5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Apr 8, 2012 | 04:03 PM
  #15321
piggylover1985's Avatar
Originally Posted by dared3vil0
well i'm... Semi-new here. I'll get to the point. Should a 2000 Maxima SE 4at Slushbox really top out at 125MPH? I had it mashed into the floor, revs were no where near redline, if anything it was a slight downhill, and it was at 125MPH for a good 8 or 9 seconds. Just wouldn't go ANY further. I think somethings wrong.
I think yours electronically limited to 130mph. I hit 150mph in my 03 6sp once
Old Apr 8, 2012 | 04:34 PM
  #15322
dared3vil0's Avatar
It's actually electronically limited :O Well, looks like i have some work to do. How would one go about un-electronically limiting their max?
Old Apr 8, 2012 | 04:40 PM
  #15323
If you have alot of mods and wants to go faster than factory limited, you can get a standalone system.
Old Apr 8, 2012 | 06:46 PM
  #15324
djfrestyl's Avatar
Suspension Yoda
Please make sure your excessive speeds are limited to a controlled environment (ie a track) and NOT public roads, ever.
Old Apr 8, 2012 | 07:24 PM
  #15325
imported_Nismo_max's Avatar
What would you guys recommend for a daily drive clutch kit? oem? autozone/advanceautoparts? aftermartket? and also any cheap place where i can get it from? TIA
Old Apr 8, 2012 | 08:41 PM
  #15326
dared3vil0's Avatar
Standing mile. Legal of course.
Old Apr 9, 2012 | 11:12 AM
  #15327
kornfed's Avatar
I have n 02 and the motor is very strong and turns on with no problems every time but recently it randomly just turns off. Driving or sitting at a light. It was throwing a code saying camshaft sensor short. Has anyone experienced the she problem and how much trouble is it to fix??? Any help would be appreciated it. This my daily driver and I wanna drive it knowing its gonna get me were I need to go
Old Apr 9, 2012 | 11:17 AM
  #15328
djfrestyl's Avatar
Suspension Yoda
Camshaft/crankshaft position sensor. Very common. I think they're $80 each for the part, or thereabouts. Fairly simple job, can be done yourself.
Post the P0xxx code just for us to be sure.
Old Apr 9, 2012 | 11:23 AM
  #15329
kornfed's Avatar
Thanks. Now there's two different ones. Does one go out more than the other???
Old Apr 9, 2012 | 11:57 AM
  #15330
djfrestyl's Avatar
Suspension Yoda
The code should tell you which is faulty. IIRC it's the same replacement part, just used twice and in different locations. Might just be better to replace both at the same time.
Old Apr 10, 2012 | 12:09 PM
  #15331
NTMastro's Avatar
Quick question...
I found this great how to on tinting the tail lights (without tinting the actual part that produces light) http://www.kevinfisher.net/web_serve...light-mod.html
O just have one question about it if anyone has done it. After tinting the light, do you clearcoat just the tinted part or the whole thing?
It seems like he might have only clearcoated the part he painted, but I would think it would leave an edge that you would be able to see and feel with regards to the paint coming off the edge.
Basically I was wondering if anyone had done this mod and if they had, were there, or would there be any repercussions of clearcoating the entire light instead of just the tinted area?
Old Apr 10, 2012 | 12:35 PM
  #15332
djfrestyl's Avatar
Suspension Yoda
Doubt there'd be any issue with clearcoating the whole thing.
But also, I wouldn't worry about the 'edge' of the spray. Unless you're putting down multiple layers that add up to many mils thick, you're fine.
Old Apr 12, 2012 | 06:54 AM
  #15333
LowerD's Avatar
I have a 2002 Maxima SE 6 speed and i wanted to know if theres any wat that i would go about shifting between gears that would get me better gas milage because iv been told that if u use higher gears and less rpm's then i will get better gas milage. . .anyone that can help me with this ?
Old Apr 12, 2012 | 07:08 AM
  #15334
djfrestyl's Avatar
Suspension Yoda
You have a 6 speed. You control the gears.
The advice is correct. Shift at lower RPM's and be in the highest possible gear you can be in that's appropriate for your speed.
Seems you answered your own question....
Old Apr 12, 2012 | 11:52 AM
  #15335
TheDude00's Avatar
Newbie Questions...
Alright so here my really newbie questions:
I have a 2000 Max. The original owner replaced the front bumper with one from a 2002 Max. So now I have to buy 02-03 Hid headlights to replace the $h!t Chinese ones on the car.
The Question I have is; How hard is it to install the 02-03 HID headlights into a 2000. I am referring to the electrical side of this not fitment side.
Second Question; What is the most recommended cat back exhaust that will help improve MPG, but not an obnoxious drone while driving
Thanks for the info
Old Apr 12, 2012 | 12:13 PM
  #15336
00MaxMayne's Avatar
I've been having problems with my car for a while now and I changed the fuel pump and filter, along with all my spark plugs and one ignition coil because of a missfire. Anyways, when I was changing my fuel pump I was planning on changing the strainer because it looks like this... But the new Airtek strainer I got didn't seem to fit in, because the strainer thats on there now has a longer connecting piece than the new strainers. The arrow is pointing at the plastic piece that goes from the strainer to the pump.
I think the only way to make the new strainer fit on would be if I remove the rubber ring from underneath the clip that holds everything together. Idk if this would be a bad move or not but I feel like the cause of the problem may be this nasty strainer not allowing enough fuel to get to my engine or something of the sort. So I'm looking to take care of it.
I also didn't see any strainers that were circular like the one that's on there now, they seem to only come in rectangular shapes. Although I'm sure that doesn't matter.
Old Apr 12, 2012 | 12:32 PM
  #15337
djfrestyl's Avatar
Suspension Yoda
Thanks for the info
You can get a conversion kit which has the harnesses needed. It *might* come with instructions, I don't quite recall. But if it doesn't, the instructions are available with a quick search.
If you understand +12v circuitry and can splice/tap, it's fairly straightforward.
I don't have an answer about exhaust, I'll let someone else answer that.
But you DO have a PM in your inbox from me from a few days ago that's waiting for a response
Old Apr 12, 2012 | 01:26 PM
  #15338
reno_famous's Avatar
I have an 03 Max and i was just wondering if anyone had experience or any info on Megan Racing Lowering Coil Springs. And also is it a simple swap out or am i going to have to do other things? Thanks in advance
Old Apr 12, 2012 | 01:38 PM
  #15339
djfrestyl's Avatar
Suspension Yoda
You have to remove the entire strut assembly, compress OEM springs, disassemble the strut assembly, compress new springs, reassemble the assembly, and reinstall the strut assembly.
And when lowering it's recommended to replace all 4 struts, front strut mounts/bearings, and all 4 dustboots.
Old Apr 12, 2012 | 02:21 PM
  #15340
Dexterity's Avatar
Im new here on this forum.
I own a 2003 Nissan Maxima se (gray color)
Its automatic transmission.
I am wondering if I should get a short ram intake.
Old Apr 12, 2012 | 04:20 PM
  #15341
DennisMik's Avatar
Thanks for the info
Wire harness conversion for 5.5 headlights into a 5.0. Give your thanks to TunerMaxima3000.
http://forums.maxima.org/5th-generat...guide-diy.html
Old Apr 13, 2012 | 09:41 AM
  #15342
grandvvazoo's Avatar
2002 GLE AC blower
Hey everyone... got a little problem I was hoping for some help with...
About a year ago my blower stopped working suddenly... about a month ago, it randomly started working again. Then a few days later started cutting in and out and now is no longer working.
I don't think it's the motor itself, bc why would it suddenly work and then not work? I don't think it's the fan control amp for the same reason.
I removed the glove box and unplugged the harness connected here: https://i.imgur.com/KxM9M.jpg
I noticed black soot on the connectors. What is this and how do I go about replacing it?
Thanks in advance for any/all suggestions.
Scott
Old Apr 13, 2012 | 09:51 AM
  #15343
djfrestyl's Avatar
Suspension Yoda
Blower motor resistor. Common issue, quick and easy fix.
Old Apr 18, 2012 | 07:03 AM
  #15344
Arsen's Avatar
Hey guys, needs help.
I have a knocking noise coming from front left. Does this sound like a ball joint to you? if not, what do you think it is? http://www.youtube.com/watch?v=Ma9CnfR69Rs
by the way, the knock is louder then what it is on the video.
Old Apr 18, 2012 | 07:11 AM
  #15345
djfrestyl's Avatar
Suspension Yoda
^^ video is private, unable to watch it.
Old Apr 18, 2012 | 07:18 AM
  #15346
Arsen's Avatar
Sorry, the video should be public now.
Old Apr 18, 2012 | 07:44 AM
  #15347
djfrestyl's Avatar
Suspension Yoda
Nope, still private.
Old Apr 18, 2012 | 08:02 AM
  #15348
Arsen's Avatar
try now
Old Apr 18, 2012 | 09:01 AM
  #15349
djfrestyl's Avatar
Suspension Yoda
Nope, even after logging in with my Google account. Still private.
Old Apr 18, 2012 | 09:07 AM
  #15350
Arsen's Avatar
Its defenatly not private now! i forgot to hit the save button ))http://www.youtube.com/watch?v=Ma9CnfR69Rs
Old Apr 18, 2012 | 09:14 AM
  #15351
djfrestyl's Avatar
Suspension Yoda
Sounds like a sway bar end link to me.
Before you spent the time to create a video and fuss with YouTube, did you try to get under the car and feel around? Put it on ramps and have a friend/family member push down on the driver's side fender and look around. The noise should be very visible.
I'm local. Let me know if you need any work done.
Old Apr 18, 2012 | 09:22 AM
  #15352
DennisMik's Avatar
One time I heard a rear wheel drive car that had broken a tooth off of the ring gear in the differential. It was kind of similiar. Jack the front wheels up and turn them by hand and see if you can hear/feel anything.
Old Apr 18, 2012 | 09:23 AM
  #15353
Arsen's Avatar
Yea i did try that, sway bar links are fine. The wheel moves slightly (whobled when i tryed moving it back and forth)
Old Apr 18, 2012 | 10:12 AM
  #15354
djfrestyl's Avatar
Suspension Yoda
In what position did you hold the wheel? 3 and 9? 6 and 12?
Old Apr 19, 2012 | 07:23 AM
  #15355
queenambeach's Avatar
Would 02-03 Maxima light be a direct fit for a 2001 Maxima?? The wiring for the HIDs I can do myself, just need to know if its a direct swap or will modifications have to be done?
Old Apr 19, 2012 | 07:32 AM
  #15356
djfrestyl's Avatar
Suspension Yoda
Fitment and mounting is perfect, you'll have no issue.
Old Apr 19, 2012 | 11:33 AM
  #15357
unrealii's Avatar
It will fit, but you will have to do some wiring. You will also need to buy headlight clips from the dealer $5-6 ea x 2 for the headlights to mount in your car.
I am selling my kit. Wiring is all done, its plug and play
http://forums.maxima.org/5th-generat...t-5th-gen.html
Old Apr 20, 2012 | 03:44 PM
  #15358
laststop's Avatar
Has anyone tried non-nissan electronic motor mounts like those on rockauto?
Old Apr 20, 2012 | 03:59 PM
  #15359
Yes they work fine, i replaced the electronic mounts with non-electronic mount and don't feel any difference.
Old Apr 20, 2012 | 04:07 PM
  #15360
pmohr's Avatar
No more Maximas...
He didn't ask about replacing electric with regular mounts.
That being said, that's the route I'd go, not bothering with getting electric mounts at all.
