Hood alignment help
Old May 31, 2020 | 10:32 PM
hithesh's Avatar
Hood alignment help
Car: 2000 infiniti i30t
Replaced my hood with one from 2002 i35
The alignment seems to be off - passenger side alignment is much closer than Driver side. Pic attached.
This also results in the hood latch being off a bit and I need to force it to lock by sitting on it.
(Bonus point, if you noticed the color difference)
hood alignment
Old Jun 1, 2020 | 06:12 AM
guapoman2000's Avatar
Did you replace the Hood Hinges?
I ask because these vehicles suffer from Hinge damage, especially when you replace a hood and/or age.
Best of luck!
Old Jun 1, 2020 | 02:12 PM
hithesh's Avatar
No, I did not replace the hood hinges.
That will be the next step if there is no other solution.
Old Jun 3, 2020 | 12:43 AM
User1's Avatar
It's called elbow grease. Body lines require it, especially if it's bee hit. Take your time and do the best you can.
Old Jun 4, 2020 | 04:59 PM
hithesh's Avatar
Can I just slightly nudge the hood hinges to the right?
Old Jun 4, 2020 | 05:11 PM
User1's Avatar
Absolutely. Start with the approach that causes the least damage (avoid bending forces until necessary) then go from there. It's common practice in body repair.
Old Jun 5, 2020 | 04:11 AM
If you do a Google search, you will see that these hinges are not that good and if you do attempt at this adjustment you might need someone to help you as I don't think these hinges from factory are all that great.
Should you attempt at this, make sure you consult someone like a pro body person to see what is the proper procedure and if I am correct, you might need additional pair of hands holding the weight of the hood so, you don't destroy the factory hinges.
Best of Luck!
Publixman99
Mar 19, 2016 03:17 PM
Nopike
24
May 21, 2010 02:30 PM
ThaMax
Mar 27, 2010 06:23 PM
joemax1
Jan 7, 2005 08:27 PM
PoePoe2797
Aug 26, 2003 09:14 AM
