5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Apr 15, 2007 | 07:48 PM
  #1721
SEmy2K2go's Avatar
Go BUCKS!!!
Originally Posted by MAi30t
....any help?
Are you having any issues at start up?
Old Apr 15, 2007 | 08:21 PM
  #1722
MAi30t's Avatar
once in a while ill have a rough start up, car will studder and RPM will be low, the car will stall without me hittin the throttle, but like i said this is once in a while , the stubling at a stop light issue is more frequent, thanx for ne input
Old Apr 15, 2007 | 08:25 PM
  #1723
SEmy2K2go's Avatar
Go BUCKS!!!
To me, it sounds like there may be some sort of charging system issue. See about having your battery and/or alternator checked to make sure they're working properly. That would be one of the first steps that you can take that aren't overly complicated and/or expensive. Once you get beyond that point, you can start to attempt to isolate the issue further.
Good luck.
  #1724
irish44j's Avatar
retired moderator
1. looks at the coil packs. Do they have a gray dot on them, or not?
2. Have you changed spark plugs recently?
3. MAF may need to be replaced
4. IACV may be bad.
EDIT: now that I re-read your post, it looks more and more like a bad IACV (Idle air control valve). I have this problem on and off as well, but it's not something I want to mess with, since some people have screwed up their ECUs trying to fix it. If this is the case, I would probably have the dealer take care of it.
Old Apr 15, 2007 | 08:36 PM
  #1725
MAi30t's Avatar
ive heard of cleaning the IACV after having similiar issues, would you sugest this? Further while accelerating there seams to be a bit of a "lapse" from when hit the throttle to when the car pulls, coulod this be relating to my MAF
Old Apr 15, 2007 | 08:38 PM
  #1726
MAi30t's Avatar
i see its il advised thanks for 4 the time
Old Apr 16, 2007 | 05:11 AM
  #1727
choopster's Avatar
any help would be appreciated
My clutch is being a lil hard to press and is making squeeky noise. I checked on my cluth fluid and it is decreasing at slow rate. any suggestions?
Which one is the first bank for the 0420 SES code. I am thinking its the most rear under the car since its a 2001 with 4 O2 sensors.
i have 2001 5-speed
regards
Old Apr 16, 2007 | 07:44 AM
  #1728
Bufflomike's Avatar
Sexier Than Simpson
I am new here, but I have an intermittent gauge light failure
I want to say hello to all and thanks for having a cool forum. I own a 96 SE 5sp with 190k miles which is for sale 2k. I just purchased an 03 Se 6sp all options except Navi with HLSD and the gauge lights go off while all other interior lights work. They may come back on, they may not. This happens in the daytime and at night. Are these lights adjustable by the dimmer? I thought they should be able to be dimmed, but it appears when they are lit they are at a constant level. The other lights dim appropriately with the wheel. My question is, does the standard operation of these lights allow the gauge lights to be dimmed along with the other interior lights? Is this a problem others have experienced because I cannot find any details. Are the gauge lights a separate fuse? I doubt its a fuse since they go on and off. Any suggestions would be appreciated.
Old Apr 16, 2007 | 08:06 AM
  #1729
Bufflomike's Avatar
Sexier Than Simpson
Clunky 1-2 and 2-3 shifts
I was reading the posts about MT-90 fluid and I am going to try that to alleviate the 1-2 clunk and 2-3 clunk. It only happens when I shift as fast as I want, if I take it slow, the shifts are perfect. I will let you know. Are these synchros prone to clunk?
Old Apr 16, 2007 | 03:24 PM
  #1730
irish44j's Avatar
retired moderator
buying a 00-01 Maxima with a rod linkage will get rid of the clunky shifting. You have a cable linkage. Get used to the clunk.....
cable shift linkages suck....
Old Apr 16, 2007 | 03:27 PM
  #1731
SoonerFan's Avatar
Cletus
MT-90 combined with ES bushing significantly help the clunky/notchy shifting.
it will never be eliminated though due to the design (like irish said)
Old Apr 16, 2007 | 03:31 PM
  #1732
atlridin's Avatar
Originally Posted by jbran555
Hey I have another question, My two back windows, they only roll down halfway. Is there any way to tweak that so they can roll down all the way?
And, is there a way to access the trunk through the back seats
I have a 2000 Nissan Maxima GLE.
I believe your ? to the back windows was answered by Irish.
The seats do fold down. To pull down the rear seat simply look along the top of the headrest on either side for a **** that sticks up (one on each side).
Pull up on **** and then pull down seat.
Do the same on the other side.
You can not access the trunk through the rear arm rest on some of the newer maximas.
Old Apr 16, 2007 | 05:35 PM
  #1733
SE My 6sp's Avatar
how do i find out if i have an HLSD??
Old Apr 17, 2007 | 07:45 AM
  #1734
Merlot02SE's Avatar
When are gas prices going down
If everything is still stock, you'll have drilled, brushed stainless pedals, like those on the 350Z and 2001 Anniversary Edition models.
Old Apr 17, 2007 | 07:55 AM
  #1735
NmexMAX's Avatar
dot dot dot ...
Those pedals can be bought aftermarket, even if the car wasn't equipped from the factory with HLSD.
This way is better just in case the car isn't still stock.
http://forums.maxima.org/showpost.ph...79&postcount=3
Old Apr 17, 2007 | 07:57 AM
  #1736
Puppetmaster's Avatar
maxima+HLSD = http://forums.maxima.org/showthread....highlight=hlsd
Look at the transaxle code under the hood on the firewall. If the code is RS6F51H you have HLSD, if not, it will be RS6F51A, which is open diff.
You can also just call Nissan and give them your VIN, they will be able to tell you everything the car came out of the factory with.
Old Apr 17, 2007 | 07:58 AM
  #1737
SoonerFan's Avatar
Cletus
  #1738
Merlot02SE's Avatar
Yes, that is a better way. I was looking for a picture of the two differentials. Forgot about the firewall plate. DUH.
Old Apr 17, 2007 | 07:59 AM
  #1739
SoonerFan's Avatar
Cletus
i have the pedals...no HLSD
Old Apr 17, 2007 | 08:06 AM
  #1740
NmexMAX's Avatar
dot dot dot ...
Old Apr 17, 2007 | 08:08 AM
  #1741
SoonerFan's Avatar
Cletus
but i actually have the pedals...do you?
Old Apr 17, 2007 | 08:19 AM
  #1742
NmexMAX's Avatar
dot dot dot ...
I did about 3:15AM this morning... Then I woke up 2 hours after...
Old Apr 17, 2007 | 08:24 AM
  #1743
I think he has two of em... and nowhere to put the third...
Old Apr 17, 2007 | 08:26 AM
  #1744
NmexMAX's Avatar
dot dot dot ...
Saving weight.
Old Apr 17, 2007 | 08:43 AM
  #1745
SoonerFan's Avatar
Cletus
so a thin one and a big fat one? well thats just silly
Old Apr 17, 2007 | 09:27 AM
  #1746
Terence's Avatar
I have been wondering if I should get 2k2-2k3 HID's for my 2001, and I was looking at the Phillips branded one from performance_depot on eBay but I noticed mixed reviews according to my search.
http://forums.maxima.org/showthread.php?t=395311
Is there a better alternative or is this pretty much the only option for now?
Thanks in advnace for the response!
Old Apr 17, 2007 | 01:34 PM
  #1747
JimmyH's Avatar
If I remember correctly, that happened to me right before I had the MAF replaced, along with hesitation and detonation while accelerating. But that was YEARS ago, so don't quote me.
Old Apr 17, 2007 | 03:16 PM
  #1748
aamir's Avatar
Hey guys,
I just finished installing my new suspension (Eibach springs and Illumina struts) and am going to get an alignment tomorrow. I did drive the car a little bit today and whenever I turn to the right, there is a loud sound that comes from the passenger front side of the car. Is this normal or will an alignment take care of this sound? Thanks for any help.
Old Apr 17, 2007 | 03:42 PM
  #1749
joeb's01max's Avatar
did anyone do the 01 headlights swap with the 02 HID's let me know if i should go oem or ebay item?
Old Apr 17, 2007 | 04:02 PM
  #1750
irish44j's Avatar
retired moderator
Originally Posted by aamir
Hey guys,
sounds like you didn't align the top hat assembly correctly, or didn't seat the spring correctly on the lower seat. the Eibachs have more preload than alot of other springs so they accentuate the problem. I suggest you take them off and inspect to make sure everything is assembled correctly and pointed the correct direction.
Old Apr 17, 2007 | 04:03 PM
  #1751
irish44j's Avatar
retired moderator
yes, many people have done them.
Buy OEM (not ebay projector crap), you can often find them used as well.
you will also need the 02-03 wiring harness to splice into yours (its not plug and play) and the lower mounting clips. Call DaveB to get both of these items.
Old Apr 17, 2007 | 05:38 PM
  #1752
MaxiPad'01's Avatar
Im new on here with a question about pricing. my check engine light came on and i brought my car to a local shop. he said the middle of the three o2 sensors was broken. they are going to charge me $300 to fix it, and he said the o2 sensor itself costs $160...to me that sounds crazy, but then again...i am new. what do you maxima experts think?
Old Apr 17, 2007 | 08:28 PM
  #1753
Tee00Max's Avatar
ok i have a 2000 max and i was lookin at the how to thread for rewiring your side markers so that they can blink with you blinkers and some people say to cut the black wire coming from the turn signal and some say its the green one. they say if you cut the black one it wont have any change but the green wire will do it??? i was jus wondering if anybody with a 2000 has done it and they kno which exact wire to cut or someone that jus knows period thank...
Old Apr 18, 2007 | 06:34 AM
  #1754
Can you get the exact codes that were pulled? If so, post em here and we can probably give you more feedback. IMO, if you know which O2 sensor it is, you can save half of that doing it yourself. It shouldn't be that hard to do but yet they are charging you 1.5-2 hours labor.
Old Apr 18, 2007 | 08:28 AM
  #1755
MaxiPad'01's Avatar
yea, i just picked it up today, i just paid the $300. they had it all done and installed correctly, which i would rather it be done how it should due to the fact that i am considering selling my car, rather than me just setting up problems for the next owner.
Old Apr 18, 2007 | 11:55 AM
  #1756
How much does that normally run? $$$ Is it expensive?
Old Apr 18, 2007 | 01:46 PM
  #1757
JimmyH's Avatar
In addition to the xenon and 9005 connectors your need, I recommend getting a pair of these:
http://store.racinglab.com/kyoplheduwih4.html
This way, you can wire these h4 plugs to the xenon and 9005 connectors, as well as a relay for the xenon, without cutting off/splicing of your Max's H4 harness.
It will save you time if you ever sell the car, because you will be able to quickly and easily swap out the halogen for the xenon lights.
Turn signals are a little trickier. I ordered a set of the park/turn signal bulb holders in the 00-01 headlights, cut off the end that holds the bulb, and then soldered wires from the leads on the plug end to the wires coming off the parking bulb holder and turn signal bulb holder on the 02-03 headlights. This created a custom adaptor to attach the turn signal harness without cutting it off either.
Old Apr 18, 2007 | 06:54 PM
  #1758
GigEmAgs07's Avatar
i kinda wanna order these fogs to match my headlights, but it says that they are stage 2 fogs. but the wattage and all that are just like the ones i have in now. What makes a fog a stage 2 fog, and should i not order these. tia. these are 55/100, and the JDM yellows i have in now are 55/130. just wondering the distinction.
http://www.automotivelightingusa.com...roducts_id=361
Old Apr 20, 2007 | 08:10 AM
  #1759
jocoo's Avatar
Intake
Still debating whether or not to get an intake for my 2002 maxima, what are the benifits from it and are there any risks i.e. water or dust getting into engine. Also any recommendations on which one i should get besides injen or berk?
Old Apr 20, 2007 | 04:40 PM
  #1760
gimmethayayo's Avatar
I just bought a 2k for 6k with 129k on it. I don't have some of the "goodies" that the newer models have. So I was wondering if I could 1) swap my cd player for a 6 disc in-dash cd changer & 2) swap my regular steering wheel for the one with the audio controls.
