Help! I'm new here and have a question....
Old Feb 12, 2011 | 08:43 AM
  #881
upstate_maxima's Avatar
Originally Posted by bommart
has any experienced a random plastic popping noise coming from the audio stack? it may be from the heat being generated behind it and causing the plasic to flex etc.
I hear it once in awhile in my 2010. Not frequent or annoying..I figure if it gets worse will take it in to dealer but hate the thought of them pulling dash apart.
Old Feb 19, 2011 | 07:45 PM
  #882
SMG's Avatar
SMG
Just picked up an '11 3.5 SV w/ Premium, Tech pkgs. yesterday. Only one issue so far: my 1st gen iPod Touch doesn't work using the center console USB port. The songs, playlists, etc. show up when I first plug the iPod in, and it will play the first few seconds of a song, but then it stops and will not play again. Is the 1st gen Touch not compatible? Would it work if I upgraded to a later software version?
Old Feb 20, 2011 | 12:32 PM
  #883
I know in the owners manual(2010) it lists what version firmware is needed and what iPod will work. I do not own an iPod so I used a Y-cable for my MP3 player. Hope that helps.
Old Feb 20, 2011 | 01:16 PM
  #884
Car Addict's Avatar
Anyone need a USB flash drive? I have an extra 16gb one. I'll let it go for free plus shipping.
Old Feb 20, 2011 | 02:02 PM
  #885
SMG's Avatar
SMG
Thanks, I figured it out. I just needed a firmware update.
Old Feb 22, 2011 | 03:18 PM
  #886
Slow Motion's Avatar
wrong gen. sorry.
Old Feb 24, 2011 | 02:15 PM
  #887
Rich007007's Avatar
Just looking for somewhere to test my signature.
Old Feb 25, 2011 | 07:23 PM
  #888
steevo's Avatar
Does anyone know if the Door Chirp was removed for 2011? I am talking about the sound the car is supposed to make when you lock and unlock the doors using the thumb button on the door handle. The manual calls it a buzzer and indicates it should buzz once when unlock and twice when locking. My 2008 Altima behaved exactly like that also. Reason I ask if it was removed is my friend also just bought a 2011 and his is also silent. Cant find any information in the manual or on the net. No settings on the nav unit either.
Old Feb 25, 2011 | 07:32 PM
  #889
sg1214's Avatar
You can disable it from what i hear, mayb someone was playing around with it before you took delivery.
Old Feb 25, 2011 | 08:20 PM
  #890
steevo's Avatar
This car came out of inventory and has a build date of Feb 2011.. So I dont think its been around long enough to have been messed with. I took same day delivery I am thinking maybe they "forgot" to set something up.
Old Feb 26, 2011 | 06:22 AM
  #891
SMG's Avatar
SMG
Press the lock and unlock buttons on the remote simultaneously until you see the lights flash. That will bring the chirp back.
Old Feb 26, 2011 | 02:47 PM
  #892
bth1457's Avatar
hi im new to this forum and ive been trying to get an answer for my problem.
my problem is... i got vleds hid kit plug and play but it just doesnt work..
i was wondering if anyone else got vleds and having the same problem as me.
does plug and play not work?
Old Feb 26, 2011 | 05:16 PM
  #893
w06ejmm's Avatar
I am the proud owner of a new 2011 SV-Sport-Technology Maxima. I have 3 questions.
1) I ordered a sub floor trunk organizer online (Nissan part # 999C2-MV001) and the deepest compartment hits the top of the spare tire and makes it sit about 2” too high. Is there a trick to this that I don’t know about?
2) How do you get the speed limit to show on the GPS map? I have that feature turned on but it never shows. I’ve driven on plenty of main roads and the Interstate highways, but no speed limit info.
3) Lastly, when changing your oil filter, what do you do to keep the old oil from getting all over the car frame that is right below the filter.
Thanks very much for any help.
Old Feb 26, 2011 | 10:43 PM
  #894
dr_2010SV's Avatar
Originally Posted by 19kdrill
Nobody???
The wheel you show in that picture isn't a 7th Gen Maxima wheel (at least that I'm aware of).
You could try "US Wheel Exchange" if you want to check out some factory Maxima PVD chrome wheels. They are $pendy though....
http://uswheelexchange.com/index.php...emart&Itemid=4
Old Feb 27, 2011 | 06:53 PM
  #895
w06ejmm's Avatar
Update on #2. I finally saw the speed limit dispalyed today while driving on I40. So I guess there just aren't many areas around here (Nashville) where speed limit info is available. My Garmin unit shows speed limits on about 95% of the roads around here.
Still looking for answers to questions #1 and #3 (see above).
Old Feb 27, 2011 | 07:39 PM
  #896
steevo's Avatar
Ill try that again. I tried it once it cancelled and restarted the short horn beep when locking with the remote. I am talking about the small chirp sound when you use the thumb button on the door handle. The manual calls it a buzzer.
Old Feb 27, 2011 | 07:44 PM
  #897
steevo's Avatar
I can make a guess on #3.. My 2008 Altima had a full size spare. The tire is taller than the well. So the trunk carpet ends up with a higher section in the middle. My guess it that it is the same way in the Maxima. So they probably designed the underfloor tray to sit as high as a full size spare would.
Old Mar 3, 2011 | 06:00 AM
  #898
jasn's Avatar
I'm no longer new here but I do have a (likely stupid) question about the NAV screen...
I like to drive known routes that I don't need intimate directions using the Status screen. That way I can also see song title AND Artist for my iPod playlists. The simplified route directions at the bottom of the screen are great... distance to next turn, remaining trip mileage and time, etc., but I have to say the blue arrows or lanes stacked along the left side can confuse the heck out of me sometimes when I'm on multi-lane highways. Sometimes they're all straight; sometimes there a combo of straight and turns, sometimes they're different colors...WTF?
Can someone give me a few pointers as to how I should read those dang things? Thx.
Old Mar 3, 2011 | 06:46 AM
  #899
steevo's Avatar
It is all the next moves in your route, read from left to right.
Old Mar 3, 2011 | 08:38 AM
  #900
Disco Batman's Avatar
iPod question incoming.
I just bought my 2011 SV with monitor package this monday. Everything is great expect this one minor issue and I figured I'd ask here before I run back to the dealership.
I have a 120gb 5th gen iPod that I had been using with my aftermarket Pioneer stereo that was in my RX-8.
It's fully updated on firmware and have never had a problem with it.
It's currently plugged in to the USB port in the center console of my Max.
When I first turn the car on it doesn't recognize the iPod is there. After a few minutes of driving the car will switch from whatever I'm listening to, FM, XM etc. To the iPod interface, and there is every thing and all is well.
I changed iPod cables and also tried my iPhone 4 with the same results. Is this normal?
Thank you for any help.
Old Mar 3, 2011 | 04:20 PM
  #901
dr_2010SV's Avatar
Originally Posted by Compusmurf
Ok, all the other forums have this thread for our newer members who have less than 15 posts and can't post a new thread. So, instead of threadjacking someones thread to get your question answered, do it here!
Please tho, search first. It's VERY likely your question has been asked by someone else.
I did not see a prior thread on this so.............
"Trim around the wheelwell opening"
I noticed a 7th gen w/Sport Package (not a 2011) yesterday with color matching trim.
Is this standard on the Sport model and not on the Premium?
My 2010 SV Preimum has no trim around the wheel well openings.
Old Mar 4, 2011 | 01:54 AM
  #902
lightonthehill's Avatar
No 7th gen Maxima comes with trim around the wheel well openings. When you see such trim, it has been added after purchase. I always apply black hard rubber trim around the wheel well openings of every vehicle I buy so as to reduce the chance of careless drivers damaging my paint by opening their door against my car.
I am using 1" wide by 1/2" thick black hard rubber on my white 7th gen Maxima. It is not noticable next to the dark wheel well opening because I sanded the white paint showing inside the wheel well and painted that area black.
Old Mar 4, 2011 | 02:12 PM
  #903
jasn's Avatar
Thx steevo.
Old Mar 4, 2011 | 03:38 PM
  #904
dr_2010SV's Avatar
Thanks for your reply LIGHT. And yes paint protection from careless drivers is the reason I would like to install some. I have the Crimson BlacK so the black trim should blend in just fine I would think.
If I may ask, where did you order or buy this trim from?
Old Mar 4, 2011 | 07:55 PM
  #905
Black molding would look great on Crimson Black.
Almost any auto store either carries this or will order it for you. I have lots of boxes of molding remnants left over from five decades of doing this, so often don't even have to buy new molding. I have bought black rubber molding from places like Advance Auto, Pep Boys, Auto Zone, Carquest, NAPA, etc, etc. Any big auto detailing shop should have molding on hand.
The size doesn't have to be anything in particular. I like 1" wide because it doesn't look as wimpy as narrower trim, but can still be curved around the opening. Wider molding gets harder to bend, and doesn't stay on quite as well. Any thickness from 1/4 inch up should work, although anything over a half inch thick might not look 'cool' with the smooth style of the 7th gen Maxima.
I load my wife's trucks down with molding, including very wide and thick side molding. I work very hard to trim the molding very neatly, in order to give an 'OEM' look.
Old Mar 4, 2011 | 09:04 PM
  #906
Beach's Avatar
Light, any pictures?
Old Mar 5, 2011 | 04:16 AM
  #907
SMG's Avatar
SMG
Mine sometimes does weird things like that. However if I turn the iPod on first then plug it in, the car recognizes it right away. The car also has no problem recognizing the iPod right away when I come back after leaving it plugged in either by accident or on purpose.
Old Mar 5, 2011 | 07:16 AM
  #908
Imago Dei's Avatar
Hello 1st post here.
I have been some reading on here and there is great info! Im picking up a left over 2010 sv for my wife on Monday. We are trading in a 07 Tahoe in hopes of saving some $ due to the gas prices. Her job requires her to have lengtly travel times. The talk about $90 oil changes at 3750 miles and 93 oct fuel have me a tad worried. We care nothing about high performace. I hoping she will be fine with 87 oct and normal 5-30 oil change? I went to the dealer planning to get an altima but she fell in love with the maxima. The Tahoe averaged about 15-16 mpg real world on hwy, can i expext to get 10 more mpg out of the Maxima? Also the Tahoe had a oil monitering system and we could get 6,000 miles out of an oil change due to all the hwy miles and few start and and stops. Can we extend the maxima to 6,000 on reg oil and gas if its mostly hwy miles? Also are there any updates to things to look for in this maxima, it only hase the cold package. Thanks for the help!
Old Mar 5, 2011 | 07:36 AM
  #909
09Maxima_Sam's Avatar
The 2010-2011 recommend Premium grade. 2009 require Premuim. It is all basically down to ECU programming and such. As for gas mileage I average about 23 MPG in mine with typical driving of less than 20 miles per day. But then I am easy on the throttle. The car has the ability to remind you of maintenance items based on mileage elapsed including oil change. But it does not truly monitor the oil quality. I change my oil on my own at 5,000 intervals using Mobil1 synthetic. If you use a quality dino or synthetic then you can avoid the stealership's outrageous oil change markup scam. I also have the cold package on mine and enjoy it very much on those cold days as I get older.
Here is a link to the 2010 Owner's manual to help you answer some more of your questions.
http://www.nissan-techinfo.com/deptog.aspx?dept_id=37
Old Mar 5, 2011 | 07:45 AM
  #910
Imago Dei's Avatar
Thanks for the info. Is 23 mpg hwy and in town? What do you average for hwy real world? thanks
Old Mar 5, 2011 | 07:48 AM
  #911
23 is basically rural small country town driving for me. If you expect all Highway driving then 28+ is possible for sure in this car.
Old Mar 5, 2011 | 07:53 AM
  #912
Imago Dei's Avatar
Good news thanks
Old Mar 5, 2011 | 05:56 PM
  #913
Imago Del - Both Nissan dealers I use automatically put 5W30 Shell dino oil in on every oil change without even asking. This meets all warranty requirements. Especially for highway driving, dino is great. I once used nothing but dino in a Maxima for 206,000 miles in Atlanta commuter traffic, and not only had zero engine problems, but saw that car still tooling around town several years after letting it go.
In 2010, Nissan changed the 'premium required' warning to 'premium recommended.' Midgrade is close enough to premium that I have run midgrade after the first 18 months on every Maxima I have owned (have owned nothing but Maximas since Oct 1984). Nissan says we can use regular in the '10 and '11 Maximas, but that this will result in measurable performance reduction. With midgrade, I have not been able to detect any performance reduction. Your wife may do OK with regular, but make sure there is not even a hint of pinging, etc.
I would still recommend oil changes at each 4K or so miles with dino, even with mostly highway miles. With a synthetic blend, I would not hesitate to go 5K to 6K mostly highway miles between changes, and, with a full synthetic oil, I see no problem with maybe 7K mostly highway miles.
Whenever you find a few moments, scan this board and you will pick up on the things going on with your Maxima.
Welcome aboard!
Old Mar 6, 2011 | 05:35 AM
  #914
Imago Dei's Avatar
Thanks! I will change oil every 4k and keep an eye on it running87 oct.
Old Mar 7, 2011 | 06:45 AM
  #915
My connection is flakier than yours it seems. The whole reason I wanted the monitor package was the supposedly great iPod interface. I'm taking it to the dealership today to get it looked at. I'll post whatever they find.
Old Mar 8, 2011 | 02:49 PM
  #916
09A35's Avatar
I just purchased a 2010 Maxima, but I cant for the life of me figure out what model I have? I believe from searching the forum that the Maxima S is a base model, and the SV is the premium w leather, and other options?
Another question is I have noticed that my car does not have the side view mirror turn signals on the actual mirror as other Maximas Ive seen do have.
Also I have noticed it has the inserts on the front bumper for the fog lights, but no actual lens for the fogs but rather a plastic cover?
I have leather interior along with sunroof, and dual power front and passenger seats so Im confused as to what model I actually have...
Old Mar 8, 2011 | 02:51 PM
  #917
09A35's Avatar
correction, it's an 09
Old Mar 8, 2011 | 05:26 PM
  #918
You have an 'S' with leather special ordered by the dealer. Every level above the 'S' has the LED turn signal lights on the outside rear view mirrors.
These are the four levels:
S
SV
SVwith Sport package
SV with Premium package.
Various technical/navigation packages are either unavailable, available or included with each of those levels.
Old Mar 8, 2011 | 07:10 PM
  #919
Need4MaxiSpeed's Avatar
When I use the door handle button, my 2011 Max beeps twice when I lock it and then it beeps once when I unlock the passenger door and then once again when I unlock all of the other passenger doors. Wish I could get the the beep to work with the remote instead of the horn from my key remote. The horn sound is annoying from my key fob..
Old Mar 8, 2011 | 07:16 PM
  #920
I am averaging 20-21 in town and around 26 on the highway. Wish I could get 28 MPG on the highway like some posters claim. When I am on the highway I even put the tranny in manual and put the tranny in 6th gear after I am up to cruising speed. Keep in mind that I usually do 70-75 MPH on the highways here in and around Washington DC.
