5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Jan 25, 2011 | 02:18 PM
  #12321
djfrestyl's Avatar
Suspension Yoda
Originally Posted by L36
Hello.
Just recently got a P0430 code, which cat is it? Says bank 2 but im not sure, want input before i order the part. Checked the O2 sensor, not it.
Cali or Fed spec?
Old Jan 25, 2011 | 02:50 PM
  #12322
L36's Avatar
L36
Cali or Fed spec?
Fed, don't need cali.
Old Jan 25, 2011 | 04:31 PM
  #12323
VQP0WER's Avatar
It's your precat behind the radiator.
Hollow it out or get a Eastern Cat.
Old Jan 25, 2011 | 05:20 PM
  #12324
L36's Avatar
L36
Elaborate on the hollow part...
Old Jan 25, 2011 | 09:29 PM
  #12325
JohnJohn0414's Avatar
I am new here. Recently bout a 2000 nissan maxima se 5 speed manual v6. was wondering what type of mods i can do to increase horsepower on this vehicle. most work will be done myself currently enrolled in an automotive technician program.
Old Jan 25, 2011 | 10:03 PM
  #12326
jowo9's Avatar
On a 2000/2001 (5th gen) Maxima the best bang for your buck bolt-on mod is going to be an aftermarket y-pipe, because that eliminates the pre-cats in the 5th gen. After that, there are a ton of other supporting mods you can do. (short ram intake, headers, NWP intake spacers, etc etc.)
Old Jan 25, 2011 | 11:20 PM
  #12327
BigLou55's Avatar
I have a question: is there a #74 LED available so I can just swap out with no soldering? I really not concerned about brightness i just want to achieve a particular color. Since the subject is somewhat related. what bulbs would I need to replace some of my warning lights specifically my abs, tcs, and slip lights on a 2000 max. What kind of bulbs do the shift selector for a auto, the auto climate control, window controls, and the stock radio. I basically want to make em all green. Any help would be appreciated
Old Jan 26, 2011 | 05:13 AM
  #12328
VQP0WER's Avatar
The inside of a precat is made of a honeycomb ceramic type material that can be removed in a couple minutes with a air chisel, or 20 mins with a normal tool.
You would also have to get a O2 simulator to trick the computer into not throwing a P0430 code again. This is all if you don't want to spend the money (about $180) for a new Eastern Precat.
Old Jan 26, 2011 | 06:21 AM
  #12329
babyphace03's Avatar
hi guys thanks for everybodys responses. Big help.
Old Jan 26, 2011 | 08:16 AM
  #12330
detroitmaximus's Avatar
BOSE SOUND :-(
I recently purchased a used 2002 Maxima GLE with the BOSE sound system in it. There is absolutely NO BASS in this system...it's terrible! The car looks like it had a separate aftermarket sub in it from previous owner. Do you think the lack of bass is from the stock BOSE sub possibly being disconnected? What do other 02 GLE owners think of their BOSE system?
Old Jan 26, 2011 | 08:45 AM
  #12331
djfrestyl's Avatar
Suspension Yoda
It sounds likely that it was disconnected because of an aftermarket being installed, but I think it would be beneficial for you to confirm if your Bose sub is actually hitting or not, prior to posting. This way we can guide you based on facts rather than speculation.
If it is actually active, then I'd recommend replacing your Bose HU with something aftermarket - it will bring out the untapped potential of the rest of your Bose speaker system.
Old Jan 26, 2011 | 03:51 PM
  #12332
Kidnasty's Avatar
Hey guys I just wanted to make sure does a MT rear motor mount fit on an AT no messing around with the cross member and stuff necessary? car is a 2001 gle
Old Jan 26, 2011 | 03:53 PM
  #12333
mikedeeo's Avatar
Maxima Year 2000 Auto Transmission idling issue
Hi, I am a newbie here, looks like a great place to get to know your car. I have a 2.0 Maxima auto year 2000, just got it a few days ago. I notice though when it is idling and in d when my foot is on the brake, it is like the engine is pulsing, kind of jumpy every few seconds, hard to explain. If I put the car in P or N, it sounds perfect, no sensation. When moving very slow, I notice this too but once on the motorway etc, it is fine moving along. It is not even like the car is trying to pull off, it is a very odd sensation. Any advice or help would be great.
All the best,
Mike.
Dublin, Ireland.
Old Jan 27, 2011 | 05:44 AM
  #12334
djfrestyl's Avatar
Suspension Yoda
Yes, it will fit. Bolts right onto the crossmember and lines up to the engine no problem.
Old Jan 27, 2011 | 10:46 AM
  #12335
Slow Motion's Avatar
What makes the SE and GLE different, when it comes to performance? Is it just the transmission or tuning?
Old Jan 27, 2011 | 12:32 PM
  #12336
NmexMAX's Avatar
dot dot dot ...
No difference in performance if you get the auto transmission. If the SE has a manual, then it's a bit different, but the engine is identical.
Old Jan 27, 2011 | 12:59 PM
  #12337
djfrestyl's Avatar
Suspension Yoda
The differences are more in the suspension and cosmetics/options/features.
Old Jan 27, 2011 | 03:23 PM
  #12338
ChiTeMax's Avatar
Hi again guys,
Turns out I cannot create my own thread (yet?) so I'll post my question here.
I tried to DIY brake master cylinder replacement. I knew I'd definitely need the Flare Nut wrench to loosen/open bleeder bolts on the MC. Well lo and behold after suctioning the brake fluid using a turkey baster, i started to loosen the brakeline bolts, the one on top came loose fairly easily. But the one that's facing throttle body seemed really hard to shake off. The wrench just spun off a little. I reseated and made sure to hold it in place so it doesn't run off again. After trying relentlessly for a while, the bolt is just semi-stripped. The corners on the bolt are almost warped. I don't think I'll be able to loosen or unbolt it using the Flare nut wrench.
So for now I've tightened up the upper bolt again since I can't take off the MC anyways till I have a solution to get the brake lines off.
Have any of you ever run into this problem? What's my best bet to unbolt the stripped bolt? I'll ofcourse replace them both with the new ones once I have 'em off. Getting 'em off is a priority right now. Please help!!!!
Thanks a mill!
Old Jan 27, 2011 | 03:30 PM
  #12339
djfrestyl's Avatar
Suspension Yoda
Can you squeeze some vice grips on there?
  #12340
ChiTeMax's Avatar
Just for reference sake, the link is to a picture i found on nicoclub and i've circled the bolt I'm referring to.
Old Jan 27, 2011 | 03:31 PM
  #12341
ChiTeMax's Avatar
I have not tried it yet. I'll have to buy vise grips. You know the spot is kinda tight though....
Old Jan 27, 2011 | 03:33 PM
  #12342
djfrestyl's Avatar
Suspension Yoda
Definitely looks like you can. Regular ones have a lot more gripping power and have a few sizes, but if you can't fit any, get the needle nose kind.
Why don't you use a regular box wrench instead of flare nut?
Old Jan 27, 2011 | 03:38 PM
  #12343
ChiTeMax's Avatar
I was under the impression that the reason you use Flare nut is because it prevent stripping of the bolt since it envelopes the bolt. lol Ironic!!
I tried to needle nose pliers already, it's a no go. The damn bolt is on there pretttttty tight.
Old Jan 27, 2011 | 03:52 PM
  #12344
djfrestyl's Avatar
Suspension Yoda
Try vice grips. The nut is already stripped so who cares if the teeth marr it up.
Old Jan 27, 2011 | 03:56 PM
  #12345
martingauvin's Avatar
changing my 01 automatic trany to a manual trany
hey guys! i was just wonderring how big of a job im looking at to change my 01 maxima from a automatic to a manual ?? i allready replaced my automatic trany a couple of times and i found that was pretty simple with the right tool but not sure about this one... i heard i had to change the computer clutch pedal and clutch cylinder and shifter ok but how hard that couple be and do i have all i need to know??? thanks
Old Jan 27, 2011 | 04:57 PM
  #12346
L36's Avatar
L36
Hello.
Anyone ever had an issue where front speakers just stop working, then come back and go out again?
Checked the fuses, and the harness connection. Weird.
Old Jan 27, 2011 | 05:07 PM
  #12347
djfrestyl's Avatar
Suspension Yoda
Hello.
It's your head unit. Replace with aftermarket.
Old Jan 27, 2011 | 05:08 PM
  #12348
djfrestyl's Avatar
Suspension Yoda
Check the all motor section. There's a LOT of info there.
Here's a link to the sticky in that section that has the 5 speed swap parts list:
http://forums.maxima.org/all-motor/3...arts-list.html
Old Jan 27, 2011 | 05:09 PM
  #12349
LongIslandMax's Avatar
It is relatively straight forward. You can use your auto ecu, but it will throw a few codes. Here is everything you need to know:
http://www.dynomagic.com/5spd_conversion.htm
Old Jan 27, 2011 | 05:55 PM
  #12350
**Please PM all Responses** I posted a few weeks ago that I had a cat code p0420 pop up, I realized that I had overlooked a test pipe that replaced the rear cat. With this new knowledge, I wanted to know if this could be the reason for my P0420 code? And if so, should I be concerned about the front cat being clogged or damage because of the test pipe? Also, would the test pipe cause the smell of a cat going bad (egg smell? It has only happened once)? How concerned should I be? I am not familiar with how test pipes operate but, plan on doing some research to find out. Could I just replace the test pipe and be fine? "Please" PM me responses or if you need more detailed information of what's happening. Thanx in advance.
Old Jan 27, 2011 | 06:05 PM
  #12351
really helpfull thanks!
Old Jan 27, 2011 | 06:37 PM
  #12352
VQP0WER's Avatar
Don't you have to install a O2 sim or antifoulers with a test pipe?
Old Jan 27, 2011 | 10:55 PM
  #12353
hey im a newbie with a 2000 nissan maxima se 5 speed looking to add more horsepower. car is basicly stock except for an injen intake what other mods can i add to gain more horsepower.
Old Jan 28, 2011 | 06:22 AM
  #12354
djfrestyl's Avatar
Suspension Yoda
What is your budget?
Old Jan 28, 2011 | 04:28 PM
  #12355
FEEZY914's Avatar
Been a member for quite a while and this is my first post. I own a 2000 Nissan Maxima, fully loaded. I opened the trunk and found that my spare tire wheel well has rusted out and there are holes in it. I finally run into some money and now i want to fix it. Are there any suggestions of how i can fix this. Do i replace the whole trunk itself? PLEASE SOMEONE HELP!!
Old Jan 28, 2011 | 05:49 PM
  #12356
L36's Avatar
L36
Hello.
Would anyone know if the alternator harness fit a 5th gen from a 4th gen?
This is what im talking about: Link
Old Jan 28, 2011 | 06:42 PM
  #12357
GrnKouki's Avatar
Hello.
Has anyone ever try putting G35 brembo brakes on a 2003 Maxima? or have any info at all please help
Old Jan 28, 2011 | 08:02 PM
  #12358
L36's Avatar
L36
Can you elaborate onto what is the "head unit"?
Old Jan 28, 2011 | 08:42 PM
  #12359
jowo9's Avatar
Are you serious??? How 'bout 4 seconds on google if you don't know...
Old Jan 29, 2011 | 07:37 AM
  #12360
djfrestyl's Avatar
Suspension Yoda
How many holes, and how big are they? The repair is really dependent on the extent of the damage.
Have you been able to isolate where the water is coming from? 99% of the time it leaks through a bad seal in the tail lights.
Also, have a look at the link in my signature. I've developed a product that replaces the saggy spare tire cover - I'm assuming yours is soaked and useless by now.
