5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Aug 30, 2009 | 07:52 PM
  #9161
max00mike's Avatar
2 other newbe question..(sorry)i plan to install a injen intake,,,but im scared to see the SES light come in...there no probable issue if i install a cold air intake i ask that because on the original intake it have one or two(dont remember)sensor(before the mass air flow sensor)there any hole in the injen to put this sensor or i can simply remove it??
and my max have 114k and always run on regular 10/30 oil(previous owner)...no problem to swap to synthetic(mobil 10/30)???
thanks
Old Aug 30, 2009 | 08:00 PM
  #9162
FRZ251's Avatar
Anybody remember some guy on the forums here did the Infiniti I35 gauge cluster swap? I love the look of those gauges, looking for the write up on how to do that.
Old Aug 30, 2009 | 09:45 PM
  #9163
VQ35DE TE's Avatar
Thanks for the post unrealii. That might just be it. One of the last times I had the car serviced, they mentioned the throttle body needed to be cleaned. I'll do some research. Thanks for the tip! =)
Old Aug 31, 2009 | 07:12 AM
  #9164
Nate218's Avatar
Hi, Just recently bought a 03 titanium edition se and would like to know my best bet on getting a small can of touch up for a few scratches and blemishes on it. Should I just call dealer or go thru a good body shop. I just did a rubbing compound and wax job on it and just would like to blend in the flaws.
Thanks for any help.
Old Aug 31, 2009 | 02:23 PM
  #9165
Bl_asd1's Avatar
My 2k maxima been acting weird lately. Sometime when I accelerate, the engine revs up to 4k but the trannny doesn't shift to second gear. I have auto tranny, I tried manuel shift. It doesn't work either. Sometime I just turn off my car and restart again then it's fine. Can u tell me what's wrong with it? Thx
Old Aug 31, 2009 | 05:31 PM
  #9166
RBW's Avatar
RBW
Hi. I am in the process of replacing the airbags on a 2002 SE, and I need to confirm the location of the airbag module.
I found this thread which said that on a 2001, the module is underneath the center armrest. Is this true of a 2002 Maxima as well?
http://forums.maxima.org/5th-generat...ag-module.html
Much Thanks.
RBW.
Old Aug 31, 2009 | 05:33 PM
  #9167
pmohr's Avatar
No more Maximas...
Much Thanks.
RBW.
Yes, it's in the same place.
Old Aug 31, 2009 | 05:36 PM
  #9168
unrealii's Avatar
I'd go to the dealer and get touch up paint. If you have a shop mix the color for you, it will be more expensive. Of course it all depends on how much paint you need. If you get touch up paint from the dealer, make sure to shake it very well. The metal tends to settle at the bottom.
Old Aug 31, 2009 | 06:36 PM
  #9169
planetd's Avatar
just bought an 02 Max
Had a question about bounce...but went over some speed bumps today...no shocks. ugh. Anyway...
Thanks!
Old Sep 1, 2009 | 03:36 AM
  #9170
Nate218's Avatar
Ok Thanks for the tip, I just need a small can so its all good.
Old Sep 1, 2009 | 01:35 PM
  #9171
doyle21's Avatar
cansomeone please help me out, i am going crazy. i tried putting in hid headlights into my 2001 maxima se and messed something up i had to go to dealership and install my old headlights back in for $500 plus i throw out hid lights which cost me $100 so in total i lost $600 to get my orginal lights put back in. unreal lifee sucks though.
but now i need to fix this other problem my climat control buttons dont light upat . i almost wrote my car off last night trying to put heater on while driving. need to put dome light on to see. someone told me changing climat control bulbs are easy to replace. i am trying to take off dash but i think i will snap it if i pull any harder.
so someone please help me and show/explain how to take off dash to replace climate control bulbs. iam losing my mind and have no money to go back to dealship to fix this problem. please i am begging someone to help me out
thanks
doyle21
Old Sep 1, 2009 | 01:50 PM
  #9172
unrealii's Avatar
Sorry, I can't help you too much. I suggest searching for various transmission issues. For the 2000 year, there is a TSB which mentions issues regarding the solenoids and TCM (transmission computer).
http://maxima.theowensfamily.com/tsb/NTB00-039a.pdf
Also, some have had issues with the revolution speed sensor and other sensors used by the transmission (abs sensors IIRC). Just read up on some of those threads.
Old Sep 1, 2009 | 01:54 PM
  #9173
unrealii's Avatar
thanks
doyle21
download the FSM's in my signature. This will give you all the info you need to take your car apart. Remember to be patient. If a dealership is too expensive, an audio install shop may be able to get your dash off for you since they have to take it out to access the radio.
http://www.youtube.com/watch?v=hlp2KuWpoFI
Is the rest of your dash lighting up? You can control the brightness with the **** on the left of the steering wheel.
Old Sep 1, 2009 | 02:47 PM
  #9174
Nate218's Avatar
Ok this is sad but my ac button does nothing when I push it in(no click)and the lil lite under it stays lit so how do u turn it off. I want to be able to turn the fan switch on and have heat come on but dont wont the ac to run at same time.
Old Sep 1, 2009 | 04:02 PM
  #9175
johnnyboy777's Avatar
Originally Posted by johnnyboy777
Clutch chatter problem ........2001 Max SE (20th) 5spd
Had a Clutch Masters FX100 (Stage 1) clutch and Clutch Masters alum. flywheel
installed as a replacement.
Significant clutch chatter at take off, even more chatter going into Reverse and some chatter down shifting into second gear.
Clutch pedal pressure is ligther than previous OE clutch, which is fine with me.
Clutch engages at half way point from the floor.
Motor mounts, tranny mounts and Axle play ..........all check out OK.
Have completed clutch break-in for 500 miles........chatter problem remains.
Also, Clutch chatter has caused small oil leak, due to crack in rear main oil seal (which was not replaced by mechanic, because it looked perfect to him during clutch and flywheel install)
Anyone running a Clutch Masters Stage 1 clutch ?? Any clutch chatter problems ??
What Flywheel are you running with the Clutch Masters Stage 1 ?? How do I pinpoint this clutch chatter
problem ??
Any advice/help would be appreciated. Thanks in advance.
BUMP
Please help.
Old Sep 1, 2009 | 04:49 PM
  #9176
awlizzonmymax's Avatar
What's good people... I just want to introduce myself... My name is Odie from Dallas, TX and I am new to maxima.org... not really but I'm just now getting to the point where I can start doing the things that I wanna start doing to the maxi... So now I can stop reading and begin to start blogging...
fyi... I will be selling my stock HID's pretty soon for 350 for the pair and about to start parting out other things as I'm replacing for my specific build... I'm not here to get rich or make money just a lil push to get where I want and help out my peoples cause I know the love will be returned...
You guys be blessed and hopefully I'll get to some of you guy's level... Maximus Beastliness.... mods so far custom Intake built by me LoL, it works and a ground wiring kit... merked my bois WRX by 3-4 car lengths :-)... lataz
Old Sep 2, 2009 | 05:30 AM
  #9177
NissanMan97's Avatar
5th gen Headlight question
Not new to the site by any means, just been away for a while, I am new to 5th gens however so I guess Im half-noob. I totaled my 4th gen and am looking at getting a 5th gen. One of the first things i want to do is get some HID's (if it doesnt come with them). Ive tried to search for my answer but I havent come up with anything conclusive. Ive seen the kits work well with the 2k and 2k1 housing and Ive also seen that you should buy some 2k3 i believe it was housings which come made for HID's
Is there pros and cons to both?
obviously with a kit you could run into a glare problem, how bad is that?
the search was giving me a headache so i stopped using it, but i will tackle it again later on. just thought i would ask here first to speed up my fact finding.
B
Old Sep 2, 2009 | 07:31 AM
  #9178
TMoney_87's Avatar
Hi, I just had my first problem
Hi I'm new, I have been reading the this forum for bit though.
Well heres my problem:
I was getting into my car(2003 nissan maxima se Automatic), started it up, then put the car into reverse, the car went into gear and started to move, but when I put my foot on the gas, the car did nothing, didn't even rev. It was moving, but just idle speed. It does the same thing in drive.
I noticed the A/T light flashing, TCS OFF light stayed on, and the SLIP was on. The service engine light has been on for a couple of weeks.
I had to get home, so I popped the hood and discounted the battery for a minute, then reconnected it to reset the computer. I then started the car, and the warnign lights didn't come back on. Service engine soon light is still on though. While driving home the car ran great, car shifted gears smoothly and everything.
Does anyone know what might cause this?, thanks
Old Sep 2, 2009 | 09:09 AM
  #9179
unrealii's Avatar
If your SES light has been on for a few weeks, its a no-brainer that you should take your car to get codes read. Also, it is stupid to reset the computer because you will lose whatever faults the computer stored. Your car is trying to tell you something is wrong, go get the codes read and report back.
For your the dash lights, search the forums for "TCS SLIP light"
Old Sep 2, 2009 | 09:15 AM
  #9180
unrealii's Avatar
B
In my search for terms "HID Wiring" I came across answers to both of your questions. Hope that helps.
Old Sep 2, 2009 | 10:01 AM
  #9181
murphy390's Avatar
Disconnecting O2 Sensor
I've replaced O2 sensors on several of my cars but on my 01 Maxima I'm getting stumped (and my fingers are getting very sore!). I've squeezed the middle green post with no results. I've used long nose pliers on the middle green post with no results. I've tried depressing the two outer green posts and then squeeze the middle one with no results. There's got to be a simple way!
Thanks!
Old Sep 2, 2009 | 10:03 AM
  #9182
pmohr's Avatar
No more Maximas...
Thanks!
Push the locking tab straight in.
Old Sep 2, 2009 | 10:28 AM
  #9183
imdupeng's Avatar
How to unscrew the PowerSteering Cap
Hello,
A quick question: How could I unscrew the cap of the power steering fluid reservoir on a 2002 Maxima?
I've tried a couple of times, the it simply didn't come off. There seems to be no threads in the cap at all.
Old Sep 2, 2009 | 10:30 AM
  #9184
murphy390's Avatar
Thanks! I assume the locking tab is the middle one?
Life is simple when you know what you're doing!
Old Sep 2, 2009 | 10:47 AM
  #9185
biffmystro's Avatar
Cylinder 6 Misfire
My check engine light is throwing a cylinder 6 misfire. A few months ago my 00 maxima with 140K miles started sputtering while trying to accelerate in 2nd - it had a lot of drag and took a while to get up to speed sputtering the whole time. The next morning everything ran fine with no signs of the misfire. I am getting significantly less gas mileage than before, and the car is dragging a bit on the acceleration. It only gives me the serious sputtering maybe once a month... then back to normal after a day or so.
I read that it might be coils? fuel injectors (just put in injector cleaners last fill up - 200 miles ago)? sprk plugs (changed about a year ago)? Chk Engine light is still on - Any suggestions?
Old Sep 2, 2009 | 10:49 AM
  #9186
pmohr's Avatar
No more Maximas...
Yes.
Are you on the original coils? Have you tested the cylinder 6 coil? Swapped it out to another cylinder to see if the misfire follows it?
Old Sep 2, 2009 | 11:01 AM
  #9187
biffmystro's Avatar
Originally Posted by pmohr
Yes.
I have not changed coils since I have owned it at 90,000 miles.... How do I test the 6 coil? The major misfire is only periodically, so I don't know how long before it misfires again- could be a month or two... Is there a way for a more immediate test? I will do the swap in the meantime. Thank you!
Old Sep 2, 2009 | 11:18 AM
  #9188
pmohr's Avatar
No more Maximas...
Test the coil. Search and you'll find instructions.
Old Sep 4, 2009 | 03:16 PM
  #9189
subzeroedj's Avatar
MT drain plug location?
A mechanic told me today that the drain plug is in the back or oposite end of the fill plug but i dont see anything back there resembling one...atleast near the bottom. I just jacked it up and now im stuck so im thinking of taking out the lowest front 6point bolt head but i chickened out....Can anyone help me out?
Old Sep 4, 2009 | 03:36 PM
  #9190
nzelinsky's Avatar
thanks
You wont get an SES from the injen.... at least you shouldnt. Just be careful when handling your MAF and it should be okay if you hook everything up and follow the instructions to the tee.
Swap to synthetic, just do it I am going to swap to mobil1 I just bought mine a few months ago
Get it from the dealer. its a perfect match and the little pen thing does the trick for scratches and scrapes. it has clear coat on the other side to give it a finished look. It worked very well for me
Old Sep 4, 2009 | 03:37 PM
  #9191
nzelinsky's Avatar
buy a haynes manual. The drain plug is the only bolt on your oil pan.,..
Old Sep 5, 2009 | 12:42 PM
  #9192
subzeroedj's Avatar
I should have specified that i was looking for the MT drain plug and not the oil drain plug.... but i found it anyways....For anyone else thats looking its facing the pass side and theres a bracket in front of it.
Old Sep 5, 2009 | 03:58 PM
  #9193
max00mike's Avatar
ok ive got 600$ to spend on my maxx...i would like hadd more power,,,i already installed a injen intake but now im looking for headers/Y-pipe but i dont know what kit buy???? and if i will have issue if i only install a aftermarket(like obx) headers/y-pipe on my original hexhaust(original cathaliser,resonator,muffler) and if the combo are made for federal emission(im from canada)
now..i want to know what combo get and and what is the real direct bolt on fit...on my maxx
mike
sorry for my poor english
Old Sep 5, 2009 | 08:50 PM
  #9194
Staticxout2's Avatar
p1102 code was read i guess i need a MAF
Should I order one for a 00-01, or one specifically for my year? I hear of people using the 00-01. What is this resistor I need to swap out? What are the benefits if I do use a 00-01? Some input would be greatly appreciated because I'm stranded right now...I'm trying someones 35 hour wait with the negative disconnected...and I doubt this is going to work...kinda just a last ditch hail mary pass.
Heeeeeeeeeelp! Stranded! I found the benefit of the 00-01 its rediculously cheaper by 200 bucks does anyone have a thread on how to make this work for a 2002?
Old Sep 6, 2009 | 03:23 AM
  #9195
pmohr's Avatar
No more Maximas...
Did you search?
http://forums.maxima.org/5th-generat...hermistor+swap
Old Sep 6, 2009 | 08:15 AM
  #9196
yeah i searched for like 2 days now i am aware i suck at it, i wouldn't have asked if i hadn't searched, this is the newb question page right? wow seems like from what i've read from these threads in the two days i've been searching, anytime anybody helps anybody out, they have to be a ****, not always but a majority of the time...wtf is that?
Thanks...you're welcome...remember that ****?
So Thanks, Thank you it really is a huge help.
Old Sep 6, 2009 | 01:22 PM
  #9197
MAXimumWarp's Avatar
COLOR
CAN ANYONE TELL ME WHAT COLOR MY CAR IS?
IS IT GREY, SUNLIT SAND, OR STERLING MIST.
Would like to know this because I want to buy a spoiler to match.
Check my profile Pic thanks a lot in advance for any help.
Old Sep 6, 2009 | 02:33 PM
  #9198
VQP0WER's Avatar
Looks for the paint code on the data plate. There's a plate on the firewall/drivers side area, and a sticker on your drivers side door jam. It will give you a 3 alpha/numeric code. Once you have that, you can bump it up to this:
http://www.courtesyparts.com/touch_u...php?cPath=1956
Sunlit Sand = EV0
Sterling Mist= KT3
Gray Luster= KV3
Old Sep 6, 2009 | 03:45 PM
  #9199
pmohr's Avatar
No more Maximas...
Yes, this is where newbie questions go.
That was hardly 'being a ****', that was me asking my own question and giving you your answer. You never mentioned anything about searching, and that took me all of 5 seconds to find (literally).
If you don't want me to answer your questions, I've got no problem with that. No reason to start crying about it, though.
Old Sep 6, 2009 | 05:41 PM
  #9200
Sunlit Sand = EV0
Sterling Mist= KT3
Gray Luster= KV3
Thanks a lot man, was looking for a good nissan parts site too
KUDOS!
