How to ground the starter? (making grounding kit)
I'm making my own grounding kit. I already grounded the battery negative to chassis and alternator ground to chassis (and have noticed smoother revs). I've been hearing that grounding the starter can result in quicker starts so for those of you who had done it, I am wondering how you did it.
Somewhere I read that the starter is grounded through its case, so where would be the best place to attach the ground? Should I attach the ground cable to one of the screws/small bolts that go into the case, or one of the two big mounting bolts?
On the case I think it's an 8mm long bolt it goes all the way through the starter then to the frame there should be a threaded hole close to it about 9" away you will see it when you start looking
The Frye
Sep 2, 2021 11:03 AM
Maxima30
Sep 7, 2015 06:13 PM
litch
Sep 5, 2015 11:29 AM
