5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Dec 15, 2010 | 01:56 PM
  #12001
slomb's Avatar
Originally Posted by foodmanry
1) Problem 1 sounds like it has to do with the security where the chip in your key is not recognized and leaves the car disabled (unable to start). Does the car show any power when you have the key in the ACC or ON position?
Yes thank I would never have thought of that - any way to test ? or is it only can be determined if it fails.
2) It is rear shock, not strut. Fronts are struts.
Thanks it's what I thought
Old Dec 15, 2010 | 01:58 PM
  #12002
Nelsito65's Avatar
Originally Posted by slomb
new here - hope this is the place to post these questions.
Have 2003 Maxima SE, and having starting issue.
1) Occasionally the car will not start, no clicking (or whirring), only has happened after starting and travelling short distance to fill gas tank. Twice now I have it towed, it starts after tow (flat bed), and the mechanic who looks at it says he can't find anything wrong it. He says he could change the starter motor but he won't garantee that is the problem. Any ideas to check for before have the starter motor changed ? NOTE: this has only occured since we have come into colder weather. not sure if this is a condition but noted.
Also
2) I need to get suspension done, when I check the part places, I note that they do not have any references to rear struts. Am I confused ? Because some of the forums talk of them. or is this just a reference to the rear shock assembly.
hope you can help
Since you don't specify whether your car is automatic or manual transmission, if it is auto, next time you have the starting issue (with no clicking or whirring), try pushing the gear selector lever as far as it can go towards to P and see if that helps. I had a similar issue with a '98 maxima and ended up being a defective ignition switch.
Old Dec 15, 2010 | 02:24 PM
  #12003
pmohr's Avatar
No more Maximas...
Rears are struts just like the front. 6th gens and above have shocks in the rear, J30/A32/A33 all have rear struts.
Old Dec 15, 2010 | 06:58 PM
  #12004
everysandwich's Avatar
Rough cold start
Hi, folks. I have a 2000 GLE that lately started running rough in the mornings, though it's better after it warms up. It's had a tune-up and the injectors cleaned, yet still idles rough. I don't know if this is related, but I hear an odd sound when it's struggling to warm up, which I've recorded. I thought someone might recognize the sound and have a clue from it. There was no one pressing the accelerator while this was recorded. Sporadically you'll hear something that sounds to me like something trying to spray air or gas, maybe. Or possibly a vacuum leak? I'm clueless and guessing though. Here's the audio. Thanks so much for any help. Hope I haven't violated a forum rule already.
Old Dec 15, 2010 | 07:15 PM
  #12005
foodmanry's Avatar
Da Roller Coaster!
Oh, really? Every time I have purchased shocks/struts they have always been labeled as shocks....
Old Dec 15, 2010 | 07:16 PM
  #12006
Nelsito65's Avatar
My 5th generation has shocks in the rear, not struts.
Old Dec 15, 2010 | 07:17 PM
  #12007
pmohr's Avatar
No more Maximas...
Check, among other places, Monroe's site for an '03 then an '04, see their nomenclature. Even the FSM uses identical wording for struts both front and rear.
If it's factory, it has struts. What makes you think they're just shocks? The integrated lower spring perch and spring retaining upper mount classify them as struts to everyone but the most pedantic (as in the rear struts don't locate the wheel as the fronts do, very few people would consider that reason to call them shocks).
Old Dec 15, 2010 | 07:26 PM
  #12008
Nelsito65's Avatar
It is factory and the rear are called shocks, whereas the front are called strut asemblies (my FSM calls them like that and KYB uses the same nomenclature)
Old Dec 15, 2010 | 07:29 PM
  #12009
pmohr's Avatar
No more Maximas...
Is there an actual reason you consider them shocks, or are you just going by wording?
Old Dec 15, 2010 | 07:31 PM
  #12010
Nelsito65's Avatar
In this case, I'm going by what they are called in the FSM, and at the place where I purchased them from.
Old Dec 15, 2010 | 07:37 PM
  #12011
pmohr's Avatar
No more Maximas...
The FSM calls the fronts shock absorbers also, so I guess you have shocks all the way around
I see there's really no point in arguing this, as it seems to be a matter of opinion as far as what to call them, even though they are struts by matter of design, not standalone shocks. The integrated spring perch says enough.
  #12012
foodmanry's Avatar
Da Roller Coaster!
Check the attached picture...straight from the FSM, "shock absorber."
Old Dec 15, 2010 | 07:39 PM
  #12013
pmohr's Avatar
No more Maximas...
Then check my picture above. Shall I quote what I said earlier?
Old Dec 15, 2010 | 07:44 PM
  #12014
foodmanry's Avatar
Da Roller Coaster!
Ok, so the consensus is there is no consensus...however, most shops do call the front suspension "struts" and the rear "shocks."
From the OP's standpoint, this is what he was looking for, not the "technical name."
Old Dec 15, 2010 | 07:49 PM
  #12015
Nelsito65's Avatar
^^Agree.
To pmohr, this a page from my FSM, front suspension:
Old Dec 15, 2010 | 07:50 PM
  #12016
pmohr's Avatar
No more Maximas...
Not in my experience, when I was working at Nissan we called them (and ordered parts as) struts front and rear, same at Firestone, etc.
Just saying, you ask for a shock, they may think you gave them the wrong year and send you a shock for a 6th gen, or some random part, not the strut you're looking for.
But looking back at the poster's original question, he says that his auto parts stores don't show a listing for rear struts. A quick search on each of these sites shows that O'Reilly's, Advance, Autozone, and NAPA all have listings for rear struts and rear strut mounts.
Old Dec 15, 2010 | 07:53 PM
  #12017
pmohr's Avatar
No more Maximas...
^^Agree.
The only difference between the struts in the front and the rear are that the fronts have a bearing in the mount, to allow the whole strut to swivel for steering. This also opens up the category of MacPherson struts, which may be what the FSM is specifically referring to there.
Either way, as I said, there's no point in arguing as the design of the rear struts really speaks for itself, though it seems it's hard for some to realize.
Old Dec 15, 2010 | 08:00 PM
  #12018
Nelsito65's Avatar
I'm not arguing the differences between the two, which in fact are more than just the swiveling action. My initial comment was that my 5th generation has shocks in the rear, not struts. That is how they are called in my FSM, as well as the place where I got them from, althought that fact seems to be hard be admitted for some.
Old Dec 15, 2010 | 08:04 PM
  #12019
pmohr's Avatar
No more Maximas...
Yes, there are more differences than just the bearing plate, but they are quite similar otherwise.
Fair enough, you continue to believe that your car has shocks in the rear, I'll continue to believe that it actually has struts. I never said that wherever you got them from didn't call them shocks, or that the FSM doesn't refer to them as shocks (which, as above, it also calls the fronts). All I'm saying is that by design, they are struts.
Old Dec 15, 2010 | 08:10 PM
  #12020
Nelsito65's Avatar
Deal. It's a good thing I got the right parts when I ordered my rear shocks.
Old Dec 15, 2010 | 08:15 PM
  #12021
djshwini's Avatar
HELPPP!!!!!!!
http://forums.maxima.org/audio-elect...surprised.html
Old Dec 16, 2010 | 12:29 PM
  #12022
Slow Motion's Avatar
O2 Problems.
2000 GLE having o2 problems, bank 1. Is there anything I should know about taking the o2 out and replacing it. I was told that it could brake if it's rusted and that I could strip the threads and have to replace the entire cat. Is there a thread on this or "how to"? I found the threads [FAQ thread and How to thread] which showed the codes and a diagram of where the o2 sensors were, I just need to know how careful I should be in this particular area. If you have gotten this done at a dealership how much did it cost you? I know it's going to be around $200 for the parts but, how much for labor? If you live in the Atlanta area, let me know if you know a good indy or can just help me with it. I want to get this done ASAP Like today or tomorrow. PM me with answers please.
Slow Motion | Atlanta, Ga.
Old Dec 17, 2010 | 11:58 AM
  #12023
JBB's Avatar
JBB
Bump -anybody able to help me with this?
Originally Posted by JBB
Hi - I need some help with a spark plug change on an '03. I'm trying to buy the gasket that will be replaced when I pull the manifold. The dealer quoted me a price of $5 and change on part #14010A. I was under the impression this gasket costs more like $30.00- Do I have the right gasket?
Old Dec 17, 2010 | 03:10 PM
  #12024
VQP0WER's Avatar
upper manifold gasket?
I'm showing about $4 at Courtesy Parts
Old Dec 17, 2010 | 03:13 PM
  #12025
VQP0WER's Avatar
Just unplug the harness, clip the zip ties, and put a dang wrench on that sucker. A little pointer would be to soak the sensor/bung with liquid wrench or other type of oil when the engine is cool.
Old Dec 17, 2010 | 03:39 PM
  #12026
sadkowmx90's Avatar
24mpg down to 16 mpg
hey, im new to this website and not sure how everything is layed out but i was wondering if anyone could help me out. i have a 01 maxima i use to get around 22-24 mpg 70%city 30% highway all of a sudden now im getting 16 mpg. i cant figure it out
Old Dec 17, 2010 | 03:42 PM
  #12027
foodmanry's Avatar
Da Roller Coaster!
Could be...bad MAF, bad O2 sensor, fuel leak. My bet is on the bad MAF as it won't necessarily throw an engine light if it is bad.
Any change in your performance?
Old Dec 17, 2010 | 03:47 PM
  #12028
sadkowmx90's Avatar
i replaced my MAF 3 months ago because it totally failed but is there a way to test the new one i have and could a in expensive cone filter screw it up ?
Old Dec 17, 2010 | 05:04 PM
  #12029
foodmanry's Avatar
Da Roller Coaster!
Hmmm....did the MPG drop correspond to the MAF replacement? A cone filter can only screw up a MAF is you are way too excessive on the oil.
Old Dec 17, 2010 | 05:12 PM
  #12030
sadkowmx90's Avatar
No i did not have a decrease of mpg when i replaced it i just checked out my MAF and its as clean as can be i dont think that is the problem. maybe clogged cats? i had a code for bank 1 catalyst below threshold efficiency but it went away. i san some sea foam through it and thats when i noticed the decrease in MPG maybe my last catalytic converter (main cat) is clogged thus causing pore mpg? i already have a whole new 3 way catalyst system waiting to be put in iv just been putting it off because its dam cold here in Massachusetts
Old Dec 18, 2010 | 07:33 AM
  #12031
foodmanry's Avatar
Da Roller Coaster!
Could be the cat, but you probably have a bad O2 sensor. If you have the cat, get the O2 sensor and replace both. Or, if you want to do a more troubleshooting analysis approach, replace the cat first and see if MPG improves. If it doesn't, replace that O2 sensor.
Old Dec 18, 2010 | 10:18 AM
  #12032
djshwini's Avatar
for the past 4-5 days my battery has been dead every morning or every other morning. The battery is only about 1-2 months old but i checked the levels and one of the cells was completely empty. So i filled that one up and toped the other ones off w/ distilled water. I was just wondering if that would be the ONLY reason why the car was dead every morning or if there would be a short or power draw from another place.
Old Dec 18, 2010 | 10:58 AM
  #12033
foodmanry's Avatar
Da Roller Coaster!
Only way to be sure is to get both your battery and alternator checked. It is possible the alternator is just not supplying enough charging. If both check our fine, then look for a power draw somewhere.
Old Dec 18, 2010 | 11:09 AM
  #12034
jakemort74's Avatar
hey ive noticed the rpms on my 2001 maxima gle have been bouncing slightly (about 100-250 rpms) when coming to a stop, what causes this? It just bounces once and then settles down to about 750 rpm.
Old Dec 18, 2010 | 01:56 PM
  #12035
:erseyFresh609's Avatar
II am looking to replace the shift **** and boot on my 2000 5speed and don't know where to began. Does anyone know where I can find pictures or a video? Thanks.
Old Dec 18, 2010 | 08:21 PM
  #12036
2kmaxseblack2k's Avatar
I have a ? How do you become maxima of the month...and what are the qualifications? GUYS check out my profile pics and let me know if you think my car has potential..also BTW i just got my profile signature to work its f**king dope. RIGHT? haha lol ...sorry im just extremmley happy i got it to work finally. someone on the other forum page told me the tricky troo and just copy and paste..i had no idea anyways let me know your comments and answers. Thanks.
Old Dec 18, 2010 | 10:10 PM
  #12037
Maxima2MAX's Avatar
Hi & Thanks in advance KNOCK SENSOR 2001 Max
Hi guys very nice site very helpful
been looking for solution to my issue, 2001 maxima SE 20th Ann.
owned car close to year, runs good after 5 minutes, even longer 10mins, now that winters apound us, up Here in Canada...
To start the car, even in mid summer beautiful days I need to hold the gas a little, for 30seconds or so, let off let sit for the 5 or more minutes, befour she idles normaly.. and dosn't want to stall. leave to soon it will Stall out soon as back out.
the only code im getting is knock sensor, so i ordered its..
couple days later i get the part, go to install.
removed the air intake & what not in way, i know its hard to see, but couldn't find it. so i started to pull on the harness, to my surprise wasn't hooked up to anything.
with little more looking/feeling around , noticed where it once was under mainifold the bolt snaped off few treads below.
So i guess my Question's would be is it in my best interest to relocate the KS.( Because i dont want to have someone remove mainifold to machine the bolt out.. above my head ) & maybe know suitable spot?
or returns parts harness and sensor i just paid for (few months back now), and try the bypass?
Thanks in ADVANCE and Happy Holidays
Green
Old Dec 19, 2010 | 08:23 AM
  #12038
VQP0WER's Avatar
Looks like a stock SE with tint.........I dont see MOTM potential.
Old Dec 19, 2010 | 11:40 AM
  #12039
JBB's Avatar
JBB
Thanks, Mark. Also, I'm trying to confirm the gasket 14010A is the one I'll have to replace to change the rear bank of spark plugs. Is this the correct one?
Old Dec 19, 2010 | 04:37 PM
  #12040
VQP0WER's Avatar
You can reuse the existing one if it's still looks alright, but for $4-5, might as well install new. And yes, that's the correct seal. Here's a write up.
http://www.vqpower.com/v2/articles.php?article_id=27
