Maxima Automatic Gear Selector Wobble / Replacement?
Old May 15, 2006 | 08:25 AM
Blulytes's Avatar
Shifter twist?
I know there is a TSB on this... but I was wondering...
my shifter twists... maybe about 10 degrees. Does any one elses? How do you stop it?
Are there nice replacements too?
Thanks!
Old May 15, 2006 | 09:49 AM
RHMax's Avatar
Newbie just Registered
I just removed the plastic on the bottom and adjusted mine. Nothing was borken, and it's been fine.
Old May 15, 2006 | 11:33 AM
po8pimp's Avatar
it's not the shifter column that twists....... you are fine...... I changed out my shift knobb with an aftermarket one...... looks better and doesn't twist.....
Old May 15, 2006 | 11:39 AM
Monotaur's Avatar
Yeah, my shifter **** twists as well. It happened after I took it to the auto body shop where they broke the little clip that keeps it in place. It hasn't bugged me enough to get it replaced yet. Besides, I like the stock look of it...
Old May 15, 2006 | 12:03 PM
po8pimp's Avatar
there are so many different shifter knobbs out there that can replace your OEM one, and still maintain the same look or even better look to accent your car better....... I used a manual shifter replacement that had a light in it that changed different colors to accent my interior lighting.....
Old May 15, 2006 | 02:11 PM
BadBlackMaxSL's Avatar
I did a small write up on a quick, 10 minute fix on this last fall. You may be able to search for it.
The groove for the Ohm clip is in the wrong spot on the shifter stalk. What you need to do is pull down the lower silver collar and take the ohm clip out and let the shifter **** go down as far as it can go. Mark the stalk thru the slits in the shifter **** with a pen or sharpie. Take the shifter **** off and take a hack saw and make the new grooves in the stalk at the newly identified marks. Make them the same shape and depth as the factory cuts. Put the shifter **** back on and put the Ohm clip on making sure it sits in the new cuts. Pull the lower collar back up and you're done.
Others here have purchased new ***** but I really like the feel of the OEM ****. Save the $100 and buy something else. Just my $.02.
Lakersallday24
Nov 7, 2024 07:31 PM
Quickgtp
Apr 13, 2017 03:30 PM
District
Aug 15, 2015 08:23 PM
MikesChevelle
Aug 10, 2015 10:53 AM
cmpowell86
Aug 10, 2015 12:35 AM
