5th Gen: What did you do to your 5th Gen today?
Old Dec 19, 2014 | 08:00 AM
  #1521
D.Stillwell's Avatar
Originally Posted by george__
engine oil was always EMPTY!
so filled her up
Old Dec 19, 2014 | 09:52 AM
  #1522
george__'s Avatar
Opps typo fixed.
City only driving though has caused oil consumption to go up.
Old Dec 20, 2014 | 04:47 AM
  #1523
Opps typo fixed.
What worries me more is not the typo, its the fact that you never check your oil before it becomes empty.
Thats horrible george. Your car needs some TLC.
Old Dec 22, 2014 | 09:06 PM
  #1524
Donkeypunch's Avatar
I recently replaced the upper oil pan seals and noticed a small exhaust leak.
.....great.
So I checked it out and turns out just a heat shield bolt was missing.
Kinda weird that it goes all the way through,
but I just put the heat shield back on and problem fixed.
The one on the right.
Old Dec 26, 2014 | 10:30 AM
  #1525
theherdmaster's Avatar
It snowed here in Colorado, and I took the Maxima out for her first snow drive during my ownership. The handling in the snow wasn't bad, I kept slipping trying to get into first though. Maybe I'll look into snow tires, who knows. Once I'm in first gear and have traction all is well.
Here she is in the snow.
Attached Thumbnails 5th Gen: What did you do to your 5th Gen today?-snow_2-compressed.jpg
Old Dec 26, 2014 | 12:34 PM
  #1526
george__'s Avatar
Ease off the gas :P
Old Dec 26, 2014 | 04:01 PM
  #1527
King_Ten_Ahead's Avatar
Starting to black out the top half of the interior. Threw a light in too
Old Dec 26, 2014 | 07:58 PM
  #1528
Mattx's Avatar
Originally Posted by theherdmaster
It snowed here in Colorado, and I took the Maxima out for her first snow drive during my ownership. The handling in the snow wasn't bad, I kept slipping trying to get into first though. Maybe I'll look into snow tires, who knows. Once I'm in first gear and have traction all is well. Here she is in the snow.
Can't recommend snow tires enough. Made a huge difference last winter with all the snow we had in Northeast. It's like being in a four wheel drive truck.
Old Dec 27, 2014 | 01:51 AM
  #1529
Jprocs24's Avatar
My tail-light burnt out, so I'll need to pick up a new bulb for that. Better to replace both at the same time or only the one that burnt out? Turn signal bulb & brake light still work. $2.00 I didn't want to spend
Old Dec 27, 2014 | 04:30 AM
  #1530
Do yourself a favor and spend 20 bucks. Get some Phillips LED bulbs and upgrade, and the bulbs are made very well in a style thats made for oem housing - so you cant see the bulb.
Old Dec 28, 2014 | 12:13 AM
  #1531
Genes1s's Avatar
Replaced wheel Bearing. This was a couple of hours of work tonight.
"pushing out" the hub.
Getting the other half of the bearing off the hub. There is a better way to do this using bearing separator plate, but I was in hurry since this is my DD. A much better way would be to junk it and get new one. When you cut, MAKE sure that you don't damage the hub shaft. Do it very slowly and you don't need a lot of cut, all it needs is a little relief from the press fit pressure. I marked the hub shaft a little but buffed out with 1000 grit sand paper and Scotch Brite pad
Hub shaft with quick scotch brite wheels
Getting the snap ring out. This was the most time consuming. I could not understand why the Nissan folks decided to put that stupid snap ring design instead of the regular kind. There is no way to use the standard snap ring pliers over this and had to use 2 flat head screw drivers to get them out.
Pushing out the bearing. I used this http://www.harborfreight.com/fwd-fro...ers-66829.html. Make sure you have plenty of penetrating oil during this procedure.
Pushing in new Timken bearing ( they are made in Korea, not sure if they hold up like the OE though)
Old Dec 28, 2014 | 07:43 AM
  #1532
Bronxboi5's Avatar
A good cheap upgrade... Did mine over the summer
Old Dec 28, 2014 | 10:28 AM
  #1533
Im excited to get everything put back together haha
Old Dec 28, 2014 | 12:42 PM
  #1534
PaleFace's Avatar
Finally replaced MAF
Did the grounding kit & big 3
GAB with K&N filter
I'm in love with my car again
Old Dec 28, 2014 | 03:52 PM
  #1535
Ease off the gas :P
Yeah, I found that to be helpful. Really gotta ease it into 1st in the snow with my current tires
I think I'll start saving for snow tires. I was in Michigan for the snowpocalypse last winter and if this winter is anywhere near that, snow tires may be a necessity. Good to know it handles well with good snow tires!
Old Dec 28, 2014 | 06:13 PM
  #1536
Mattx's Avatar
Yeah, I found that to be helpful. Really gotta ease it into 1st in the snow with my current tires I think I'll start saving for snow tires. I was in Michigan for the snowpocalypse last winter and if this winter is anywhere near that, snow tires may be a necessity. Good to know it handles well with good snow tires!
I have a full set of Bridgestone Blizzaks that I got cheap that came mounted on 16" rims. Last winter was the first time in all my years of driving that I ever tried using a snow/winter tire. Let me tell you, I wish I would've done so long time ago. It makes someone like myself who has a long commute to work, much more confident you'll make it there without a problem.
Old Jan 2, 2015 | 05:14 PM
  #1537
Fatboy98maxima's Avatar
just got a fresh set of all season tires today now set for some snow
Old Jan 3, 2015 | 04:07 PM
  #1538
16.4 gallons of gas for $28 today)
Old Jan 3, 2015 | 05:23 PM
  #1539
maxiiiboy's Avatar
That's $1.70/gal - unreal. It's still $3.30-3.70 here in California.
Old Jan 3, 2015 | 09:12 PM
  #1540
Its been that low for about a month here in Northwest Indiana.. Im thankful it hasnt snowed at all yet (its a mystery haha) because Ive just been cruising. Gas being so cheap makes driving for the fun of it so much easier to do.
Old Jan 4, 2015 | 07:07 AM
  #1541
Yup. $2.60/gal for 93 octane here in VA, went ahead and filled up full tank yesterday first time in a while, I usually run qtr tank.
Its good no snow and lower gas prices...loooks like Cali is getting the snow and expensive gas this time lol
Old Jan 4, 2015 | 10:36 AM
  #1542
a33_ridah's Avatar
^Socal Snow. Thats a new one to us The day it snows in SanDiego; well that day may be one day closer to the END of it all lolz.
Gas is about 2.40 for 87 out here; about as low as its been. I doubt were going to see lower than $2 here.
Old Jan 4, 2015 | 02:57 PM
  #1543
put some weather stripping around cold air snorkel.
I don't even know if it's tall enough to make a seal, but it's something :P
Old Jan 6, 2015 | 05:29 AM
  #1544
Time for more pics up in here for the new year, yes sir!
Snow time for us, dammit (early as fkuc this morning):
I love the look of it all in the snow, really makes for some good picture taking. Gotta really set up a nice photoshoot later today maybe, make it an occasion as my baby is only 40 miles away from hitting 100k as of this writing and it may even happen today
Old Jan 6, 2015 | 07:20 AM
  #1545
george__'s Avatar
Nice home!
Old Jan 6, 2015 | 08:05 AM
  #1546
Nice home!
It's an expensive townhome, common for my area, sucks and nothing special. Not my house BTW george lmao
Mine is directly behind the one in the pic, you think I was gonna show yall where I live? Lol come now
Old Jan 6, 2015 | 08:08 AM
  #1547
george__'s Avatar
Ok then, well thanks I guess? Lol
I really like that type of exterior on a home. Looks better than the plastic material thingy covering many new homes
Old Jan 6, 2015 | 08:11 AM
  #1548
I agree, brick home is way nicer than typical vynil siding.
Old Jan 7, 2015 | 08:11 PM
  #1549
Jprocs24's Avatar
Put on my new muffler, undecided on the looks... It's a Magnaflow 14816
Old Jan 8, 2015 | 04:29 AM
  #1550
^^ Nicely done.
I hit 100k miles last night, was a bit disappointed in myself because I forgot to take a pic until 33 miles over.
I have this weird ritual I do when a car hits 100k which entails that I has to floor it WOT and goes up to 100mph to commemorate the 100th anniversary. Yes
So that was fun not on public roads
Old Jan 8, 2015 | 06:24 AM
  #1551
george__'s Avatar
in before engine took a dumb thread 5-10 years from now
Old Jan 8, 2015 | 07:52 AM
  #1552
Dumb? Can you elaborate please?
And I'd be happy as hell if my engine lasts another 10yrs. I'm more concerned with the chassis making it that long vs. engine
Old Jan 9, 2015 | 07:07 AM
  #1553
Maxima50's Avatar
Put 35% tint on the entire front windshield. I was a little hesitant at first about it being too dark at night with the tint, but I can't really tell a difference at night. Glad I did it.
Old Jan 9, 2015 | 07:31 AM
  #1554
nestorlugo's Avatar
my 88 cutlass supreme had 5%all around and 35% on the front it was impossible to see in it at night without a pig flashlight, perhaps being a gangster car and the tint got me 19 citations before an azzhole cop keyd all my tint so i had to remove it :fukkdapolice:
Old Jan 9, 2015 | 09:24 AM
  #1555
Maxima50's Avatar
I also got 5% all around, no problems here in KY.
Old Jan 9, 2015 | 11:23 AM
  #1556
jjubert's Avatar
I have 2% on front and back windows as reflected by officer's digital measuring device, but he let me go since he recognized me from when he was doing security at my job I was going to joke with him about fighting real crime, but I didn't want to press my luck
Old Jan 10, 2015 | 09:26 AM
  #1557
jjubert's Avatar
Spray washed the engine bay...I should have took some before pics, but trust me it needed it:
Old Jan 10, 2015 | 10:56 AM
  #1558
a33_ridah's Avatar
^Looks good! U rock it like this without engine cover off mostly as well?
Old Jan 10, 2015 | 11:47 AM
  #1559
jjubert's Avatar
Nah just did it for cleaning purposes bro
Old Jan 10, 2015 | 09:09 PM
  #1560
Boxness's Avatar
Got some more of my soon-to-be '03 put together. Put pistons from a '12 in and split the head gasket, (per recommended from the lead tech at my dealer that im buying it from, the little boost in compression plus lighter pistons he had laying around. free perks right?) Ordering the rest of the parts monday, hopefully I can drive it next weekend.
