Headers for a 5.5th gen really harder to find nowadays?
#42
Thanks for the replies guys. I dont really want to deal with OBX so my 2 options are the Altima headers and a Thomas Purdue Y or go with the 3.0 manifolds and warpspeed Y. Again im mostly concerned with getting rid of the precats but performance gains would be nice too obviously.
#44
For someone that doesn't have the means to fabricate (or if Thomas isn't making the y pipes), the 02-03 OBX headers are still a great buy and install with very little hassle/modification. For reference I'm not talking out of my butt here, I've installed a handful of both headers on 4th and 5th gens.
#45
warpspeed website back up and running, it was down the last time i checked, i am wondering if i should proactively buy a 3rd one, because in the north east my warpspeed y-pipe only lasted 3 years before it failed inspection/emmisions from salt and snow etc
and let me say I am not knocking warpseed , they provide great products and for this literally micro niche market and have continued to do so over many years. so props to them! i am on my 2nd y-pipe, and thinking about a 3rd if that says anything.
#46
#47
#49
#51
got it, thanks! i saw the post above about how restrictive the 3.5 manifolds are compared to the 3.0, trying to find someone who is running the 3.0/warpspeed y setup on a 5.5 gen so i can pick their brain... also noticed youre in SE PA. im in Downingtown if you know where that is
#60
The header are the same except 02-03 VQ35 don't have any EGR ports and 95-01 VQ30 do have a EGR port with the extra fitting that can be plugged!
Non EGR https://caautoparts.com/products/sta...ima-hds-na02v6
EGR http://www.epartsgo.com/Exhaust/Epar...g-Set/-/209880
I would use the Nissan Altima 02-06 headers and modify the y-pipe to fit the 5th Gen Maxima. The hangar needs to be relocated to the top of the ypipe rear section. A decent mechanic with decent skill can probably figure out what needs to be modified or opt into using the secondary choice of headers from yesteryear....OBX. Can't believe they're $599.00 now! Back in the early 2000's Cattman headers were $850 and OBX were roughly $300-$350 and didn't fit worth-a-****, had to chop the car's Crossmember up to get it to clear it It was a mess!
http://www.obxracingsports.com/products.php?pk=944#
#61
Here's a bunch of what call starter kits: You got the manifolds just Fab the y-pipe to fit your chassis
https://www.ebay.com/itm/OBX-Racing-...75.c100623.m-1
#63
So they fit other than the hanger?? I have a set otw, more info on what I need to do to them would be appreciated. Just cut the hangar off and reattach it where it needs to be??
#64
To answer my own question, no. I don't know what CMax03 even meant to say, but the modifications needed to make the 02-06 Altima headers and Y work on the 5.5gen are a LOT more than moving a hangar, and it's gonna take more than a decent mechanic. The 02-06 Altima Y pipe literally exists in the same space as the cross-member, so needs completely reworked to fit with the crossmember. The headers mostly fit without the Y if you notch the engine mount and reweld one of the flanges at a slightly different angle, but you need a completely different or heavily modified Y pipe than what comes with them.
#66
I'm sure it's not hard to even build a mandrel bent ypipe for this application! Just need a chop saw, tape, marks-a-lot, jack stands, safety wire or tie wraps, and plenty of patience. I've fabbed two catbacks for a 3rd and 4th Gen and it was easy and they're still active service!
#68
Judging by your glossy description of what needs to be done to make it work, you've never dealt with these headers on a A32/3.
I'm not saying its impossible, but it definitely more difficult than you make it seem.
Is a little tricky getting the bends correct and smooth for the rear bank for a header meant for a different subframe, but it will be easier for an experienced fabricator (which can mean $$).
Photos from a 5.5 gen 6mt I found at the junkyard with altima headers:
![](https://cimg5.ibsrv.net/gimg/maxima.org-vbulletin/1500x2000/img_20200719_151310246_hdr_f41ed050003e160640cbc8e7c8009ae3f76bbd01.jpg)
![](https://cimg5.ibsrv.net/gimg/maxima.org-vbulletin/2000x1504/img_20200719_151317373_hdr_d4d58de4dea105ddeaddc89ce18f18f9b326f83d.jpg)
![](https://cimg2.ibsrv.net/gimg/maxima.org-vbulletin/2000x1504/img_20200719_151328477_hdr_02790ccda0e4e019468af3d6bd430df84df6c587.jpg)
![](https://cimg7.ibsrv.net/gimg/maxima.org-vbulletin/2000x1504/img_20200719_151333065_hdr_5c302910e20a8f69032e9e30a6fb8f0775210333.jpg)
For anyone thinking about tackling this you can see the iterations I went through trying to get the y pipe right for the altima headers back when it was relatively unknown (sources linked in my thread). I was a budding fabricator at the time and had a friend with a welder "that could do it". Took me a few iterations to get it right and I learned along the way.
Is it going to take everyone this many tries to get it right? I sure hope not.
https://maxima.org/forums/all-motor/...-knockoff.html
Thomas Perdue (fb) or t4367p (or something like that on here) makes a great y pipe for these if you are unsure of fabrication skills at local shops near you.
#70
It would seem they do, as stated their site was still active and i spoke with someone via email regarding a Y-Pipe not too long ago before i made the decision to go through Thomas Purdue instead.
