 35's Avatar
Originally Posted by Quicksilver
Check the other thread on this page dude...someone is trying one now.
thanks for the tip...
Old Sep 9, 2003 | 09:25 PM
  #83
beejo's Avatar
but if i unplugged the sensor?
will it cause any problem?? or is it dangerous to do so??! concern?!
Old Sep 9, 2003 | 09:56 PM
  #84
][ 35's Avatar
i test drove it for 2 days about 200 miles and i didn't get the SES light.... but like most people said there is big thug going form 1-2nd but after i didn't feel the thug as much.....
Y2Kevse said it's actually better for the transmission but thug is going to hurt the mount....
hopefully some one will do a write up to attach a switch....
Old Sep 10, 2003 | 08:26 PM
  #85
DonGfun's Avatar
VW = 30 MPG
I did it!!! I want to put it on a switch ... Too much rush hour driving
Old Sep 10, 2003 | 08:28 PM
  #86
Quicksilver's Avatar
OT n00bs FTMFCSL
The motor mounts from Cattman for the 4th Gen will work in the 5th Gen IIRC...
Old Sep 25, 2003 | 06:25 AM
  #87
Timz96SE's Avatar
Originally Posted by soundmike
Oh, wth i went ahead and did it.
These guys are right about the stronger shifts, but it's way too strong for my tastes. When pulling out of the driveway and/or trying to go slow the shifts really get to you - not only do you feel it, but it makes a *thud*. 1-2 is quite abrupt, 2-3 is moderately so.
I also tried gunning it from a stop to highway speeds, i didn't like it. The shift is just *hard*. Not like 1-2 shifts on a manual hard... but car shaking/thud sounding hard.
Didn't get an SES light, but when i reattached the connector i had my AT light blink. Turned the engine off a sec, turned the ignition to ACC for a couple of seconds and started. AT light gone.
Ok for one the Drop Resistor mod is great. It will make your tranny last 4 times longer than leaving it plugged in. The reason for that Resistor is so you get a more soft and comfort shift. Our Transmission's are electronically controlled with shift solnoids. Now when you disconnect the resistor. You will get very harsh feeling going into first to second gear being that there is more line pressure. The reason, go right into gear, rather than slipping into gear. See its the slipping into gears that screws your tranny up, in the long run. Because slipping into gears will make your clutches in the tranny wear out quicker. You should also get a tranny cooler, which is about $40.00. This will keep the temp down in the tranny. Because if you increase the line pressure in your transmission, the fluid will get hot. Hot tranny fluid is bad. You can even wire a switch to your resistor. So you will only use it when you want. Yes it is proven to make my car 3 tenths quicker in the1/4 mile.
Old Sep 25, 2003 | 06:38 AM
  #88
soundmike's Avatar
Very sound, Mike
It may be good for the transmission, but i can only imagine what kind of damage it can give to other areas. Mounts come to mind.
Old Sep 25, 2003 | 02:29 PM
  #89
bremner44's Avatar
Anyone do a write-up on how to install a switch and what kind of switch yet? If so post the link.
Old Sep 25, 2003 | 02:47 PM
  #90
bremner44's Avatar
Oh yeah, what's a VB mod? Can you post a link for it?
Old Sep 25, 2003 | 08:12 PM
  #91
Timz96SE's Avatar
Here is a link to Dons VB MOD.
http://www.mobiletek.net/
It will explain how it is done and what are the benifits.
Old Sep 25, 2003 | 09:12 PM
  #92
bremner44's Avatar
I unplugged it for the first time today. The shift from 1st to 2nd IS pretty stiff. The shift from Reverse to 1st is pretty healthy itself. It felt good when driving hard, but under normal driving it felt like I was running somebody over every time I went to 2nd. Need a switch to put where the steering wheel heater would be if I had one. I changed th color of my guage lights tonight, it's pretty cool. I'll take a pic and put it on .org when I get a chance.
Old Sep 26, 2003 | 05:12 AM
  #93
bigdo26's Avatar
Originally Posted by bremner44
but under normal driving it felt like I was running somebody over every time I went to 2nd. .
ha ya it does feel like i'm runnin someone over under light acceleration - not that i know
Old Sep 26, 2003 | 05:32 AM
  #94
soundmike's Avatar
Very sound, Mike
Definitely!
Old Sep 26, 2003 | 12:15 PM
  #95
kcowden's Avatar
Where is this sensor your talking about??? The pic's aren't showing up on my computer. Is there a write up on the resistor mod??
Old Sep 26, 2003 | 12:18 PM
  #96
soundmike's Avatar
Very sound, Mike
Copy and paste this link into your browser's address bar:
http://www.nissanx.net/gall/alb/album24/1_G.jpg
Old Sep 26, 2003 | 12:38 PM
  #97
kcowden's Avatar
Thanks. Did you make a switch fot the resistor? Iv'e read the whole thread and know that with the switch it's either on or off,.
Old Sep 26, 2003 | 12:41 PM
  #98
soundmike's Avatar
Very sound, Mike
I actually plugged it back in only 10 minutes after taking it off. I didn't like it at all - it may be good for the transmission, but i can only guess what bad thing it can do to the mounts to say the least.
Sorry i can't be of more help
Old Sep 26, 2003 | 12:58 PM
  #99
kcowden's Avatar
Thanks for the pic.
Old Sep 26, 2003 | 01:35 PM
  #100
kcowden's Avatar
Mine is in a different place than the picture. Does anyone know where it is on an 03??? Thanks in advance.
Old Sep 26, 2003 | 01:39 PM
  #101
soundmike's Avatar
Very sound, Mike
Really? I'm surprised that's the case... what's in its place instead?
Old Sep 26, 2003 | 01:42 PM
  #102
kcowden's Avatar
There is a long thin 1/4 inch square about 3-4 inches long connector. It doesn't look anything like the pic.
Old Sep 26, 2003 | 01:44 PM
  #103
soundmike's Avatar
Very sound, Mike
That could be it... maybe Nissan changed the connector type?
Old Sep 26, 2003 | 01:45 PM
  #104
kcowden's Avatar
My thoughts exactly.... hmmmmmm.
Old Sep 26, 2003 | 01:46 PM
  #105
soundmike's Avatar
Very sound, Mike
If it was me i'd try it, but if they changed the connector type - there's also a chance it may not be the right one either.
It's up to you, to try it or not.
Old Sep 29, 2003 | 11:22 AM
  #106
bremner44's Avatar
Still waiting for someone to make a switch so you can turn it on and off in the car and post instructions on how to do it. I'd try it but I don't have a clue about that kind of stuff.
TallTom
57
Oct 14, 2025 05:16 PM
fx4five
Oct 18, 2015 06:57 PM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
