5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Dec 11, 2007 | 12:59 PM
  #4161
02Maximan's Avatar
Originally Posted by NmexMAX
to Kyle00, and to add:
In the case of a muffler, the stock unit has proven itself and it can support up to 250fwhp, so, unless you're putting down more, or have not been able to break 250 with it, I wouldn't worry.
If you have read some of my previous threads on questions about installing a flowmaster on my car you will know that I installed the muffler for sound purposes ONLY. (refer to the post below, it sums it all up) I'm just wondering why my top end seems less substantial than before. I was wondering if the flowmaster actually flows less at high rpms than the stock? I did change my intake setup : I swapped out my WR midpipe and replaced it with the stock resonator. Would this explain the loss of top end?
If you want power, get headers, nothing more. If you want tone, get a b-pipe, if you want sound, get a muffler, if you want rasp, get a test pipe, if you want noise, get all of the above.
Actually I got more tone than sound with my flowmaster 50 deltaflow btw.
Old Dec 11, 2007 | 01:02 PM
  #4162
NmexMAX's Avatar
dot dot dot ...
Unless you dyno'd said set-ups, or took MAF data, no one can answer that question.
Well, that's what I experienced.
But good for you, do you want chocolate chip, or peanut butter?
Old Dec 11, 2007 | 03:51 PM
  #4163
ATX02SE6spd's Avatar
Originally Posted by kgallerie
I would tend to doubt that its your clutch. 107 k isnt that much for a clutch these days unless its been driven really hard.
I have the same hesitation that you do. My buddy who is a mechanic at nissan is going to update my software per the TSB and see if that helps the problem.
It will probably be just after the holidays and I can let you know how it works.
Thanks man, I would really appreciate it. I'm thinking you're probably right as to the cause. Are you replacing your MAF per the TSB?
Old Dec 11, 2007 | 07:03 PM
  #4164
cefiro80's Avatar
Originally Posted by Kyle00
There are no significant power gains from adding a muffler on our cars. They flow fine.
Old Dec 11, 2007 | 07:08 PM
  #4165
wyche89's Avatar
Have someone who really knows what to look for look at the car. If you want the car that badly, thats what I'd do. I'm guessing this is a dealer your buying from?
yeah, it's a dealer.. i don't think i have anybody like that.. however.. from my understanding and experience, you make sure the frame is aligned straight, and look to make sure the gaps between the hood and the panels are smooth, and that no engine parts are painted.. is there anything else i should look for? (my girlfriend's car was in a wreck and fixed up EXTREMELY poorly.. that's how i know to look for all that stuff)
Old Dec 11, 2007 | 07:24 PM
  #4166
kukx30de's Avatar
Does anyone know why the search through google doesnt work anymore?
I have a rather peculiar problem. 01 gle auto 157k.
The car idle drops when i put her in reverse, there is some vibration in the steering but no vibration through the seats or pedals. In drive the car appears to idle closer to 600 than 700. and in reverse drops under 600 but not very close to 500.
I am wondering if i need to clean the MAF, throttle body? i have never done that before.
no codes... fresh auto trans fluid drain+fill .. oil change due in 800miles... all other maintenance has been done...
Old Dec 11, 2007 | 07:36 PM
  #4167
OOmaxSE's Avatar
What browser are you using? If it’s FF, try opening the thread using IE.
I'm running Safari/Firefox on OS X Leopard, I'm trying to configure various settings tho
... this might be a tough one
Old Dec 11, 2007 | 08:14 PM
  #4168
rroderiques77's Avatar
Demodded and Forgotten
Running lean...
Anyone heard of or used Techno Square for tuning? Mine runs lean because of intake and exhaust mods.
Old Dec 11, 2007 | 08:18 PM
  #4169
SoonerFan's Avatar
Cletus
techno square isnt for tuning. its a reflashed ECU.
this is for tuning http://www.uprev.com/index.html
Old Dec 11, 2007 | 08:39 PM
  #4170
NmexMAX's Avatar
dot dot dot ...
How do you know you’re running lean? Do you have an AFR readout prior to any catalytic converters?
You’re probably running rich, either way, TS is a cookie cutter ‘tune’. Get it(TS reflash) if you have the $$ and don’t really want to dive into changing/monitoring ECU/engine parameters yourself.
Old Dec 11, 2007 | 11:24 PM
  #4171
spdfreak's Avatar
Our cars run rich, and I highly dought you are running lean from the intake and exhaust. If you are indeed running lean, there is a possibility that something is wrong with your MAF, fuel pump...I'm sure you see where i'm headed...
Old Dec 12, 2007 | 01:15 AM
  #4172
DasYears
Originally Posted by soonerfan
this is for tuning http://www.greddy.com/products/displ...SubCategory=47
this is for watching http://www.uprev.com/index.html
Old Dec 12, 2007 | 12:26 PM
  #4173
spdfreak's Avatar
Originally Posted by DasYears
Apexi makes the SAFC II, VAFC II and the new Neo.
Read this: http://forums.maxima.org/showthread.php?t=334314
Old Dec 12, 2007 | 07:48 PM
  #4174
I know because I had the vehicle dynoed. It's definetely lean.
Old Dec 12, 2007 | 07:49 PM
  #4175
Wouldn't a faulty MAF or FP throw a code?
Old Dec 12, 2007 | 07:51 PM
  #4176
I tried using the NEO. The '02 Maxima has some sort of electronic idle control. The NEO did not work.
Old Dec 12, 2007 | 07:52 PM
  #4177
Have you even heard any feedback from TS?
Old Dec 12, 2007 | 07:54 PM
  #4178
NmexMAX's Avatar
dot dot dot ...
I’m guessing you didn’t connect it correctly. Stop being so vague, give greater details. We all know 02+ are electronic throttle, not a big deal, i have an AFC and it works fine, give more details to back your claim. And no, an incompetent installer is no excuse.
Old Dec 12, 2007 | 08:04 PM
  #4179
Thanks for the tip. I'll try another installer...
Old Dec 12, 2007 | 08:24 PM
  #4180
DasYears
i also have one installed, along with many many members here. if you get it installed correctly it will work. dont forget to cut the MAF wire
Old Dec 12, 2007 | 08:26 PM
  #4181
It looks like Uprev reflashes as well
Old Dec 12, 2007 | 08:27 PM
  #4182
DasYears
not for our cars
Old Dec 12, 2007 | 08:35 PM
  #4183
NmexMAX's Avatar
dot dot dot ...
There’s only one true aftermarket ‘performance oriented’ ECU reflash for our cars, and it is Technosquare.
Also, the context for which you used the term reflash in this post:
implies that you consider an AFC a reflash, and that is incorrect. An AFC is not a reflash.
not for our cars
This is correct, it can only be used on 350zs/Titans/G35s. It has not yet been tested on 6th gen Maximas yet, and will not work with 5gens (or 5.5 gens).
Old Dec 12, 2007 | 08:41 PM
  #4184
NmexMAX's Avatar
dot dot dot ...
Explain feed back? I have a TS ECU, so, is that feedback? Need ………… more……….descriptive…………posts.
Also, how lean was it, and was your AFR reading taken BEFORE your catalytic convertors?
More than likely.
Old Dec 12, 2007 | 08:55 PM
  #4185
What do you mean explain feedback? Feedback means the return of information about the result of a process or activity. You have a TS ECU. So, you sent your ECU to TS for a reflash. Upon getting it back, you tuned it by hooking up an AFC to it?
Last edited by rroderiques77; Dec 12, 2007 at 09:29 PM. Reason: to make less vague
Old Dec 12, 2007 | 08:58 PM
  #4186
There are no cats. I removed all the cats when I installed the headers.
Old Dec 12, 2007 | 09:14 PM
  #4187
As soon as I find the results, I'll let you know.
Old Dec 12, 2007 | 09:33 PM
  #4188
Here are the dyno results: whp 190.32 wtq 197.56
AFR fluctuated around 15.
Old Dec 12, 2007 | 10:51 PM
  #4189
DasYears
what type of dyno? was the AFR taken using a tailpipe sniffer or WBO2 before the cat?
Old Dec 13, 2007 | 06:31 AM
  #4190
NmexMAX's Avatar
dot dot dot ...
TS Feedback:
http://forums.maxima.org/showpost.ph...79&postcount=6
Old Dec 13, 2007 | 09:07 AM
  #4191
wyche89's Avatar
anybody?
Old Dec 13, 2007 | 09:09 AM
  #4192
merlin2375's Avatar
/\/\ I think you've pretty much got it all, does the dealer happen to know where the body work was done, any records of it? Reputable body shops warrant their work for a long time.
Old Dec 13, 2007 | 10:34 AM
  #4193
NmexMAX's Avatar
dot dot dot ...
anybody?
You paranoid maxima.org member. You've got it covered.
Old Dec 13, 2007 | 10:35 AM
  #4194
Kyle00's Avatar
WSH for teh cup
anybody?
I think your safe with looking for those things
Old Dec 13, 2007 | 11:11 AM
  #4195
MoeBelikeMax's Avatar
anyone have the headlight swap thread
Old Dec 13, 2007 | 11:45 AM
  #4196
wyche89's Avatar
lol.. thanx guys.. i'm goin to look at the car tomorrow.. wish me luck
  #4197
NmexMAX's Avatar
dot dot dot ...
Read the stickys, most namely the one entitled:
http://forums.maxima.org/showthread.php?t=543973
Then go to the How To Sticky, and locate the post you want, here it is:
Hit control F, and type in: HID, after you scroll down a bit, you’ll be here:
http://forums.maxima.org/showpost.ph...0&postcount=38
Now apply what you learned by reading the first sticky/link I provided, and you get this:
http://forums.maxima.org/showthread.php?t=47646
Next time, I won’t be so nice, so, my advice:
Take some time to read the firs post of this thread, and while you’re at it, read stickys.
Old Dec 13, 2007 | 11:46 AM
  #4198
tailpipe.
Old Dec 13, 2007 | 11:47 AM
  #4199
NmexMAX's Avatar
dot dot dot ...
tailpipe.
Have you removed your main cat? Under the car? The header system only removes the pre-cats, so unless you have replaced the stock cat with a test pipe, you still have a cat. And a cat back does not replace the stock main cat, so that would rule it out in that case too.
Old Dec 13, 2007 | 11:49 AM
  #4200
Old AFCs are discontinued according to Apex. The old units were replaced by the NEO, which is more "universal" and will not work for our cars according to the company. Sounds like I need to find an old AFC on ebay or something.
