5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old 04-20-2007, 05:17 PM
  #1761
dot dot dot ...
NmexMAX's Avatar
Originally Posted by jocoo
Still debating whether or not to get an intake for my 2002 maxima, what are the benifits from it and are there any risks i.e. water or dust getting into engine. Also any recommendations on which one i should get besides injen or berk?
DO NOT get the Injen. My advice would be to stick with the stock airbox. Get a midpipe and make it fit (cut it 2" or so)
NmexMAX is offline
Old 04-20-2007, 08:39 PM
  #1762
IHAVEA2KMAXIMA's Avatar
I guess it would be appropriate for me to post here... I just installed a Warpspeed y-pipe. A day after, I got around 20miles in the new y, and then I got the SES. I tried searching for some info, but didn't really help. I found a write up for 2k2-2k3 on how to reset the TCM but it didn't work for my 2k. Can anyone comfirm the these 2k2 reset procedures for 2k or did I do something wrong? Here's the link (post #94)
I would really appreciate the help. Thanks in advance.
IHAVEA2KMAXIMA is offline
Old 04-20-2007, 09:01 PM
  #1763
aamir's Avatar
Originally Posted by irish44j
sounds like you didn't align the top hat assembly correctly, or didn't seat the spring correctly on the lower seat. the Eibachs have more preload than alot of other springs so they accentuate the problem. I suggest you take them off and inspect to make sure everything is assembled correctly and pointed the correct direction.
Thanks irish for the suggestion. The top hat assembly was not aligned correctly so I fixed that. But there is another problem now. While putting the wheel back on, two of the studs that the lug nuts screw onto broke off. I now need to replace that so I was wondering if there are directions on how to do that. Thanks for any help.
aamir is offline
Old 04-20-2007, 11:40 PM
  #1764
atlridin's Avatar
Originally Posted by gimmethayayo
I just bought a 2k for 6k with 129k on it. I don't have some of the "goodies" that the newer models have. So I was wondering if I could 1) swap my cd player for a 6 disc in-dash cd changer & 2) swap my regular steering wheel for the one with the audio controls.
I have a 2k Maxima too. I was concerned with some of the same things. I had an 01 accord loaded that had the steering wheel control and the 6cd changer. I looked around the forum and found that the steering wheel is a pain to change (you have to get one with wires and harness, etc) and the cd changer was not worth it. I plan to buy a touch screen DVD and many come with a remote. Kenwood has a touch screen DVD with GPS for under 1000.00 and comes with remote. Go to overstock. com. It will be cheaper and more used then the stock. I have spent most of my money on making my ride smoother. Check out the Delphi Roady XT, it fits perfectly in the ash trey and looks clean. Will post a picture if interested.
Enjoy blowing all your extra $$$ on the ride.
atlridin is offline
Old 04-21-2007, 06:22 AM
  #1765
choopster's Avatar
can an automatic trans cluster fit on manual trans maxima without any problem?
choopster is offline
Old 04-21-2007, 09:59 AM
  #1766
LA02MAX's Avatar
It does physically fit, but it might have an extra pin or something for the wiring harness since the auto gauge cluster has the gear indicator on it. I would just try to find a manual one if you can....
LA02MAX is offline
Old 04-21-2007, 10:03 AM
  #1767
LA02MAX's Avatar
You're going to have to remove your rotors and then the studs come out through the back. Just one good whack with a hammer will do it.
When installing the new studs, just put it through the holes in the hub on the back side, and make sure to tighten them down using a lugnut first (put a couple washers over the stud, then torque down the lug nut). Then re-install your brakes and wheels, and you're done. For a few days after, try to re-torque the lugs to make sure they have seated completely.
Here's some pictures of what I'm talking about (albeit this is for the rear, so it'll be similar but not exactly the same)
http://www.cardomain.com/ride/695690/8
LA02MAX is offline
Old 04-23-2007, 05:48 AM
  #1768
ricodemus's Avatar
Alright, I was doing some maintenance on my maxima and I saw that the tie rod ends were shredded. Are these hard to replace - do you need a press, etc? I was wondering if it's just that bushing and it needs to be pressed in, then it probably won't be worth it to try and do myself or outside of a shop. I get good deals on oem parts so I usually buy them myself assuming I can handle the install.
Anyone want to buy a 20th AE max? :P
ricodemus is offline
Old 04-23-2007, 01:53 PM
  #1769
aamir's Avatar
Thank you very much. I replaced all five studs and lug nuts just to be on the safe side. Everything works perfectly now. Thanks once again.
aamir is offline
Old 04-24-2007, 12:10 PM
  #1770
02Maximan's Avatar
I am wanting to clear the headlights on my car (remove the orange turn signal lens) and I am wondering exactly how much risk I will taking if I tackle this job. Headlights can be quite expensive and I'm just wondering how smart this is. I know lotsa people have done this so it must not be too risky?? Help me out here. BTW I have a 2k2.
02Maximan is offline
Old 04-24-2007, 12:21 PM
  #1771
SiLvErBaCk82's Avatar
[QUOTE=02Maximan]I am wanting to clear the headlights on my car (remove the orange turn signal lens) and I am wondering exactly how much risk I will taking if I tackle this job. Headlights can be quite expensive and I'm just wondering how smart this is. I know lotsa people have done this so it must not be too risky?? Help me out here. BTW I have a 2k2.[/QUOTE
Well, first off I'd search before the maxgods see this.....but after weighing my options this isn't something I wanted to try and tackle myself seeing the replacement cost is very expensive. It does look sick though
SiLvErBaCk82 is offline
Old 04-24-2007, 12:40 PM
  #1772
retired moderator
irish44j's Avatar
No, all you need is a balljoint seperator. About $10 at any autoparts store. Undo the bolt that secures it to the spindle, then use the BJS to "seperate it" from the spindle. Then screw it off the steering tie rod. then screw the new one on to about the same place (make sure you mark it on the thread), re-attach to the spindle, and get an alignment immediately (since it will be way off).
get a Haynes manual and it shows exactly how to do it.
irish44j is offline
Old 04-24-2007, 01:20 PM
  #1773
ricodemus's Avatar
Thanks irish. I hope it's in the service manual too since I do have that somewhere. I may change out my struts too before I get the alignment, I think one of them is actually leaking. I was going to attempt to do this myself as well too, you think it's possible with a normal set of tools? I know I'll have to get a socket to get the axle nut off which is huge (33mm or something). Other than that I've only helped while suspension replacement was done.
  #1774
Dynasty47x1's Avatar
My car was misfiring because the harness went bad and it fried the computer repair cost $3600 is that worth it what should i do i just got the car in august and i dont actually want to go into a car bill.D*** this sucks.
Dynasty47x1 is offline
Old 04-24-2007, 02:18 PM
  #1775
retired moderator
irish44j's Avatar
you only have to take off the axle nut if you're changing the CV axles - struts/spring changes you don't take that off (I mean, you can, but you don't need to...there is still room to get the strut assembly out without doing it - just make sure you put a towel over the CV boot so you don't ut it with the bottom of the strut accidentally.
To do springs/struts IIRC you will need 14, 17, and 19mm sockets, some needlenose pliers to take off the brake line bracket, a little (8mm?) wrench to take off the ABS line bracket, and spring compressors (about $20 at Sears - buy theirs, they are the best).
irish44j is offline
Old 04-25-2007, 08:14 AM
  #1776
ricodemus's Avatar
Ok, I have all that except for the spring compressors. Cool, I'm glad you don't have to take the axle nut off, I was relating this to my honda. I'm gonna do my research before I get into it, but it sounds like it's doable.
3600 covers what?!!! Just the ECM and the harness? I would involve insurance at that point because that is a huge out of pocket expense if you can't find the parts yourself.
Old 04-25-2007, 06:44 PM
  #1777
hottmaxx2003's Avatar
question about my maplight
I have an 03 and i have been trying to find an LED replacement for the maplight, (near my sunroof controls). The problem is, i can't even find out what kind of lights are in there in the first place... Everytime I do a search for "03 maxima maplight", the search results always bring me to dome light links, styles and pictures. It's a tiny ball-like bulb... Please help!!!
hottmaxx2003 is offline
Old 04-25-2007, 08:00 PM
  #1778
is invisible
CoolMax's Avatar
Ba9s
i use polarg m26
http://www.moodym.com/maxima/tech/maxbulbchart.html
http://www.autolumination.com/
CoolMax is offline
Old 04-26-2007, 07:26 AM
  #1779
longjas's Avatar
BOSE HU Removal Help
I have read alot of the posts about the the stock Bose HU removal and using stock speakers or replacing the speakers. What I want to do is replace my BOSE with a new deck and add a 12" sub in the back and not use the bose sub. I already have the sub, amp, and capacitor from my old car so I am good there. But, my question is what are the adapters i need if i want to use the stock bose door speakers? Or should i just scrap them all together and get new door speakers. I have read a bunch of posts but it still seems a little unclear what actually works. If anyone can help me I would appreciate it. Thanks
J
longjas is offline
Old 04-26-2007, 07:34 AM
  #1780
USF Class of 2009
flxsunxchick's Avatar
My clutch is being a lil hard to press and is making squeeky noise. I checked on my cluth fluid and it is decreasing at slow rate. any suggestions?
Which one is the first bank for the 0420 SES code. I am thinking its the most rear under the car since its a 2001 with 4 O2 sensors.
i have 2001 5-speed
regards
I just had a problem with mine - it got really stiff and then all of a sudden it went really soft and my friction point dropped to the floor, literally. I took it to my mechanic and they said that one of my metal pressurized lines had been leaking, (which explained the lack of fluid in the resevoir), and replaced it. After that replacement, I still noticed problems with my clutch - the friction point would vary as the car warmed up. It also felt quite sluggish. I took it back and they did a clutch system flush for no charge. She's running great now.
She still has a squeak, but it just sounds like something needs some lubrication, not like the whoosing air-in-the-line sound I was hearing before the flush. Good luck!
flxsunxchick is offline
Old 04-26-2007, 04:25 PM
  #1781
cpo_sharky's Avatar
Are 5th Gen Max throttle bodies compatible with 02-03 Altima 3.5L's?
cpo_sharky is offline
Old 04-26-2007, 04:28 PM
  #1782
SE My 6sp's Avatar
No Cold Air
I have a 5.5 gen with the digital Climate Control Option. I turned the temperature **** all the way to the cold side and it only went to 60F and turned up the fan and no cold air came out . I checked under the hood and the Compressor clutch wasn't engaged like the A/C wasnt even on. i'm pretty sure its not a bad cluch because its a newer car, but is there a button that i'm not pushing on the dash to engage the cold air???
SE My 6sp is offline
Old 04-26-2007, 04:41 PM
  #1783
Cletus
SoonerFan's Avatar
was it in "auto" mode? or "econ"?
the econ is used for heating and the AC compressor doesnt turn on.
after using the econ button all winter, i turned on my air the other day and the air wasnt cool. realized i had hit econ out of habit.
SoonerFan is offline
Old 04-27-2007, 09:04 PM
  #1784
SE My 6sp's Avatar
ohhhhhh ok thanks it worked i am such an idiot About those anti theft brackets for the 2k2-2k3 headlights, where can i get them from, and how much, HID's are like gold around where i live.
Old 04-27-2007, 09:10 PM
  #1785
retired moderator
irish44j's Avatar
they are only available from the dealer IIRC...unfortunately, they don't seem to help much. The theives just do MORE damage to the front of your car trying to get your lights....
Don't know the cost.
irish44j is offline
Old 04-27-2007, 09:15 PM
  #1786
retired moderator
irish44j's Avatar
In case you are interested, there are also stainless steel braided clutch lines available for the 00-01 5speed. An inexpensive, worthwhile mod if you want a slightly better, more direct clutch feel (it won't get stiffer, just more responsive). IIRC there is still a group deal someplace in the GD section here.
On an unrelated note, on your cardomain site you mention upgrading to "HIDs or projectors."
Let me save you alot of hassle and disappointment: If you are looking to upgrade, go directly to the 02-03 OEM HID setups (which are a perfect fit and just require some rewiring). The projectors available on ebay and other "tuner shops" are total crap in terms of light output. And HIDs in your stock housings will just cause excessive glare.
irish44j is offline
Old 04-28-2007, 10:58 AM
  #1787
dot dot dot ...
NmexMAX's Avatar
02/03 Maxima TB's are compatible w/ 02/03 Altima TB's.
NmexMAX is offline
Old 04-28-2007, 09:31 PM
  #1788
longjas's Avatar
bump... if anyone can shed some light on this for me
J
longjas is offline
Old 04-28-2007, 09:35 PM
  #1789
retired moderator
irish44j's Avatar
J
I'm running a high-end Alpine deck with the OEM bose speakers and it sounds fine for normal listening. You need (IIRC) the PAC OEM-2 adaptor or something like that. Check the audio/ICE forum here for more details. it's in the stickies.
irish44j is offline
Old 04-29-2007, 12:55 AM
  #1790
Bad *** Newb
Child_uv_KoRn's Avatar
I'm too poor to buy rims, but I need good tires as wide as I can. I run toyo proxes (very strong tire) right now, 225-40-17 and burned my front tires off in less than 5K miles (so I rotated them to the back :P). On my old 2000 maxi I ran 255-45-16 yokohamas (they had excellent traction) and toyos on the stock rims and never even noticed a problem with the tire being 7.5", since the crappy stock rims are 7" wide. I want to run 265s as my next set and am wondering what you guys think about that.
Child_uv_KoRn is offline
Old 04-29-2007, 07:06 AM
  #1791
retired moderator
irish44j's Avatar
If you are using your stock 17x7 wheels, the widest tire you can safetly use is a 235. You cannot run 265's on a 7" wide rim. It is not safe, and any respectable tire shop would not even mount them up for you. Not to mention it will look stupid as hell. Even my autocross tire are only 245, and they are on an 8" wide rim, not a 7" wide stocker...
The CORRECT size you should be using is 225/50/17, but 235/45/17 would work as well.
If you're "burning off" Proxes 4 in <5k miles, you either have a terrible alignment or you do too many ricer burnouts. I drive hard and corner hard, and my Proxes 4 typically last 15-20k miles.
irish44j is offline
Old 04-29-2007, 07:59 AM
  #1792
MaxiPad'01's Avatar
ive seen a few 00-01 guys with 02-03 front ends, is that a direct fit?
MaxiPad'01 is offline
Old 04-29-2007, 08:35 AM
  #1793
retired moderator
irish44j's Avatar
yes, but you will need the 02-03 headlights (the 00-01 light will have a big gap)and the 02-03 fog lights (the 00-01 foggs won't fit)..
irish44j is offline
Old 04-29-2007, 09:43 AM
  #1794
Bad *** Newb
I don't know wtf a ricer burn out is, but I just mash it and it spins like a mother****er. 255s look completely normal and those were drove till they were completely bald with nails, shrapnel, and wire sticking in them (several pieces were in them when the tire was changed) and the damn things still held up.
Old 04-29-2007, 10:00 AM
  #1795
Cletus
SoonerFan's Avatar
thats a ricer burnout
dont blame the tires for the spinning your tires and wearing them out.
i also drive hard (without doing burnouts) and my toyos have about 10K miles on them so far
Old 04-29-2007, 10:40 AM
  #1796
retired moderator
irish44j's Avatar
1. you just described a ricer burnout.
2. it doesn't matter what they "look" like. The bottom line is that Toyo lists 8.5" as the MINIMUM width for the 255/17 Proxes 4 (9.0" as the preferred size). There is a reason for this - it's called safety. If you want to be a moron and put tires that are not even CLOSE to the correct size on your car - well, it's a free country. But you're going to be the one who is hating life when you take a corner on the highway and the tire unseats itself from the wheel and you wrap your maxima around a tree at 70mph.
According to Toyo, the correct size tire for a 17x7" rim is 225/50ZR17 98W (6.0-7.0-8.0) rim widths in parenthesis.
read: http://www.toyo.com/docs/tires/produ...ategory=luxury
3. Driving around with bald tires with "nails, shrapnel, and wire" sticking out of them is dumb as hell. Are you really as stupid as you're making yourself sound?
irish44j is offline
Old 04-29-2007, 12:22 PM
  #1797
MaxiPad'01's Avatar
would my ae front lip fit on the 02-03 front end
Old 04-29-2007, 12:23 PM
  #1798
MaxiPad'01's Avatar
^^^i dont know how you do the quote thing, sorry, im a true newbie i guess
Old 04-29-2007, 12:30 PM
  #1799
Bad *** Newb
3. Driving around with bald tires with "nails, shrapnel, and wire" sticking out of them is dumb as hell. Are you really as stupid as you're making yourself sound?[/QUOTE]
Hey, I didn't know the damn things were punctured until the tire was changed. I was just saying the tires I had on before handled it just fine and I thought they only required 7.5 width. I know .5" is not going to be a hazard with a tough tire. The specs changed or somethin, b/c the ones I bought said 7.5.
Old 04-29-2007, 12:33 PM
  #1800
Cletus
SoonerFan's Avatar
no................
Quick Reply: 5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
