5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Aug 9, 2010 | 12:58 PM
  #11201
The6spdMax's Avatar
Originally Posted by foureverlow
FNG here I'm looking for pics on the DIY short throw shifter for my 5th gen 6-speed just need a lil help please, Thanks!
http://forums.maxima.org/5th-generat...arts-list.html
Old Aug 9, 2010 | 02:24 PM
  #11202
djshwini's Avatar
Ok a couple of weeks back i had to replace my battery because its was dead. Yesterday i went to start the car and it didnt start, so i had AAA jump start it ( didnt think it was a battery issue, thought it was starter) but it turned on. So i let it sit so the bat would charge some. I took it to pep boys and they said everything is fine, just the battery voltage is alittle low, so just as you drive it will charge.
This is get, but i still have no idea why the battery discharged in a couple of weeks. I was thinking there was some short somewhere or the alternator was bad (but it alt. checked out). Any ideas?
Old Aug 9, 2010 | 02:53 PM
  #11203
The6spdMax's Avatar
It could be a short somewhere... did you install any aftermarket audios to your car?
Old Aug 9, 2010 | 03:04 PM
  #11204
Ghost_capo's Avatar
No i havent changed anything, only thing i attempted was changing the drivers window switch unless that triggered the fuse to blow as well as the dash light. And ive read if it was a short it would go out immediately the fuse is still good after ive put it in and drove around for like an hr
Old Aug 9, 2010 | 03:06 PM
  #11205
Henryzx's Avatar
My car started to have "Engine Service Soon" light on this morning, does this mean there's something wrong with it (there's no indication as far as functionality - still drive like new). or it just needs a 100k service ? it has 116k miles btw.
Thanks in advance for all your helps
Henry
Old Aug 9, 2010 | 03:26 PM
  #11206
SoonerFan's Avatar
Cletus
Henry
the light is for an emissions problem 90% of the time
find out what the code is (most auto parts stores with check for free are a small price) and then post the code on here and we will go from there
Old Aug 9, 2010 | 05:27 PM
  #11207
Ghost_capo's Avatar
I have an update to my lighting problem, when ever my headlights are off the inside lights work fine but once they are on the lights go out..
Old Aug 9, 2010 | 05:40 PM
  #11208
djshwini's Avatar
I didnt install any aftermarket audio. Got it back from pepboys everything is fine right now, hopefully it stays like that.
Old Aug 9, 2010 | 07:05 PM
  #11209
galheit's Avatar
Hey all noob here /lol a question . Ive benn benn getting a p0446 and a p0455 continsely for a year now . Visually inspected vac ,line to the evap. seems to be no leaks . Cleared the codes today with my handy dandy scanner ( whicch has paid for its self over n over again ) aaaand it fast past at the Ohio Echeck . also gas cap passed no prob, also. Ive drove it for a few hours and no light ? any way Ive done this manny times and it will stay off for a few weeks . 186000 miles n goin strong. I beat the crap out of it , and rolled a 2010 mustang form the get go . anyways any idea what could be causeing these codes ?
I would be greatful for aaaaany input
thanks
Old Aug 10, 2010 | 12:06 AM
  #11210
Henryzx's Avatar
Thank you, i'll have it scanned, but this car just passed smog 3 weeks ago...
Old Aug 10, 2010 | 04:32 AM
  #11211
prmaxi's Avatar
Originally Posted by prmaxi
first my check engine light is on,,,,, ok this my story, i recently replaced all my ignition coils, from someones that i brought off ebay,i put them in everything went just fine besides the part where the rubber connecter got stuck in the spark plug chamber on to the spark plug,,well anyways i replace them and i thought everything was fine but after turniing it on and off a couple times the light soon came back,so i took the neg and pos off the battery let it sit for about 15 minutes and now my tcs/off and slip lights are along with check engine WTF!!!!, so after some research i read that it could be the CrankShaftPostioningSensor,so i replaced the one on the left side, right off the front side valve cover,( i replaced this with the neg and pos off the battery,) it stood off for about 20 minutes and a whole crap load of me turning it on and off,......now its back on again and im just at the point right now,,thinking WHATS NEXT???????? HELP GUIDANCE PLEASE
some one helpppp me pleasseee!!
Old Aug 10, 2010 | 05:16 AM
  #11212
gdal's Avatar
Originally Posted by gdal
I just purchased a 2000 SE with 81k. I'm planning on changing all the fluids. I'm thinking about performing a tune up, but I'm still debating what things to get.
Here's my list:
1. Spark plugs
2. PCV valve
3. Fuel Filter
4. Throttle Body Cleaning
5. IAVC Cleaning (or whatever it's called)
6. New Air Filter
I'm still debating if I should replaced all coils. I have all service records and the MAF was replaced a few years ago so I'm cleaning that too. Only one coil has been replaced since new. It's not throwing any codes and it's running great. I'm thinking about running seafoam or bg 44k too.
What do you guys recommend?
Any input guys?
Old Aug 10, 2010 | 06:05 AM
  #11213
NmexMAX's Avatar
dot dot dot ...
Any input guys?
I wouldn't replace the coils unless they needed it. And your list looks fine. I'd inspect the belts too and replace if needed.
Next logical thing would be to get the code read.
Old Aug 10, 2010 | 07:39 AM
  #11214
prmaxi's Avatar
i did still giving me the p1320, why would the tcs and slip come on after i change the coils i dont get it
Old Aug 10, 2010 | 08:59 AM
  #11215
djshwini's Avatar
Ok, so i have a problem thats pretty aggravating and i cant figure it out. So i bought a battery 3 weeks ago because my last one was dead. 2 days ago my car didnt turn on so i had it jumpstarted yesterday. Took it to pep boys and they "said" that the battery and alternator looked fine, and to just let the car charge as you drive. They said the battery was healthy, but the voltage was just low. Today, to my surprise when i was in a rush to get out of the house, the battery was completely dead. No crank on ignition, no clicking, nothing.
I honestly have no idea what it is now, i think there is a short circuit somewhere, but i really dont know.Just need to know why my "new" battery is getting discharged Any input would be great. And i just want to thank all the ppl on the org for being so nice about helping me and everyone about their maxi-pad probs. Thank yaa!
Old Aug 10, 2010 | 09:23 AM
  #11216
VQP0WER's Avatar
I had this issue once and it turned out the battery cable was slightly loose on the battery post. I would have to wiggle the cable until I got a post shim. It's not a guarentee this is your problem, but worth a look. If it's not that, it's either your alternator or you have something is leaking power.
Old Aug 10, 2010 | 10:26 AM
  #11217
djshwini's Avatar
Yeah I tried adjusting the cable but no luck. I was trying to think of something that would leak pwr, but nothing came to mind, considering i dont leave random things on on my car. I also think its the alternator. I now dont think its a short because im pretty sure i would see sparks, and voltage of the battery wouldnt slowly go down it there was one. But im going to have sears check it out. I really think pep boys didnt even do anything, prob just did a visual inspection or something.... Thanks for the input tho.
Old Aug 10, 2010 | 11:32 AM
  #11218
djshwini's Avatar
A little off topic but the guy at pep boys recommended a fuel induction (r injection, one of the 2) service. He said they would pour cleaner in the tank (can do myself) but they also said they would spray the throttle body with some spray to rid it of carbon build up or something. And there was one other thing they were going to do. Worth it or way for me to waste $. Im at 123k miles btw.
Old Aug 10, 2010 | 12:51 PM
  #11219
Nismo822's Avatar
You might want to just take out the alternator and get it tested yourself at autozone or o'reillys. But even if it is the alternator going bad, you should have the battery light on the gauges to tell you the car is running off the battery. It might be somthing else that's on and is draining ur battery while the car is off. Did u install anything prior to this or change anyting electrical?
Old Aug 10, 2010 | 01:36 PM
  #11220
SoonerFan's Avatar
Cletus
do it yourself
1. BG44K in gas tank (cleans injectors, etc)
2. seafoam in brake booster hose (cleans intake manifold)
Old Aug 10, 2010 | 01:56 PM
  #11221
Ghost_capo's Avatar
Hello again.. I changed the window switch and dimmer and now my lights and window problem is solved only thing left is the radiator fan fuse that keeps on burning out, i went to a electric auto mechanic and paid him 125 to diagnose it (it hurt me so bad) after he poked his meter thingy around he said the fan it self has a short and i have to get it changed, I went ahead and tried to remove my old fan and managed to do it fairly easy, so i was looking online and i see they have fan assemblies on eBay and amazon
i was looking into getting one of these, would you guy recommend it?
http://www.amazon.com/INFINITI-CONDE...473275&sr=8-34
http://cgi.ebay.com/ebaymotors/NISSA...Q5fAccessories
I was also thinking can i just change the motor and keep the fan i currently have?
Old Aug 10, 2010 | 03:02 PM
  #11222
VQP0WER's Avatar
I know you are not wanting to spend alot of money, like most of us, but look into getting a OEM replacement from rockauto.com. I've had good luck with them, and if you go to http://www.retailmenot.com/view/rockauto.com , you can get a coupon for even more money off.
Old Aug 10, 2010 | 05:57 PM
  #11223
djshwini's Avatar
do it yourself
I researched alot on the topic but there are two things i cannot find out. One, where exactly is the brake booster hose. And is it recommended that you put some in your gas tank?
Old Aug 10, 2010 | 06:03 PM
  #11224
Specd_out's Avatar
Brake booster line is located on the firewall. It goes to the brake booster on the drivers side firewall. Its a large black circular object.
You will see that the line goes from brake booster to aluminum pipe then to the intake manifold. Disconnect it from the aluminum pipe to the intake manifold.
Make sure you pour it very slowly. too much and you damage the motor.
FYI the car will run like absolute crap while doing this. and will want to stall. I find it works best having some one in the car keeping the idle around 1500.
Old Aug 10, 2010 | 09:29 PM
  #11225
Ghost_capo's Avatar
Thanks for that, but any other opinions cause im super broke right now
Old Aug 11, 2010 | 06:10 AM
  #11226
NmexMAX's Avatar
dot dot dot ...
www.car-part.com
Keep in mind, it's a junkyard part so .... yeah.
Old Aug 11, 2010 | 06:55 AM
  #11227
NmexMAX's Avatar
dot dot dot ...
Can anyone help with this question?
Originally Posted by ColdRain
Apologies for reviving old thread, but does anyone know how to take off Residue left from rubbing alcohol/acetone on Window Glass? I used it to remove tree sap, but I forgot to clean afterward and overtime it created this clear residue coat which is very visible from inside of car. Glass seems to have clear stains. I may try to capture a photo, but any clues?
Old Aug 11, 2010 | 10:02 AM
  #11228
Henryzx's Avatar
I know this old, but hey I'm new ... and I've done lots or searches ... so just want to confirm one thing ... MAXSPEED springs will be OK with Tokico Blue ?? in term of reliability? I'm not concern about the ride, I used to have an 88 Z31 Shiro Ed , anyone has it know how stiff that little z is... Anyhow, please just give me a ya or nay ... before break my bank for an eibach pro kit .... thank you
Old Aug 11, 2010 | 01:09 PM
  #11229
SoonerFan's Avatar
Cletus
reliability will be fine
Old Aug 11, 2010 | 01:16 PM
  #11230
SoonerFan's Avatar
Cletus
everything you need to know, and more
http://forums.maxima.org/fluids-lubr...-manifold.html
Old Aug 11, 2010 | 02:14 PM
  #11231
VQP0WER's Avatar
It can be one of two things:
1. Tree sap
2. Etched glass
Try some Goo Gone for the tree sap, and if that doesn't work, get 1 tablet of denture cleaner and mix it with 8 ounces hot water and scrub it.
Old Aug 11, 2010 | 04:21 PM
  #11232
Ghost_capo's Avatar
Just wondering would the radiator fan from a 96 max fit on my 2000 maxima, was looking at the diagrams on courtesy parts and they look exactly the same
Old Aug 11, 2010 | 04:26 PM
  #11233
maximadave's Avatar
detailerdaveb@gmail.com
Use BG44K in the tank and Seafoam thru the brake booster line.
Old Aug 11, 2010 | 04:40 PM
  #11234
VQP0WER's Avatar
I'm showing different part numbers, but they maybe the same.....
Old Aug 11, 2010 | 05:28 PM
  #11235
SoonerFan's Avatar
Cletus
great minds...
do it yourself
Old Aug 11, 2010 | 05:56 PM
  #11236
gdal's Avatar
my dark gray interior pieces in my 2000 maxima are all scratched up. Are these things too expensive to replace? Can I paint them instead? What do you guys recommend?
Old Aug 11, 2010 | 06:37 PM
  #11237
galheit's Avatar
2000 max GLE , Im looking to change my muffler . The one im looking at is basically a 2.750 straight thru . WWill this hurt me in power ? not enough back pressure ?
thanks Gary
Old Aug 11, 2010 | 07:06 PM
  #11238
The6spdMax's Avatar
Depend what specific pieces you are talking about. I would just get them when someone is parting out their car, or junk yard.
Old Aug 11, 2010 | 07:15 PM
  #11239
gdal's Avatar
I'm talking about the shifter trim piece, center console vents (2 vents), and the window switch trim for all doors. I have found several maximas at junkyards around my area, but everyone wants me to buy the entire door.
Old Aug 11, 2010 | 09:29 PM
  #11240
pepox369's Avatar
thanks Gary
the back pressure deal is almost a myth.. but i believe that as long as you have a muffler at the end you will be fine.. and if you dont get headers, all the 2.75 piping will not be as effective..
