Old May 18, 2012 | 12:25 PM
  #1481
Rods03Max619's Avatar
Originally Posted by Shift_Max
From bestbuy. They are offering a $500 discount from msrp already. And i would wait till thanksgiving for some sales however I do not have a tv at all right now.
For some reason I do not want to get a plasma unit.
Best Buy is usually the highest, with them have to wait every week to see if a better deal comes up, do you guys have a Frys Electronics near you.....
Old May 18, 2012 | 12:26 PM
  #1482
aackshun's Avatar
Originally Posted by essential1
Lol. Aside from the full swap (which is in progress) this has been the progression of my car.
Hopefully mine starts off smooth!!! That damn nats better plug in!
Fry's... that place... omg
I can't help myself in that store.
  #1483
Galactica's Avatar
Plasmas are a double-edged sword. On the one hand, they are very bright and they all run at 600Hz so you never have a distorted picture. On the other hand, you will eventually have pinkish crap filtering in to the white parts of the picture as the pixels start exploding. It's weird. My 42" Samsung plasma is 6 years old and works great, but I have that pink only on totally white screens, but if it goes to anything else, the picture is perfect and the hi-def looks fantastic. I did the proper 100 hours break-in with the contrast turned way down and the picture relatively dark. I have no burn-in anywhere, but I still have the pinkish-white screen now... The other problem with plasmas is they weigh a half-ton compared to an LCD or an LED. My next TV will probably be a 55" LED or LED-LCD, at least 120Hz, 240Hz if I can afford it.
Old May 18, 2012 | 12:27 PM
  #1484
Galactica's Avatar
Frys is good and here in Oregon we have a Video Only which will beat anyone's price for a TV, even Frys.
Old May 18, 2012 | 01:00 PM
  #1485
cjandura's Avatar
Hhgregg looks nice i never been in there tho
Old May 18, 2012 | 01:43 PM
  #1486
Waxima's Avatar
Keep it that way. HHGregg sucks. I went there once when one opened by me. Small, poor selection, stupid store layout, and most of all everything was horribly overpriced.
Old May 18, 2012 | 01:45 PM
  #1487
EuroDriver's Avatar
Plasmas don't have pixels. The pink crap is the anti-glare filter they put on them (and Panasonics are notorious for it). LCD's have pixels and suffer from pixelation (pixels burn out and you start getting black dots on the screen). LED's suffer from uneven picture brightness, especially when LEDs start to burn out. Plasmas suffer from burn-in (an image will burn onto the screen, causing a "ghost" image). But most plasmas nowadays come with a tool in the settings to "erase" burn-in.
Basically, each has its tradeoff against the other types. If you're dead-set on an LED, get the highest quality you can afford, 'cause it sucks when the LEDs burn out.
Old May 18, 2012 | 01:54 PM
  #1488
EuroDriver's Avatar
Go bigger and get Plasma.
Called the body shop that's got the wife's outback for a status update, and I get told that the $1420 insurance estimate has morphed into a $3600 repair ! Shee-it, good thing we're only on the hook for the deductible.
The assessed value of the car is $4200 so it's in that territory...... I want it fixed, not totalled.
It will generally be deemed a total loss once the repair bill reaches 80% of the value. If they do total it out, the silver lining for you will be that you can "buy it back" from them dirt-cheap (they pay you the difference). Then you can find a cheap, reputable body shop (plenty of mom & pop shops are cheap and reputable) to do the repairs and you can end up with a nice wad of cash in your pocket.
Old May 18, 2012 | 01:55 PM
  #1489
Galactica's Avatar
Can you explain how a plasma makes it's picture? Because I can tell you when I look very closely at the picture I can see individual squares in the picture that look an awful lot like pixels.
Old May 18, 2012 | 02:01 PM
  #1490
EuroDriver's Avatar
From what I understand (and I'm no expert on the subject), plasmas use a gas inside the panel that when energized, produces light in the necessary colors. http://wiki.answers.com/Q/How_does_a_plasma_TV_work
Here's a decent explanation of the differences: http://www.cnet.com.au/plasma-vs-lcd...-240036500.htm
Old May 18, 2012 | 02:06 PM
  #1491
Galactica's Avatar
OK, so I just did some reading on how a plasma is made up and I'm sort of going to have to disagree with you Euro on plasmas not having pixels. They are in fact made up of many hundreds of thousands of tiny cells of xenon and neon gas sandwiched between 2 plates of glass. Now maybe the actual "technical" term for it is a "cell", but it amounts to exactly the same thing as a pixel.
From Wiki, the definition of a pixel: pixel, or pel,[1] (picture element[2]) is a physical point in a raster image, or the smallest, addressable element in a display device; so it is the smallest, controllable element of a picture represented on the screen
Old May 18, 2012 | 02:39 PM
  #1492
cjandura's Avatar
Thinks someones HD is off plasma contains no pixels i can explaim more later btw i am isa certified thru BB to calibrate and R&R ht equipment
Old May 18, 2012 | 02:41 PM
  #1493
cjandura's Avatar
The pinkish hue you see is from a coating on the glass to reduce glare look at some car windshields feom a angle you will see a blue or pinkish hue at the top its the same concept
Old May 18, 2012 | 02:42 PM
  #1494
TunerMaxima3000's Avatar
I know that the lwfw doesn't change engine output. But if it changes the rate of acceleration through the minimization of drive train loss, doesn't that mean the rollers on the dyno will spin faster? Thus resulting in a higher number on paper?
I'm thinking of it the same way you look at AT vs MT dynos. The engine puts out the same power of course. But the wheels see more of that power it was missing out on which results in a higher number on the dyno.
From My understanding? No. dyno's aren't just free wheels that measure speed, they actually measure the load applied, etc.
This means that even it accelerates faster that wont change the actual output numbers.
Yes, auto vs. manual will put diff. numbers down but that's becuase the power flow is completely different, the transmission of power is different, this translates in to different power loss through the geartrain.
This is why comparing a DM flywheel to LW one piece you could see minor gains on a dyno, becuase a DM flywheel could potentially rob some power in it's dampening effect.
Old May 18, 2012 | 02:47 PM
  #1495
ShocknAwe's Avatar
force is equl to mass*acceleration. THis is the principle they work off of. The weight of the rollers is known. The computer is connected to the ignition system to measure the RPMS. Once the speed of the rollers is measured they use these numbers to calculate wheel HP. Simple concept but is different from brake horsepower which is the actual engines HP without loss through the drivetrain
Old May 18, 2012 | 02:49 PM
  #1496
ShocknAwe's Avatar
Oh and btw thanks for answering my msg about the LED's tuner
Old May 18, 2012 | 02:53 PM
  #1497
essential1's Avatar
My axles cry for mercy...
All of this is the reason why till this day, I prefer to street tune. I'm not saying that a dyno is useless at all. I think it is essential to fine tuning. But i've beaten cars that dyno upwards of 260whp. And I know for a fact that i'd be lucky to pull 220whp in perfect conditions.
Old May 18, 2012 | 02:58 PM
  #1498
ShocknAwe's Avatar
Did you see them dyno at this number? Either they are lying or they use a crappy dyno. Some less than reputable tuners change smoothing factors to make it seem like they made your car 30hp faster to get you to come back. Old software and numerous other things can affect output as well. On a modern dyno in a reputable shop. ITs accurate to within 10hp. A decent shop doesnt need to falsify numbers because they dont need anymore customers lol. You dont NEED a dyno like most people seem to think but its safer to do it in a controlled environment and if you frequent shops like I do you get a good bang for your buck
Old May 18, 2012 | 03:01 PM
  #1499
essential1's Avatar
Did you see them dyno at this number? Either they are lying or they use a crappy dyno and some less than reputable tuners change smoothing factors to make it seem like they made your car 30hp faster. Old software etc. On a modern dyno in a reputable shop. ITs accurate to within 10hp. A decent shop doesnt need to falsify numbers because they dont need anymore customers lol. You dont NEED a dyno like most people seem to think but its safer to do it in a controlled environment and if you frequent shops like I do you get a good bang for your buck
search up dynos of full bolt on acura cl-s 6MT. They tend to dyno pretty high.
Old May 18, 2012 | 03:05 PM
  #1500
ShocknAwe's Avatar
lol my msg made no sense when I reread it lol had to edit. Oh there are some cars that dyno way high and others that dyno low. Its weird and I couldn't tell you why. Then again 300hp is all relative to what car its in too. Im just saying that a good dyno is pretty damn accurate and unless you want to take your engine out to get a true number then its really the only game in town. Not all roller are created equal either.
  #1501
essential1's Avatar
Just did a quick search myself and it looks like the average ones dyno around the 240whp range with a few up in the 260s. Still, that should be more than enough to take this old tired dek down.
Old May 18, 2012 | 03:09 PM
  #1502
ShocknAwe's Avatar
You would think. Like I said its probably them lying or the dyno/software that is downright ancient. Im lucky to live in ATL where there are tons of shops competing against each other but a lot of people only have 1 game in town so the shop has no reason to upgrade equipment you know? It can be a shady game
Old May 18, 2012 | 03:12 PM
  #1503
cjandura's Avatar
*** dyno best measure of HP there is
Old May 18, 2012 | 03:13 PM
  #1504
Galactica's Avatar
Looking forward to an explanation of how hundreds of thousands of individual cells of excitable gas are not "pixels".
Old May 18, 2012 | 03:14 PM
  #1505
Galactica's Avatar
So is that coating breaking down as time goes on then? Because I only see it on parts of the screen that are turning white. Once they change color, the pink is gone.
Old May 18, 2012 | 03:17 PM
  #1506
cjandura's Avatar
In reality how fast do you want to go?190mph why?how fast do you think you have to go in order to loose your licence is it worth it?
Old May 18, 2012 | 03:19 PM
  #1507
Amerikaner83's Avatar
So, then...if they total it out we can buy it back? Our deduct is 1K, so if they total it at 4k they give us a check for 3k, yes (our deduct minus value)? If we "bought it back", the check would be like, 2k? I'm not sure. BUT then we'd have a car with a salvage title yes?
Old May 18, 2012 | 03:20 PM
  #1508
cjandura's Avatar
Pocketed glass was only used on early plasma before the use of the current plasma grid amplifers
Old May 18, 2012 | 03:22 PM
  #1509
essential1's Avatar
Whatever's fast enough to send me back to the future. I tried 88mph, but it didn't work out to well...
Old May 18, 2012 | 03:29 PM
  #1510
Hell yeah deals all through the week in the Newspaper on Mon. Weds. Fri. and Sunday....
Old May 18, 2012 | 03:30 PM
  #1511
cjandura's Avatar
See if aackshun has a flux capasitor and harness off a 80's delorian you'll also need a Mr.Fusion maby the chinese joint has a extra one of them next to the 3fer5 packs of 4B hair and $5 wigs
Old May 18, 2012 | 03:34 PM
  #1512
Got a Samsung 50'' Plasma had it for about 2 yrs going on 3, No Problems at all and bomb a$$ picture, I got my kid a 32'' Sanmsung LCD for video games but he likes to play on the Plasma since its bigger I only let him play like a hour or so dont want burnt images on the screen.....for me Plasmas I love Em and pretty cheap as long as I get 4yrs off of them Im happy...but sure will get way more out of it....
Old May 18, 2012 | 03:35 PM
  #1513
cjandura's Avatar
Yup mostly dynex,visio,sharp and lower brands use this coating instead of eglass
Old May 18, 2012 | 03:43 PM
  #1514
Old May 18, 2012 | 03:46 PM
  #1515
Dynex my bro in law had one it wasnt a pretty picture...
Old May 18, 2012 | 03:57 PM
  #1516
just like anything there's a billion variables.
Many concede that 1/4 mile times and 0-60 are the most accurate times, but tuning must be done via dyno to really do a good job.
HP numbers are what you tell the boys around coffee. If you're serious about shyt, those numbers don't mean a lot, it's the times you put down in a race that matter.
Old May 18, 2012 | 04:29 PM
  #1517
Well Put....
Old May 18, 2012 | 05:13 PM
  #1518
T_Behr904's Avatar
QFT...
Btw, what caliber is it?
Old May 18, 2012 | 05:26 PM
  #1519
T_Behr904's Avatar
Here's a Gerry can full of gas. In order to light it on fire, you have to first remove the safety cap by depressing the locking tabs, and turning it in the proper direction, then you have to pour the gas out over something.
But this is still safe. As an added safety feature, you need a Lighter to do anything further!
Even more safe, there's a safety depress tab on the lighter before you can strike it. Once depressed you can now use the lighter. Then, you have to actually put the lighter, WHILE lit, up to the gasoline.
So that's why lighters and gas are perfectly safe, and don't light on fire. People light fires.
I appreciate your effort in this matter, and you can truly argue with me and win on many fronts about pro-guns. But that concept is way to ignorant for you to believe CJ, yo'ure far to smart for that. Wash that concept out of your head.
That's a bad description to use to make your point. You're talking about using gasoline in a manor it wasn't designed for. A firearm has a purpose, to fire a round. Gasoline has a purpose, fuel for internal combustion engines. So in order to compare gasoline to a gun as you have, you would have to describe it in a way where you're using gunpowder from the rounds. This actually doesn't even involve the gun itself at all since where talking about the rounds. And you don't have to take a bullet or a shotshell apart for this. You can go to any local sporting goods store and buy gunpowder.
  #1520
cjandura's Avatar
QFT...
9mm with 20rd mags filled with black talons
xdm are on sale right now you get a total of 5 20rd mags with them 2 in the case and 3 free in the mail
