Installed Jet V-force
Old Jun 17, 2001 | 01:48 PM
nismomax's Avatar
I just installed the Jet V-force in less than an hour. I did couple of hard accerations with the V-force on and then off to feel the difference in gains. The car certaintly pulls harder at all gears, especially noticable from 3rd gear and up. I would say that performance gain is equivalent to an intake and exhaust, maybe more, but would need dyno to be certain.
Old Jun 17, 2001 | 01:51 PM
MarshMan's Avatar
what exactly is the Jet V-force?
Jonathan Marsh
Old Jun 17, 2001 | 02:01 PM
nismomax's Avatar
V-force is a power control module that optimizes the ingnition sparks and the air/fuel ratio. I think it's similar to the HKS AFC except HKS does not optimize ignition.
Jonathan Marsh
Old Jun 17, 2001 | 03:21 PM
Max_Vader_2K's Avatar
Web site????
Or place of purchase?
Old Jun 17, 2001 | 03:30 PM
nismomax's Avatar
Re: Web site????
Visit www.jetchip.com They have info there.
Old Jun 17, 2001 | 04:03 PM
Re: Re: Web site????
What was the install like?
Old Jun 17, 2001 | 05:08 PM
footemps's Avatar
i heard the jet ecu upgrade doesn't do as much as other ecu upgrades
Old Jun 17, 2001 | 05:31 PM
annimax's Avatar
Thanks for the info! This sounds like an affordable mod that adds a nice HP gain KULE!
Old Jun 17, 2001 | 05:52 PM
nc00max
A few ?'s...Do you have to have anything else to go with it, did it kill your gas mileage, and what did it take to install. For $240, I might have to make it my next mod...
Old Jun 17, 2001 | 06:05 PM
2kseman's Avatar
V-force module, yes I can relate!
Nismomax, it't great to see another "actual" V-force module user. Several people have inquired about it, and I gave them the info. I know exactly what your talking about by the car pulling harder in all gears!! Yes, some one who can relate!! Like that Infinity commercial, "Own one, and you'll understand" Btw, I installed it right under the steering wheel column, it's a perfect fit....
Old Jun 17, 2001 | 06:35 PM
AznWontonboy's Avatar
u sure these gains arent physcological?some people have said it had no gains.. neone have a dyno chart to show the gains?
Old Jun 17, 2001 | 06:42 PM
If it is easy to install....
I will buy one, install, and get it dynoed.
Old Jun 17, 2001 | 09:10 PM
MarshMan's Avatar
Re: If it is easy to install....
Wow, thanks.
Jonathan Marsh
Old Jun 17, 2001 | 09:43 PM
nismomax's Avatar
Installation can be done by a novice. The hardest part is drilling a hole in the firewell for the wires.
Old Jun 17, 2001 | 10:32 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
If it's that easy to install, you should dyno your car, install it, and then get another dyno hopefully within the same day.
Old Jun 18, 2001 | 06:20 AM
mdeal's Avatar
Didn't you have to send your ecu off to get it re-programmed?
Old Feb 2, 2003 | 12:59 PM
MaxSpeedSE's Avatar
Anyone dyno theres yet?
Old Feb 2, 2003 | 01:14 PM
02MaximizedVQ's Avatar
JET is a joke on most car forums. *I am not saying they don't make some legitimate products* If I saw some dyno gains I'd buy this week.
Old Feb 2, 2003 | 02:56 PM
Sam03's Avatar
On the 3rd Gen Eclipse GT, which I am also an owner of, the Jet is pure and simple junk. I am a Moderator at www.eclipseforums.org and I am very familiar with Jet, the V-force, and the fact that on multiple dyno'd Eclipse's. The Jet didn't do a single thing.
Jet may be great for big block Domestic cars, but from my experience, you don't realize any power from it on a smaller displacement Japanese engine/ECU.
Old Feb 2, 2003 | 03:19 PM
Guru's Avatar
Yep, I'd be pretty darn skeptical too. I once scanned one of their so called custom Honda chips and came up with an exact copy of an old Dinan program. I scanned a different one and it was stock mapping. They really have no clue as to what they're doing over there and I'd be worried about engine damage if they are messing with your timing and fuel curves.
Old Feb 2, 2003 | 03:38 PM
MaxSpeedSE's Avatar
a lot of people say there junk, but that's because jet has done nothing for them... ive read 2 or 3 people on this post clam this product they make works, and even a guy in my local area swears by it, so personally im convinced on this product...id like to see some real proof though before i buy
Old Feb 2, 2003 | 10:59 PM
DrVolkl's Avatar
I had one on my 98 GSR and all it did was trip the SES light...I hated the damn thing. It felt a little faster when it worked, but it rarely worked without screwing up the computer and causing limp mode.
Old Feb 3, 2003 | 12:42 AM
clipse's Avatar
MaxSpeedSE,Nice Sig Pic. I'd install my Jet V-force in her to see how much HP gains I can get.....Just kidding (don't take it personal) Like MaxSpeedSE said,I'd like to see real proof also. Before purchasing. Does this unit work like a FIELDS VTEC Controller/APEXi VAFC????....
Old Feb 3, 2003 | 08:40 AM
MaxSpeedSE's Avatar
From the person ive been talking to that owns one, does compare it to Vtec...he said that it helped his car in only higher RPMs and he feels no lose in low rpms...but then agian hes just saying that by feel...id like to see some before and after numbers still
Old Feb 3, 2003 | 08:58 AM
MaximaMan77's Avatar
Re: Re: If it is easy to install....
There is never a need to drill through the fire wall for sipmle wiring! There is a boot for the harness above and behind the the fuse box. It goes into the drivers side wheel well, from there you route it to the engine compartment. Jack up the car take off the front drivers side wheel. Then remove the slpash gaurd and you will see it. It's 2 to 2-1/2 inches in diameter. Just cut through the rubber run your wires and seal it up with silicone.
Old Feb 3, 2003 | 09:07 AM
2k2kev's Avatar
It's chrome alright...
WHERE'S THE DYNO?!?!
I keep reading about "feel"... what about some numbers???
So, 2kseman, you'll find more
"actual" V-force module user(s)
if someone (not Jet) DYNO'S THE DAMNED THING!
Old Feb 3, 2003 | 09:08 AM
IceY2K1's Avatar
Re: Re: Re: If it is easy to install....
There is no need to jack up the car. It can easily be done on the ground.
Old Feb 11, 2003 | 09:57 PM
2k2PhatMax's Avatar
Sold 2 99Silvermist SE :)
ANY ONE DYNO THER CAR YET??????
Old Feb 12, 2003 | 07:48 AM
2k2kev's Avatar
funny how people will spend $240 on something but won't pop the cash to see if it actually did anything!
I'd hate to throw lots of love on something like this chip only to dyno and actually find out it doesn't give any gains, and may in fact cause you to lose power in some areas.
I think mods should lock all threads on this topic until someone (NOT JET!) dynos it. If it does "make the car pull harder in all gears" I'm sure there'll be a backorder on these things in the near future as we all pile on the V-chip wagon.
bbsitum
Sep 6, 2019 07:31 PM
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
