5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Feb 13, 2011 | 11:52 AM
  #12441
fsaenz10's Avatar
Hello, I urgently need some advice regarding my 2000 Maxima. I have been battling multiple codes for a long time and I am almost out of money to keep putting into this car.
The car currently has 86K. I replaced the MAF (after market) for the first time on 6/2010 and it went bad again in 2/2011. I replaced it the 2nd time with Nissan original part since the car was not running. I did not have the ECM reprogrammed by the dealer after changing the MAF. I have also had other codes present for P1320 (along with P0302 and P0306). After doing a lot of research here I decided that I will purchase the ignition coils from Dave B and had my mechanic replaced all 6. The old ones had the grey dot on them so it is not that I have the original bad coils. I replaced them and now I have codes P0158 and P0420. One time in the past I also had code P0430 but it went away and never came back.
Is it possible to have so many codes and so many things go bad all at the same time?
Regarding my P0158 and P0420, I know the P0158 is probably for the O2 sensors and the P0420 is for the cat. My car is CA emission so it has 4 O2 sensors. I need the car to pass inspection in NJ and the car won’t pass with the light on. The car runs fine otherwise.
I really do not want to keep on putting money into the car if I am not going to be able to get the CEL fixed. Maxima is a great car when it works fine but I am sure Nissan knows they messed up with all the emissions parts.
Any advice?
Old Feb 14, 2011 | 06:28 AM
  #12442
j_p_designs's Avatar
Idle control valve issues
Ok, so I bought my 01 AE about 2 months ago. I guess I didn't do a long enough test drive because ever since I got it, it dies at idle after about 15 minutes of driving. It has 185k miles. I cleaned the MAF, throttle body and ICV about a month ago and did the idle learn procedure. That didn't help so I ordered a new ICV and just put it in this weekend. The problem is now worse. What should I do?
I just put the ICV in late last night and had to drive it to work today so I have not done the idle learn procedure yet. Anything else I should do?
Thanks!
Old Feb 14, 2011 | 08:28 AM
  #12443
ChiTeMax's Avatar
Hey guys,
Hope you're all doing well. Quick Q! What type of wrench (size, recommended type from experience, etc.) will I need to remove the bolts and install FTSB on a 2003 maxima. It's a Custommaxima Front Strut bar.
Thank you so much.
Or socket(s) for that matter since i'll be using a torque wrench...
Old Feb 14, 2011 | 01:34 PM
  #12444
NmexMAX's Avatar
dot dot dot ...
A good general tool set, very basic, should get you what you need.
Old Feb 14, 2011 | 05:58 PM
  #12445
89se's Avatar
jpdesigns--I've never had that on a max, but I did have that on my girl's jeep. Drove me crazy until I replaced the engine coolant temperature sensor...cheap enough to try. Easy install too. You might have 2 sensors, one for guage & fan, one for ECU...might as well replace both. Probably less than $40, good preventative maintenance if it doesn't help. No guarantee, but worth a shot.
So I think my knocking sound is the fuel damper...there are horrible sounds of "clank clank clank" in the fuel line, which are louder than on top of the cylinders. I can also see a bit of exhaust when I fire it up (in the engine compartment), so I'm thinking I may need headers soon (not pulling 'em for just a gasket) . Any CARB legal headers for calispec?
Old Feb 14, 2011 | 06:05 PM
  #12446
89se's Avatar
fsaenz...sounds like bad O2 sensors or cats..., you may need to find out if your car still actually has working cats, or if the O2 sensors failed. If you had a bad MAF, could they be simply fouled? Have you tried clearing codes and seeing if they return...I think Autozone can do that. Sometimes codes pop during temporary events like smoky bad-MAF engines...otherwise, probably see if a muffler shop can check your cats cheap and replace oxygen sensors if they're fine...
Old Feb 14, 2011 | 06:27 PM
  #12447
broadwayblues35's Avatar
This might seem kinda minor, but I can't get my trunk light to come on. I assume that the trunk switch might have something to do with it, but I can't get the switch itself off of the assembly that it is mounted on. (Trunk latch.) The bulb itself works, and if I can't get a new switch is there a way to bypass the switch? There doesn't seem to be much wire to work with there. Thanks in advance.
Old Feb 14, 2011 | 08:21 PM
  #12448
SuperTurbo's Avatar
Hi
can someone tell me when do your maxima need to change the catalytic converter?
(at what mileage, usually how you drive, which brand of cat did you use, any performance difference, and cost)
thanks
Old Feb 15, 2011 | 06:03 AM
  #12449
Nissan2000Maxima's Avatar
Originally Posted by SuperTurbo
Hi
thanks
Dont go out of your way to change it, rather change it when you get the full life out of it and its busted / gone / rusted - thus, needs changing. I usually get an OEM one.. then again, I dont care much for "performance" on this car.
  #12450
sleepyzzz's Avatar
ok, the wife went out to her 2000 Maxima SE manual tranny with a little over a 100,000 miles on it, and comes back in, saying her car won't go in gear.
i tell her to take my son's Sentra SE R to work cause his butt is still in bed, and i don't have time to mess with her car.
going out to the garage, i raise the hood, and find the oil resivoir bone dry to the clutch master cylinder. going to give my Nissan dealer an ear full when i go up there, since they just serviced the car not a week ago.
putting brake fluid in the resivoir doesn't fix the problem. do i need to adjust or bleed the clutch? and how do i go about that? never done that before.
sorry for the long post, just ranting i guess.
Old Feb 15, 2011 | 06:06 AM
  #12451
Hi guys, I have question, on my moms 2000 Nissan Maxima, the dash e-brake light comes one, the red "!" with " (!) " - Why does this come on? The light came on a few days ago (Sunday/Saturday) and then yesterday (Monday) the entire master brake cylinder was empty. I topped it off about 3/4 and the brake seems good, but the light is still on. Any ideas as to why? The pads still have easy 60% life on them with cross drilled rotors. Whys the light on and how did my fluid drain away all of a sudden?
P.S. I recently changed my ball-joint, and the mechanic had the suspension wayyy right ---> towards the driver door ....? It was pushed over pretty far, It looked like it was going to snap
Old Feb 15, 2011 | 06:08 AM
  #12452
Try to top it up atleast 2/4 and see if that helps any, even a little. Thats the best temporary fix to get the car going, otherwise you'll leave it parked like that? Try to google it or take it back to the Nissan dealer and have them bleed it for free since they did the job and it leaked.
Old Feb 15, 2011 | 06:32 AM
  #12453
sleepyzzz's Avatar
thanks for the reply and yes i tried that, and the pedal does come off the floor about halfway, but still doesn't let the tranny shift into gear.
i may have air in the line, but again, i don't know how to bleed it.
Old Feb 15, 2011 | 06:53 AM
  #12454
Any other opinions? I know many people on here are familiar with the issues I'm having with the ICV.
Old Feb 15, 2011 | 01:17 PM
  #12455
Waxima's Avatar
Didn't think it was necessary to make a thread for this, so...
What are these called and what are the part numbers for them?
First thing, plastic piece that secures with pop tabs on the underside of the front:
Second thing, plastic piece that goes inside the passenger side wheel well:
Old Feb 15, 2011 | 01:26 PM
  #12456
Not sure, but I just pulled these off of my 2000 Max until I can get some zip-tie action going. It looks like you still have it on there, but half of it is pulled back. Or am I seeing it wrong?
I think the zip-ties might work just fine, can't afford much these days.
Old Feb 15, 2011 | 01:30 PM
  #12457
Waxima's Avatar
On the underside piece, yeah, it's still on there but it's shredded pretty good. I ran over a fire hydrant which is what did the damage.
I'm trying to figure it out because I'm ordering all the parts to fix the car including a new bumper and I need these two pieces as well, but I don't know what they are.
Old Feb 15, 2011 | 01:33 PM
  #12458
djfrestyl's Avatar
Suspension Yoda
Just zip tie them back up. You can make new holes. I've done it about 15 times on various Maximas.
Old Feb 15, 2011 | 02:31 PM
  #12459
SuperTurbo's Avatar
yea, I mean when do the OEM usually get busted or gone?
Because I heard one of my mechanic keep saying that the cat will be gone around 180k km, and I am like..... that sounds kind of low......
Old Feb 15, 2011 | 02:45 PM
  #12460
djfrestyl's Avatar
Suspension Yoda
You'll know you have to replace it when your car tells you that it needs replacement, via SES codes.
Old Feb 15, 2011 | 05:27 PM
  #12461
ovaldes's Avatar
2001, Nissan Maxima, GLE, ECM Replacement
I was driving from Atlanta to Jacksonville a couple of weeks ago and my IACV went out on the highway. This happened one week after I had my Mass Air Flow replaced. I kept throwing it into neutral and found my way to a mechanic. The mechanic did not have the IACV in stock and could not get it for another day. However, he adjusted the idle manually so I would be able to get it back to Atlanta. I had the IACV replaced, but the car started reving too much and took off everytime I took my foot off of the brake in drive. My mechanic had me go to a nissan service center, and they informed me that the new IACV shorted the ECM.
I discussed this with my original mechanic and they said they could find me a refurbed ECM and have it installed for $310. However, in speaking with the Nissan dealer they said that it would then have to be towed to the dealership and the ECM would need to be reprogrammed.
To get around this, I am wondering if I can just buy the ECM from my mechanic ($180), drive to the Nissan dealership and install it in their parking lot. If I do this they can reprogram it there. This will save me the towing fee as well as the labor to half way install it at my mechanic.
However, I can't find a DIY on how to install the ECM. Will this work? Is it difficult? Can anyone give me some help? I am thinking of trying to get this done tomorrow if possible. Your help if greatly appreciated!
Old Feb 15, 2011 | 05:36 PM
  #12462
djfrestyl's Avatar
Suspension Yoda
It should work, it's not difficult at all. Maybe 15 minutes with some handtools.
Old Feb 15, 2011 | 06:58 PM
  #12463
ovaldes's Avatar
Is there a step by step or DIY available? I'm not very savy when it comes to cars, but I can follow directions.
Old Feb 15, 2011 | 07:35 PM
  #12464
djfrestyl's Avatar
Suspension Yoda
There probably is but it would involve some searching. The ECU is located between the drivers and passenger side foot wells. There are small panels which pop off to reveal the ECU. Disconnect the battery, disconnect the large harness, and it should be removed with a few 10mm bolts.
Old Feb 15, 2011 | 07:55 PM
  #12465
BoDenKai's Avatar
Is there a way to take off the shifter **** on the 5.5 autos? and replace with a 6 speed ****? I just want it there because of my keepsakes from my first girl. Already have her old SER license plate on my max.
Also is there anywhere to get the new SER badges for cheaper than 20 bucks each?
Old Feb 16, 2011 | 10:36 AM
  #12466
Do you want to know the specific name of that plastic thing in the wheel-well? Or do you know that their called fenders liners ... your questions confuses me.
If you want new fender liners or decent ones, buy them online/locally etc etc and installed them via self-tapping screws.
Same goes for the undercarriage plastic. Call your local dealership and tell them you want the part number / name for the plastic trim that protects your AC condenser and Rad, the plastic trim under them thats held in by push-in pins.
Old Feb 16, 2011 | 10:37 AM
  #12467
Any answer 2 this ?
Old Feb 16, 2011 | 11:43 AM
  #12468
NmexMAX's Avatar
dot dot dot ...
Any answer 2 this ?
Add more fluid.
Old Feb 16, 2011 | 04:24 PM
  #12469
Thanks!
Attempted to do the idle learn procedure just now. I'm not sure it took because it's supposed to idle for 20 seconds after you hook the brown sensor plug back in and it died right around 20 seconds. Also, I can see coolant dripping out of the ICV/hose connection even though the hose is tight. Would this mean anything? I ready to sell this car even though I would love it if it would just run.
Old Feb 16, 2011 | 07:18 PM
  #12470
Ghost_54's Avatar
Have received any codes (SES light on at all)? Have you checked to see if there are any pending codes, your SES light may not be on now but you could still have pending codes stored in the memory you should check this out. Also when you mentioned you cleaned your throttle body, did you in any way touch or move the buttery fly valve inside.
Old Feb 16, 2011 | 08:08 PM
  #12471
No, my light was on, but I checked it and it was an o2 sensor. I cleared it and have probably driven 200 miles since then with no more SES light. Yes, when I cleaned it I moved the valve. Is that bad?
Old Feb 16, 2011 | 08:27 PM
  #12472
Ghost_54's Avatar
From all the threads I have read about cleaning the throttle body every guys has stated "don't move the butterfly with you fingers" as you run the risk of permanently damaging the small servo mechanism which in turns screws the your ideal air flow. I am sure those that have performed throttle body cleaning will jump in now that you have brought light to the fact you may have messed with the butterfly valve ... I don't have an answer for what can be done if you did damage the servo mechanism.
Old Feb 17, 2011 | 07:33 AM
  #12473
Can someone confirm this? I didn't think the butterfly valve was in use for the car to idle, I thought the ICV acted as a bypass for it.
Old Feb 17, 2011 | 07:35 AM
  #12474
djfrestyl's Avatar
Suspension Yoda
The need to be careful is really only for the 02+ TB's, as they are drive by wire. The 00-01's are drive by cable, which you don't have to be as careful on.
Old Feb 17, 2011 | 09:37 AM
  #12475
vinco's Avatar
You'll have to find the slave cylinder to bleed it. It's at the top front of the transmission, right where the engine and bellhousing meet. You can bleed it by yourself, but it takes a lot of trips back and forth from under the hood to inside the car.
To actually fix the problem, go ahead and order up a braided stainless replacement line from ImportRP - a sponsor here on this site, and order a new slave cylinder from Advance Auto Parts or Oreilly - stay away from AutoZone unless you can get Beck-Arnley parts from them. You just need the short line from ImportRP, not the full replacement long line.
There's a few threads on this topic, if you'll do a search.
Old Feb 17, 2011 | 10:29 AM
  #12476
polg20's Avatar
ok first post.
im looking to buy a i35 or 02-03 max if i can find a clean 6 speed, currently drive a p11(g20) and had a b14(sentra) before that. Nissan FTW
ive been reading on here for a while now, and just want to ask couple things.
Is looking at those cars with 100k+ a bad idea?i know the motor is good if maint. is up to date but how about other stuff? mostly scared of the 4speed auto.
i know of the oil issue on 02-03 and read that somemotors were replaced under warranty, the the recall fix the issue on all cars or just a fresh motor that still burns oil?
i like the i35 looks better but the only drawback is the auto trans. Is that a reliable transmission? anyone added extra coolers to help keep the oil temps down?
looking forward to join this community.
Thanks for answers
Old Feb 17, 2011 | 12:02 PM
  #12477
01max5spd's Avatar
will a 2000 nissan maxima throttle body fit/work properly on my 2001 nissan maxima? both 5speed. thanks.
Old Feb 17, 2011 | 12:20 PM
  #12478
djfrestyl's Avatar
Suspension Yoda
Yes, it will
Old Feb 17, 2011 | 12:38 PM
  #12479
homeyclaus's Avatar
Originally Posted by polg20
ok first post.
Thanks for answers
I am much more weary of low mileage cars than higher mileage ones. Most of the engine wear happens on cold starts, and the less a car does that the longer the engine will typically last. If maintenance has been done on time and documented, it's fine.
At high mileage, there are issues with transmission wear for any car, but the 4 speed in the 5 gen and I35 is said to be as good as it gets in the durability department. The problem is that many people obviously abuse them.
As far as the oil burning goes, it's hit and miss. Some do, many don't. I am not sure what Nissan's policy is to them now, but the safest assumption is that you're on your own.
Old Feb 17, 2011 | 03:38 PM
  #12480
Originally Posted by NmexMAX
Add more fluid.
Do I gotta bleed my system? And what would have caused the red ! light to come on and lose all the fluid in the first place?
