5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old May 29, 2007 | 06:17 PM
  #2161
choopster's Avatar
NEED HELP...My 01 maxima is throwing P0505 - Idle Air Control Valve / Auxiliary Air Control Valve. also something fried last nite. I hope it didn't fry the ecu. can anybody tell me the location of the ecu.
thx
Old May 29, 2007 | 06:50 PM
  #2162
sirjinx21jay's Avatar
My Car Keeps Throwing A P0420 Code
Hey Guys,
I have a 2000 SE Max 94,450 miles on it and the other day the car threw a P0420 code but this is not the first time it has done this....... Should i be worried cause the first time it threw up a P0420 code i bought this stuff CRC Guaranteed To Pass complete fuel system cleaner and after like 300 miles the light went off on its own..... and then one day it came back on so i took it to Auto Zone and it was the same code and then when i was started the car to leave Auto Zone the light was off again....... Now on Sunday the check engine light is back on but i did not get the code read cause i think that its the same code....... What should i do?
Old May 29, 2007 | 07:14 PM
  #2163
irish44j's Avatar
retired moderator
Originally Posted by sirjinx21jay
Hey Guys,
P0420 is usually associated with a bad 02 sensor
Otherwise, it could be:
1)a bad main cat<~~doubt it.
2)exhaust tube<~~leaky y-pipe/flange
3)intake air leak<~~stillen intake
4)injectors
5)injector leak
6)spark plug<~~depends on mileage
7)improper ignition timing<~~doubt it.
BTW, it's always a bad idea to dump anything into your fuel system when you don't know what the problem is...
Old May 29, 2007 | 09:49 PM
  #2164
BhB's Avatar
BhB
Originally Posted by JimmyH
They sell some on ebay still I think, though they are halogen. You can buy xenon projectors, that with a little work, will replace the halogen projectors. It will still cost probably near what the oem Nissan housings cost. Personally I prefer reflectors (oem) over projectors. Projectors have too sharp a cutoff, and while wide, have a short beam path.
If you search here on ebay and projectors, you can find some info; here is one thread:
http://forums.maxima.org/showthread....bay+projectors
But do the world a favor, and dont put xenon upgrade lights into halogen housings. They are not designed for it and you will blind everyone in front of you.
Yeah I'm not really looking to blind anyone...So reflectors are what come in 02-03 Maximas? Thats really all I'm looking for I think...Is there a noticeable amount of light difference between Xenon projectors and the OEM reflectors?
Also, how hard is it to paint the housing on an OEM HID.
Old May 30, 2007 | 08:03 AM
  #2165
4)injectors
5)injector leak
Thanks.......... But i was goin to try and do the Seafoam thing before all this started happening again, i think that it may be the spark plugs (i hope) cause i have yet to do the 90 000 mile schedule maintenance.......... so when i can get the car to someone trustworthy i will get it done but no one in the DC area i think is trustworthy or they are but they want a arm and a leg and i cant do that cause i a college student.........But thanks for the help though.....Any suggestions.......
Old May 30, 2007 | 10:24 AM
  #2166
JimmyH's Avatar
Seafoam... I cannot abide by anything that makes your car look like a five-alarm-fire.
Old May 30, 2007 | 10:45 AM
  #2167
JimmyH's Avatar
Yes, you have seen the difference. Reflectors are the chrome plated "bowls" that the bulbs reflect the light off of and onto the road. Projectors are those small, glass "camera-lens" style units that focus light directly from the bulb onto the road.
I suppose it depends on what cars/headlights you are talking about. I much prefer the reflectors in my Maxima over the projectors in my CTS-V. The CTS just has this sharp cut-off that makes you feel like you are driving into a void. The Maxima has nice gradual falloff, so even things beyond the beam path get an ever-so-slight amount of light. The CTS has a brighter, wider beam path, but that just seems worthless to me. By the time something makes it into the ultra-bright area right in front of your car, it is too late to react to it. And other than a stray deer, I am not interested in looking at side of the road scenery at night. Of course if you are just looking for range, you are better off staying with halogen lights.
To paint the oem housings, you would have to remove everything (wiring harnesses, bulbs, hid compartment cover, hid ballast, hid starter) then stick the whole thing in the oven to soften the sealant so you can separate the clear front from the black back. Or you could use a heat gun around the seam, but that would take alot of labor on your arms.
It's been a while since I did it (to clear the turn signals and install angle eyes, then again to remove the angel eyes after one came apart, I did not paint mine) so I dont remember the right temp. Search, but probably about 200 or so for 10 min or so. Just enough so the sealant is soft. Then you have to pry the two halves apart. I would use heat resistant engine paint. I am sure the lights make it hot in there, and in case you ever have to take the housing apart again so the paint will stand up to the oven.
Old May 30, 2007 | 04:26 PM
  #2168
gbwillner's Avatar
Originally Posted by gbwillner
I live in Houston and I'm tired of idiot drivers slamming their Lincoln Navigator doors into my car and scratching up the paint. Luckily, most of the damage is on the passanger side doors, over those door bumper things. I have a 2002 metallic grey GLE. Is there any way to replace this piece without having to repaint the car?
Also, does anyone make chrome versions of this piece? I think that would look sweet with the chrome lining around the windows... and would take the punishment a little better...
bump? anyone?
Old May 30, 2007 | 06:03 PM
  #2169
FRZ251's Avatar
Hello everyone, I am excited to join the forms. My 03 SE is pushing two codes reading : "Small leak in EVAP system" and other code reads : "Check EVAP small leak detected". We replaced the gas cap and erased the codes and it stayed off for a while but then a week later engine light came back on. Any Ideas to what is leaking? I heard something about blowing charcoal out of the EVAP cannister but am not sure what that means. Thanks everyone.
Old May 30, 2007 | 06:17 PM
  #2170
GigEmAgs07's Avatar
so lately my max is havin some trouble when in park. It struggles to say alive, and will sometimes drop down to 200 rpms or so and survive, other times it will die. Either way, it's just not convincing. When stopped at red lights, it doesn't seem to be as smooth as it once was, and maybe it's in my head, but the engine seems to vibrate more than it used to. MAF? any ideas welcome, tia.
Old May 30, 2007 | 06:27 PM
  #2171
irish44j's Avatar
retired moderator
what is the specific code it is throwing (i.e. p0120 or whatever)?
Old May 30, 2007 | 06:28 PM
  #2172
irish44j's Avatar
retired moderator
Sounds like an IACV problem. Does the car run fine when you're on the gas?
if it is rough when accelerating as well as when at idle, it could be:
- transmission/clutch problem
- MAF problem
- bad coil causing a misfire.
If it is just rough when idling, it's probably the IACV.
Old May 30, 2007 | 07:21 PM
  #2173
JimmyH's Avatar
I think the reason no one has answered is your question is it does not make alot of sense. Why would you have to repaint your car if you are just going to replace the door trim? And why replace it? Just buff it or repaint it.
And while chrome over metal is pretty durable, I dont know if the same is true of chrome plating on plastic. What makes chrome so durable is the fact that it is a very hard metal. If bends even slightly, it will crack. Chrome alloys are much more malleable, but I dont know what exactly chrome plating consists of.
Old May 30, 2007 | 07:47 PM
  #2174
vansskaterfreek's Avatar
hey guys, i'm new to the 5th gens.. used to have a few 3rd gens before, well i have a question...... my 01 SE 5 speed just threw an air bag light on today, and i'm wondering if there is a common problem with these cars on certain parts???? thanks guys! Doug
Old May 31, 2007 | 12:06 PM
  #2175
gbwillner's Avatar
Thanks for the response- You actually answered my question. Does anyone know where I can get the stock paint to fix the door trim?
Old May 31, 2007 | 12:55 PM
  #2176
JimmyH's Avatar
You can get touch up paint at auto parts stores. They usually dont have a very good selection for imports though. Your other option is the dealer. Or go to courtesyparts.com to get some. They are a little cheaper, and saves you a trip to a dealership.
Old May 31, 2007 | 05:52 PM
  #2177
macnolias's Avatar
Well I was reading the post on the oil catch can http://forums.maxima.org/showthread.php?t=469585 and was wondering if any of you guys went ahead and bought an official oil catch can which would be bigger and less frequent trips under the hood to pour the thing out? I bought the setup at home depot and the catch is very small and I'm not looking to drain the ting out every two gas fill ups.
Old May 31, 2007 | 07:34 PM
  #2178
PandaXpress's Avatar
OK...i just need to make sure (100%). Will a 5th gen exhaust fit a 5.5 gen?
Old Jun 1, 2007 | 08:48 AM
  #2179
aamir's Avatar
Hey guys,
I have an 02 Maxima 6 speed with 54k miles. Recently a noise has arisen whenever I start the car and drive it. I believe it is coming from the driver side in the engine bay and seems to be going in a circular motion. I know this sounds vague but I think it might be the clutch. If anyone can help me with this, I would greatly appreciate it. Thanks
Old Jun 1, 2007 | 09:00 AM
  #2180
ManUtd18's Avatar
Originally Posted by aamir
Hey guys,
I don't think it is the clutch or else you would feel it. Describe in detail what the noise sounds like.
I might be a heat shield somewhere but I'm not sure though. Need more detail.
Old Jun 1, 2007 | 09:25 PM
  #2181
aamir's Avatar
Thank you for the reply. It is a rattling noise that occurs when I let off the gas in any gear or when I push the clutch in. It also happens when I accelerate, but not as loud. Maybe I should check the oil level to see if the car needs oil. Any help would be appreciated. Thanks
Old Jun 2, 2007 | 09:11 AM
  #2182
JimmyH's Avatar
CV joints maybe? They were making noises on my 97.
Old Jun 2, 2007 | 10:01 AM
  #2183
DonS's Avatar
Tachometer problem
Howdy,
My car's a 2K with a 5spd transmission. Just had the tranny rebuilt (diff bearings shot at 81k and here's me giving the finger to Nissan!) and the car came home yesterday. Now, the tach won't go past 3100 rpm. Engine spins fine, but the tach just stops dead at 3100. Could be my imagination, but the car doesn't feel quite as strong as before. No CEL and the engine sounds smooth...again, the power-loss thing may not be real.
Sure, it could be that the tach just needs to be changed...and that won't be a problem if need be as the one if there now isn't the original; it's an SE tach I put in a few years ago...but I'm wondering if the problem isn't the tach itself, but related to the work done on the tranny. Something to do with a sensor, perhaps.
Or, could just be that needle is sticking; it's currently quite warm and muggy here in upstate NY.
Anyone with any ideas, please chime in.
Thanks!
D.
Old Jun 2, 2007 | 11:51 AM
  #2184
machinehead131's Avatar
Originally Posted by DonS
Howdy,
Thanks!
D.
Try replacing your MAF
Old Jun 2, 2007 | 12:31 PM
  #2185
DonS's Avatar
The MAF in there is only 2 years old. All 6 coils have been changed, too.
Is their a correlation between the MAF and a finicky tach?
Thanks,
D.
Old Jun 2, 2007 | 01:28 PM
  #2186
Thanks,
D.
Eh. Go to autozone/advance auto and get codes pulled, post em up and we can know for sure what it is.
Old Jun 2, 2007 | 02:56 PM
  #2187
NmexMAX's Avatar
dot dot dot ...
Thanks,
D.
I would further investigate. i.e.e take the dash assembly apart and see/verify if it IS sticking. If it is, then I would get a new assembly.
The tachometer gets its reading from the ECU(crank sensor). I wouldn't think the tranny work would affect it. If anything, IMO, the tranny work would affect the speedometer before the tach.
Old Jun 2, 2007 | 08:40 PM
  #2188
replicant's Avatar
how much do you think you all have spent, total, for your current mods (excluding car audio, alarm, tint, sound deadening). i'm sure those of you with superchargers or nos have spent a lil bit more. i'm just curious what i should be budgeting for the most common mods. i know "common" is a subjective term, but i just want some sort of ballpark. i'm mostly looking to do the basic suspension stuff: FSTB, RSB, eventually do a modest drop (something like 1.5/2 finger wheel gap), CAI, eventually full exhaust, and of course all of the lighting mods (interior and exterior), powerslotted front and blank rear rotors and new brake pads, lastly i'm already dropping about 3 large on some body work and paint job. i'm sure the cost also depends on GD's you've been involved with, ebay deals, etc etc.
thanks for the roundabout dollar amount info.
Old Jun 2, 2007 | 10:39 PM
  #2189
CoolMax's Avatar
is invisible
that's a newbie poll question, but i've spent about $2k
Old Jun 2, 2007 | 11:03 PM
  #2190
NmexMAX's Avatar
dot dot dot ...
2k... cripes. I'm about 2.5x that with all my damn wheels and such.
Old Jun 2, 2007 | 11:25 PM
  #2191
replicant's Avatar
hrm, ok 2k i can live with. 2.5x that? yeah thats gonna suck. wheels will prolly be my last purchase. i'm more concerned with handling and a few exterior mods right now. i've got the standard k&n drop in air filter for now (big whoop right?), then i'll move onto a CAI setup (with comes the huge amount of research to figure out which one is the best, why does it have to be so hard to decide on these things????!?!?!11). anyway, yeah i figure i'll keep this car until she dies (or until i win the lottery and get that bmw m3 i've always wanted), so i might as well put some extra cash into her to bring her back to life (she's been stock since the day i got her back in 02).
thanks again.
Old Jun 3, 2007 | 09:44 AM
  #2192
DonS's Avatar
Makes sense. Thanks!
D.
Old Jun 3, 2007 | 12:23 PM
  #2193
macnolias's Avatar
I figured my post might be read here for fast feedback so my appology for not posting in the right place.
So I installed the oil catch can on my 2k2 max and something is messed up.
My car is taking 10-15 cranks for a cold start instead of the usual 2-3. I turn the car off and let it sit for a minute and it's taking a consistent 7-9 cranks to start. Any idea on what could be causing this?
I just put the setup back the way it was before and it's still the same. I did notice that I didn't move to O-ring from the old PCV to the new one which I did also just now.
Will it take the CPU or whatever time to adjust back to the way it was before?
Any help is greatlyyyyy appreciated.
Old Jun 3, 2007 | 12:55 PM
  #2194
NmexMAX's Avatar
dot dot dot ...
Double check all connections to and from your catch can. Seems as if something occurred during the install/reinstall.
The ECU doesn't need time to readjust, something went wrong.
Old Jun 3, 2007 | 01:08 PM
  #2195
macnolias's Avatar
I put everything back the way it was but with the new PCV valve. It's kind of embarassing how long it's taking to start.
One thing I'd like to add is that I heard something very small and metal fall during the install right near the PCV valve. It wasn't any of the clamps and everything looks normal in the area of the instalation.
Helppppp
Old Jun 3, 2007 | 01:10 PM
  #2196
NmexMAX's Avatar
dot dot dot ...
Is your MIL on? How does it idle?
Old Jun 3, 2007 | 03:27 PM
  #2197
macnolias's Avatar
No MIL light and it purs like a baby. Is it possible for a vacuum leak? Also I is there a way to do a member find to see if anyone is close by with an 02-03 max? I just want to listen in the general area and see if something on mine doesn't sound the way it's supposed to.
Old Jun 3, 2007 | 04:59 PM
  #2198
slickrick's Avatar
I live in FTL...but I have headers + b pipe.
Old Jun 3, 2007 | 05:04 PM
  #2199
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/forumdispla...sprune=-1&f=22
Old Jun 3, 2007 | 05:51 PM
  #2200
macnolias's Avatar
The find members has been disabled by the administrator
