fix dangling side mirror?
I'm wondering if it's possible to re-attach a dangling power side mirror that still "works." It responds to the fold and mirror-move switches, it just doesn't stay on without being tied to the post. It got knocked off by driving too close to a pole, but I don't see anything "broken" on the post or on the base of the mirror.
Photos attached.
Thanks a lot.
Photos attached.
Thanks a lot.
http://www.partswebsite.com/nissanca...imagecallout=2
Could not find the clip, you might want to check with Nissan Dealer see if they can pull up just the clip.
Most likely it is an assembly, mirror plus swivel bracket, and entire assy has to be replaced, be it heated, or non-heated, powered or non-powered mirror, it does not matter. The only way to access fasteners usually would be taking the trim panel off. I've never deal with side mirrors on this car, but most mirrors are accessed from inside the door. Also, if this car is insured both ways (comp and collision inclusive) and you have a low or zero deductible, you may want to claim your insurance to pay for a new mirror.
As far as accessing the mirror, it is bolted inside the car behind the black trim piece on the door. Removing the mirror might give you better access to figure out what is going on. In order to see inside the mirror itself, you have to remove to mirror from the housing. It is attached with high grade glue. A heat gun should help in removing this.
If I was doing this, I would just keep it tie wrapped and purchase a new one and get it painted when I got the money. Using insurance is another option, however depending on the company, you could get your rates increased.
If you could locate those pics I would appreciate it. My mirror is a 15 wire auto-dimming one, so if I end up buying a replacement mirror, is it a big deal to work instead with a simpler one, even a manually folding one? I think that a manual one is a safer bet than a power folding one, since it will fold when hit, rather than break off!!
boomerbrian
Oct 31, 2018 10:25 AM
flu2000
Sep 8, 2015 02:23 PM
