5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Dec 4, 2007 | 05:27 PM
  #4041
Tee00Max's Avatar
has anyone tried pressure washin their floor mats??? factory.....
Old Dec 4, 2007 | 05:32 PM
  #4042
MoeBelikeMax's Avatar
Whats is the Door speaker Size On the 2000 Se...Got a big sell at best buy and i want to buy some speakers ...oh and the Tweeters size Too
Old Dec 4, 2007 | 05:37 PM
  #4043
El_PrOfE's Avatar
Question, I know its stupid but I have been hearing this rattling noise coming from the front end of my car when I go over a speed bump. anyone know what it can be? Could it be a TSB?
Old Dec 4, 2007 | 05:55 PM
  #4044
Nismo1's Avatar
Originally Posted by chopstix2nrz
holy crap im surprised no one posted you an answer on this, this isnt safe at all!
IIRC your car should come with ABS standard, dunno whats up with your car though. Reason why i say it should have ABS standard because when i look up parts for our cars at work esp cv axles and other driveline/brake components i do not get an option for non abs equipped vehicles
I agree with you that the 2001 SE Maxima should come with ABS standard. I have a car dealer appointment to see what happened for the ABS system. By the way, would you mind taking a look under the hood on the drivers side right in front of the battery? There should be a relay box. On top of the cover should indicate what are the relay uses? For exmaple, ABS motor, ABS actuator, radiator fan, etc. Can you open the relay box and see if the positions are filled with these relays?
I appreciate your help!
Old Dec 4, 2007 | 06:00 PM
  #4045
00SEMAX19's Avatar
Mine has both an abs solonoid and abs motor fuse. both are 40A and are there. Good luck and let us know what you find.
Old Dec 4, 2007 | 06:09 PM
  #4046
Nismo1's Avatar
Nissan Maxima SE ABS
Originally Posted by 00SEMAX19
I've also been thinking about this.
First thing I would do is check your computer to see if there are any stored codes. Did you buy your car from a private party or a dealer? The abs light should come on when you turn the key to ignition on. Maby somebody disfunctioned the abs and removed the bulb from the instrament cluster. Not a good idea but I've done this on a lexus before and all it did was make the brakes function like a car that never came with abs. Good luck and let us know what you find.
I bought the used car from a dealer. I have not checked the computer yet, but I do not have the check engine or any lights on. My ABS light has never come on, no matter how I turn the ignition. I do not know if the bulb has been removed. Do you know if it could be disabled?
There are no self test ABS diagnostic after start up. I am familiar with the ABS self test sound since I do have different Nissan vehicles in our family.
What's the other possibility that the ABS light never comes on?
I appreciate your input.
Old Dec 4, 2007 | 06:27 PM
  #4047
Nismo1's Avatar
2001 se Maxima
Are you talking about fuse box left side of battery?
Yes, I do have ABS solonoid and ABS motor fuse in the fuse box on the left side of the battery. I am talking about the one black relay box front side of Battery. It should be said ABS actuator, ABS motor, radiator fan and so on.
Old Dec 4, 2007 | 06:28 PM
  #4048
Nismo1's Avatar
2001 se Maxima
Old Dec 4, 2007 | 07:46 PM
  #4049
rony_espana's Avatar
Originally Posted by NmexMAX
Do the MAF and take it from there. If it is still acting up, do the ECM update.
Try sanding them first, if that doesn't work, look for some cheap used housings (www.car-part.com, on here, eBay, www.pinnaclenissan.com, Dave Burnette, etc) . You have an 02 so you can still retain the HID's, meaning all you need is the housing.
Yeah basically I just want to see how it looks with the oem headlight capsules, want to compare, I may just go alone with trying to clean them up, but want to try the stock bulbs. Oh and by the way I didn't buy the projector headlights, just the stock looking ones with phillips HIDs, kind of like these:
http://cgi.ebay.com/ebaymotors/02-03...QQcmdZViewItem
So I guess my question is if all capsules are the same wattage? If so I don't think it should be a problem. I'm sure someone here has replaced capsules, so I'm guessing this is possible.
Old Dec 4, 2007 | 08:14 PM
  #4050
Scottwax's Avatar
That's Mr. Detail to you
Originally Posted by UConnJack
Thanks. Is cleaning the MAF worth trying first, has anyone had any luck with this solving the problem? Or should I just go right to the replacement?
Well, since cleaning is free, I'd try that first. You may get lucky.
Old Dec 4, 2007 | 08:17 PM
  #4051
SoonerFan's Avatar
Cletus
usually MAF problems are because they are going out...not dirty.
but if you want to try http://forums.maxima.org/showthread....ht=maf+cleaner
  #4052
Scottwax's Avatar
It would be fine. You can also soak them in the tub for a few hours with some laundry soap, rinse, squeegee out the excess water, let drip dry, then toss in the dryer for 20-30 minutes on medium heat.
Old Dec 4, 2007 | 08:20 PM
  #4053
SoonerFan's Avatar
Cletus
or buy new ones.
http://www.courtesyparts.com/Merchan...=A33_mats_2002
Old Dec 4, 2007 | 08:30 PM
  #4054
Scottwax's Avatar
Originally Posted by soonerfan
Once I cleaned mine, they looked really good. The back ones are pretty much perfect, honestly, the whole back of the car looks like it has rarely been used.
Good price on the mats though.
Old Dec 4, 2007 | 08:38 PM
  #4055
SoonerFan's Avatar
Cletus
i steamed cleaned mine several times and they still looked bad. not just dirty but worn out. especially the drivers side....worn down spots from my heels.
Old Dec 4, 2007 | 08:59 PM
  #4056
Scottwax's Avatar
I've noticed that in customer's cars that have manual transmissions. The driver's side mat takes a real beating.
Old Dec 4, 2007 | 09:06 PM
  #4057
SoonerFan's Avatar
Cletus
exactly why mine are bad. both feet are used and move around a lot more.
Old Dec 4, 2007 | 09:54 PM
  #4058
spdfreak's Avatar
Made my own from Home Depot.
I bought commercial grade carpet runners (usually made for hallways) with a rubber backing. Traced the factory mats, but cut the carpet slightly bigger for the added protection.
Singed the edges with a lighter, and if you want it to conform to the contours of the floor you can heat it with a heat gun and while still warm place it in its desired location, but it will eventually place itself and form to the floor.
Works great for me, and also matches the interior.
Old Dec 5, 2007 | 06:29 AM
  #4059
NmexMAX's Avatar
dot dot dot ...
Cleaning it is a good idea, but my guess is that it wont help much if at all.
Worth a try I guess.
Old Dec 5, 2007 | 10:20 AM
  #4060
Dynasty47x1's Avatar
Is there a writeup somewhere on the Gab mod i see Irishi's Os mod?
Old Dec 5, 2007 | 10:37 AM
  #4061
ktcp643's Avatar
I know this has been discussed a lot, but i havent found quite what i was looking for. If i missed it im sorry. I Have a 2002 and my maf went out, after some reading i decided to replace it with one from an '01 (2y001 or something like that) The car runs now, but I feel like I have lost A LOT of power on the lower end. I have asked dealerships but of course they tell me it's because I have the wrong sensor in. Has anyone else experienced this? Is it possible to just get my ECU reprogrammed? Everyone else has said it worked like a dream but i was left happy because my car was ruinning again but very pissed off when i really step on the gas. any help would be great!
Old Dec 5, 2007 | 03:22 PM
  #4062
maxximaa's Avatar
what's emanage? aftermarket ECU?(for auto) If piggy back is not the same, what's the difference from emanage? what does it do? cant i just tune/map out the OEM ECU?
i need details on this if someone has a link. sorry not a pro on cars....
Old Dec 5, 2007 | 04:44 PM
  #4063
NmexMAX's Avatar
dot dot dot ...
Read the All Motor Stickys.
Read the 5th gen stickys.
Any new codes?
Old Dec 5, 2007 | 07:10 PM
  #4064
UnseenShadow's Avatar
I have a 2002 GLE and my driver side windshield washer nozzle does not spray near as well as the passenger side... the pressure is very low compared to it. Could this be a pump problem or do i need a new nozzle? I really hate to take it in to the shop to have this looked at. But with the snow flying and the salt hitting the road i need to fix this one ASAP. Thanks
Old Dec 5, 2007 | 07:14 PM
  #4065
AceofSpds's Avatar
wat
They both use the same pump, check the hosing for leaks. And have you cleaned out the nozzel with a needle? It might help.
Old Dec 5, 2007 | 07:19 PM
  #4066
ill check the hoses tomorrow and see about the needle... i am kinda iffy on the needle because im worried about breaking something... im cautious about my baby but ill see what i got
Old Dec 5, 2007 | 07:40 PM
  #4067
NmexMAX's Avatar
dot dot dot ...
Use a needle or knife end to clear it. Don’t be a , use some force, and don’t be afraid.
Works on mine all the time.
Old Dec 5, 2007 | 08:27 PM
  #4068
SoonerFan's Avatar
Cletus
bump for people like "hotstartup"
Old Dec 5, 2007 | 08:29 PM
  #4069
Scottwax's Avatar
Clean the nozzle. 95% of the time, that is the problem.
Old Dec 5, 2007 | 11:34 PM
  #4070
spdfreak's Avatar
IIRC clean it with a pin used by tailers to keep a hem of a pair of pants up. They are the really thin ones.
If you do replace them, you may want to replace them with Nissan Murano nozzles. They are fan spray, insead of stream.
Old Dec 6, 2007 | 08:27 AM
  #4071
s10_mack's Avatar
Does anybody know, if it is possible to swap in an R33 RB26DETT motor into a 2000 Maxima GLE? If it is would it be possible to swap the differential as well, so that it would be all-wheel drive?
And I want to know if any companies make polyurethane body kits for the 5th gen maxima?
Old Dec 6, 2007 | 08:29 AM
  #4072
SEmy2K2go's Avatar
Go BUCKS!!!
With enough money, you can do anything. But...why? Just buy a skyline and get it over with.
Yes, this question has been asked about 3 million times before.
Old Dec 6, 2007 | 08:35 AM
  #4073
s10_mack's Avatar
I don't want a skyline, I want a Maxima with a skyline motor because I have a family that needs a sedan, and I want just want something to occupy some of my spare time. It's just a project.
Old Dec 6, 2007 | 08:40 AM
  #4074
SEmy2K2go's Avatar
Go BUCKS!!!
AGAIN...with enough money you can do anything.
Good luck
Old Dec 6, 2007 | 10:06 AM
  #4075
Scottwax's Avatar
Probably be more cost effective to find a totaled G37 and snag that motor, transmission and wiring harness for a swap. 85 hp more than stock right off the bat.
Old Dec 6, 2007 | 10:10 AM
  #4076
SEmy2K2go's Avatar
Go BUCKS!!!
Which is also RWD. People talk about doing these swaps a few times a year. I've yet to see one actually happen.
Old Dec 6, 2007 | 10:13 AM
  #4077
AceofSpds's Avatar
wat
here ya go
  #4078
Any info would help...
Old Dec 6, 2007 | 10:43 AM
  #4079
spdfreak's Avatar
Are you asking what the highest wattage bulb can be run in a capsule?
IIRC it's 50 or 55 watts.
Old Dec 6, 2007 | 10:44 AM
  #4080
spdfreak's Avatar
here ya go
On my way out later, I will check for you to compare.
