5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Oct 24, 2007 | 09:10 PM
  #3441
spdfreak's Avatar
Originally Posted by rocketsled
Does anyone have a supercharger installed on their 5.5 gen? Or are there any bolt on supercharger packages available for the 5.5 gen? i have an 03 SE 6spd, and want more power without using nitrous. Is there anyone out there running a custom supercharger setup on a 5.5gen? And could you let know know what info you guys have about the topic?
IIRC a 4th gen guy (I think the car is white) has done a 3.5 swap, and supercharged it. I think he used the unit deigned for the 3.0. I think it fits.
Check out the Advanced performance section.
Old Oct 24, 2007 | 09:17 PM
  #3442
NmexMAX's Avatar
dot dot dot ...
It's not that simple. The reason it worked is because he was using A32 timing equipment. If you use the stock A33B equipment, the CVTC covers get in the way. There is a kit in development but it's on hold right now for the next few months to a year.
So, as I stated earlier, there are threads on the FI forum for which you should read up on, extensively, before taking on such an endeavor.
Old Oct 24, 2007 | 10:04 PM
  #3443
spdfreak's Avatar
As you stated, it's not that easy. I reccomended he look there too.
Old Oct 25, 2007 | 06:40 AM
  #3444
NmexMAX's Avatar
dot dot dot ...
But giving an A32 swapped example is deceptive, that's my point.
Any A32 swapped 3.5L using A32 timing equipment can use existing hardware.
A33B timing equipment = custom, right now.
Old Oct 25, 2007 | 12:38 PM
  #3445
rony_espana's Avatar
TCS
So I see theres a lot of rules on what you can ask and stuff on this forum, but I'll try anyways...I did search but most of the results don't answer my question.
I just bought an 02 maxima SE 6 sp, fully loaded but it doesn't have the TCS button beside the steering wheel heater. Does this mean that I don't have TCS or that it just can't be turned off.
Old Oct 25, 2007 | 12:40 PM
  #3446
NmexMAX's Avatar
dot dot dot ...
TCS was not available in MT form.
Old Oct 25, 2007 | 12:49 PM
  #3447
Damn thats going to suck this winter!
Thanks, been looking for that info everywhere.
Old Oct 25, 2007 | 01:26 PM
  #3448
SoonerFan's Avatar
Cletus
the closest equivalent for the MT is HLSD.
i dont even have it and it isnt an issue in the winter. you just have to know what you are doing.
Old Oct 25, 2007 | 01:53 PM
  #3449
Kyle00's Avatar
WSH for teh cup
Just learn how to drive in the snow, etc and you'll be okay
Old Oct 25, 2007 | 02:03 PM
  #3450
So I guess you expected this question was coming....how can I tell if mine has HLSD?
I read in a thread that if the firewall sticker has RS6F it has HLSD, is this true???
Old Oct 25, 2007 | 02:08 PM
  #3451
SoonerFan's Avatar
Cletus
quickest way...look for brushed aluminum drilled pedals.
and yes, you can tell on the firewall...lemme search for the actual HSLD code
Old Oct 25, 2007 | 02:10 PM
  #3452
NmexMAX's Avatar
dot dot dot ...
It's in your effing sig IBitwasbeingsarcastic
RS6FS1H
Old Oct 25, 2007 | 02:12 PM
  #3453
SoonerFan's Avatar
Cletus
RS6FS1H
thats MY tranny code...i dont have HLSD
i knew it was the last digit but wanted to double check
Old Oct 25, 2007 | 02:13 PM
  #3454
NmexMAX's Avatar
dot dot dot ...
Hence the change to H
Old Oct 25, 2007 | 02:15 PM
  #3455
SoonerFan's Avatar
Cletus
i was 99% sure it was H...was double checking so i wouldnt be wrong. i found it and came back to post and you had replied.
bastard
Old Oct 25, 2007 | 02:20 PM
  #3456
NmexMAX's Avatar
dot dot dot ...
bastard
Wow, competing to help the 's.
I want a cookie.
Old Oct 25, 2007 | 02:27 PM
  #3457
Kyle00's Avatar
WSH for teh cup
I want a cookie.
You sure deserve one
Old Oct 25, 2007 | 07:55 PM
  #3458
Hey thanks a lot for the help guys, I checked that number when I got home and it has the H, so I guess I'm good to go.
Old Oct 25, 2007 | 08:26 PM
  #3459
SinGin's Avatar
Help, Got Check Engine Light Today
Last saturday I cleaned my throttle body and drove around for the day and the max ran fine. On sunday I filled up at Shell with 92 octane as normal. But on the way home I noticed that the idle was high and thought nothing of it.
But today I got the dreaded SEL light
Pulled codes P0550 and P0550
I kind of know what they are P0550= Power Steering Pressure and P0507=Idle Control System, Idle High. I did look for air leakes in the intake system and found none. Can it be bad GAS or did I F*%^ something up.
03 Maxima GLE with 40,000 miles
Old Oct 26, 2007 | 05:18 AM
  #3460
Kyle00's Avatar
WSH for teh cup
It's happened before for sure. Here are some threads that may be helpful. http://forums.maxima.org/showthread.php?t=315306
http://forums.maxima.org/showthread.php?t=383970
Old Oct 26, 2007 | 07:01 AM
  #3461
SinGin's Avatar
thank you for your help we will try that
Old Oct 26, 2007 | 01:56 PM
  #3462
drtybirdjo's Avatar
Annoying squeeky/grind noise
Ok so im a newbie and i do not know much about how to work on cars but i love maximas and have one. But i do know people who can do it for me. So I have this ridiculous squeeky noise coming from my front steering and everytime i turn left usually accelerating or braking(going no faster than 20 mph) it starts to do it and its pretty loud. Any ideas?
Old Oct 26, 2007 | 02:48 PM
  #3463
ChevelleRH's Avatar
Throttle Position Sensor
What is the resistance on a 2000 TPS(open/closed/etc)... Rpm drops to the point at which it almost stalls when coming to a stop, and is inconsistent when shifting. Ive replaced the MAF and have a service report for an IACV replacement, so I am going to try to adjust the TPS.
Old Oct 27, 2007 | 11:01 AM
  #3464
SinGin's Avatar
Help P0507 and P0550
See 5th post up.
Well I did the ECU Resetting Procedure, Accelerator Pedal Position Learing, Throttle Valve Closed Position Learing and the Idle Air Volume Learning (Throttle Position Learning)
Nothing has worked. Idle drops down during IAVL Procedure but, once restarted idle is back to around 1000RMPs. SEL is gone for now. Do I need to replace the Throttle Body???? Also can the P0550 code be causing
some of the problems. I did a search for the P0550 code and all of the treads go to the wrong subject. Anyone have a clue to how to fix this code(P0550)??? And what would cause it ???
Old Oct 27, 2007 | 11:25 AM
  #3465
NmexMAX's Avatar
dot dot dot ...
I left my battery unplugged for 36 hours and it is back to normal. ^^^
Old Oct 27, 2007 | 03:08 PM
  #3466
my03maxi's Avatar
i have a ? abt the forums
i dont know if it was ever asked or questioned or maybe even mentioned but im going to ask anyway.. how hard would it be to add the rss feature? i kno you can subscribe to a thread but would it be practical to incorporate it? i kno wats coming next -- a flaming by sooner but oh well
Old Oct 29, 2007 | 06:24 AM
  #3467
vball_max's Avatar
Fog Light Bulb Size
Newbie question that I am sure has been discussed but cannot find answer through search.....
Is H3 the stock fog light bulb size for the 5.5 gen? The owner's manual and every website I go to doesnt provide a size.
Any help would be appreciated.
Thanks.
Old Oct 29, 2007 | 08:19 AM
  #3468
Kyle00's Avatar
WSH for teh cup
Thanks.
yes, your bulbs are H3's
Old Oct 29, 2007 | 08:22 AM
  #3469
SoonerFan's Avatar
Cletus
for newbies with bulb questions...bookmark it
http://www.moodym.com/maxima/tech/maxbulbchart.html
Old Oct 29, 2007 | 08:31 AM
  #3470
vball_max's Avatar
Thanks for the bulb info guys.....Thats what i figure but wanted to make sure before I ordered them.....
Thanks for not flaming me sooner.....
Old Oct 29, 2007 | 08:47 AM
  #3471
SoonerFan's Avatar
Cletus
not in this thread.
this thread is to ask any question you want.
Old Oct 29, 2007 | 09:20 AM
  #3472
bigjoe87865's Avatar
The sunroof switch isnt working..
the first sunroof switch *the manual one/tilt* opens and tilts the sunroof w/o a problem....
but the automatic 5stage switch doesnt do anything....
am i looking for a fuse or something? since it aint the motor?
it was working a couple days ago....
Old Oct 29, 2007 | 11:38 AM
  #3473
alxarmanialx's Avatar
03 max
ok so after rewiring my fogs im getting a light coming up. i followed houscors instructions to a t... can anyone tell me if you have the same light pop up.
thanks...carmine
Old Oct 29, 2007 | 03:56 PM
  #3474
NJYTHRD's Avatar
REAR PASSENGER SOLENOID
MY PASSENGER REAR DOOR SOLENOID IS BAD. IT WONT UNLOCK.....WHERE CAN I GET ONE CHEAP AND DO I NEED A SPECIAL TOOL TO TAKE THE DOOR OFF?
THANKS IF YOU CAN HELP
Old Oct 29, 2007 | 04:01 PM
  #3475
NJYTHRD's Avatar
THIS HAPPENED WITH MY SUNROOF.....IT LASTED ABOUT 2 DAYS....HOW LONG HAS YOURS NOT WORKED?
IT SEEMED THAT I STARTED UP MY CAR ABOUT 8 TIMES DURING THOSE 2 DAYS AND IT RESET ITSELF....IT WORKS NOW WITH NO PROBLEM....STANGE I KNOW......I WAS LOOKING FOR THAT SAME FUSE IN ONE OF THE THREE OR FOUR FUSE BOXES THERE ARE.....
Old Oct 29, 2007 | 04:21 PM
  #3476
NmexMAX's Avatar
dot dot dot ...
thanks...carmine
I had a similar light as that one when my right rear brake lamp went out. Recheck your wiring.
Old Oct 29, 2007 | 06:23 PM
  #3477
03 max
i did .. i checked it 3 or 4 times jsut to make sure i wasnt doing anything wrong ..the thing is .. my taillights work .. and my fogs go on .. so y is there a light?? i mean i do live in ny.. and it was a ice cold morning .. do u think the weather could have affected the wire or splice point??
Old Oct 29, 2007 | 06:24 PM
  #3478
SoonerFan's Avatar
Cletus
switch need to be reset...from the owners manual
Restarting the sunroof sliding switch
The sliding switch will become inoperable after
the battery terminal is disconnected, the electrical
supply interrupted and/or some abnormality
detected. Use the following re-set procedure
to return sunroof operation to normal.
1. If the sunroof lid is open, push the tilting
switch repeatedly toward tilt DOWN to fully
close the lid.
2. After the lid has closed all the way, keep
pushing the tilting switch toward tilt DOWN
for more than 1 second.
Old Oct 29, 2007 | 06:42 PM
  #3479
02SE6MT's Avatar
please help! 2500 rpm rev, then shutoff
ok,my car is new to me (about 3 weeks) this being my second post i made sure i researched before i asked but my car just started the drop in power at 2500 rpm process. its more like a rev limiter , the engine just cuts off at 2500 rpm. is this a bad MAF sensor. ive had the CEL come on a couple of times but it goes off a few miles down the road everytime(not on now). if so how can i get in contact with dave b. im asking because apparently it could be the air temp sensor??? any reccomendations? and thanks to all you guys in advance. by the way this happened ONE time before about a week after i bought it and i just turned it off and on again and it was cured... this has left me puzzled...
Old Oct 29, 2007 | 06:45 PM
  #3480
SoonerFan's Avatar
Cletus
sounds like a bad MAF
call daveb
