5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Apr 17, 2009 | 03:47 PM
  #8321
at24's Avatar
Originally Posted by C-Young
I just called the Nissan dealership here and they told me they would have to take the "font cover" off to do this. Said it was about 8-10 hours labor.
I then stated it should only be a small programming procedure using a CONSULT II machine and he still said it would be 8-10 hours labor.
So that's a little more than $70 dollars...
Are they just feeding me some BS cause they don't know what theyre talking about or what?
Please shine some light...
WOW...
they are saying a whole bunch of BS... the whole reason why not everyone does it is because the consult machine itself is like a 1000 dollars, but a monkey can do it himself, its very very simple and it would take less than 4 minutes i swear, so go check another dealership or a mechanic that has the machine.
good luck and dont even pay above 50 for it except if u want too lol
Old Apr 17, 2009 | 03:48 PM
  #8322
at24's Avatar
Originally Posted by memphisballer
Not bad.Just mainly for looks not performance.Or for doing a fairly simple projector retrofit.
well there are some of them that already have projectors and they even are HID compatible, are their performance bad?
Old Apr 17, 2009 | 04:34 PM
  #8323
xshadow715's Avatar
hey guys umm i have a couple of questions. im getting my first car soon and im thinkin about getting a 02-03 max is there anything i need to know about it when i look at the car? im goin to college in the fall and im gonna be up in buffalo so would this be a good first car?
Old Apr 17, 2009 | 04:36 PM
  #8324
VQP0WER's Avatar
Take whatever car you are interested in, and take it to a reputable mechanic to have them look over it before purchasing. Test drive it.
Old Apr 17, 2009 | 05:01 PM
  #8325
SuperStasiu's Avatar
The projectors are sh!tty and the light pattern coming from them sucks and the headlights look cheap and riced out. But hey your money spend it how you want it.
Old Apr 17, 2009 | 05:02 PM
  #8326
Well the 02-03 have problems with the engine burning oil do to several reason. If i was you i'd get a 01 stick shift and call it a day VQ30DEK FTMFW!!!!!!
Old Apr 18, 2009 | 03:50 PM
  #8327
kpmikey808's Avatar
i have a 2k max with 81 k's on it. is there any tuneup or maintaince i should do to it and if so what is it.
appreciate the feedback and help thx
Old Apr 18, 2009 | 06:07 PM
  #8328
VQP0WER's Avatar
Look in your owners manual under maintenance. You should have flushed the trans fluid by now, if you haven't, I'de do that. Replace the plugs.......
Old Apr 18, 2009 | 08:50 PM
  #8329
segundo3000gt's Avatar
Noob question. I've got a 2002 Maxima and I tried replacing the rear struts. As I tried to remove the lower mounting bolt I realized that the nut was spinning with the bolt. There isn't any access to the nut though because of the shield behind the rotor. Is there a trick to this? Will I be able to access the nut by removing the shield or am I overcomplicating it?
Old Apr 19, 2009 | 08:19 AM
  #8330
VQP0WER's Avatar
Odd. I don't remember mine ever spinning. I thought the nut was welded on.....I don't remember. Anyhow, you may have to remove the shield to double wrench it. I would look back there and make sure the 'nut' is seated properly and not broken.
Old Apr 19, 2009 | 09:34 AM
  #8331
Thanks for the response. I was suspecting that the nut was supposed to be held in place but it broke free. My hope is that I do have access after I remove the shield.
Old Apr 19, 2009 | 09:40 AM
  #8332
pmohr's Avatar
No more Maximas...
Indeed, the nut should have a tab on it, or it should be in a hex shaped hole to hold the nut in place (haven't touched that area in a while).
Old Apr 19, 2009 | 10:08 AM
  #8333
tshay1's Avatar
does anyone know if the is a hid kit out there that will do both high and low beams in one ballast per headlight?
Old Apr 19, 2009 | 10:33 AM
  #8334
scarface4522's Avatar
what is this and y is it leaking brake fluid?
it doesnt look like its coming from the hose, it looks like its coming from the bushing lookin thing
Old Apr 19, 2009 | 10:50 AM
  #8335
Jordan22's Avatar
anyone have illuminated door sills???
does anyone know or have for a 2001 the illuminated door sills. i have been searching for weeks and i cant find them for this gen. i want them in chrome and glow blue but i feel like its a lost cause. anyone have any ideas or sites that can help me in this seems like quest i been on.????
Old Apr 19, 2009 | 10:53 AM
  #8336
Czerkas's Avatar
Hey guys one of my bulbs went out for my 03 maxima and somebody told me that I can get certain acura headlight bulbs for cheaper and they are the exact same thing. can nybody let me know if this is true.
Also, im assuming its a simple process to replace bulbs, but in case im overlooking something, is there anything I should know before tacling this?
Old Apr 19, 2009 | 10:55 AM
  #8337
http://www.paradox-systems.com/produ...products_id=65
Old Apr 19, 2009 | 05:50 PM
  #8338
Shadowes61's Avatar
Hey all. Im new hear and just bought my 2001 maxima se about 2 months ago. Wondering if i could possibly get some insight on a problem i am having. And for the record..the dealership i bought it from is just horrible. My mistake but i have wanted a maxima for a long long time and since i work off the books and have no co signer..i had no choice but to go with a lone shark.
The problem is after i fuel it up..it doesnt want to start. Take about 2 cranks..and the second crank starts it but very hard. Now..i brought it back to the dealer and they said it was Fuel Pressure Regulator. So they switched it out (and charged me full price heh). Turns out that wasnt the problem. So i called them back 2 days after i got it replaced and told em about this problem. Now there saying vapor lock wich they pointed out is a 10 hour fix. But i get confused because it only happens after fueling. Never stalls any other time. My personal mechanic told me to leave the gas cap off when i start it. But it still does it. And the gas cap being open allows the ventalation needes to prevent the vapor from escaping. So im clueless..and responces with ideas would be greatly appreciated.
Thanks in advance and sorry for such long post.
Old Apr 19, 2009 | 06:06 PM
  #8339
pmohr's Avatar
No more Maximas...
It would help if you actually said what part of the car we're looking at.
Is that the trailing arm?
Old Apr 19, 2009 | 06:08 PM
  #8340
yessir but i already kno whats leaking.thanks neways
Old Apr 19, 2009 | 06:09 PM
  #8341
pmohr's Avatar
No more Maximas...
What is?
Old Apr 19, 2009 | 06:10 PM
  #8342
im pretty sure its the trailer arm bushing because its definitely not the brake line so im gonna replace them... http://www.energysuspensionparts.com...sp?prod=7.7108
Old Apr 19, 2009 | 06:14 PM
  #8343
pmohr's Avatar
No more Maximas...
Ah. It does help to say whether it's actually brake fluid, or if you think it's brake fluid. If you say specifically that it's something that it's not, it misleads diagnosis.
Also FWIW that isn't a brake hose, that's the parking brake cable along the trailing arms.
Old Apr 20, 2009 | 07:30 PM
  #8344
Merovingian7's Avatar
Hello everyone I'm new here. I purchased an 02 max and I'm very happy with it. Can anyone tell me what kind of rim is this? I can't seem to figure out.
Old Apr 20, 2009 | 07:34 PM
  #8345
pmohr's Avatar
No more Maximas...
Does it not have any manufacturer or model number stamp either in the lugnut area or on the backside of the wheel?
Old Apr 20, 2009 | 10:16 PM
  #8346
kjunior's Avatar
still the same problem
Hello guys,
i have a weird problem! I give u the situation. My engine is cold, I start my car, put on Drive, press the gas,and then the engine hesitate like it dont want to take gas for 2 sec. After, everything is ok. Someone here told that could be the MAF. I change it. It's a little bit better but not good. Do you have a another idea of what is the problem. I just don't want to broke something else because of that.
Thank you !!
Old Apr 20, 2009 | 10:49 PM
  #8347
Stormzusmc's Avatar
Originally Posted by kjunior
Hello guys,
Thank you !!
Read what you typed out loud, then fix and try again....oh and try more detail as well....
Old Apr 21, 2009 | 09:00 AM
  #8348
TheOnlyMax88's Avatar
^^^ lmao ^^^
Old Apr 21, 2009 | 09:46 AM
  #8349
NmexMAX's Avatar
dot dot dot ...
My 03 does the same thing. The gas cap thing works, but, what I do is remove the key, and wait about 5-7 seconds, then start it again. Seems to work for me and my gas cap can stay on.
Old Apr 21, 2009 | 11:31 AM
  #8350
papasuede's Avatar
http://www.nissanusa.com/owning/vehi...intenance.html
Old Apr 21, 2009 | 03:27 PM
  #8351
asdf1855's Avatar
I'm having a problem with my 6cd Bose (2002 GLE). I've read the various posts which relate to my problem of the audio cutting out. I'd like to replace the old ribbon cable with a new one myself, but I can't find any info/links on where to find a replacement ribbon cable. Does anyone know where to get a replacement cable?
Old Apr 21, 2009 | 04:48 PM
  #8352
I went back and took a closer look and the only thing I saw was this weird logo......I'm sorry if I sound newbish but thats all I saw....
Yes I know they aren't pretty but I'm curious so if anyone knows please help me out.
Thanks in advance.
Old Apr 22, 2009 | 08:31 PM
  #8353
tailz's Avatar
I still can't make a thread for some reason but. My tranny needs a rebuild(front diff bearing) . Its a 2000 maxima se tranny. I'm going to tackle it myself as I'm thinking I can do it. My question is what all will i need parts wise for doing this? Can you buy rebuild kits from the dealer?
Anybody done this and has a good write up on it, thanks
Old Apr 22, 2009 | 08:44 PM
  #8354
pmohr's Avatar
No more Maximas...
No 15 posts, no new thread.
Assuming 5 speed? Did you search around at all?
http://forums.maxima.org/4th-generat...te-up-pix.html
Several rebuild kit threads as well, just search for them.
Old Apr 22, 2009 | 09:12 PM
  #8355
Shadowes61's Avatar
Made my night :)
Hello guys,
Thank you !!
Hehe. My hyundai had that problem. Mechanic told me it was just a bad make of the car..in other words had no idea what he was talking about i would assume. But then again...now we have maximas..wich is obviously better. Let me know if you find the problem.
Old Apr 22, 2009 | 09:23 PM
  #8356
tailz's Avatar
I've searched around, I heard that 4th gen and 5th gen tranny's are different? No?
Old Apr 22, 2009 | 09:25 PM
  #8357
pmohr's Avatar
No more Maximas...
They are different, but barely.
Old Apr 23, 2009 | 05:46 AM
  #8358
01Trickster's Avatar
Used motor parts 01AE
I have a motor with a few bent valves looking to part out or sale the whole motor, any takers. Going to put in the paper next week.
Old Apr 23, 2009 | 07:23 AM
  #8359
jam52571's Avatar
Service engine light
Help,
The service engine light came on in my 02 max, a guy at my work check the code, it came back ignition timing advancing too fast, any suggestions.
Old Apr 23, 2009 | 09:43 AM
  #8360
pmohr's Avatar
No more Maximas...
Originally Posted by jam52571
Help,
How about posting the actual code?
