Help!!!!! Key Ingnition Problem
Old Feb 19, 2007 | 04:26 PM
Tee00Max's Avatar
Someone please help this is killing me, this started yesterday when i put the key in the ignition, it wont turn or do anything, its not the steering wheel lock because i know what to do when that occurs but i mean i been wiggling and turning the wheel all day and and the key aint thought about turning so i was wondering what could it be, i mean sometimes i can get right in and turn the key and crack her right up and sometimes i gotta sit and wiggle it for like 30 damn minutes. help the car hasnt been moved all day...
Old Feb 19, 2007 | 04:39 PM
NisTech's Avatar
ignition lock cylinder seized. You have to replace that and code it by the dealer to match your keys.
Old Feb 19, 2007 | 04:45 PM
Tee00Max's Avatar
where do i even begin to do any of that???? do you know how much it will about cost???
Old Feb 19, 2007 | 04:48 PM
oldskooljdm's Avatar
sweet another greensboro maxima owner
Old Feb 19, 2007 | 04:49 PM
Tee00Max's Avatar
yea from the g-boro!!!!
Old Feb 19, 2007 | 05:01 PM
SoonerFan's Avatar
Cletus
http://forums.maxima.org/showthread.php?t=511261
Old Feb 19, 2007 | 05:02 PM
NisTech's Avatar
no clue bud. Few hundred $$ It's probably gotta be a special order item. Dealers don't stock those...
Old Feb 19, 2007 | 05:05 PM
Tee00Max's Avatar
alrighty appreciate it for everyones info....
Old Feb 19, 2007 | 05:09 PM
Tee00Max's Avatar
so its pretty much a no go for moving the car or even gettin it cranked up until i do this huh???
Old Feb 19, 2007 | 05:21 PM
Love_00_Max's Avatar
Wrong... Dude if you haven't seen the problem don't comment, just shut up.
I had the very same problem, it with the ignition key, get a locksmith, he will get the whole cylinder out and fix the ignition. Not all locksmiths can fix this, you need to call them and ask them if they can fix these kind of ignition keys.
I spent $200 for fixing it. The problem in my car was the first pin was screwed up.
Old Feb 19, 2007 | 05:23 PM
Tee00Max's Avatar
iight appreciate it Love 00 Max ill try that 2mara appreciate it....
Old Feb 19, 2007 | 05:40 PM
NisTech's Avatar
ouch! You mean there's an alternate route to fixing it. I'm sure there is.
BTW i think the first pin in your head is screwed up not your cylinder so don't tell me to shut up.
Also i've replaced a few of those myself just FYI so i did see the problem.
I am sure a locksmith could Re&Re your pins. It's their job after all
Old Feb 19, 2007 | 05:45 PM
NisTech's Avatar
Moving your car you could but just back and forth not actually starting it. If you wanna move it off the driveway there is a shift lock button on top of your gear shifter. It's got a cover remove it and just push a small screwdriver through that hole to get it out of park. So no P/steering
Can't start it though
DJLAX152
May 4, 2021 11:46 AM
maxinout93
Oct 16, 2015 02:53 AM
ajahearn
Sep 19, 2015 03:03 PM
jerrod99_se-l
Sep 19, 2015 06:54 AM
intimidator
Sep 5, 2015 07:23 PM
