Help me with my pulley
Old Jun 21, 2014 | 11:45 PM
Need help's Avatar
Recently my car has been making a funny sound from the pulley area, like a squealing.......the pulley was shaking some, so we adjusted the belt on it, but the sound is still there, I pm not sure if I need a new pulley(idler or tensioner) and if I need the bearing or the whole assembly...... So if you can help please do
Old Jun 22, 2014 | 02:24 AM
Bronxboi5's Avatar
Did you replace new belts???
And if not just buy new ones and check for cracks
Old Jun 22, 2014 | 10:38 AM
DennisMik's Avatar
If the pulley looks like it is wobbling, it is coming apart and needs to be replaced.
Old Jun 22, 2014 | 10:49 AM
Need help's Avatar
No
No I did not buy a new belt, and I'm not sure which pulley to buy.....here's a video I took the other day....
Old Jun 22, 2014 | 11:38 AM
tosheto's Avatar
That is an interesting sound. Sound like the pulley is gone. Hopefully more people that have had problems with that jump in and confirm.
Old Jun 22, 2014 | 12:38 PM
speedy25's Avatar
Once you take off the belt it should be fairly obvious what the problem is. There is only one ldler pulley and if it spins freely and doesnt have any slop its good. I bet yours isnt.
-SP
Old Jun 22, 2014 | 03:46 PM
Need help's Avatar
Ok I'll get the belt off, then we'll look......so you think it's the idler pulley or tensioner? Ik it's hard to tell
Old Jul 6, 2014 | 06:09 AM
Need help's Avatar
The belt was good, I put a new idler pulley on but the sound is still there, so I'm not entirely sure
Old Jul 6, 2014 | 08:49 AM
CMax03's Avatar
Apparently you have a defective crank pulley...Your pulley is a 2 piece component (The inner Hub and the outer belt shell) which is separated and bonded together by an elastomeric layer!!!! The 2 pieces are no longer bonded together the inner and outer are now slipping upon each other! You need a new crank pulley so please inspect your crank pulley first....
Old Jul 6, 2014 | 09:20 AM
Child_uv_KoRn's Avatar
Bad *** Newb
Definitely looks like it.
Aftermarket UDPs pulleys are much cheaper than this stock crap.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
02PearlSE
Feb 1, 2016 12:37 AM
rbarnes
Dec 31, 2015 06:29 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
