HID/Headlight/Foglight combo thread.
Old Jan 27, 2012 | 07:58 AM
  #641
blingmaxmia's Avatar
Hey I purchased my hid kit and bulbs from this sitehttp://www.blinglightsmotors.com as well as my fog lights. They are great with customers and if you need help with installing the product they are available at all times so help. I too have a maxima and i know for a fact that these lights work well and look great with my car. here is the direct link to the maxima page.
Old Jan 27, 2012 | 07:59 AM
  #642
Originally Posted by Ryan31
Yes, the kit for the S model is an H11 Kit for the low beams.
The S model does not have the switch to turn on the fogs. There is 2 routes you an go on that. Either buy Ebay OEM style Fog Lights that come with the housing, Foglights, wiring and a push button or you can plug buy an actual Nissan OEM kit (a bit more money) since the existing Fog Light wiring is there, just tied back, in this case you would need to order a Combo switch for the steering column which has the turn on for the fogs.
Old Jan 27, 2012 | 08:00 AM
  #643
Hey I purchased my hid kit and bulbs from this site http://www.blinglightsmotors.com as well as my fog lights. They are great with customers and if you need help with installing the product they are available at all times so help. I too have a maxima and i know for a fact that these lights work well and look great with my car. here is the direct link to the maxima page.
Old Jan 27, 2012 | 08:13 AM
  #644
Nemo7's Avatar
^ Spam?
Old Jan 27, 2012 | 09:19 AM
  #645
PSU09MAXIMA's Avatar
So going to be getting a 35w 5000k from DDMTuning.com and I wanted to know if I need to get an HID Harness, Error Eliminator, & Adapter cables sorry about some many questions. I appreciate the help
Old Jan 27, 2012 | 10:38 AM
  #646
Nemo7's Avatar
from what i have been told they are plug and play no harness needed unless running the switch to turn off and on
Old Jan 27, 2012 | 10:54 AM
  #647
Tee00Max's Avatar
Im running 35W 5k in my heads and fogs and I love it!
Old Jan 28, 2012 | 04:22 PM
  #648
  #649
Did you have to get a relay harness and error eliminator?
Old Feb 1, 2012 | 07:53 PM
  #650
Gman1337's Avatar
Quick Question.
Sorry if this was asked in earlier posts. I couldn't find a issue similar to mine.
I bought the headlight D2S NOTTO 10000k replacement bulbs from CarID.com. I already have the HID kit as a standard in my car (11' SV-S model). Installed the bulbs properly and am having an issue with them turning on. At start of car sometimes no bulbs turn on. After turning lights on/off a few times 1 or both of the headlights turn on. What is the problem? 35w bulb replacing another 35w bulb, i don't understand. Please help!
Old Feb 6, 2012 | 07:09 PM
  #651
rcdude1990's Avatar
Hey guys i need some help.... i just installed 20,000k hids in my fogs and they look awsome!!! 2011 Maxima
my problem is this, i changed the DRL to a blue LED (Which works fine) but im having trouble with the turn signal. i want to buy a Blue led turn signal. i purchased one from ijdmtoy and installed it but it popped a fuse (which i cant find the fuse, which resulted to me giving it to the dealership to change) i dont want to place the led back in a pop it again. anyone know were this fuse is?
also the guy i just bought my hids from said the led turn signal i bought is ment for a signal polarity somthing when a turn signal actually needs double polarity something. so i guess the leds i have are pointless.. any suggestions on finding a blue led turn signal that wont pop a fuse?
also my car comes stock with hids in the headlight, but there not really cutting it for me. i purchased a new pair of d2r bulbs and there better than the stock bulbs, but i kinda wanna match my headlights with my fogs now. i see online d2r hid conversion kits but im totally confused on how to even install them... can anyone help me on this?
this site is great but for some reason im not permitted to create a thread... ive posted like 20 messages but i dont know why i cant post a new thread lol
Old Feb 6, 2012 | 07:33 PM
  #652
Tee00Max's Avatar
Yea I have relays on both but no error eliminator, shouldn't need one of those...
Old Feb 7, 2012 | 09:10 AM
  #653
seesole's Avatar
Hid light pattern
Hey guys, I am thinking about doing 6K HID for the fogs and change my bulbs to 6K for the lows, my question is, I have the D2S bulbs from factory and just wondering if the factory fog lights are set up for HID bulbs, would the pattern be good? or is it just going to throw the light out all over the place, worried about blinding oncoming vehicles! Should I even be worried about this?
Old Feb 7, 2012 | 09:22 AM
  #654
If your asking if they are already set up for HID the answer is no. Also they don't have the projector beam set up like the low beams do so they may tend to throw light everywhere but I'm sure some1 here can give a more detailed answer to this.
Old Feb 7, 2012 | 09:24 AM
  #655
rcdude1990's Avatar
bump... anyone help?
Old Feb 7, 2012 | 10:43 AM
  #656
eljoker's Avatar
20,000k? Wow what color is that, is it even visble?
Old Feb 7, 2012 | 11:39 AM
  #657
alexishaze's Avatar
If you're putting 35w, there's nothing to worry about. The light gets scattered everywhere mostly on the road.
Old Feb 7, 2012 | 11:46 AM
  #658
eepowers's Avatar
OK, I need help guys. I attempted to install my kit from ddmtuning last night, plug and play it is not. the socket from the factory light did not fit into the ballast. I don't know if they are different, or what, but it would not fit. the two wires fit into the factory socket, but for this I'd have to use electrical tape to secure the wires. anyone know of an adapter?? I really want a true plug and play kit.
I want to go from this: Name:  20120206_203749.jpg
to this: Name:  20120206_203828.jpg
Old Feb 7, 2012 | 12:03 PM
  #659
tonyn3b's Avatar
to this:
Yeah I had the same issue too. Was disappointed that I had to use electrical tape around the plug since it is not a clean installation and not as convenient.
Old Feb 7, 2012 | 12:40 PM
  #660
alexishaze's Avatar
There's a connector for H11 to standard ballast that should be included in all pnp kits.
Old Feb 7, 2012 | 01:14 PM
  #661
rcdude1990's Avatar
Deep blue
Old Feb 7, 2012 | 01:17 PM
  #662
rcdude1990's Avatar
Yea the bulb included in the hid kit should have the connection piece that goes into the ballest... The connection that goes from the car (which u have included a picture of) gets connected to the connect on the hid bulb, not the ballast
Old Feb 7, 2012 | 01:18 PM
  #663
tonyn3b's Avatar
I ordered mine a month ago from ddmtuning and they came with 2 pins instead of the connector. The online instructions shows the install for both types.
Old Feb 7, 2012 | 01:24 PM
  #664
rcdude1990's Avatar
Yea ive notice that they send them now with just the connectors and not with the plastic piece... Just be sure your positive goes with the positive and negative to negative
Old Feb 7, 2012 | 01:32 PM
  #665
tonyn3b's Avatar
Do they sell that premade wire or adapter for the pins anywhere?
Old Feb 7, 2012 | 01:56 PM
  #666
Ghozt's Avatar
I'd return any that came bare wires and re-order one with the plastic connector - problem solved. Yes they still sell them with the plastic connector.
Old Feb 7, 2012 | 02:12 PM
  #667
eepowers's Avatar
there is no other connection on the hid bulb for the plug from the car. there is a port on the ballast. the wires our of the ballast connect to the bulb. there is a seperate set of wires that have the exposed wire tips and a connection that fits into the ballast. when I placed the wire tips into the connector from the car, and connected the other end to the ballast, it turned on. but this is obviously not ideal since I have to tape the ends, I.e. not plug and play.
Old Feb 7, 2012 | 02:16 PM
  #668
alexishaze's Avatar
Bare wires plus extra modifications does not equal plug n play and shall not be sold as.
Old Feb 7, 2012 | 02:38 PM
  #669
tonyn3b's Avatar
Found these h11 adaptor covers. Wonder if its sold locally anywhere. http://www.ebay.com/itm/230699394908
Old Feb 7, 2012 | 05:49 PM
  #670
rcdude1990's Avatar
The seperate set of wires that have the pins exposed... Are those on the hid bulb? Those exposed wires are the ones that get connected to you cars connections... Im at work... Insert ur email address and ill email you a picture of what the connections should look like... I would post a pic here byt im on an iphone
Old Feb 7, 2012 | 06:52 PM
  #671
eepowers's Avatar
i know the exposed wires go into the cars connectors. The issue is thats not true plug and play because i have to tape the connectors to keep them from coming out. The kit looks like above, but should have looked like this...
connectors on both ends, not exposed wires. the one in the picture from ddm is true plug and play. the one i got is not.
Old Feb 7, 2012 | 07:10 PM
  #672
rcdude1990's Avatar
Oooooo i understand your point now. Yea they should have the connectors, but i judt recently purchased two hid kits and they both have the wires exposed, i conected and placed electrical tape around it to prevent water getting into... But yes now i understand your point
Call ddm maybe they can help you out by replaceing it... I have no patience lol so it wouldnt really bother me
Old Feb 7, 2012 | 07:20 PM
  #673
eepowers's Avatar
i tried to call them, but no answer, so i emailed instead. If they cant send the other part, i might as well send it back and just order the one from vme as i originally planned. The only reason i didnt is cause i was inpatient and didnt wanna wait the 20 days they said it would take to ship out. the other issue is, the next time i get into the wheel well, i wanna do the headlights, install fogs, and install HID into them at the same time (lazy so i dont have to go into the wells again. lol)
Old Feb 7, 2012 | 09:09 PM
  #674
MikeRS1981's Avatar
Mine came shipped to me like that as well. I couldn't figure it out and got frustrated, so I threw everything away. On top of that it took like 3 weeks to get them. Everyone used to rave about DDM but I can't stand them. Good luck returning something with 3 week turn around times
Old Feb 7, 2012 | 09:17 PM
  #675
tonyn3b's Avatar
Just ordered these from ebay. H11 connectors $6.99 with free shipping from the US.
http://www.ebay.com/itm/180699005375?
Old Feb 7, 2012 | 10:02 PM
  #676
rcdude1990's Avatar
Is there a way to have a aftermarket hid kit in the headlights? My car came with the d2r setuo but like i said i would want my fogs and headlights to match... I see d2r kits online but i cant figure out how to install them... Any help? Also any idea on blue led front turn signals?
Old Feb 8, 2012 | 07:17 AM
  #677
In order to get to the fogs to change the bulbs or put HID into the Fogs do I have to go threw the wheel wells/ or can I just lay on my back under the front bumper and get to them to change out the bulbs?
Old Feb 8, 2012 | 07:27 AM
  #678
eljoker's Avatar
You have d2S bulbs in there not d2R. Go order a set of these http://www.diodedynamics.com/store/i...all-sizes.html in D2S fitment and chose the color you want. Then order a set of HIDS in H11 size in the same color you bought the D2S bulbs to match up.
I bought 8000k and kinda wished I had boughten 6000k. I have h11 for my fogs in 3000k waiting to go in. Once they go in ill decide if I want to stay with the 8000k.
For some reason, my 8000k dont seem as bright as the 8000k that i had in my impala.
Old Feb 8, 2012 | 07:32 AM
  #679
rcdude1990's Avatar
Yea for the fogs. Jus lay on ur bac and take out the first 2 pins thats close to the fog light. Thats how i did it
Old Feb 8, 2012 | 07:59 AM
  #680
rcdude1990's Avatar
Hmmm i bought 6,000k buks i. D2r and they fit and work hahah... I just purchased 20,000k bulbs for my fogs so i was wonderig if i could put a new ballast and stuff ( like my fogs) in the low beams... And i belive they are less bright because of that lens in front of the light
