Hid Kit Install
Old Apr 9, 2010 | 12:21 PM
carrottop's Avatar
Hid Kit Install
So i just installed my hid kit yesterday and couldn't wait for it to get dark to turn them on. I turn them on and only my high beams work =( besides that the lights were the same brightness as my old bulbs which werent hid. I bought :
H4 Hi/Lo 6000K Xenon HID Conversion Kit Super White for 50.00
it came with 2 bulbs, 2 ballasts and wiring,
Can anyone help me out?
Old Apr 9, 2010 | 02:00 PM
anomaly117's Avatar
those kits are not just simple plug and play, which i am assuming is what you did. the hid bulb needs to be wired directly to the battery via a relay in order to work. there's too much voltage drop through the circuit. the high beam comes on because the conversion kits have a little halogen bulb (worthless) for the high beams, not HID, which will work when you plug and play.
google is your friend. go to an auto parts store, pick up 2 relays, and search "how to wire a relay into an HID conversion kit".
Old Apr 9, 2010 | 02:15 PM
nalc's Avatar
afaik the 00-01 is ground switched, so just swap the two wires into the ballast and see if that fixes it.
Old Apr 9, 2010 | 02:20 PM
VQP0WER's Avatar
FYI, you don't NEED a relay kit. I installed my HID kit directly to the stock wiring with no problems. I ended up removing the HIDs because of the awful glare.
The OP needs to reverse his polarity coming out of the ballast.
Old Apr 9, 2010 | 02:49 PM
carrottop's Avatar
anomaly117 ur from mass? im from pawtucket thanks for all the help guys, ill try and do it but i suck with this stuff so ill update u after i try
Old Apr 9, 2010 | 03:56 PM
ramanx806's Avatar
are you sure there hi and lo? put a pick up of the bulb
Old Apr 9, 2010 | 04:47 PM
carrottop's Avatar
well they said they were high/low and they also have two different bulbs
even when i put on the high beams they are sooo dim
Old Apr 9, 2010 | 04:52 PM
Goomz's Avatar
those are not hid lo/hi beams. they do have A high beam, but not in the form of an hid.
Old Apr 9, 2010 | 04:56 PM
Goomz's Avatar
and iirc, they have the red and black plugs, which go into the ballast from the bulbs, and 2 other wires...that plug into the hid harness that plugs into the car's headlight harness. those are you high beam connections.
Old Apr 9, 2010 | 05:19 PM
carrottop's Avatar
Are they hid bulbs at all?
Old Apr 9, 2010 | 05:20 PM
carrottop's Avatar
i tried unplugging both smaller wires red/black but that didnt work, even when i disconnected them the high beams still worked...
Old Apr 9, 2010 | 08:51 PM
CMax03's Avatar
Then that makes it a (Hi/Lo)HiD setup,....Bi-Xenon have hi-beam HiD and low-beam HiD....Just so you'll know the difference between the 2.....
Old Apr 9, 2010 | 11:33 PM
Goomz's Avatar
thats what i meant to say. but apparently you worded it better lol.
and carrottop you would want to disconnect the other wires, and plug in the red and back connectors back into the wires from the ballast. those are ur lo beams.
Old Apr 10, 2010 | 12:44 PM
carrottop's Avatar
can anyone explain it through this diagram?
Old Apr 10, 2010 | 03:56 PM
carrottop's Avatar
bump..*
Old Apr 10, 2010 | 07:39 PM
DrunkieTheBear's Avatar
Turbo'd Saab
THIS!
You need to switch two of the leads around on the harness that plugs into the old harness on your car. Put the ground where the low beam is and the low beam where the ground is
Old Apr 10, 2010 | 07:54 PM
Turbo'd Saab
Pics are so small don't really tell us much
Old Apr 10, 2010 | 08:02 PM
carrottop's Avatar
pics below
Old Apr 10, 2010 | 08:06 PM
carrottop's Avatar
Old Apr 11, 2010 | 06:33 PM
carrottop's Avatar
Damn do i feel stupid, friend came over today and just rotated this plug 180 degrees and plugged it back in, thanks for all the help guys sorry im such a noob...p.s hids look good
Old Apr 11, 2010 | 06:57 PM
bigpopaj369's Avatar
glad u got it figured out man take a couple pics n show us
Old Apr 12, 2010 | 05:51 AM
Prophecy99's Avatar
say no to Illegal HID abuse.
Old Apr 12, 2010 | 06:58 AM
VQP0WER's Avatar
Yup, see post #4. Glad you got it working!
Old Apr 12, 2010 | 05:46 PM
carrottop's Avatar
yeh will do. think they would be much brighter if i got better bulbs and polished my lights.
Old Apr 13, 2010 | 07:08 AM
merovi's Avatar
Not sure how much difference bulbs will make unless you are changing the temperature but cleaning the headlights will make a world of difference.
Old Apr 13, 2010 | 07:10 AM
Turbo'd Saab
sig quote!
Old Apr 13, 2010 | 08:28 AM
Prophecy99's Avatar
sig quote!
I was thinking the same thing.
Old Sep 20, 2012 | 08:12 AM
watut's Avatar
Bumping this up, had one of those eBay special HID kits laying around in the garage. Put it into the Maxima, the high beam would come on but not the Xenon. Switched the low beam and ground wires around in the harness, now the xenon's come on but not the high beams. WTF?
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
mpbclutch33
Sep 8, 2015 06:21 PM
MaxLife17
Sep 8, 2015 02:36 PM
A32goldylocks
Sep 2, 2015 06:39 AM
