Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
K-Sport Coilovers Talk
Old Mar 1, 2006 | 09:16 PM
  #801
Stagnet04's Avatar
From jinsu
Yes
Yes
Whatever you think is best. The range is very large
THANKS MAN!!!! REALLY APPRECIATE IT!!!! MAN I LOVE MAXIMA.ORG!!!!
Old Mar 1, 2006 | 09:50 PM
  #802
Mr.Duck's Avatar
Originally Posted by Stagnet04
I didn't want to sit here and take a week to go through 27 pages of this forum so hopefully someone can help me out with my questions.
-Where can I get these k-sport lowring springs the cheapest?
-Is it possible to install them yourself if not how much would it cost to install them?
-After installation would I be able to lower and higher the car at anytime?
-What is a good "inch" drop for the front and back?
mmmm, I think thats it. LOL sorry, If anyone can help me out, I'd really appreciate it.
actually the guy that responded to you is wrong.
if you are looking for the "lowering springs" not the "coilovers" than no you cannot change the height. they are just lowering springs, and you would need spring compressors to change them out,
also youwould need to buy some new struts because the stock struts will not be able to handle that kind of drop.
for the installation, if you are going to get the full coilover set up the installation is very simple, take out the entire suspension assemply, and pop in the coilover easy as that.
also people, i am getting sick and tired of reading "i am too lazy to read 27 pages" or "i am too busy" I am getting sick and tired of seeing the same questions over and over again in this thread, take some time read the thread, you will learn a ton of information. The whole reason for this thread is so that we could have all the info on these coilovers in one place. not to keep asking the same questions over and over again. /rant
Old Mar 2, 2006 | 06:04 AM
  #803
d00df00d's Avatar
Old enuf to pick his own gears
Originally Posted by azn_s3nsation87
About to install my Ksport, probably after finish off all my tests. Just wondering what would be some good preload and dampen settings, thanks guys. I'm too busy to read all of the pages in this thread.
Zero preload
Half-turn from full soft, or full stiff
That info is repeated several times in the thread...
I guess I need to add a link to it in the first post.
Old Mar 2, 2006 | 06:05 AM
  #804
d00df00d's Avatar
Thank-you.
Old Mar 2, 2006 | 06:12 AM
  #805
azn_s3nsation87's Avatar
Yah...man, You should add a link on the first pages on Ksports settings and crap, !!!!
Old Mar 2, 2006 | 02:54 PM
  #806
lex4style's Avatar
Originally Posted by max929
Whats up Lex,
First off, the car looks SICK!!!!! The drop was the finishing touch. The popping sound is probably the collar issue that you have heard so much about. The car is safe to drive so don't sweat that, next time you chk on the coilover just give the collars a little tap with a skrew driver/hammer to tighten it down. About the collar on the rears, make sure that you are going counterclock wise, don't go by my arrows. I hope this helps......Damn the Max looks good
thanks man. yea thats what i thought. i just here is once and awhile. The ride is great! i sometimes forget im on coilovers...im going to pull off the wheels tomorrow and make sure everything is nice and tight.
Old Mar 2, 2006 | 03:42 PM
  #807
one more question, on the front struts, does it matter what which struts goes on which side? Because the camber plates are different from each other, right?
Old Mar 2, 2006 | 03:51 PM
  #808
Black Maxima
Yes, it does matter. It is very noticeable. The two camber slots on each side should be running from the right to left. Not front to back. The inside strut bolt is off center a tad. Look out for that on the KSport.
Old Mar 2, 2006 | 03:52 PM
  #809
max929's Avatar
MAKE SURE the camber plates are facing each other. You want them horizontal, not vertical (side way, not up & down) The pionts facing the engine.
Old Mar 2, 2006 | 03:54 PM
  #810
2kayznmaxima's Avatar
as long as the camber plates face horizontal than you should be good. they can only go in one way if you have the camber bolts horizontal. as in when you move them they should go left and right, not up and down.
Old Mar 2, 2006 | 04:03 PM
  #811
djfrestyl's Avatar
Suspension Yoda
Mr. coilover expert over here
Old Mar 2, 2006 | 09:05 PM
  #812
Stagnet04's Avatar
Zero preload
Yeah you should add some links like how to install link, where to buy link, ect...ect... if it's possible......
Old Mar 2, 2006 | 09:16 PM
  #813
haha i learn from the best
Old Mar 2, 2006 | 09:49 PM
  #814
thanks everybody
Old Mar 3, 2006 | 05:33 AM
  #815
i30dvr's Avatar
Originally Posted by enomik-1
I finally got my Ksports in today and I pretty much know what every thing is
fo exept 2 little black wrench type thingys that say D2 on it.. Can any one
tell me what these things are and what theyre for? Thanks. Oh and also wanted to know exactly what preloading is and if it can be done by hand?
I just wanna be sure every things done right cause I heard Noise issues are
eliminated if the springs are pre loaded.. Thanks again in advance.
in your pic, is your car lowered all the way???
Old Mar 3, 2006 | 08:15 PM
  #816
Poowill's Avatar
Wow that must of been an old post by enomik-1.
As he probably won't be in here to answer your question, i will. He is probably lowered about the same height as me which is not even close to being all the way.
Old Mar 4, 2006 | 12:36 PM
  #817
Black Maxima
Measured today. Exactly 24.75" in front and 25" in back...
I like this picture, but it's kind of dark:
Old Mar 4, 2006 | 03:17 PM
  #818
Mr.Duck's Avatar
hey guys here some new pics of my car dropped on ksports and Enkei OR52's
Old Mar 4, 2006 | 03:51 PM
  #819
Bluesbrekr's Avatar
Doctorate in Detailing
Lookin' good, Duck! Did you take those pics today?
Old Mar 4, 2006 | 04:11 PM
  #820
Mr.Duck's Avatar
why yes i did right after work
Old Mar 4, 2006 | 07:41 PM
  #821
lex4style's Avatar
this sucks azz....i tried and tried to loosen my rear coilovers bottom collar but that damn thing wont budge. I even tried to tap it with a mallet and a screw driver, but it doesnt come loose. i guess im gonna take it to a import tuner shop that specializes in all this stuff and see if they have any bright ideas.
Old Mar 4, 2006 | 08:03 PM
  #822
VQuick's Avatar
Chassis Freak
Drop looks great Mr. Duck, just right. I'm not digging the mudflaps, though, mudflaps should always be body color IMO.
Old Mar 5, 2006 | 12:18 AM
  #823
Mr.Duck's Avatar
hey lex, were you able to move the bottom collor b4 you installed?
thanks for the compliment vquick, hopefully we can get a huge meet going again this year
Old Mar 5, 2006 | 10:09 AM
  #824
lex4style's Avatar
yea man i tried, but it wouldnt budge. im just gonna take it to one of the import tuner shops, my friend said they will know what to do. worse comes to worse ill have to send it to ksport to get it fixed or replaced.
Old Mar 6, 2006 | 11:05 PM
  #825
Mr.Duck's Avatar
so you installed them, even when they werent able to move, how did you adjust height than?
Old Mar 7, 2006 | 01:11 PM
  #826
I just install my coilovers, i dun here ani major 1 click or clunk sound, but when i cruise above 40 mph, i start to here a countinuously clunk on the right side. am not sure what it is, can some one point out the problem so i can go fix it.
Another question is that, do you guys adjust yur height by taking out the whole coilover or yu guys just jack it up and adjust it with the two top perches, but is it that like preloading? My rear is too low, its cover almost my tires. Thanks for help guys, cuz i i dun kno anithing about coilovers, got it for a present.
Old Mar 7, 2006 | 01:24 PM
  #827
d00df00d's Avatar
Check to see if the dust shields behind your brake rotors have been bent such that they are making contact with the rotors. Also check to see if your brake pads are loose and able to slide around even slightly.
The best way to adjust height is to unbolt the coilovers and adjust the bottom collars. If you raise the car by adjusting the upper collars, you will be adding preload.
Old Mar 7, 2006 | 02:14 PM
  #828
thanks a lot d00d, i love the ksports, fun to drive with and it give me less body roll.
Old Mar 7, 2006 | 02:32 PM
  #829
lex4style's Avatar
nope wouldnt budge. i guess im going to send them to ksport if this tuner shop cant loosen them.
Old Mar 7, 2006 | 02:39 PM
  #830
d00df00d's Avatar
Have you tried Liquid Wrench or something?
Old Mar 8, 2006 | 03:39 PM
  #831
brooklynK3Y
How Do these ride? Stiff?
Old Mar 8, 2006 | 07:54 PM
  #832
d00df00d's Avatar
Great for the highway, bad for rough roads.
Old Mar 9, 2006 | 10:45 PM
  #833
Originally Posted by jinsu
The noise issue in the ksport is solved by lube up the springs and luck nut, loosen and retighten the top sturt valve nut.
Can some one explain what Jinsu is trying to say, am understand mostly everything in this threat now, after i got my coilovers install, but this, i do not get! What a nub am i.
Old Mar 9, 2006 | 10:57 PM
  #834
djfrestyl's Avatar
Suspension Yoda
The noise issue is resolved by lubing the springs (and their perches) and the lock nut, and loosening and retightenting the top strut valve nut.
What's so hard about that?
Old Mar 10, 2006 | 11:01 AM
  #835
TJ_Max's Avatar
Paradox Systems Vendor
Okay, so I got a little tired of guys complaining about dropping the car and ruining your front lip. Also a little tired of people just getting rid of wheel gap and calling their max's "Slammed". Fellas, these are two guys in BROOKLYN, NYC. You have to learn how to drive with a drop. Period. Are they the lowest Ksported out Max's?
Note: Guy in the orange shirt is not the owener of this car.
And you've seen this one before:
Old Mar 10, 2006 | 11:03 AM
  #836
TJ_Max's Avatar
I tried to get my foot under his front lip, didn't quite make it....
Old Mar 10, 2006 | 11:23 AM
  #837
chillin014's Avatar
2nd car looks hawt as hell. That's mine when I get my cf hood. Love that dropped look man.
What's his name?
Old Mar 10, 2006 | 11:29 AM
  #838
TJ_Max's Avatar
What's his name?
Studio718 on NYCMAXIMAS.org, I believe he posts on here too.
Old Mar 10, 2006 | 03:35 PM
  #839
95bkackmax18s's Avatar
dam, that white max is dropped. im low and i can go alittle bit lower, but i need my c.f. lip.
Old Mar 10, 2006 | 03:42 PM
  #840
lex4style's Avatar
well here is the verdict on my coilovers. I #1 had a problem like all others with the clicking sounds. well i fixed that today. #2 my driver side rear coilovers collar was stuck so i couldnt adjust the height on the rear. And today i realized another damn problem, the right rear coilover is drenched in oil, so looks like i have a busted rear coilover. I believe its time for the rears to go in and get fixed. sux major azz.
