5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Nov 15, 2006 | 05:07 PM
  #521
Succinct's Avatar
Originally Posted by Puppetmaster
The Injen intake sucks and is a huge waste of money. Make yourself a GAB (look it up in the How-Tos) or get a short RAM intake like the JWT popcharger or Berk.
The JWT Popcharger looks like the Stillen "Hi-Flow" intake that only adds a K&N filter on the upstream side of the MAF, with no other "straight tubes" or anything - are they the same?
I've read on here that such an intake will do a better job of preserving low-end torque than the Berk and still provides a nice sound. True? What is the disadvantage of such an intake relative to the Berk? Thanks!
Old Nov 15, 2006 | 08:50 PM
  #522
Mike_Amaral's Avatar
Nos?
Just picked up my 2000 Maxima SE today and am still trying to figure out what I will do first...
My question is will nitrous set up on a stock engine make a significant difference in the performance, or does it need to be highly modded? Also, NOS cant be all that good for the engine, right?
I know there are different setups, dry, wet, direct port, blah blah, would any of these be more suited for a stock 3.0 nissan? Thanks alot for any and all help!!
Old Nov 15, 2006 | 09:15 PM
  #523
NmexMAX's Avatar
dot dot dot ...
My question is will nitrous set up on a stock engine make a significant difference in the performance, or does it need to be highly modded? Also, NOS cant be all that good for the engine, right? I know there are different setups, dry, wet, direct port, blah blah, would any of these be more suited for a stock 3.0 nissan? Thanks alot for any and all help!!
Nitrous for Maximas Forum
And for the record, it's not NOS, it's Nitrous Oxide. N2O
Try reading a lot in there before posting. The information you seek is in there, you just need to look very carefully.
Old Nov 16, 2006 | 05:21 AM
  #524
maxig0's Avatar
thanks for thread, irish44j, lots of help
Old Nov 16, 2006 | 08:09 AM
  #525
My bad, there is just so much info here, alot useless to me, that looking through every thread would be a waste, especially cause I cant search.. Isnt that what this thread is for.. newbie questions?
Anyway, thanks for the info, thats what I needed...
Old Nov 16, 2006 | 08:39 AM
  #526
Nissanaholic's Avatar
In the cold morning my car will not stay alive unless I hit the gas and keep it there until it starts to get warm then it will sit there and studder until it gets warm.
Would this be due to and O2 sensor at the cat, or possibly the cat?
Old Nov 16, 2006 | 09:04 AM
  #527
delguiner's Avatar
Originally Posted by delguiner
my right headlight doesn't work, but only when i use the headlights. Daytime running light works, and so does my highbeams, but when i put the lights on to drive at night, the right one doesnt work. I changed the bulb, so i know that the bulb isn't the problem. I'm guessing it's electrical, or possibly a fuse. Anyone have any idea's?
Joey
no one can help out?
Old Nov 16, 2006 | 11:48 AM
  #528
Staticmax's Avatar
I was wondering about getting a HP chip. Are they available for 2k2? And how do I achieve/Install one? Your reply is appreciated.
Old Nov 16, 2006 | 12:00 PM
  #529
NmexMAX's Avatar
dot dot dot ...
Don't get it, it's probably a better paper weight than it is a performance enhancer.
Old Nov 16, 2006 | 12:34 PM
  #530
Staticmax's Avatar
Why do you say that? I've heard good things besides i didn't think it could possibly qualify as a paper weight.
Old Nov 16, 2006 | 12:49 PM
  #531
SEmy2K2go's Avatar
Go BUCKS!!!
There isn't a "real" chip made for the Maxima and the versions found on ebay are a complete ripoff and waste of money.
Old Nov 16, 2006 | 01:03 PM
  #532
Staticmax's Avatar
Ok. I guess I'll put my money else where on the car. Thanks guys.
Old Nov 16, 2006 | 01:36 PM
  #533
707SE's Avatar
here's an easy one. what do the following mean:
5.5 gen?
3.5 Swap?
I have an 02, how does these relate to me?
Old Nov 16, 2006 | 01:56 PM
  #534
maxig0's Avatar
5.0- 2000-2001
5.5- 2002-2003
6.0- 2004 and up
guys, correct me if i am wrong.
have no answer for 3.5 swap.
guys.... any one?
Old Nov 16, 2006 | 01:59 PM
  #535
707SE's Avatar
Originally Posted by maxig0
5.0- 2000-2001
5.5- 2002-2003
6.0- 2004 and up
guys.... any one?
Thanks. I'm assuming the 3.5 swap is a swap between the 5.0 gen engine and the 5.5 gen engine...
Now, I was reading a post that was talking about an AE kit. What exactly does that include. I'm in the process of buying door sills. What else is there?
Old Nov 16, 2006 | 02:08 PM
  #536
VaporHead
I think they say 3.5 Swap when they are taking a 5.5 gen motor and sticking it in a 4th Gen. Though I guess you could say that for a 5 to a 5.5.
AE have the different door sills, pedals, shiftknob, engine cover, front lip, and some other things I believe.
Old Nov 16, 2006 | 02:51 PM
  #537
maxig0's Avatar
need an opinion about this one, please:
http://www.redlinemax.com/catalog/pr...092f527d880570
thanks
Old Nov 16, 2006 | 05:28 PM
  #538
Succinct's Avatar
Would a non-noob that knows the answer please answer my question? Thanks
Old Nov 16, 2006 | 05:43 PM
  #539
VaporHead
So, are you calling PuppetMaster, who is a moderator with over 12,000 posts a noob?
:attention
Old Nov 16, 2006 | 07:45 PM
  #540
Puppetmaster's Avatar
IIRC, the JWT and Stillen are basically the same. Those set-ups do not have a mid-pipe like the Berk and Frankencar intakes, as you already know. The mid-pipe really only smooths the flow of air which probably just makes it sound better. It has been argued that the power curves on the dyno are much smoother with a mid-pipe, but that doesn't alter performance in any practical way, IMO. I think the peak whp is slightly different between the two set-ups, but once again, hardly significant. See if you can find Nmexmax's intake dynos; he's dynoed just about every set-up involving the GAB, POP charger, and short ram.
Old Nov 16, 2006 | 07:46 PM
  #541
But it does say "Newbie" under my name....
Old Nov 16, 2006 | 07:48 PM
  #542
Yeah, it mostly applies to 4th Gen guys swapping in a VQ35. No one really swaps out the 5th Gen DE-K for a VQ35. Chris's Max did on his 2000 but it turned out to be a pain.
Old Nov 16, 2006 | 07:52 PM
  #543
thanks
Redlinemax is no longer in business.
Old Nov 16, 2006 | 08:00 PM
  #544
irish44j's Avatar
retired moderator
99% of of us are in the US, where our maximas don't have daytime running lights
Old Nov 16, 2006 | 08:02 PM
  #545
irish44j's Avatar
retired moderator
:attention
what do you mean...he IS a n00b
Old Nov 16, 2006 | 08:10 PM
  #546
Old Nov 16, 2006 | 08:13 PM
  #547
VaporHead
I can't help but to post these smileys. They are the funniest I've seen, along with Puppets Newbie title!
Old Nov 16, 2006 | 10:05 PM
  #548
Succinct's Avatar
Thx for the response! (wasn't calling you a noob despite your obviously bogus title of "newbie.")
Old Nov 17, 2006 | 05:33 AM
  #549
maxig0's Avatar
Thats strange... site is still up. i tried phone number and get busy signal.
any place else i could get it for the same price or close to this price? I searched and could not find anything.
thanks.
Old Nov 17, 2006 | 01:43 PM
  #550
Rossello's Avatar
Proeblem With driver seat
Hi:
I am looking for the worm gears of the drivers electric seat for a
maxima se 2000. The motors are working fine I just need the worm
gears. I can't find it anywhere if any one of you have any idea please let me know and If it comes a repair kit I buy it so please let me know!
Here are the pics of the damage worm gear
Old Nov 17, 2006 | 02:29 PM
  #551
irish44j's Avatar
retired moderator
Originally Posted by Rossello
Hi:
call 1-888-254-6060
Ask for Dave Burnette (not the "other Dave" there)
tell him you're from the org
he'll hook you up.
Old Nov 17, 2006 | 10:41 PM
  #552
Staticmax's Avatar
So Im goin with berk
Old Nov 18, 2006 | 06:18 PM
  #553
aamir's Avatar
Hey guys,
I have a 2002 6 speed Maxima. When I am accelerating in either 1st, 2nd, or 3rd gear and let go of the gas, the car starts jerking back and forth. The jerky feeling does not happen in 4th, 5th or 6th gear though. Any ideas on what is causing this? If anybody could help, I would really appreciate it. Thanks
Old Nov 18, 2006 | 06:29 PM
  #554
VaporHead
Originally Posted by aamir
Hey guys,
Do you know how to drive a standard?
It could be a clutch problem.
Old Nov 18, 2006 | 06:41 PM
  #555
aamir's Avatar
Yes, I do. To help clarify my problem of when I encounter this, I'll give an example. I make a turn into my neighborhood and then another turn straight after to get to my house. I make the first turn in 2nd gear and keep it in 2nd until I have completed the second turn. There is a brief period in between the two turns when I let go of the gas in 2nd gear. This is when I feel the car start jerking. I have had no other problems. I hope this helps to clarify the problem. Thanks once again.
Old Nov 20, 2006 | 02:08 PM
  #556
mikessilvermax's Avatar
Grill Removal
I need to remove the grill on a 2k2. I got the top 4 clips off the 3 nuts on the inside of the grill off. What else do you have to do to get the grill off ? I noticed two clips on the bottom left and right corners of the grill, do they have to do with anything concerning removal of the grill. I tried to lift and or push with my fingers and they dont budge. Didnt want to break it so I stopped.
thanx for the help.
mike
Old Nov 21, 2006 | 05:55 AM
  #557
choopster's Avatar
can we upgrade the manual climate control on 2001 GXE to automatic GLE version without changing the wires?
thx
Old Nov 21, 2006 | 06:02 AM
  #558
thx
No, you need new wiring, temp sensors, and a lot of time.
Old Nov 21, 2006 | 07:21 AM
  #559
Rossello's Avatar
call 1-888-254-6060
he'll hook you up.
I Call him today and he told me that he sell me the whole thing for $206 and that they don't sell the worm gears alone
I am just looking for the worm gears!
can anyone have any idea where I can find them cause $206 for the whole thing when I just need that little piece
Old Nov 21, 2006 | 08:07 AM
  #560
Succinct's Avatar
How about taking your worm gear pieces to a machine shop and getting steel ones fabbed from scratch? Couldn't cost near $200, and they'd last forever (just keep 'em greased). Just an idea.
