ballast replacement
Old Nov 15, 2013 | 03:14 PM
Maxident's Avatar
ballast replacement
Is there any way to replace the ballast without taking the headlights out altogether? Is rather not have to remove the bumper cover, etc...
Old Nov 15, 2013 | 03:53 PM
CauzinDrama's Avatar
I dont think so. You dont have to remove the bumper cover though. There is 2 bolts on the top and if you have the security strap theres 2 bolts that can be accessed if you pull down the splash guards. I recommend taking the guards down and looking for the strap first so you dont break the assembly.
Old Nov 15, 2013 | 05:12 PM
Maxident's Avatar
Thanks. There's actually a really good "how to" video thru A1 car parts or something on Youtube, and they say you do have to take the bumper cover off. If I don't really have to though that will make life a lot easier. They talk about the straps so I'll check for those as you suggest.
Old Nov 15, 2013 | 05:25 PM
Yea it can be done without the bumper coming off but just be sure to check for the strap. I've done it several times just in the past few days.
Old Nov 15, 2013 | 08:27 PM
Claybob86's Avatar
Yep, it's very easy to do without removing the bumper. Just be careful, there is a tab on the outermost side of the headlight and it can scratch the fender when removing and installing if you're not careful.
Old Nov 15, 2013 | 09:24 PM
Genes1s's Avatar
No need to take the bumper off. You might need to take few plastic fasterner that hold the grill close to the headlight to pull the light out. You want to pull the light upward after the side pin allignment that goes to the fender is off.
PM if you need OEM ballasts replacemnet, I have few of these.
Old Nov 18, 2013 | 06:37 PM
Will's Avatar
Did your ballast burn out from old age?
PH98I30
29
Feb 10, 2025 12:03 PM
The Frye
Sep 2, 2021 11:03 AM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
