Oh ****... Now ive done it..
Old May 10, 2007 | 10:11 AM
sypher's Avatar
I just finished replacing my radiator on my 2000 GLE. All was well. Everything woks great, then I accidently broke off one of the bolts that hold the radiator bracket (with rubber gromet) in place. So i decided it would be a good idea to drill a hole through the bracket and through the brace that runs in front of the radiator. Little did i know that the main wiring harness is tucked under that brace (a big 2 inch diamater group of wires). I just drilled straight through the wiring harness. Now i have the folloing problems:
One headlight is out.
One foglight is out.
Both interior dome lights are out.
All power door locks are not working.
Visor Mirror lights are out.
Keyless entry doesnt work.
The harness seems impossible to get to...
I'm screwed...
Old May 10, 2007 | 10:30 AM
AcidJake75's Avatar
Stealership time - bend over and get ready to take real nice like..haha..
UNLESS - you think you do the job yourself..I would call around and find out prices man..
that really blows...GL
Old May 10, 2007 | 10:50 AM
NYghettoGLE's Avatar
holy ****.
time to bend ovar!
Old May 10, 2007 | 10:57 AM
rmd0311's Avatar
Ouch... A good mechanic should be able to help. Dealership will be a pretty penny.
Old May 10, 2007 | 11:10 AM
gen4maxima536's Avatar
or spend countless hours pulling it apart and splicing all the wires back together.
Old May 10, 2007 | 11:31 AM
aw89maxSE's Avatar
Yeah man, that sucks. Good luck with that
Old May 10, 2007 | 12:04 PM
BLUEMAX01SE's Avatar
Oh chit mon, now you've done it!
Old May 10, 2007 | 12:13 PM
Rydicule's Avatar
Don't you know who I am?
Did anyone else just hear the stealership yelling "Cha-ching!"?
There it is again!
Sorry to hear about that bro
Old May 10, 2007 | 12:21 PM
mist max2000's Avatar
damn that really really sucks,... well.. i guess its time to get under there and red to red blue to blue yellow to yellow everything together or prepare to empty ur pocket
..at least you have 1 headlight and ur car still starts
Old May 10, 2007 | 12:27 PM
jeff5347's Avatar
do what gen4 said. Go to the junk yard and grab the harness. Disconnect your bat and spend a sat splicing. Maybe cost you a couple bucks instead of a couple hundred or thou. You can do it..i have faith or see if an orger is close to you that you can pay to do it.
Old May 10, 2007 | 12:48 PM
The Law's Avatar
I R The Law
Damn I think the dealership will be having a smile on their faces unless you do it yourself.
Old May 10, 2007 | 01:17 PM
sypher's Avatar
it was a very small drill bit.. i wouldnt have a problem splicing severed wires back together.. my fear is that the metal drill bit crossed connections and shorted a bunch of electronic components.. i still havent checked any fuses (at work now).. but im not counting on any luck there.. what a mess im in...
Old May 10, 2007 | 01:27 PM
D-Twelve's Avatar
I would splice wires then look for other problems...
it sounds like it was mostly accessorie wires, might get lucky, and be able to fix it in an hour or so with only a few bucks...
WOW, that sucks... I cant help but chuckle, it sounds like somthing I would do... LOL
Old May 10, 2007 | 01:30 PM
Jeff92se's Avatar
I'm needing a caw
I bet it's not that bad. One power wire could cause multiple problems. Pull the harness out, peel back the wrap and see what's damaged.
Old May 10, 2007 | 01:34 PM
AcidJake75's Avatar
yeah dude if it was a small drill bit - Id attempt it..let us know the outcome and the cost regardless if its done by the dealer or you..
Old May 10, 2007 | 01:44 PM
SEmy2K2go's Avatar
Go BUCKS!!!
If you could replace the radiator by yourself, you should be able to get this taken care of as well. I wouldn't think it would be all too difficult if it were a small bit that caused the damage.
Old May 10, 2007 | 02:32 PM
sypher's Avatar
Yea thats what I'm hoping.. I dont have much experience with electronics. and the small bit of experience i have has taught me its better not to mess with it.. lol.. im definately going to give it a shot though.
Old May 10, 2007 | 02:41 PM
slvrmax7's Avatar
Definitly go to a junk yard or sum and just swap it. should work okay.
Old May 10, 2007 | 03:34 PM
SoonerFan's Avatar
Cletus
just reconnect all the wires.
for the people saying "replace it"...those wire all go to diffirent places. you know how long it would take to remove the yards of wire and replace all the wires? its not like they all start at one place and end on the other side of where they were cut.
Old May 10, 2007 | 03:38 PM
^^^ lol he has a good point..... like i said before.. start connecting them back together... and good luck
Old May 10, 2007 | 05:12 PM
doublea's Avatar
It's not that difficult, you need to remove the with plastic holder, then you should be able to pull the cable underneath but you may have to remove the radiator in order to have room to solder the wire back together, ask a friend to help you then you should be done in 2-3 hrs.
Old May 10, 2007 | 05:15 PM
Kevlo911's Avatar
Kevlo for President
Soldering iron + a couple of feet of wire(to cut into little pieces and connected the broken ends)
Reminds me of when I had to redo my ac/clock/radio after my car got broken into.
doublea's Avatar
Swapping that cable is a biatch maybe more than you can chew, trust me unless the cable is all focked up, just fix it.
Old May 10, 2007 | 07:17 PM
Maxim(a)SerjVQ's Avatar
Nightmare = Reality
Anyone remember the second Gremlins movie with the electrical one stuck on hold? somehow this reminds me of that...
Old May 12, 2007 | 05:50 AM
doublea's Avatar
Here is some pics:
The plastic part that retain the wire underneath:
Old May 12, 2007 | 08:58 AM
Scooobay's Avatar
See children drugs are bad..
tnewbs
Aug 28, 2015 10:15 AM
KCTYPHOON
27
May 9, 2001 10:02 PM
PRPmax
Mar 29, 2001 12:30 PM
maxspeed79
Mar 8, 2001 05:49 PM
SethMax
Jan 16, 2001 08:06 PM
