my car sometimes won't shift past Neutral
As the title says, this has been happening for a few months. When I stop the car to park it, I can't shift past Neutral, so I can't actually put it into Reverse or Park. Sometimes I just have to turn off the car in Neutral then turn it on, once it worked by turning off the car in neutral and putting key in ACC, other times I have to wait a while I googled this and have seen one similar post and they say it is the "shift linkage". I am not sure what to do. Any advise is greatly appreciated. BTW, I don't think it is the transmission but if you need to know it is a 5 speed that hasn't given me any trouble. Thanks in advance
Check the brake switch and shift interlock solenoid
In a pinch, you can use the shift lock release button to put it into park.
If it won't shift into park when using the shift lock release button, then could be a sign of bound linkage in the shifter.
This thread references a similar problem with solution;
Check here
Check here
thank you for the reply. I will check the brake switch. I will also be on the lookout for a shift interlock solenoid next time I'm at the junkyard. In the mean time, I will carry use the shift lock release button. I wasn't sure what to do with the cover, but now I know I can "pry" it off .
I think you are correct. The link to that thread references the exact same issue this vehicle is having and that it was only solved once that part was replaced. I had no idea what it was called. Could also be found at the local yard
Thanks for the tip. Does it make a difference if one of the times I couldn't go past Neutral I heard a click somewhere then I was able to shift into Reverse and Park? I only remember hearing that because I didn't have any music playing, so I don't know if that happens every time I can't shift past Neutral.
I forgot to post an update. I went to the pick a part and found a shift control unit. I paid $8 for it. They charged it as a relay. I replaced mine with the "new" one and problem fixed. I went about a week using a screw driver to press the shift release lock. Thanks again! I really appreciate it.
zourtney
08-08-2008 08:52 AM
kevp
06-25-2001 07:12 AM
