5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old 02-23-2007, 12:25 PM
  #1281
is invisible
CoolMax's Avatar
Originally Posted by lake3031
Again, asking for your expert assistance...I'm planning on getting the TEIN H-tech springs, with the tokico illumina struts/shocks. If anyone disagreeing with that set-up, give me some insight on why??? Lastly, what are some other upgrades that are cost effective and well worth while??? Thanks Again
There's plenty of suspension info in the Stickies, start there for your research.
http://forums.maxima.org/showthread.php?t=449807
Here's one good link for a start:
http://www.innerbean.com/housecor/sp..._decision.html
CoolMax is offline
Old 02-23-2007, 01:28 PM
  #1282
lake3031's Avatar
Suspension, or other upgrades recommended????
I did read the sticky's, and thats how I determined that set-up. Should drop it nice with my 18" wheels. I'm hoping it will clear that huge gap between the wheel and the fender. Lastly, what are some other upgrades that are cost effective and well worth while??? Thanks
lake3031 is offline
Old 02-23-2007, 03:55 PM
  #1283
eastnwest88's Avatar
Chattering Noise on cold starting
I have a 2002 SE auto with 80400km which I bought in April 2006.
When starting from cold I get a chattering noise for 2-3 seconds, the motor runs fine and sounds fine .
I did do a search and found some replies on the same problem but nothing telling me what the cause is or how it can be corrected. I have the extended warranty and would like to get it fixed while still under Nissan's warranty if it is a problem.
Thanks for any help
eastnwest88 is offline
Old 02-23-2007, 04:12 PM
  #1284
is invisible
CoolMax's Avatar
Thanks for any help
Most likely the VTC (Valve Timing Control) sprocket; there is a TSB: http://maxima.theowensfamily.com/tsb/NTB03-060.pdf
CoolMax is offline
Old 02-23-2007, 08:19 PM
  #1285
Puppetmaster's Avatar
H-techs will look good with 18s, will ride decently for the drop they give, and you should experience a decent handling upgrade compared to stock. The last two are assuming correctly matching dampers of course. They're basically a good compromise. If you're really into advanced handling however, you'll probably be disappointed.
http://forums.maxima.org/showthread....ghlight=h-tech
There are positive discussions on H-techs out there, but they're mostly gonna say what I said up top.
Puppetmaster is offline
Old 02-24-2007, 08:49 AM
  #1286
UKmaxima's Avatar
Originally Posted by CCS2k1Max
Besides what puppemaster says, what tires are you running? Cheapo tires with mushy sidewalls will do that. Before spending tons of dough on suspension upgrades, make sure it's not something as simple as granny tires.
Running brand new Michelin Pilot Sports on the stock 17's.
UKmaxima is offline
Old 02-24-2007, 08:51 AM
  #1287
UKmaxima's Avatar
My car was manufactured 10/01. Do I have an 01 or 02? It was sold as an 02 model and I believe a manufacture date of 10/01 would probably be an 02 model year.
UKmaxima is offline
Old 02-24-2007, 08:54 AM
  #1288
Cletus
SoonerFan's Avatar
there are ways to figure out what year it is besides the build date.
main thing...engine!!! 3.0 vs 3.5
SoonerFan is offline
Old 02-24-2007, 09:05 AM
  #1289
UKmaxima's Avatar
Its a 3.5
UKmaxima is offline
Old 02-24-2007, 09:07 AM
  #1290
Pointy Elbows
00MaxSE's Avatar
Wow, that is the definitive post.
00MaxSE is offline
Old 02-24-2007, 09:09 AM
  #1291
Cletus
SoonerFan's Avatar
Its a 3.5
then....its an 02.
i still dont understand the point of that "question". you really answered it yourself when you said it was built as an 02 model
Old 02-24-2007, 09:28 AM
  #1292
ricodemus's Avatar
I hope this isn't too late. The P0420/430 codes were, for the most part, caused by too narrow acceptance criteria in the programming. There's a TSB (I don't recall the number) for reflashing the ECU. I'd ask the tech if the reflash you're getting done will cover this too and if not, see if you can slip him $20 and get it done while you're there. It might take changing a lazy O2 sensor or two.
Man I don't know if it will cover all that or not. Unfortunately I didn't see this post in time and the car is already in there, probably be picking it up soon.
ricodemus is offline
Old 02-24-2007, 09:41 AM
  #1293
UKmaxima's Avatar
Well guys, coming from England, the date of manufacture is the year of the car, not the model year or the year in which it was sold. So they were legit questions for me.
This is the second used car we've bought since I've been in the US, the first had a manufacture date the same as the year on the title. All our other cars where new and manufactured in the same year they were purchased.
UKmaxima is offline
Old 02-24-2007, 09:43 AM
  #1294
Cletus
SoonerFan's Avatar
yeah, here in the US, the car can be made the year before the model year. you can also buy them the year before. the 02 model went on sale in the fall of 01.
Old 02-25-2007, 06:59 AM
  #1295
ricodemus's Avatar
Well, I called the dealer after I read this and there wasn't anything "extra" they could do. The guy was real cool and I told him I planned on fixing the P0430 myself after I try and spend a little more time diagnosing the problem. He continued with the reflash and originally told me that it only influences the MAF. When it was done, he called me and said the code went away and I have "the latest updtaes on for the computer". He may have just been speaking down to me, but the car is running stronger than it has in the last 2 years and we'll see if the SES light comes back on. Thanks for the help.
Rick
Old 02-25-2007, 07:15 PM
  #1296
Patrick.R's Avatar
I tried to use search and it wont let me so hear i go
My tranny is going into neutral (i think) when im at a stand still about to start accelerating I thinks its going into neutral because when im about to stop i feel the tranny lightly kicking into neutral then when I rev it back up it takes about till 2000 rpm for it to kick back into drive(which i feel alot more)
Its not slipping in any way in higher rpm's.
I just changed my motor mounts the other week. I'm not sure what the sensors control that are on those mounts.
I've read that it can be cpu ? I cant remember or find the post i saw it in.
I just hope I dont need a new tranny,Its been perfectly fine till yesterday.
Patrick.R is offline
Old 02-26-2007, 06:24 AM
  #1297
Patrick.R's Avatar
Well I woke up this morning and theres tranny fluid on the ground where my car was parked.
The car only made it 5ft before the snow was too much.
You can feel the tranny shift and then unshift out of drive and revearse
Does anyone have an opinion? before i waste money on a tow and send it to the shop.
Am I in denial about having to replace the tranny?
The tranny was running pefectly fine for the 2 years I've had the car showed no signs of trouble.
Old 02-26-2007, 08:44 AM
  #1298
jocoo's Avatar
Brake Caliper
Does anyone know if and where I can buy pre-painted brake calipers? Or do I have to paint them myself?
jocoo is offline
Old 02-26-2007, 08:56 AM
  #1299
LA02MAX's Avatar
Many of nissan's new calipers come painted silver from the factory, but you would have to do the entire 6th gen brake swap to get them. I would just paint them myself. Google the G2 caliper paint kit.
LA02MAX is offline
  #1300
retired moderator
irish44j's Avatar
it is really easy to paint them yourself, even if they're on the car. Buy some G2 brake paint and go at it.
irish44j is offline
Old 02-26-2007, 09:05 AM
  #1301
Patrick.R's Avatar
Anyone? Is my tranny toast?
like i said it was running perfectly fine then this.
Old 02-26-2007, 09:27 AM
  #1302
KhanMan13AK's Avatar
Damn You Guys!!!
Well.. I bought this car last week (03 GLE) swearing that I would keep it stock but after lookin at all 30+ pages of the members rides I just can't do it....
My first round of mods I want, I have been unable to find or links on the board are outdated.
1 - Angel eyes
Where is the best place to buy em? Lookin for best quality that will last and are bright as shiet...
2 - Clear front side markers
I called auto dynamics lookin for these and they said they were discontinued.... Anyone know where I can find a set?
3 - Clear lens for headlight
I dont want to do the dremel approach... anyone know were I can buy a set?
4 - 01 Se tailights
Autodynamic has em for like 70 each. Is there a better place to buy them? Where do I find the harness?
I am going for this look for the lights:
Thanks in advance guys and I will get pics posted once the mods get rollin...
KhanMan13AK is offline
Old 02-26-2007, 09:29 AM
  #1303
Pointy Elbows
00MaxSE's Avatar
^^ Hey that's my car!
00MaxSE is offline
Old 02-26-2007, 09:40 AM
  #1304
huffdaddy2008's Avatar
i painted my calipers w/ VHT high temp. caliper paint about 8 months ago but its already startin to fade. Are the G2 kits any better than VHT or is it all pretty much the same?
huffdaddy2008 is offline
Old 02-26-2007, 09:41 AM
  #1305
LOL... in that case... nice lights homey
Where did you get the angel eyes and lenses?
Old 02-26-2007, 09:43 AM
  #1306
Pointy Elbows
00MaxSE's Avatar
Thanks I got the angel eyes from Umnitza.com and the lenses from Home Depot.
00MaxSE is offline
Old 02-26-2007, 09:56 AM
  #1307
Thanks man... U have any problems with the Angel eyes? Do they look OEM when they are off?
Old 02-26-2007, 11:55 AM
  #1308
Patrick.R's Avatar
So since nobody can answer my questions how about this
Will just a regular performance shop be able to diagnose the proablem?
Or is it something I have to take to the stealership?
I'd like to tow it this afternoon so any advise would be great.
thnks.
Old 02-26-2007, 02:39 PM
  #1309
retired moderator
irish44j's Avatar
thnks.
if you're having a transmission problem, I most definitely would not go to a "performance shop." I would take it to a dealer or to a transmission shop where the people might actually be able to diagnose your problem
irish44j is offline
Old 02-26-2007, 03:35 PM
  #1310
Tee00Max's Avatar
i have a 2000 and i was wondering what was the best way to get the HID look without buyin them. I have the silverstars now and there is a lil difference....was the ultra's any diff???
Tee00Max is offline
Old 02-26-2007, 04:52 PM
  #1311
UKmaxima's Avatar
Patrick.R
Your problem sounds like a bad transmission leak. I've seen cars that act exactly as you describe due to low fluid level.
UKmaxima is offline
Old 02-26-2007, 05:38 PM
  #1312
retired moderator
irish44j's Avatar
the silverstars are about as good as you can do without getting real HIDs. Those other "ultra white", "hyper white" and bluish bulbs are junk...
irish44j is offline
Old 02-26-2007, 08:28 PM
  #1313
Cletus
SoonerFan's Avatar
i second the silverstar. had them on my 00.
Old 02-26-2007, 08:36 PM
  #1314
PandaXpress's Avatar
I used you in a thread to point out "The Law's" hypocrisy again...I hope thats okay..
Link to where i mention you (click here)
just thought i should let you know...
PandaXpress is offline
Old 02-26-2007, 09:23 PM
  #1315
Cletus
SoonerFan's Avatar
well me and him get along and agree on everything so.....
im gonna side with him again. the person that he flamed in that thread deserved to be flamed. you have a grudge...dont include me when you try to make an example of him.
Old 02-26-2007, 09:27 PM
  #1316
Lol...im not dissing him, im just messing with him. Lawrence and I are cool, i just like to give him a bit of his own medicine. I dont mean for him or anyone else to take it the wrong way, Its just a joke.
Old 02-27-2007, 03:00 PM
  #1317
GigEmAgs07's Avatar
two questions about my engine. First off, is this connector supposed to be connected to anything? It is right behind the drivers' side headlight.
Secondly, is this gap supposed to be here? I doubt it is, but who knows. Is it a huge deal?
tia.
GigEmAgs07 is offline
Old 02-27-2007, 05:49 PM
  #1318
Ephraim's Avatar
tia.
well im not sure what that plugs into, where does the wire lead too? get a pic of where the wire leads too.
also with that gap, it is a gap between the scoop and the intake box that has the air filter. that gap being there should not cause any problem because air still goes through your filter before going into your engine.
Ephraim is offline
Old 02-27-2007, 05:54 PM
  #1319
Cletus
SoonerFan's Avatar
the intake gap...there is a collar there that needs to be slide over the gap.
Old 02-28-2007, 11:51 AM
  #1320
GigEmAgs07's Avatar
good eye, sooner.
as for the other connector, it stems out just above the front left corner of the battery/the fusebox in the pic. The wire bundle it stems from... one way leads to the fusebox to the right of the battery, and the other way leads across the grill. I looked for connectors in the vicinity, but there are none that i saw at a quick glance. here's another pic.
thanks. and yes, i'll be cleaning my engine up tomorrow.
Quick Reply: 5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
