Brembo pads/rotors
Old 12-14-2018, 09:24 AM
smokeydriver's Avatar
Brembo pads/rotors
Hi all. So I recently went ahead and replaced my front pads/rotors with Brembo's. According to Brembo none fit, but these fit like a glove. Just hoping to help anyone else that needs it. Also, I ordered it on Amazon but 2-3 months later Amazon cancelled my rotor order because they couldn't fulfill it. Autozone was up next and did delay the shipping a couple days but otherwise it went smoothly with them.
Brembo front pads-Part Number: P56062N
Brembo front rotors- Part Number: 25844
smokeydriver is offline
Old 12-14-2018, 11:47 AM
robtroxel's Avatar
Wow. Could you keep us in the loop about the performance as well as the wear factor? I always felt to Max brakes (Not breaks) needed just a little more grab.
robtroxel is offline
Old 12-15-2018, 03:36 AM
Will do! So far they're great. Literally the smoothest brakes I've ever had, and I've owned a ton of cars and was a mechanic on high end cars.
Old 05-28-2019, 09:29 AM
BlackNYMax's Avatar
How have the Brembo rotors and pads held up? and did you do the rear? I need to do my brakes in the next few weeks and am looking for options as far as rotors go.
BlackNYMax is offline
Old 05-29-2019, 10:59 AM
They're holding up great. I do have very minor brake squeal on on rotor but it's only at very light braking and it's super short. I would highly recommend switching to them along with the Brembo pads.
Old 06-03-2019, 05:33 AM
BlackNYMax's Avatar
I would like to replace these, Did you do the rears as well?
Do you happen to have the part numbers for the rear Rotor and Pads?
Old 06-03-2019, 05:45 AM
robtroxel's Avatar
Noticed your car desciption and a 160 MPH top speed. How did you coax that out of the current Gen Maxima? See why you might need the Brembos now.
Old 06-04-2019, 06:19 AM
Sorry, no. I didn't need rears and didn't spend time looking for those part numbers. I do recall it would have taken even more work to figure out then the fronts though.
Old 06-04-2019, 06:22 AM
That's actually funny. I posted that a LONG time ago but it used to show what car I was talking about. I have a MR2 Turbo that those stats applied to when I'd gotten rid of my last Maxima. The new one is a 2016 that's stock except for the tint and front pads/rotors. Definitely cannot do 160+ in this car.
Old 06-04-2019, 08:11 AM
BlackNYMax's Avatar
Thank you for getting back to me. I think I will be passing on these. I will probably just be getting all 4 from autozone or somewhere and use what is meant for the car and call it a day.
If I decide to keep the car after a lease then I will worry about better brakes.
Old 06-11-2019, 06:55 AM
JS Bach's Avatar
I've been researching the Brembo parts catalog for matching rear rotors and pads. I might have a match, but will need to await confirmation from my mechanic--who will be changing the oil in my '16 SR this week (as well as checking the brakes).
From my research, the rear rotors/pad of the 2015 Infiniti Q40 may be the cross-reference equivalent. When I check applicable vehicle(s), it lists a bunch of Nissan/Infinit models, so I know there is a match for the 8th gen Maxima.
As for brake systems on the 8th gen, I assume they are all the same across all trim levels? (S, SV, SL, SR, Platinum). Can anyone confirm?
JS Bach is offline
antnvlz1294
25
07-28-2016 03:23 AM
murderedmax05
01-09-2010 08:00 AM
str8max
05-13-2009 07:08 AM
paulpearl
04-07-2009 08:27 AM
ghostrider17
05-12-2005 08:37 PM
Quick Reply: Brembo pads/rotors
