5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Mar 23, 2008 | 03:54 PM
  #5441
Puppetmaster's Avatar
Originally Posted by Topher3284
Thank you, appreciate the guidance. You know anyone that has used this system? Any feedback on them?
Ask Don aka Pearl96Max, the OP of that thread, or just look around the Audio and Electronics forum for old threads on that. I personally have no idea, I just happened to speak to Don last week and he mentioned the GD, which is why I thought of it when I saw your question.
Old Mar 23, 2008 | 04:13 PM
  #5442
Topher3284's Avatar
Right on, I will do just that. Thanks again for the help.
Old Mar 23, 2008 | 04:39 PM
  #5443
Jess's Avatar
SHIFT_In2D
Originally Posted by NismO2max
anyone have an idea how my car would ride with Illuminas paired with Eibach in front and Tein H-tech in the rear? Just read irish's thread about his Eibachs and too much sag in the back makes me think my 18" Z rims would rub...
just trying to save labor time and whatnot
It's best not to mix and match spring rates. Best thing is to have the same springs all around.
If you are afraid of rubbing do what nsrider suggested.
Also called "fender rolling" ...
http://tom.actionfit.com/fenderolling.html
Cheaper than buying different sets of springs, a shop should charge around $50 to get it done. Make sure they follow procedure and use a heat gun to avoid chipping paint.
If you want to do it the cheap way, there is the baseball bat method, but I would not recommend this.
Old Mar 23, 2008 | 06:39 PM
  #5444
pbn85's Avatar
noob question here...
I have my jwt popcharger bolted up the maf right now but I want to get a midpipe or what some people say, the upper intake tubing. Berk makes them I know. Can this work in conjunction with my popcharger?
Old Mar 23, 2008 | 06:51 PM
  #5445
SoonerFan's Avatar
Cletus
Originally Posted by megalos
i'm looking into buying a performance intake for my 2k max and am trying to decide between an injen cool air intake, berk intake or a cattman just looking for any opinions
the injen for our cars isnt a true CAI...dont believe the hype...its just an overpriced intake. i would suggest the berk
Old Mar 23, 2008 | 06:56 PM
  #5446
SoonerFan's Avatar
Cletus
yes...the midpipe connects to the MAF housing with a rubber coupler. if you have everything from the MAF housing forward, its easy to add the midpipe
Old Mar 23, 2008 | 07:07 PM
  #5447
pbn85's Avatar
this is my setup right now:
[IMG][/IMG]
pic is almost a year old and I promise the engine bay is MUCH cleaner now
but yea...Im ONLY doing this to get a cleaner look by getting rid of the accordian piece thats connected to the TB. Im pretty much aiming towards what your setup looks like except I'll have a popcharger.
Im also going to a hardware store to buy some aluminum. I'd like to make a nice heat shield box...may not be 100% effective but it should do more good than nothing
Old Mar 23, 2008 | 07:16 PM
  #5448
SoonerFan's Avatar
Cletus
yup, that will work. you just need the midpipe and two couplers.
Old Mar 23, 2008 | 07:25 PM
  #5449
pbn85's Avatar
awesome thanks
Old Mar 24, 2008 | 01:37 PM
  #5450
megalos's Avatar
thanks for the help on the performance intake i was leaning toward the berk because i had heard before the injen was overrated i just wanted to hear a second person say it
Old Mar 24, 2008 | 04:25 PM
  #5451
spdfreak's Avatar
Old Mar 24, 2008 | 05:57 PM
  #5452
SoonerFan's Avatar
Cletus
my opinion counts as 10...so 11 people have told you that injen is crap
Old Mar 25, 2008 | 12:47 PM
  #5453
SLPMAXDuP's Avatar
Oh, speaking of the clock. I saw one max with a blue clock and blue radio display on a stock head unit. How do I do this?
Old Mar 25, 2008 | 01:39 PM
  #5454
gigglehush's Avatar
My back windows only come down half way. How can I get them to open all the way? Thanks!
Old Mar 25, 2008 | 01:45 PM
  #5455
NmexMAX's Avatar
dot dot dot ...
quick question...Im getting a used one for $50 but its for an 01. It will still work on my 03 right?
You'll need to plug 2 holes on there. The 02+ does not require an external IACV due to its Ethrottle, therefore, that port + another vacuum port is eliminated, and all that is left on the 02+ is the PCV port.
Old Mar 25, 2008 | 01:47 PM
  #5456
NmexMAX's Avatar
dot dot dot ...
It's un-possible, live with it.
Old Mar 25, 2008 | 02:18 PM
  #5457
amomaxima's Avatar
you dont need to plug the hole
get a saw and cut the piece right behind the t part at the end and you will have a perfect match. Did it on mine and it works PERFECTLY the only thing you have to get is a longer valve hose. 5 buck at PepBoys and they are a rip off.
here is a pic
Old Mar 25, 2008 | 02:19 PM
  #5458
amomaxima's Avatar
this is what you need to do. take the door panel off after you roll the window down and look at the corners of the window in relation to the curve of the door. There is no way to get the window down any further. It sucks but what can we do
Old Mar 25, 2008 | 05:04 PM
  #5459
pbn85's Avatar
oh b/c on berk's website they list the intake for 00-03 so I figured it was interchangeable for those years...ah well..
and they never answer their phone too! wtf..I left messages and no repsonse...
Old Mar 25, 2008 | 05:08 PM
  #5460
maximadave's Avatar
detailerdaveb@gmail.com
stick with the berk (I have one) Injen is crap
Old Mar 25, 2008 | 05:51 PM
  #5461
amomaxima's Avatar
i have to be honest with you guys i think if someone has a small amount of tools and know how they could make a mid pipe from the universal **** from pep boys i would test fit it before i spent the money on a berk
thats my opinion
Old Mar 25, 2008 | 05:54 PM
  #5462
SoonerFan's Avatar
Cletus
break off both nipples...cover with electrical tape
i have the same one i had on my 00
Old Mar 25, 2008 | 06:11 PM
  #5463
megalos's Avatar
haha thanks alot ill make sure to look for you when i have another question
Old Mar 25, 2008 | 09:28 PM
  #5464
NmexMAX's Avatar
dot dot dot ...
I never said to plug the PCV hole. I said that all you're left with is the PCV, which you NEED.
I personally would recommend leaving the stock resonator in, I've dyno tested it, and it9stock piece) gives the best power curve.
  #5465
NmexMAX's Avatar
dot dot dot ...
I too have used a midpipe from a 00 on my 03.
Old Mar 25, 2008 | 10:10 PM
  #5466
MoeBelikeMax's Avatar
i want to get some black sidemarkers light whats the best way to go on getting them ...ebay or is there a site or something.
Old Mar 25, 2008 | 10:36 PM
  #5467
SoonerFan's Avatar
Cletus
you mean like this?
just paint your stock ones...still reflect and illuminate the proper color so its legal
Old Mar 25, 2008 | 10:53 PM
  #5468
what kind of paint did u use
Old Mar 26, 2008 | 06:25 AM
  #5469
NmexMAX's Avatar
dot dot dot ...
Originally Posted by SoonerFan
Red tire tread =
Old Mar 26, 2008 | 11:41 AM
  #5470
gigglehush's Avatar
They say the recommended fuel for a maxima is premium unleaded. Is it a bad idea to go with regular?? how many of you would recommend the premium?
Old Mar 26, 2008 | 12:46 PM
  #5471
vball_max's Avatar
Red tire tread =
LMFAO!!!!!
Most on here would say "if you care about your car, use premium as recommended"
Personally, after everything I have read on hear about people using regular, I wouldnt let anything but premium touch my gas tank.
Old Mar 26, 2008 | 01:12 PM
  #5472
phatboislim's Avatar
anyone in here ever repaint their interior plastic parts? mine are scratched and i'm at my wits end to find some paint that matches the interior parts..besides paint, my next move is to find some used climate and shifter console parts in good condition
Old Mar 26, 2008 | 03:39 PM
  #5473
GigEmAgs07's Avatar
has anyone here made lights to illuminate their floorboards? I know that places sell little 12" led bars that can get power through the cig lighter... so could i, in theory, mount those under the seats and wire them to a hot wire?
any insight?
Old Mar 26, 2008 | 04:33 PM
  #5474
amomaxima's Avatar
any insight?
if you put them under the seats they dont light as well
get two lights
put them under the dash on both sides and wire it to the cig lighter
cig lighter shuts off with the car
took 30 minutes to do my 2k max
Old Mar 26, 2008 | 04:36 PM
  #5475
GigEmAgs07's Avatar
get two lights
where did you get the lights? are these the kind you can get from pepboys and junk? any pics?
Old Mar 26, 2008 | 04:52 PM
  #5476
amomaxima's Avatar
dont have any pics
im not a huge fan of them, IMO make you look rice
but you can get any setup from the internet or pepboys
Got mine from Circuit City when i worked there
If you do it go LED
neon is too fragile if someone hits it by being and *******
Old Mar 26, 2008 | 05:56 PM
  #5477
SoonerFan's Avatar
Cletus
Red tire tread =
its called mAd tYtE oKlAhOmA rEd cLaY
Old Mar 26, 2008 | 05:57 PM
  #5478
SoonerFan's Avatar
Cletus
its been proven many times...for years...that you need to use whats recommended.
Old Mar 26, 2008 | 06:30 PM
  #5479
Mattlikespeoples's Avatar
couple questions....Asked about it in another thread and was told to search. That yeilded only mentions of the acronym istelf with out explanation of WHAT is was so...SSIM. 'something something intake manifold'? stainless steel? short stuff?
Also, what is a pop charger and what does it do?
Old Mar 26, 2008 | 06:31 PM
  #5480
Just need this post to ask a question in the audio sub forum...sorry for whoring 15 posts ftw!
well, i guess that didn't work. still says i cant post in the audio forum. Now that I have this problem it makes this a legitimate post. But what gives? It says i need 15 posts in the FAQ to post in there. Am I mistaken?
