Rattling Noise When Starting Cold
Old 02-11-2007, 04:50 PM
  #41
shobuddy's Avatar
shobuddy is offline
Old 02-11-2007, 05:03 PM
  #42
U wanna try me young boy?
Scruit's Avatar
My 96 rattle when it's 1) cold, 2) oil level is low and 3) FRAM filters.
Take away any of those three things and the rattle goes away.
Scruit is offline
Old 02-13-2007, 07:57 PM
  #43
BigFly_2K2SE's Avatar
Originally Posted by shobuddy
I've got an 03 Max and have been experiencing the rattling noise on start for a little while now. Like most of you guys, it usually happens on a cold start and doesnt' happen every time. Glad to know theres a TSB out there. Does anyone know how much this would cost to get fixed by the dealers or a service shop. Also, is the rattling causing any damage? Or is it ok to ignore the sound if its not going to cause/causing any problems.
I don't know for sure how much the TSB would cost but they take apart half your engine so it would be expensive.
As far as I have determined reading this sight, the rattling is not causing damage to anything other than maybe your sanity. My 2K2 does the same thing and I plan to ignore until it is unbearable. It has been doing it for a year or so now and it hasn't gotten any worse.
BigFly_2K2SE is offline
Old 04-04-2007, 12:01 PM
  #44
djchinky's Avatar
i talked to nissan service advisor and told him about the TSB for 02 maxima's, but he said that is not the problem because that tsb was for 02 maximas.. does this sound right? i have an 03??
djchinky is offline
Old 04-04-2007, 01:02 PM
  #45
shobuddy's Avatar
According to http://www.nissanhelp.com/ownership/.../NTB03-060.htm it applies to 03 Maximas as well. Print that out and show them.
shobuddy is offline
Old 06-27-2008, 09:30 AM
  #46
NismO2max's Avatar
-Has anyone done this TSB #60???
-How much did it end up costing?
-Did it actually take care of the issue?
-Is this something I could order from Dave B and have my mechanic do?
Trying to stay away from the stealership.
NismO2max is offline
Old 07-15-2008, 10:38 PM
  #47
Borg79's Avatar
i too get this rattle, about 1 sec, only when its warmer out but the car is dead cold...the VTC sprocket is under the timing chain cover, and that would be complete hell to replace, personally i would just live with the rattle rather then fix it
Borg79 is offline
Old 07-15-2008, 11:00 PM
  #48
CMax03's Avatar
try the Wix filters and stay away from those sorry *** Fram filters...Fram has never been the same since bought buy Allied signal about 15-20 yrs ago. Fram of the 60's- the early 80's was the real deal in reliability and durability and was the world's standard for racing oil filters (HP series).....
CMax03 is offline
Old 07-16-2008, 08:42 PM
  #49
Amit56's Avatar
i would not worry about, it only has 15k miles correct.
Amit56 is offline
Old 07-16-2008, 10:29 PM
  #50
That's Mr. Detail to you
Scottwax's Avatar
Mine has done it since I got it. Last just a second or two. Since Nissan only put out a TSB instead of a recall, it seems the noise isn't the sound of impending engine failure. At the last Dallas area Maxima meet I was at, it seemed all the 5.5 gens had the start-up rattle, regardless of mileage.
Scottwax is offline
Old 07-17-2008, 07:53 AM
  #51
ghostrider17's Avatar
Yep - mine has done it intermittantly since I drove it off the lot new....not once yet heard anyone say theri engine failed because of this.
Mine will remain as is.
gr
ghostrider17 is offline
Old 07-17-2008, 09:19 AM
  #52
'02_EMILBUS's Avatar
I got a price from DaveB a couple weeks ago for $332... its not an easy job and not cheap either. It pisses me off as well, but I'm going to have to deal with it.
I changed my oil filter to a Mobil1 (m1-108) this week so we'll see if that helps much.
I agree with Scruit (post #42).
It definitely rattles more when the oil level is low... sucks for us that have an oil burning 3.5!
It's just kustom, if anyone asks thats in the car.
'02_EMILBUS is offline
Old 07-17-2008, 09:24 AM
  #53
dot dot dot ...
NmexMAX's Avatar
Try an OEM filter. Mine improved w/ the M1, but, who knows, maybe yours will w/ the OEM Nissan unit.
NmexMAX is offline
Old 07-17-2008, 02:14 PM
  #54
sublime258's Avatar
I have the timing chain rattle too...lasts for about 1/2 second, right after the starter cranks. Doesn't bother me too much.
sublime258 is offline
alahjahwan09
18
09-21-2015 09:12 PM
jfl330
09-04-2015 01:44 PM
trungg86
09-04-2015 04:58 AM
Justin Kroll
09-02-2015 11:06 AM
Quick Reply: Rattling Noise When Starting Cold
