5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Mar 14, 2008 | 07:27 PM
  #5361
IHAVEA2KMAXIMA's Avatar
How do I disassemble the MAF sensor from the housing? Must I need the security torx key to separate the two?
Old Mar 14, 2008 | 07:44 PM
  #5362
SoonerFan's Avatar
Cletus
yes...
Old Mar 14, 2008 | 07:46 PM
  #5363
There is a lil blueish green tab, but I donno what it is for. I tried pushing and whatnot but nothing happened. And yes, my engine bay is not the cleanest and yes the screwing corner of my MAF housing is broken.
Old Mar 14, 2008 | 07:52 PM
  #5364
SoonerFan's Avatar
Cletus
you shouldnt work on your car
1. press in green tab
2. pull off harness from MAF
Old Mar 14, 2008 | 08:13 PM
  #5365
p2kmax's Avatar
where can i get me a b-pipe at? i check ebay and a few other searches but cant find nothin
Old Mar 14, 2008 | 08:23 PM
  #5366
SoonerFan's Avatar
Cletus
cattman
classifieds forum
Old Mar 14, 2008 | 09:58 PM
  #5367
p2kmax's Avatar
Originally Posted by soonerfan
cattman
classifieds forum
thanks sooner ill try the classifieds and ill check out the cattman site...but should i just replace that or get a whole system from the headers back i found a set on ebay but dunno how good they would be.
Old Mar 15, 2008 | 07:02 PM
  #5368
nebojsa_o's Avatar
I'm looking to buy a rear view mirror with the compass. Was the '03 Titanium Edition mirror the same as a '02 mirror except for the compass? (shape, buttons, size) And I saw some Infiniti mirrors on eBay that seem to be the same, wondering if those look the same?
On another note, I bought two new Falken Zeix 912ZEs today, and the front end feels better than the worn out Potenzas, and there is very little wheel hop now. It used to be terrible. Next week or week after that, the other two should arrive.
Old Mar 15, 2008 | 07:23 PM
  #5369
SoonerFan's Avatar
Cletus
you really only NEED the b-pipe for performance. a muffler only adds noise.
Old Mar 15, 2008 | 07:25 PM
  #5370
SoonerFan's Avatar
Cletus
its the same and the plug is the same...compass gets power from the same lines as the auto diming.
should have gotten toyo proxies 4
Old Mar 15, 2008 | 10:09 PM
  #5371
Scottwax's Avatar
That's Mr. Detail to you
Are they really that good? I've got Yokohama 520s with about 80% tread life left so I won't need tires right away, but it is always good to plan ahead.
Old Mar 15, 2008 | 10:13 PM
  #5372
SEmy2K2go's Avatar
Go BUCKS!!!
In a word, yes.
Old Mar 16, 2008 | 11:13 AM
  #5373
megalos's Avatar
i have a 2k maxima se and was looking into buying an air intake and catback exhaust system and was wondering if anyone had suggestions or any advice on what brand to buy or a short ram intake vs a cold air intake
Old Mar 16, 2008 | 11:46 AM
  #5374
SoonerFan's Avatar
Cletus
berk intake (there is no true CAI currently made)
cattman b-pipe with no muffler
Old Mar 16, 2008 | 12:51 PM
  #5375
megalos's Avatar
forgive me for being ignorant but i was wondering what part of the exhaust system the b pipe is i'm pretty new to cars but i really want to start learning about performance parts and everything else
Old Mar 16, 2008 | 06:06 PM
  #5376
SoonerFan's Avatar
Cletus
between cat and muffler
Old Mar 16, 2008 | 06:25 PM
  #5377
megalos's Avatar
oh alright thanks for the clearification on that
Old Mar 17, 2008 | 05:54 PM
  #5378
Nicktard's Avatar
Im currently riding 225/45/18 tires on 350z wheels and looking to drop my car, which drop will be more noticeable Eibach or H&R? Do Illuminas really give you a difference also?
Old Mar 17, 2008 | 06:05 PM
  #5379
SoonerFan's Avatar
Cletus
or you talking about look? or ride?
here is my car on H&R springs and Z wheels
and yes, Illuminas make a huge difference over other since you can adjust them.
Old Mar 17, 2008 | 06:09 PM
  #5380
Nicktard's Avatar
I like the way your back looks but it looks like the front sits a little too high. what size tire are you on? what can you adjust with the illuminas?
Old Mar 18, 2008 | 01:11 AM
  #5381
dblock75's Avatar
Got a noobie question...
If you have your temperature at 90 on your heater/AC and when you turn it off, you can still feel hot air coming from the leg area on the drivers seat. Does this still mean you are using the heater and using gas even though its off? The same applies when you put it to 60 degrees and you get cold air....just curious about this..
I change mine to 60 when i dont need to use it in order to save gas
Old Mar 18, 2008 | 01:17 AM
  #5382
Jess's Avatar
SHIFT_In2D
Yes H&R's do look like that. From experience, if you have an audio system the rear will be much lower than the front. Progress is a bit lower in the front than the H&Rs, but H&Rs ride the best. Especially paired with Tokico Illuminas.
Illuminas are comfort adjustable from 1-5. With 1 being the softest setting and 5 being the stiffest.
Only with coilovers/ground control (sleeves) are you able to adjust ride height.
Old Mar 18, 2008 | 11:45 AM
  #5383
Maxima112's Avatar
Curb Rash Repair 100 a wheel
i gotta newbie question.
I just got a P0133 Code pull. o2 sensor. Bank 1 sensor 1.
1. Is this pre cat or post cat? also front or rear?
2. Looking at oxygensensors.com is the left or right if it is the front?
3. Does anyone have instructions for the universal install? What color represents what?
thanks!
Old Mar 18, 2008 | 12:10 PM
  #5384
rony_espana's Avatar
Hi guys, I recently installed a Berk Intake and am really impressed with it overall, however when I hit about 4000 rpm the car start the bounce, shake...not sure how to explain. I removed the intake and tried the oem one and it goes right past 6K smoothly? Is there something else that has to be done if an intake is installed?
Its an 02 maxima 6spd btw.
Old Mar 18, 2008 | 12:39 PM
  #5385
ICEMAN76's Avatar
I thought I read on here that they Y-pipe was also really restrictive in our stock exhaust system. Wouldn't replacing the Y also help out alot?
Old Mar 18, 2008 | 03:23 PM
  #5386
Saccian's Avatar
I've done some searching on the site about MAF sensors and still have a couple small questions. I apologize if they have already been answered many times. I've so far only read about 50 pages of this particular thread(mostly the beginning and middle). I'm an absolute car newbie as far as tinkering with them(I've only changed a battery and air filter so far) although this site gives me motivation to learn all I can and do my own maintenance if possible.
Anyways, I've seen many-a-thread on cleaning MAF sensors and went out and looked at my car and it seems easy enough. Found my MAF assembly and I felt that removing just the sensor itself would be much easier then removing the whole assembly. Getting at some of those bolts for the assembly would seem to be a pain in the %$#. I did notice though that the screen leading into this assembly had a bit of dirt caked onto it. Is there any easy way of cleaning this screen without having to remove the whole assembly? And should I just use the CRC cleaner to clean this screen or is using a wet microfibre cloth or something similar sufficient? Thanks guys.
Old Mar 18, 2008 | 03:29 PM
  #5387
ohannon7's Avatar
5th gen & 5.5gen suspension is interchangable right? specifically springs/struts/top hats? Thanks
Old Mar 18, 2008 | 03:32 PM
  #5388
spdfreak's Avatar
thanks!
IIRC Bank 1 is on the side closer to the fire wall, and it's in the header.
Old Mar 18, 2008 | 03:33 PM
  #5389
spdfreak's Avatar
Possably a air leak causing a lean spike.
Old Mar 18, 2008 | 03:36 PM
  #5390
spdfreak's Avatar
Clean that out asap. That screen is after the filter and any dirt that gets loose will end up in your engine.
Old Mar 18, 2008 | 03:37 PM
  #5391
spdfreak's Avatar
IIRC they are identical.
Old Mar 18, 2008 | 04:19 PM
  #5392
Saccian's Avatar
Thanks for the advice. For now I just vacuumed it off, looks clear now. I'll do a more thorough cleaning sometime in the near future. I bought my Maxima used last November and never thought to check the air filter until a few months ago. It was beyond what I consider dirty and probably way past changing time. I'm hoping thats when the dirt got on the screen, and I hope nothing really made it through. My K&N filter seems to be all sealed properly so I don't think the problem is occuring now.
Old Mar 18, 2008 | 08:18 PM
  #5393
Mattlikespeoples's Avatar
Picked up my 02 6spd a couple of weeks ago. Just got the emmisions done THEN a CEL came on. guy at the oil change place said it was probably MAF and that the max's had like 5 of them...that sounded off. Is there more than one MAF and would cleaning it (what would i do that with) possibly clear it?
Also, two more things. I think i've got the wheel bearing issue. Metal on metal sqeaking from the front while turning at 58k mi. :-\ could i order the bearings online and use a friend's tools to press them in myself? would need instructions but i'm pretty sure the tools are there...
Ans last but not least, the cigg lighters dont work. got my car and went to fry's to get an adapter for my phone, plugged it in and nothing happened. the rear one is also not working. Fuse?
Old Mar 18, 2008 | 08:49 PM
  #5394
DataMan's Avatar
P0505 Idle Air Control Valve , TB, MAF ECM programming
I have read a lot about these issues with the 5th gen.
I have an Infiniti I30 2001.
one night the ECM burnt and next morning it did start but wouldn't turn on unless I pressed on gas while I was starting the car (it was fine when the car was warm). Mechanic said the P0505 code is in the engine and we changed the Throttle body and the ECM, then a friend with Cons. II came and reset the ECM with the Keys.
The guy who programmed the ECM didnt know anything about idle air control programming, he said the computer will learn everything by it self.
at the point a second problem much more major:
The car idled at 1700rpm and when it was warmed up the rpm would go up and down like hiccups. and the engine was acting funny.
When the car is in drive it does not act as bad, it has some nock here and there but in idle it goes crazy.
Do I need to flash the ECM and relearn the idle air by a dealer? will that fix my issue?
or is it something more serious?
like Mass air Flow MAF?
Please advise ASAP...
Old Mar 19, 2008 | 06:43 AM
  #5395
kjchevy3's Avatar
Bulb Replacement
I am looking at replacing the high beams and wondered what the thoughts were on sylvania silverstars. I'm hoping to get rid of the yellow appearance and find something closer to the HID low beams. Any experiences or input is appreciated.
Old Mar 19, 2008 | 06:57 AM
  #5396
Scottwax's Avatar
The Silverstars offer some improvement but aren't an identical match.
Old Mar 19, 2008 | 06:59 AM
  #5397
Scottwax's Avatar
1. You only have 1 MAF sensor and if it was bad, your car won't rev past 2500 rpm. More likely it is an O2 sensor if there are no symptoms (or maybe a bad thermostat) but you really need to pull the code to know.
2. If your friend has the tools and know-how, he should be able to press them in.
3. Fuse is always the first place you look.
Old Mar 19, 2008 | 09:33 AM
  #5398
thanks scott. car revs JUST fine, thank you
Saw a write up on the wheel bearings...think i'll get it done. yeesh! I'm nowhere close to being that mechanically inclined. I know it's just taking out bolts and fitting little things but i'd forget a step and my wheel would fall off sometime later while driving.
any idea which fuse it is? It's the only electronic thing in the car that doesn't so i guess if it were a fuse then it's be a small dedicated one.
ALSO, how come i cant start any new threads? need to ask some stereo questions in the A/V forum but cant
Old Mar 19, 2008 | 09:35 AM
  #5399
found the answer to my new thread question. this is post 10/15
Old Mar 19, 2008 | 09:58 AM
  #5400
kjchevy3's Avatar
Thanks. I don't expect to find an identical match, the ones that are currently in the car are soooo yellow compared to the low beams I was hoping to find something in a halogen that is a little closer.
