5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Sep 19, 2006 | 07:15 PM
  #161
gephelps's Avatar
I have seen some claims that the pedal came on cars without the hsld. They seemed to be a common mod for a lot of people due to their looks and not terrible cost.
If the rest of the car is completely stock then the chances are pretty good, but the code is the real way to tell.
Old Sep 19, 2006 | 07:32 PM
  #162
beano's Avatar
Originally Posted by Romster
Here's my problem: the driver side window opens 3" by itself when I auto-close it. I found a thread about it, read through it, and didn't find any answers. So I'm throwing it out there again in case someone has any updates. Thank you for you time.
Did unplugging the battery with windows help? I'd rather know than to have to reprogram all my radio stations. Thanks.
Old Sep 19, 2006 | 07:45 PM
  #163
gephelps's Avatar
http://forums.maxima.org/showthread.php?t=492484
Was this the thread? The one it links to seems to have a solid answer. Which isn't unplugging the battery.
Old Sep 19, 2006 | 07:46 PM
  #164
irish44j's Avatar
retired moderator
Originally Posted by Succinct
First, I want to thank irish44j for all of the time spent answering our noobie Q's! Thanks!
My first post was about 3 weeks ago (page 3 of this thread), when I was shopping for a replacement for my beloved-but-unreliable-and-expensive 540 6-speed. This week I finally found what I was seeking - a 2003 SE 6-speed with the "limited" (leather,etc) package, with JUST the ext/int colors I was seeking, at a fair price. My Q's:
congrats. be sure to stop by the DC area forums...several Richmond folks hang out there and are very knowledgeable about all things Maxima....in case you ever need local help.
1) I don't know whether it has LSD, but figure it has everything else, so it's probable. How can I tell for sure without the original window sticker?
what the other n00b said is correct. That, or you can lay down some rubber and see if there are two full tracks (not suggested)
2) The car has what seems like a rear tire imbalance and noisy rear tires. The front/steering is rock-steady. The tires are new Hankook Ventus HR2's. I figure it's probably the cheap tires creating all of the "ruckus". Any other theories?
tires may be out of balance, and certain tires are just louder than others. As to Hankooks...yeah, they're inexpensive, but not "cheap." Actually very good performance tires in most cases. I'm on my second set for autocross and they are superior to the top autocross tires out there, the Falken Azenis 615 and Kumho MX, in my opinion.
3) The lower part of the center of the rear cross-member looks damaged, as if run up on a curb at some point. Is this common? How hard to fix?
If you mean the member that goes below the b-pipe....don't worry about it. It's just there in case the pipe somehow breaks, so it doesn't drag on the ground. I scrape the hell out of my crossmembers all the time.
I'm sure I'll have more Q's but for now will absorb all I can from the FAQs.
excellent plan!
Old Sep 19, 2006 | 07:47 PM
  #165
irish44j's Avatar
retired moderator
Originally Posted by gephelps
If you don't trust the drilled aluminum pedals then what you need to do is pop the hood and observe the tranny code stamped on the aluminum plate which is riveted to the firewall. The same plate that shows the VIN, the engine code (VQ35DE) will show the trans code. Nissan names their gearboxes almost the same way that they name their engines. The code for the HLSD equiped 6 speed is RS6F51H. The 'H' suffix denotes the Helical device. The 6F I believe denotes 6 forward gears. Other suffixes I know of include 'A' and 'V'. My '98 Maxima had RS5F50A. The 'A' meant the car had a regular diff. But my old SE-R has RS5F32V and of course the 'V' represented the viscous coupling limited slip diff. Perhaps someone could confirm for us that their non helical equiped transmission is coded RS6F51A.
Ripped from http://forums.maxima.org/showthread....highlight=hlsd
you are an impressive n00b indeed.....I foresee a bright future for you around here.
Old Sep 19, 2006 | 08:02 PM
  #166
gephelps's Avatar
I guess noob is a step up. I used to just lurk until they forced you to register.
Old Sep 20, 2006 | 05:53 AM
  #167
PitchBlackMax's Avatar
Irish and gephelps, thanks for the help, I appreciate it.
As for the window issue, the lcokout switxch was the first thing I tried, but I will try testing the circuit. Thanks again!
Old Sep 24, 2006 | 06:02 PM
  #168
Eenis's Avatar
Originally Posted by irish44j
Originally Posted by Memphis2k1
What is this piece that is sticking out?
Here is the deal. I put on new(er) 2002-2003 stock 17inch rims and tires. Everything went smooth until I backed out and heard this...tink tink tink sound. I noticed these when I went to install but didin't think anything of it. Can I mod them, remove it, bend them? My drivers-side isn't the one making the noise, its the passenger-side (i think).
Orignally I had the ugly 16 inch rims that the rim covered where this piece is tapping on my new 6 spokes...when the wheel spins.
That is one of the spring clips that puts outward pressure on the pads so they don't rub the rotors when you're not braking. When pads are installed, the little metal piece circled should go INSIDE of the little tab/loop on the pad itself. Look closely and you'll see what I mean.
To his question, what about the pads that don't put loops on all 4 pads? Should we put the pads w/ the loops on the outside of the rotor and those with the clips on the inside of the rotor so that the clips don't clip against the wheels? Also, wouldn't missing the loops cause the pad to continuously rub against the rotor since there's nothing to foroce the pad off of the rotor?
Old Sep 24, 2006 | 07:28 PM
  #169
DukeN's Avatar
Can someone point me to the direction of a master thread or thread(s) with regards to the sub cutting out?
Have a '00 GLE with the Bose setup, the sub dies and comes back. Seems to work better in the summer, lately in the last couple of weeks has not worked at all.
Any ideas would be appreciated, thanks.
Old Sep 24, 2006 | 07:31 PM
  #170
SEmy2K2go's Avatar
Go BUCKS!!!
How about trying the audio section since that would be the "master" of everything audio related?
Old Sep 28, 2006 | 06:46 PM
  #171
irish44j's Avatar
retired moderator
back to the top....where this thread is needed!
Old Sep 29, 2006 | 08:27 AM
  #172
Succinct's Avatar
Can I raise the rear of my '03 6-spd Maxima with a floor jack centered under the rear axle beam? Risks/considerations? Also, what is the best floor jack location in the front (so that I can raise the car & put jack stands under the stock jack pad locations)?
Thanks!
Old Sep 29, 2006 | 08:54 AM
  #173
Nineleven
Anyone know where the O2 Sensor Thread is located for 5th Gens?
J
Old Sep 29, 2006 | 09:14 AM
  #174
Puppetmaster's Avatar
Thanks!
You should be fine. The beam is one of the jack points specified in the service manual. For the front, there is a little knub on that your jack will fit on.
See also:
http://forums.maxima.org/showthread....ht=jack+points
Old Sep 29, 2006 | 09:16 AM
  #175
J
What do you need to know exactly?
There is some useful info here:
http://maxima.theowensfamily.com/tsb/NTB02-051a.pdf
Old Sep 29, 2006 | 11:59 AM
  #176
Nineleven
I need to find the location of O2 sensor, Bank 1, Sensor 1
I've already changed out 2 O2 sensors in the past 3 months, those being Bank 2, sensor 2 and Bank 1, sensor 2
Im just not sure if Bank 1, sensor 1 is Upstream or Downstream
Old Sep 29, 2006 | 12:07 PM
  #177
Nineleven
Originally Posted by Puppetmaster
Hey thanks Puppetmaster, that was very helpful....it sent me right where I needed to go
Old Sep 29, 2006 | 12:09 PM
  #178
Succinct's Avatar
My instincts (yeah I'm a newbie, but I'm 44 and have owned over a dozen cars) tell me that sensor 1 would be the upstream sensor whereas sensor 2 would be the downstream.
Edit - I see that you already got the answer. Sorry if my response was misleading at all.
Old Sep 29, 2006 | 11:05 PM
  #179
rrj72's Avatar
ran the 1/4 mile tonight
Ok so I took my stock 2002 auto max to the track tonight to see what she'd do in the 1/4 mile...did 5 runs and the best I could pull was a 15.173
that sound pretty normal? I was hoping for like a 14.9 or atleast 14 flat. I did get a lot of tire spin, running Nitto Extreme 450's 225 width. I'll scan in the timeslips if anyone wants to see.
Old Sep 30, 2006 | 12:55 AM
  #180
matt_aitchison's Avatar
I Have A Question For My 20th Anniversary Maxima. Can A Clogged Fuel Filter Cause Missfiring, Also How Ofter Should You Change Your Fuel Filter?
Old Sep 30, 2006 | 07:28 AM
  #181
Take a look around here to see what others have done:
http://forums.maxima.org/forumdisplay.php?f=45
IIRC, people have run in the mid to high 14s with a stock AT 02-03 Max. I know Gooey did it for one.
Old Sep 30, 2006 | 08:46 AM
  #182
AceofSpds's Avatar
wat
There are other variables that will affect your track times, if you didnt know, like humidity, air temp, track temp, and altitude
Old Sep 30, 2006 | 10:57 AM
  #183
machinehead131's Avatar
Question....does anyone know or have a picture of which wire to tap into for the switched power to the auto dim mirror and the vanity light.. im hardwiring my radar detector if that helps. Thanks
Old Sep 30, 2006 | 12:59 PM
  #184
rrj72's Avatar
Not what the difference between track temp and air temp was, but I live in AZ with low humidity and it was about77-80 degrees according to the gauge cluster in my car.
Old Sep 30, 2006 | 04:38 PM
  #185
02bluese's Avatar
Does anyone have a black headliner in there 5 gen? I have a 5.5 with the black leather and was wondering what my options are???
Old Oct 1, 2006 | 07:45 AM
  #186
Trevor28's Avatar
I have looked all over this site, can't get a straight forward answer..or i'm using the wrong terms to express what i'm trying to say.
I have a 2000 Nissan Maxima GXE/SE and I believed I hooked up my AE HU just fine.
I purchased the wire harness and color matched them and grounded the unit near the car's computer ( it was bulky and shielded in the center console)
The only thing is ever since the install...all i'm getting is a high pitch sound.
I ran the rca wire from the HU to the AMP on the passenger side of the car....and the remote and power wire on the drivers side.
When I removed my factory HU, it said Clarion underneath...it would have said BOSE if it was right?!? I thought I got the wrong harness but it clearly said 1995 and up for non-bose system. Does the non-bose system in the 2000 Maxima have crossovers or amplifiers that i'm not aware of that could cause this high pitch noise? Would getting the Scoshe OEM Amplifier Adapter make a difference on a non-bose system?
Thank you for your patience in reading this...thanks for any help.
Old Oct 1, 2006 | 12:28 PM
  #187
irish44j's Avatar
retired moderator
it sounds like you have a bad ground. Try running a ground wire directly to a frame piece behind the dash.
Also, the Bose setup uses a 2 ohm system, while the non-bose is 4 ohm, IIRC...
Old Oct 1, 2006 | 12:34 PM
  #188
AceofSpds's Avatar
wat
I belive you are going to have to dye your headliner
Old Oct 2, 2006 | 07:43 AM
  #189
Nineleven
What size tires are most of you running, standard being 225/50/17?
Old Oct 2, 2006 | 09:55 AM
  #190
Succinct's Avatar
Did you check out this page:
http://search.yahoo.com/web/advanced...r=fp-tab-web-t
Not trying to be a wise-guy, I just don't think you'll get many responses from the seasoned players on this newbie thread regarding such a topic. It's prolly been discussed. I'm interested in the answers as I am running bone stock too, but feel a 235/45-17 size would yield many more hi-perf tire options. Good luck!
Old Oct 2, 2006 | 06:13 PM
  #191
Old Oct 2, 2006 | 07:35 PM
  #192
Can nobody answer my fuel filter question I asked earlier on page 6 i believe?
Old Oct 2, 2006 | 07:46 PM
  #193
irish44j's Avatar
retired moderator
On my browser, I'm only on page 5 right now. Please repost your question down here.
Old Oct 2, 2006 | 07:47 PM
  #194
Succinct's Avatar
Good Q - all I found on the FAQs/How-Tos was wiring the detector via running wire under the A-pillar and tapping into 12V somewhere under the dash. I guess no one in that thread had an auto-dim mirror.
I have that mirror, but I live in the Draconian state of Virginia, where the state flagrantly violates the Federal Communications Act of 1935 (or was it 1933?) by prohibiting people in Virginia from receiving police radar signals, so I have no radar detector, nor any hope of ever having one...
Old Oct 2, 2006 | 07:54 PM
  #195
irish44j's Avatar
retired moderator
I'm happy we don't have them. I'm going 80 on the highway and people are still blowing by me. I always hope those people get tickets
Old Oct 2, 2006 | 07:55 PM
  #196
irish44j's Avatar
retired moderator
pm soonerfan, he has his radar hardwired and hidden in the sunglass holder. Oh, and he lives in VA (but has Oklahoma tags)
Old Oct 2, 2006 | 08:12 PM
  #197
Hillsboro Max's Avatar
"Can't Tell Me Nothin"
Trunk Problem
Crossbar that holds trunk open somehow popped off.....easiest way to get this fixed?
Old Oct 2, 2006 | 08:21 PM
  #198
SEmy2K2go's Avatar
Go BUCKS!!!
"Pop" it back on
Old Oct 2, 2006 | 08:45 PM
  #199
Not as easy as it sounds!
Old Oct 3, 2006 | 06:13 AM
  #200
DJ Kaanco's Avatar
ok so i wanna trade my car for a maxima se. question is...what is the difference from a 2000, 2001, 2002 and a 2003 se.
i know some people will say to just jump on a 2003. but i still have a lease on my car and i will be trading it in to nissan so i need to know why the big price difference. like can i jump on a 2001 instead of a 2003. is the body different in all 4 yrs?? the engine?? what makes them so different other than the years.
thanks!
