5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old May 16, 2007 | 09:38 AM
  #2081
SoonerFan's Avatar
Cletus
Originally Posted by hotjiggaman
can you mix the bosch n 02stock sensor together? or replace all 4
just change the one(s) that need(s) to be changed
Old May 16, 2007 | 09:48 AM
  #2082
hotjiggaman's Avatar
my car need new brake pads . it been stock ever since(2000-2007) including the brake disc. should i go with the stock pad at the dealership or is there other pad out that are good for my car? i see ppl are choosing the hawk hps is that better than the stock? also what type of Brembo brake disc to use cause there are alot of type?
  #2083
SilverBulletGTP's Avatar
Okey, I'm a total newbie to Maximas. I have a modded Grand Prix GTP right now and I'm looking to buy a 5th gen Maxima as a daily driver. I have a few questions.
-I will most likely be buying an 02-03 with the 3.5 engine but if I find a good deal on an 01 I'll settle with it. Is the 3.0 engine any less reliable than the 3.5?
-I'll probable be buying one with a stick shift, but again if I find an automatic for the right price. How reliable are the auto transmissions in these cars?
-Any silly annoying common problems with these cars?
Thanks.
Old May 16, 2007 | 09:54 AM
  #2084
machinehead131's Avatar
Thanks.
The 3.0 is known to be more reliable in a sense. The 3.5 has been known to burn oil but both motors good. MAF sensors go bad on 02's sometimes, coilpacks go bad. Others will add more.
Old May 16, 2007 | 12:00 PM
  #2085
bwinter7's Avatar
Originally Posted by NmexMAX
Cable? Do you mean coil?
Need details of this. Are you sure you didn't get water into anything?
This means you have a misfire(multiple cylinder).
Why not check the 3 rear?
This portion of your post seems to point to a MAF problem.
Check the cam sensor (specs)
They may have already been bad.
Stop with the theory making and just check and see what codes are popping up.
Let me say I am a dumbass for refering to the coils as "wires". To be honest, none of my other VQ's ever had any engine problems. I changed the oil, plugs, filters, O2 sensors on my 01, but that was it.
No, I didnt spray my engine down, I just had a damp rag and wiped the engine cover, and the air intake. I made sure not to touch any wires or plugs.
I didnt check the 3 rear coils because it was already 11:30pm and I wouldve had to take off the manifold and collectors, which I didnt have time for. Plus, I didnt touch them in the first place, so I didnt think that was the problem.
The codes I pulled were
1- Multiple cylander misfire (pending)
2- Timing overadvanced (Bank 2 )
3- Camshaft sensor
4- Vacuum leak (Large)
*That was a cracked gas cap, which I replaced
But now, none of the codes are pending, and the idle is smooth. Is it possible that by me resetting the ECU that the computer is now compensating for the misfire? I thought that was a long shot because I dont think that if I was only producing power with 5 cylinders, that It would run as smooth as it does now at idle and under acceleration and highway speeds.
Old May 17, 2007 | 04:04 PM
  #2086
bwinter7's Avatar
3- Camshaft sensor
Never mind guys, (and gals ) Today my ses light turned itself off and the car runs great. Maybe it was the humidity when I did all this, because about 5 min after I plugged everything back in and went on my way, It started pouring like hell. Either that or it was the Magical Maxima Fairy who fixed it......
Old May 18, 2007 | 08:45 AM
  #2087
hottmaxx2003's Avatar
LED Interior Lighting...
I am looking for LED bulbs for a few things in my interior, but i am having a hard time locating the model numbers... I have looked up almost every lighting application guide, but still no help. When i call or go to a Nissan dealer, they just give me an internal part number... no help!!!
can anyone else help???
These are the ones i'm looking for...
1) ashtray light
2) glovebox light
3) sunvisor/vanity mirror lights
4) front map lights (not the dome... already got that one)
5) instrument cluster/dash lights & how many are there???
HELP!!!
Old May 21, 2007 | 10:05 AM
  #2088
Bufflomike's Avatar
Sexier Than Simpson
Bump for front page
Old May 21, 2007 | 10:56 AM
  #2089
BMWHIGH1's Avatar
Can anyone please tell me if if there is someone/place where i can have my angel eyes done, i'm talking about the ones were you have to baked the headlamps and all that good stuff. Anybody in Northern New jersey. A place that doesnt cost an arm and a leg, i went to this place on route 22 they wanted like between $300 and $400 dollars for them. I've had this light sitting in my living room collecting dust for a year anybody please
Old May 21, 2007 | 12:49 PM
  #2090
macnolias's Avatar
One thing that I've been wondering in my two weeks of driving is if there's any simple ways to improve gas mileage? It's an 02 with 55k on it and I'm thinking about doing the fuel filter fairly soon and any other suggestions?
Second thing is the in-cabin microfilter. I took out the factory and cleaned it for temporary use. Would you guys suggest getting another factory filter (non-rubber edges) or go for the 2 piece filter? Also what does it mean by carbon activated? I did a quick search and found nothing that explains that one.
Old May 21, 2007 | 12:55 PM
  #2091
bwinter7's Avatar
It'll be a little easier if you have a 6-speed, just dont let the revs go above 2500 before you shift. I routienly go 45-50 in sixth and reset my trip computer, I get 31mpg (That's if it doesnt lie, which I think it does a little)
I dont know if the in-cabin microfilter would make a difference. But that is just my .02
Old May 21, 2007 | 04:06 PM
  #2092
CoolMax's Avatar
is invisible
Might have better luck in the regional forum: http://forums.maxima.org/forumdispla...aysprune=&f=15
Old May 21, 2007 | 04:11 PM
  #2093
CoolMax's Avatar
is invisible
Properly inflated tires, PCV valve, O2 sensors, clean air filter.
I just washed mine, per housecor's instructions: http://www.innerbean.com/housecor/cabin_filter.html
Old May 21, 2007 | 04:26 PM
  #2094
macnolias's Avatar
Well my filter is a little bit beyond the possibility of saving by a good cleaning. Anyone have any preference the straight up factory one or the two piece?
My kind warranty just replaced the 02 sensors which made a big difference. I'll go threw the other ones tommorow and see how they're looking.
Old May 21, 2007 | 04:45 PM
  #2095
irish44j's Avatar
retired moderator
the factory one IS a 2-piece....
Old May 21, 2007 | 04:48 PM
  #2096
SoonerFan's Avatar
Cletus
incorrect
the factory is one piece paper.
the replacement one you buy is two piece and carbon activated.
nissan decided the paper one sucked and started making a better one.
(i know, i just replaced mine yesterday)
replacement http://www.courtesyparts.com/Merchan...de=B7200-00005
Old May 21, 2007 | 05:04 PM
  #2097
JimmyH's Avatar
that "increased output" stuff is garbage. They are 60W bulbs and that's what they put out. You can't put out more than you consume! It's just a marketing ploy.
So to answer your question: yes, you will be fine with them and do not need a new harness.
Oh, they put out more, which is why the bulb starts melting after a few dozen hours of use.
But I agree with you, they are garbage. And blinding to oncoming drivers as well.
Old May 21, 2007 | 05:22 PM
  #2098
macnolias's Avatar
That's one hell of a price for it (high).
This might be one of the dumbest things I'm ever going to ask.
Do you think spraying cologne on it would affect the filters performance? lol
For those of us that like a certain smell during driving I'm wondering where I could spray to keep good flow of smell in the car to last the longest between sprays.
Old May 21, 2007 | 05:25 PM
  #2099
SoonerFan's Avatar
Cletus
i replaced mine and noticed the AC was blowing a lot better than it was before. the old one was very clogged.
Old May 21, 2007 | 05:28 PM
  #2100
CoolMax's Avatar
is invisible
Other people have done it, but "stale" cologne=
I just Febreezed it.
Old May 21, 2007 | 06:10 PM
  #2101
irish44j's Avatar
retired moderator
Originally Posted by soonerfan
incorrect
mine didn't come with one standard. All I've ever used is the 2-pc that I bought from Nissan.
Old May 22, 2007 | 01:17 AM
  #2102
YungmaxiOwna21's Avatar
Is it true that when i get out of my car and lock it via keyless entry and the blinkers flash twice there is a mechanical problem i need to discover?
Old May 22, 2007 | 04:56 AM
  #2103
Bufflomike's Avatar
Sexier Than Simpson
Mine does that normally. Not sure if there is a mechanical issue at all I thought it was normal. My 96 did the same thing. I believe you can set it to either flash twice or beep, but I am unsure how.
Old May 22, 2007 | 06:15 AM
  #2104
NmexMAX's Avatar
dot dot dot ...
That's true. Hold down the lock/unlock buttons on the fob for a few seconds to alternate between the 2. You can also roll up/down your windows by inserting your key into the door, and performing a turn & hold procedure. Where either direction either rolls them up or down. Try it and see.
Only for 02/03 models.
Old May 23, 2007 | 01:47 PM
  #2105
Bufflomike's Avatar
Sexier Than Simpson
Is 5th speed or 6th speed a direct gear
Are 5th and 6th countershaft gears or is 5th a direct mainshaft gear?
Old May 23, 2007 | 02:35 PM
  #2106
milek's Avatar
Engine Control Unit
Can some explain this ...
Here is the story:
10 minutes after I parked car I got smoke under the hood. I was afraid that whole car will burn but eventualy smoke stopped. Could not start the car.Towed to dealeship and they found that chip burned out on my EC module. I checked the price for ECU and it is more less same in different dealerships (around $900).
Also they mentioned that I have to replace part which is in charge for quiet/steady operation of engine itself (engine mounts my guess!?) and that this part caused all trouble shorting the wire and blowing the chip.
Does this story make a sense?
What could cause this? Is it just part got older or any other issues caused this? Is this usual problem on maximas?
I saw some wires on engine mounts:
http://market.autopartsfair.com/niss...ine_mechanical
Any info how this system works?
Thank you!
Nissan Maxima 2001 GXE
Old May 23, 2007 | 02:43 PM
  #2107
SoonerFan's Avatar
Cletus
talking to a service manager, he said that for some reason, electronic motor mounts burn out ECUs. he said they usually unplug them to prevent it and the customer cant tell the difference. when he installed my new ECU, he was gonna unplug them before he realized mine arent electric.
Old May 23, 2007 | 03:05 PM
  #2108
milek's Avatar
Hi Soonerfan. Thanks for respond! Do you have idea what is "some reason" . I think that this is completely stupid engineered if engine mount wearing-out could burn ECU!?
Old May 23, 2007 | 03:08 PM
  #2109
SoonerFan's Avatar
Cletus
he said he didnt know why but he has gotten cars with bad ECU and the motor mounts had gone bad.
Old May 23, 2007 | 03:21 PM
  #2110
macnolias's Avatar
Quick question I'm doing the whole 60k tune up (spark plugs, fuel filter, O ring, PCV valve, radiator flush, tranny fluid change, in cabin microfilter) and shopped around for spark plugs trying to find the best price. So going on a recommendation I found on the forum
http://forums.maxima.org/showthread....80#post2815980
I found some close to my house that I think is the right ones but not sure
http://cgi.ebay.com/ebaymotors/ws/eB...7554805&rd=1,1
Could someone lend me a hand and let me know if they are the same? If so it's one hell of a deal it looks like!
Old May 23, 2007 | 03:28 PM
  #2111
fastman's Avatar
I just got my loaded 2002 6spd LSD Maxima about a week ago and I have been loving every minute of it. This car has been a dream car for me since it came out and due to my sister totaling my Mazda6 (sis is ok) I know have my dream car. I plan on posting some pics of the car once I get around to detailing it. However in the mean time and have a few noob questions.
First what should I do if I want to make it bi-xenon. Do i need to buy a bi-xenon kit or will buying projectors just for the brights and keeping the OEM ones work. Also what size do i need?
Second I am thinking about getting the windows lightly tinted (35% gray/titanium) and was wondering how much it normally costs. I have a quote for 340 from a reputable place.
Finally one of the bulbs for the heated seat switch dose not work. What type of bulb/led will work and is there any guide on how to do it?
Thanks in advance and I look forward to being a part of this community.
Old May 23, 2007 | 03:41 PM
  #2112
bwinter7's Avatar
1. There are a couple of threads about the lighting kits, I do think they have different way's of doing it. The best way would be to get some ballasts and xenons, but that way, of course, is the most expensive way. If you do a search you should find plenty of info on the subject.
2. 340 sounds a little high, but if they are reputable, then I say go for it. Trust me, You get what you pay for when you pay for tinting But, of course there is a limit. I would ask what kind of tint they will be applying, and if they are really good, should have more than 3 types of tinting, not just color
3, I have no idea lol. I would never even think one of those things would ever burn out. I'm sure someone else knows....
Old May 23, 2007 | 04:12 PM
  #2113
SoonerFan's Avatar
Cletus
you need these
Old May 23, 2007 | 04:45 PM
  #2114
macnolias's Avatar
So nobody likes using the copper? I read the whole spark plug discussion and a few like the copper especially for the price, I was trying to economize the plugs a little bit so a no go on copper?
Old May 23, 2007 | 04:50 PM
  #2115
macnolias's Avatar
Also what kind of price did you find on the NGK?
By the way I ordered some of my maintenance stuff from Dave Burnette and everyone is right he's fast friendly and knowledgeable!
Old May 23, 2007 | 05:30 PM
  #2116
macnolias's Avatar
or even these?
http://advanceauto.shoplocal.com/adv...6StartRow%3d10
Old May 23, 2007 | 05:47 PM
  #2117
SoonerFan's Avatar
Cletus
has nothing to do with "liking". it has to do with using the correct ones for the engine.
Old May 23, 2007 | 05:49 PM
  #2118
SoonerFan's Avatar
Cletus
$57 for all six
http://www.courtesyparts.com/Merchan...=22401-00018P6
Old May 23, 2007 | 06:40 PM
  #2119
NmexMAX's Avatar
dot dot dot ...
Apparently I'm using incorrect spark plugs on my vehicle.
Old May 23, 2007 | 08:48 PM
  #2120
macnolias's Avatar
damn I'd imagine by 18,000 post you would've figured out which plugs to get by now?
well if you go ahead with the thread http://forums.maxima.org/showthread....80#post2815980 it looks like there's 3 choices for me
what kind of spark you using nmexmax?
