5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old May 3, 2012 | 12:02 AM
  #15401
Gil's03Max's Avatar
Originally Posted by pmohr
http://courtesyparts.com/
Or call Dave B. Search for his contact information.
thanks i didn't find the clips for the lower engine cover, the site is missing a few specific parts but it does have 95% of what I'm looking for.
Old May 3, 2012 | 09:43 AM
  #15402
tseng1023's Avatar
I am installing Alpine- type S components in the front of my 5.5... It comes with an inline crossover. What I need to do is connect one end of the crossover to the tweeter and one end to the woofer. I'm sure you guys know where the tweeter mount is and where the woofer hole is. I was wondering where I could run the wire through from the tweeter mount to the woofer mount. I was thinking the door but I'm not exactly sure..
Old May 3, 2012 | 10:03 AM
  #15403
djfrestyl's Avatar
Suspension Yoda
Originally Posted by Gil's03Max
Just bought an 03 Maxima SE and i really need some help with this car it is my first nissan. Ive owned hondas and acuras and they have websites like hondaautomotiveparts.com that sells every single clip and bolt on your car basically at a discounted price (no need to go to your local dealer). I don't even care if the price is discounted but I'm looking for a nissan website that i can buy these parts for example my lower engine cover is hanging and i want to buy the clips for it, do you guys know of a website like this? I live in NJ but obviously if its an online parts site then it doesn't have to be local. Thanks and i will ask many questions some dumb so have some patience with me guys.
www.nissanpartsasap.com has nice blow up part diagrams.
Old May 3, 2012 | 10:04 AM
  #15404
djfrestyl's Avatar
Suspension Yoda
I should do this install too...
Put the crossover in the kickpanel. Run the tweeter line straight up. Then run the woofer line into the door. You'll have to drill if you don't want to tap.
Old May 3, 2012 | 10:20 AM
  #15405
tseng1023's Avatar
I think I got this .
Without drilling I tap the crossover line into tweeter line, correct? Where would I run it through?
Old May 3, 2012 | 10:30 AM
  #15406
djfrestyl's Avatar
Suspension Yoda
For the source of the xover, you need a full range signal, so you can't tap the tweeter line. The wires should be in the pack running from front to back, under the carpet. Speaker wires are a twisted pair. When you pull off the kickpanel you'll see a square block of foam. Pull that out and drill through the car. Then slit the rubber wire loom and feed your wire into that, which then goes into the door for your woofer. In the 5th gen there is no way to run new wire into the door without drilling.
Personally if you're running components I wouldn't tap. I run fresh wire into each door directly from the amp. If your comps are amped then I DEFINITELY would use fresh wire.
Old May 3, 2012 | 11:33 AM
  #15407
tseng1023's Avatar
There is already wire from my 4 channel. Last set of components blew out and I'm just replacing. Everything is hooked up and working except for the crossover which I'm stumped on.
Old May 3, 2012 | 11:34 AM
  #15408
djfrestyl's Avatar
Suspension Yoda
Then it should be straight forward - just mimic what was previously done.
Old May 4, 2012 | 03:40 PM
  #15409
Gil's03Max's Avatar
So i finally got my maxima on the road but i noticed something i did not like today, whenever i accelerate the engine makes a rattle sound mostly when I'm going uphill. This has happened to me in many cars I've had and it really bothers me and I've never had an idea of what causes it or what could be wrong. The car is an 03 SE with 155k and it has no CEL and idle is perfect but it never fails every time i hit the gas after a few seconds i hear rattling under the hood and i can tell its not suspension related because it happens over any road surface. Does anybody know what could be my problem? This is scaring me a bit considering i JUST bought the car last week.
Old May 4, 2012 | 04:34 PM
  #15410
piggylover1985's Avatar
Could be rusted exhaust heat shield rattling.
Old May 4, 2012 | 04:36 PM
  #15411
Gil's03Max's Avatar
My heat shield is very rusted yes but then it would rattle all the time when the car is moving not specifically when i hit the gas.
Old May 4, 2012 | 04:40 PM
  #15412
My heat shield is very rusted yes but then i would rattle all the time when the car is moving not specifically when i hit the gas.
When you give it gas, the engine move a little bit more because of "torque" causing it to rattle more. It might make same rattle if you are to "power braking" it.
Old May 4, 2012 | 05:03 PM
  #15413
Gil's03Max's Avatar
ahhh i see, you might have something there. Im gonna lift it up at my mechanic and see if i can rattle the shield on my own while the car is cold see if thats it i hope its nothing engine related.
Old May 4, 2012 | 05:55 PM
  #15414
DjHackStyle's Avatar
dude dont go crazy!! i just bought my car in february, a 2003 maxima and i had the same problem, i used 87 gas and it rattles at 2000 RPMS, this is called engine pinging, look it up !, i used 93 and i ran about 5 tanks of it and no more noise!! i must have used some really cheap gas!
Old May 4, 2012 | 06:11 PM
  #15415
Gil's03Max's Avatar
YES!! Thats the exact noise i hear its a loud pinging from the engine, I knew it had something to do with the engine itself thanks a lot bro i will fill up with 93 a few times to see if that fixes things. wheeewww lol
Old May 6, 2012 | 06:59 PM
  #15416
tseng1023's Avatar
Aren't our cars suppose to use premium gas??
Anyway, is there a 'safe' way to remove the clips along the lining of the trunk lid? I'm planning to lay on some deadener on, but I've broken so many of these tabs in the past I want to make sure I don't screw any of these up.
Old May 7, 2012 | 06:34 AM
  #15417
djfrestyl's Avatar
Suspension Yoda
Do they have a philips screw head or are they the pop-clip type?
Old May 7, 2012 | 07:06 AM
  #15418
tseng1023's Avatar
pop-clip
Old May 7, 2012 | 07:30 AM
  #15419
djfrestyl's Avatar
Suspension Yoda
Are they two piece or one piece?
Old May 7, 2012 | 08:47 AM
  #15420
djfrestyl's Avatar
Suspension Yoda
Post a pic. What you're saying doesn't make sense.
Old May 7, 2012 | 10:13 AM
  #15421
djfrestyl's Avatar
Suspension Yoda
Your link doesn't take into account that some people might not be using Safari.
Also, I said post a pic, not a search query.
Old May 7, 2012 | 10:51 AM
  #15422
tseng1023's Avatar
Old May 7, 2012 | 11:29 AM
  #15423
djfrestyl's Avatar
Suspension Yoda
I had a feeling those were it, those are the standard clips that hold the trunk lining in.
They are two piece. It's a screw/pop combination.
Use a small flathead and a regular philips head. Using the flathead, hold the side of the clip - the round part, prevent it from spinning. Using the philips head, unscrew the top. You'll see a gap appear. Then use the flathead to increase the gap, continue to unscrew the top until it raises a bit more and won't raise anymore. Then remove it like a pop-clip.
Use finesse, not force.
Old May 7, 2012 | 03:05 PM
  #15424
DennisMik's Avatar
Tseng1023 - those clips require a 1/4 turn to unlock them, and make the center stem (the part you turned) to pop up. Then you pull the entire clip out of the hole. Sometimes the center stem doesn't pop up by itself and you will have to pull up on the stem before you can pull the clip out of the hole.
Old May 7, 2012 | 04:03 PM
  #15425
tseng1023's Avatar
Got it, thanks guys
Old May 11, 2012 | 01:52 AM
  #15426
Gil's03Max's Avatar
great thread, many simple questions answered.
Old May 11, 2012 | 03:36 PM
  #15427
Gil's03Max's Avatar
My car makes a really bad clunking sound coming from the front suspension when i go over pot wholes, from my experience it sounds like the sway bar is moving but i heard the strut mounts are also a common issue with our cars. I recently ordered the front sway bar links and bushings from the dealer hoping that fixes my problem do you guys have any idea of what this clunking sound could be? (03 3.5L)
Old May 12, 2012 | 11:09 AM
  #15428
Gil's03Max's Avatar
anybody?
Old May 12, 2012 | 03:04 PM
  #15429
DennisMik's Avatar
It could also be a motor mount.
Old May 12, 2012 | 09:48 PM
  #15430
rimi's Avatar
Tire size question
Hello guys, quick question:
I found some really nice 225/60R16 tires for free. Can I use them on my maxima 2001 GXE (I really need a tire change) ?
I tried the tire calculator and it's about 1.5 inch more diameter, and 5% difference fro stock.
I can put up with the wrong speedometer, but are there any other things I should consider, like turning and handling of the car? Any safety issues?
btw, I'm currently running on 215/60R16 which are bigger than stock anyway...
Old May 13, 2012 | 03:19 PM
  #15431
djfrestyl's Avatar
Suspension Yoda
Shoulda gone Moog/Energy Suspension.
Old May 13, 2012 | 03:20 PM
  #15432
djfrestyl's Avatar
Suspension Yoda
Old May 14, 2012 | 12:09 PM
  #15433
rimi's Avatar
Anyone?
Old May 14, 2012 | 03:14 PM
  #15434
NmexMAX's Avatar
dot dot dot ...
Anyone?
They're about 0.77" taller than the stock SE 225-50-17's.
They will be fine. If you're lowered, they might rub slightly, taller gearing and softer (thicker sidewall) are the only items I can think of.
Old May 15, 2012 | 12:08 AM
  #15435
rimi's Avatar
I noticed that my "service engine soon" light IS NOT COMING ON!
I am doing like it says in the owner's manual, and I see all the different lights/symbols except for the service engine light....
I don't know what to do. I should see it when the key car is in the ON position, correct? What if it is supposed to be ON for some reason...
PS Thanks NmexMAX for the reply.
Old May 15, 2012 | 07:18 AM
  #15436
homeyclaus's Avatar
If the car starts and runs fine, the simplest answer is that the bulb is burned out.
There are a bunch of picture series on the org on how to do this.
Old May 15, 2012 | 01:06 PM
  #15437
rimi's Avatar
I ran a search ("remove cluster" on 5th gen forum) and found different threads that I read... I just want to confirm some things before I unscrew something.
1) The 2 famous screws to remove first are at the top of the gauges, on the underside of the top trim of the cluster, correct?
2) After removing the 2 screws, I have to take out the plastic trim around the cluster, correct? But there are switches on that plastic trim, light the dimmer and TCS...
Only then I can see the other 3 screws, right? (not before?)
3) How to I know where the SES light is located, are there indications on the back, green circuit board?
4) I also read BT 28-31 and they talk about airbags. Is one of the connectors I remove from the cluster airbags, or do I have to do any separate procedures for that?
5) I understand from different threads that the bulb is a T6.5, and it's hard to find that bulb. Can I just take out the handbrake bulb and put it in the SES for now?
Thanks. Sorry if these are newb questions but I'm worried about this since I learned that a new cluster is 700$. Don't wan to mess up something, but can't spend money on a new one either.
Old May 16, 2012 | 04:42 AM
  #15438
VQP0WER's Avatar
That's not exactly true. If he has a failing O2 or cat, he will not likely feel a difference in the vehicle.
Old May 16, 2012 | 10:56 AM
  #15439
rimi's Avatar
Ok I did some more digging last night after work and found this excellent tut with pics:
http://gtamaxima.darkbb.com/t295-chr...ritten-by-will
But I'm still not clear on Q 3-4-5 if someone can help.
Old May 16, 2012 | 11:02 AM
  #15440
homeyclaus's Avatar
But if the bulb were working, it would be on then.
If you're going to pull the instrument cluster, just replace all the bulbs and be done with it.
There is a link here to the factory service manual that outlines how to handle this, but the summary is that whenever you work near airbag wiring you need to disconnect the battery and leave it disconnected for some time before commencing work.
See above.
