2009 Nissan Maxima SV Air Conditioning Mode Question
Old Jan 18, 2019 | 07:04 AM
QueefKing's Avatar
Yesterday I replaced the blower motor in my car and all works well but I can't seem to remember that if when the AC is set to Auto if the mode for which vents the air comes out of can be set to bottom and top. At the moment when I set the AC to Auto the air can only come out the bottom vents. If I switch mode to top and bottom the AC automatically goes into Manual mode. I don't remember this behavior in the past so if anyone can confirm this is normal let me know!
Old Jan 18, 2019 | 07:55 AM
LtLeary's Avatar
In AUTO mode, you only control the temp, not the vents. Once you select either a fan speed, or vent selection, it goes into manual mode.
Old Jan 18, 2019 | 08:16 AM
tbm5690's Avatar
Depends on the temp that is set...warm air should default to the floor vents, and the system should default cooler air to the upper vents.
Old Jan 18, 2019 | 08:26 AM
QueefKing's Avatar
Thanks for the replies guys. I guess I didn't mess anything up after all.
Old Jan 18, 2019 | 08:50 AM
mahanddeem's Avatar
A side question please: does manual mode (no light on A/C button) still mean the A/C compressor is on?
Old Jan 18, 2019 | 12:05 PM
LtLeary's Avatar
No, if the light isn't on (unless it is burnt out) the AC is not on either.
Old Jan 18, 2019 | 12:12 PM
mahanddeem's Avatar
That exactly answers my question. Light works if I push it on.
Thanks.
Old Jan 24, 2019 | 01:11 PM
Ryan Callaway's Avatar
If yu don’t mind me asking how did you go about doing your blower motor replacement am needing to do so but not sure how to tackle this
Old Jan 24, 2019 | 01:41 PM
QueefKing's Avatar
It's a real easy fix. Basically you remove the glove box (8 screws), and then the small side panel that is between the glove box and passenger door. Then you remove the harness and screws from the blower motor, install new one and put everything back. I did it all during my lunch break with time to spare.
Old Jan 24, 2019 | 03:34 PM
thank you sir much appreciated
hieppo
May 12, 2015 01:34 PM
NissanSE98
May 15, 2008 03:23 PM
Gemini67
Dec 5, 2006 02:40 PM
fhs8860
Jun 6, 2006 08:24 AM
WetDry
Jan 11, 2005 11:10 PM
