5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Feb 10, 2007 | 12:05 PM
  #1161
mokiblk2k2's Avatar
hi. can anyone help?!? i'm new, and just purchase an 02 6 speed. nice car, good deal, but was victum of a vehicle prowl. oem navi and bose head unit taken by someone who thought they needed it more. i'm not worried about the head unit, but i need to find a navi touch screen with funtion buttons to get the hvac climate control working. anyone know anybody that might have a unit or a wrecked car with a stock navi setup? also, can this car easily be switched to the digital climate control or will a pathfinder or infiniti nav unit be a suitable replacement? the dealer said they cannot cross reference one vehicle to another for the navigation, just that the maxima unit number ends with 5Y700. i need to have harness pigtails too, as the idiot cut the harness instead of upplugging. thanks for any help!
Old Feb 10, 2007 | 02:52 PM
  #1162
dblock75's Avatar
Hello, I was looking at a 02 AT and it has 75k miles on it. I am wondering if there are alot of problems with these cars or will they run fine? I noticed there was a MAF issue or something and wanted to know if that was a problem and if there is anything else. Would you recommend me getting it?
Old Feb 10, 2007 | 07:02 PM
  #1163
djcallao's Avatar
Originally Posted by Topher3284
Thanks djcallao, Hopefully there are still some available.
NO PROBLEM MAN.
Old Feb 10, 2007 | 07:05 PM
  #1164
djcallao's Avatar
02 WITH 75K SOUNDS ALRIGHT. AS FOR THE MAF PROBLEM. YOU CAN GET A NEW ONE AT AUTOPARTSWAREHOUSE.COM FOR ABOUT 90 BUCKS. WHEN YOU REPLACE IT YOU'RE CAR SHOULD RUN LIKE NEW CONSIDERING THAT IS THE ONLY PROBLEM WITH IT. IT ALSO DEPENDS ON HOW MUCH YOU ARE GONNA PAY FOR THE CAR. HARD TO SAY IF IT IS A DEAL WITHOUT KNOWING THE PRICE.
Old Feb 10, 2007 | 08:19 PM
  #1165
djcallao's Avatar
Can Anyone Help Me Out On Where To Find An Ae Engine Cover For My 2000 Max.
Old Feb 11, 2007 | 05:59 AM
  #1166
SoonerFan's Avatar
Cletus
call daveb (number in stickies). he will sell you the cover and all the hardware for a good price.
Old Feb 11, 2007 | 11:03 AM
  #1167
djcallao's Avatar
THANKS MAN
Old Feb 11, 2007 | 11:12 AM
  #1168
djcallao's Avatar
HOW DO I FIND HIS NUMBER?
Old Feb 11, 2007 | 11:14 AM
  #1169
irish44j's Avatar
retired moderator
look in the FAQ stickies....it's there.
Old Feb 11, 2007 | 11:32 AM
  #1170
djcallao's Avatar
SORRY MAN I'M STILL HAVIN TROUBLE FINDIN IT
Old Feb 11, 2007 | 01:35 PM
  #1171
00MaxSE's Avatar
Pointy Elbows
Took me 3 seconds. http://forums.maxima.org/showpost.ph...8&postcount=85
Old Feb 11, 2007 | 03:10 PM
  #1172
Little John's Avatar
2003 GLE, about 75k miles, and I'm staying on top of maintenance. Makes a thunking type of sound that seems to be coming from the engine area (can't hear it differently with the window open on either side). It's linked to wheel speed and if my foot's off the gas. If I touch the gas or the brakes, the sound stops, and starts right up again when I get my foot off the pedal.
Any ideas would be appreciated. Thanks. -LJ
Old Feb 11, 2007 | 08:46 PM
  #1173
irish44j's Avatar
retired moderator
is there any vibration that you can feel related to this sound, or is it only the noise?
The only thing I can think of is that it might be a worn CV axle - since it goes away when pressure is applied (via gas or braking) to the driveaxle. Is the sound more apparent when turning or in a straight line (or does it make no difference)?
Old Feb 11, 2007 | 09:02 PM
  #1174
KEV03SE's Avatar
I run 17x8 fno1r-c's with a 35mm offset and 245/45/17 tires. They are almost flush in the front, and about 10mm in in the back.
Thanks Irish. Would you have a guess at the clearance inside from suspension to tire/rim with your 35mm 8inchers? Just making sure the online calculator I am using to estimate is correct.
http://www.rims-n-tires.com/rt_specs.jsp
Old Feb 12, 2007 | 05:13 AM
  #1175
No vibration yet, but the sound was worse this morning than last night. I don't notice any changes when steering. One theory was U-joint?
Old Feb 12, 2007 | 12:51 PM
  #1176
JohnWEngle's Avatar
I'll second Irish's guess-timate. CV joints are usually more noticable when you turn the steering wheel a lot and at low speeds. Try going to a parking lot and turning the steering wheel to full lock and drive slowly (not faster than say 35mph). If no noise, then try full lock the opposite direction. You should get much more noticeable thunking/clunking noise this way. If it is more noticeable doing this, then I'd say you definitely have a worn CV joint. You may also want to check the cv joint boots for holes or tears. A boot that is torn or has holes will throw most of it's grease out fairly quickly and you should have an nice layer of "chocolate frosting" somewhere on the bottom of your car.... A damaged boot and clunking is definitely a CV joint.
Happy hunting.
Old Feb 12, 2007 | 06:01 PM
  #1177
PandaXpress's Avatar
OK...this is a NOOB question...but where the hell do i buy mesh to make a grille for the front and bottom of my 00-01 bumper? I cant seem to find it anywhere...can someone help me out? Thanks in advance
Old Feb 12, 2007 | 06:04 PM
  #1178
SoonerFan's Avatar
Cletus
gutter guard from home depot
Old Feb 12, 2007 | 06:34 PM
  #1179
irish44j's Avatar
retired moderator
CV axle (it's not a u-joint, it's a CV joint) or (shot in the dark) perhaps one of your pulleys is loose...
Old Feb 12, 2007 | 06:36 PM
  #1180
irish44j's Avatar
retired moderator
Happy hunting.
I'm not disagreeing with you - I'm just thinking out loud. When the car is coasting the CV assembly is "unloaded" and somehow maybe is causing noise (or maybe the CV axle bearing on the passenger's side??), which goes away when braking or accellerating ("loading" it). It's a longshot, but with not much details, it's hard to make a call on what a noise is.
Another thought: check your brake pads for even wear. Perhaps a piston is stuck or something in a caliper.
Old Feb 12, 2007 | 07:28 PM
  #1181
isnt this like some chicken wire? or is it like what street scenes uses for their grilles?
Old Feb 12, 2007 | 07:32 PM
  #1182
00MaxSE's Avatar
Pointy Elbows
No, it is not like chicken wire. It is similar to the Street Scenes material, but helluva lot cheaper.
Old Feb 12, 2007 | 07:33 PM
  #1183
irish44j's Avatar
retired moderator
no, chicken wire is much thinner. Gutter guard is thicker and stiffer (and galvanized, so it won't rust). It kind of looks like the ungalvanized stuff street scenes uses....
Old Feb 12, 2007 | 08:51 PM
  #1184
lol..why laugh? ive seen chicken wire on the civic..lol..i was being serious ...so trip to home depot is in my near future!
Old Feb 12, 2007 | 09:05 PM
  #1185
djcallao's Avatar
Now can someone help me with a legitimate question? What would be the best drop in inches for the front and rear to use with 20 " wheels?
Old Feb 12, 2007 | 09:17 PM
  #1186
The Law's Avatar
I R The Law
I'm assuming you havn't done any research at all with suspension. You can make any 20" rims fit with the right offset with any type of drop if you wanted.
I'm sorry but I'm not going to spood feed when there is a suspension thread that is stickied on in this forum.
Old Feb 12, 2007 | 09:25 PM
  #1187
LA02MAX's Avatar
I would advise against 20" wheels, but that's another issue
You will need to check offset clearances, but most drops available will accomodate 20" wheels...your tires will just be rubberbands.
Old Feb 12, 2007 | 09:38 PM
  #1188
djcallao's Avatar
Haha rubberbands, I like that, what is the problem with 20" wheels? Can you let me know. If I can avoid problems than I will. If 20's will give me problems in the future than forget about it. Right now I have 02 Max stocks on my 2000. Thanks man
Old Feb 13, 2007 | 04:11 AM
  #1189
It was really bad yesterday on the way home from work - I had to skip class that night cuz of it. Dropped it off at the dealer instead (warranty), so we'll see what happens.
Incidentally, it was happening at highway speeds, too. We shall see. And I'm renting a Neon. What a POS.
Old Feb 13, 2007 | 09:05 AM
  #1190
I'm an idiot. Wasn't the CV. Or a pulley. Or the transmission. It was loose lugnuts. I did the brakes back a month or two ago, and I guess I didn't do the lugs tightly enough. I'm an idiot.
Old Feb 13, 2007 | 09:15 AM
  #1191
00MaxSE's Avatar
Pointy Elbows
I'm an idiot. I'm an idiot.
Torque those suckas down to 87 ft-lbs.
Old Feb 13, 2007 | 09:16 AM
  #1192
Puppetmaster's Avatar
It happens... at least you got things sorted out without dropping a lot of time or money into it.
Old Feb 13, 2007 | 10:09 AM
  #1193
Yep. And do it again a few days later. Me--> <-- My stupidity
Old Feb 13, 2007 | 11:16 AM
  #1194
irish44j's Avatar
retired moderator
There is no "problem" per se, only:
1. 20" wheels are heavy as hell, and will make your car considerably slower than stock, and will also adversely affect how the car handles.
2. With ultra-low-profile tires, you will feel every crack, bump, and divot in the road. Even moreso if you lower the car. Heavy wheels + ULP tires + stiffer springs + less spring travel = terrible ride qualit and terrible handling. It's that simple.
3. Tires for 20's are damn expensive (at least "quality" tires).
4. Very easy to bend a rim on a pothole because there's not much tire between the rim and the road. Better buy an extra one....
5. Most here will agree that 20's look idiotic on a 5th gen (most, not all) but that's a personal choice. Most here prefer 18's (or 19s at most).
As to the springs: read the sticky at the top of the 5th gen forum. There is far too much to just discuss here, and there are a million discussions on this topic already.
  #1195
irish44j's Avatar
retired moderator
yup...that'll do it
Old Feb 13, 2007 | 11:27 AM
  #1196
djcallao's Avatar
Thanks, that is very helpful info. I'll take all of this in consideration. Thanks again.
Old Feb 13, 2007 | 04:23 PM
  #1197
The Law's Avatar
I R The Law
Omg!!! Bump!!! Stupid Newbies Making Stuipd Threads!!!
Old Feb 14, 2007 | 11:33 AM
  #1198
irish44j's Avatar
retired moderator
lies! That never happens!
Old Feb 14, 2007 | 02:36 PM
  #1199
jocoo's Avatar
Dashboard Removal + Gauges
I'm new driver and new to the whole car mod scene and would like to replace my dashboard gauges and lights in my 02 maxima. How do I got about removing the dash? Also does anyone know where to find reverse glow guages for 2002 maxima?
Old Feb 14, 2007 | 05:15 PM
  #1200
MaxGirl970's Avatar
I am a noob and just thought I would introduce myself. I don't have my max yet but am eagerly awaiting the "perfect" 02/03 SE with an auto trans. I test drove one about three weeks ago and have been anxious to find one with everything I want ever since. I'm wondering though, are there any Haynes type manuals out there for the 5.5 gens? I've only been able to find ones that go up to 2001.
