Sponsored by:
Sponsored by: CARiD
DE-K 01 in 97
Old Apr 19, 2006 | 07:14 PM
muradk's Avatar
DE-K 01 in 97
gonna put de-k in my 97. just wonderin if anybody can tell me how to rewire injectors. and wats the best rpm switch to use? and tuned ecu such as ts shud work just fine i belive? wat other issues might i ran into? thank u
update
just updating on wats goin on with my swap.. well 1st of all THANK U all of u guys for answerin my annoyin pmz 8-) ... i just got an 01 de-k with 21,000 mil on it for $450. looks clean and well kept, it was all rapped up in clear plastic. oh well, it gonna take me couple of weeks to actually do anytin to it, cause i work 7 days a week 8-( there is never enough cash 8-) besides i wanna try to get that ts ecu i was talkin about and unorthodox stock size pulley. so yee dont give up on me yet plz. if anybody have any suggestions about some extra i shud do to the engine while its out plz tell me 8-) ... thanx
btw junkyard ppl were mad annoyed with me. i asked to open valve covers and oil pan 8-) anytin to make sure my maxima gets the best 8-)
Old Apr 20, 2006 | 09:31 AM
scrhale's Avatar
EManage Ultimate FTW (EU). ECU upgrades cost more, are less efficient, cost to be reprogrammed, and have less features. It is like going out and buying VHS. Sure it works, but why when you can get DVD.
I couldn't tell you how to rewire injectors because I have never done that or spliced wires in my life. Forgive my noobishness
Old Apr 20, 2006 | 09:58 AM
tavarish's Avatar
fwd gone rwd cr00
you don't have to rewire anything. You cut the old injector clips off, and solder the new ones on. It's 2 wires per clip. Summit RPM switch should work good, you can get one at www.summitracing.com The Greddy Emanage Ultimate is the best option, but If you don't wanna be bothered with tuning, a TS ecu (if you can find it) is a good way to go.
Old Apr 22, 2006 | 03:44 AM
jcy98maxse's Avatar
Turbo is too much fun!
Can the sidefed injectors be re-used for on the DEk? the reason I ask is I'm boosted and I already have 500cc sidefed and wouldnt want to get rid of them to get topfed if I can make my current ones work. Can anyone point me in the right direction?
Old Apr 22, 2006 | 06:22 AM
Kevlo911's Avatar
Kevlo for President
PM Stephen Max and ask how much he charges for a modded 4th gen lower IM
Old Apr 22, 2006 | 11:01 AM
jcy98maxse's Avatar
Man I already pm him about some other questions regarding the swap, I hope he mentions this cuz I also asked him about the injector re-use. Still a noob on the swap but what other sensors are needed to swap over? EVAP/EGR and MAP right? How bout the crank pulley, r they the same?
Old Apr 23, 2006 | 08:05 AM
Kevlo911's Avatar
Kevlo for President
Same crank pulley. Swap over EVAP and parts of EGR.
Old Apr 23, 2006 | 10:45 AM
jcy98maxse's Avatar
Is the headers the same distance between each other? I'm hoping my feedpipe wont need modifying to fit. Does the motor sit about the same from the fans also as compared to the DE?
Old Apr 23, 2006 | 06:05 PM
nismology's Avatar
Yes and yes...
Old Apr 23, 2006 | 07:00 PM
jcy98maxse's Avatar
thanx and thanx..
Old Apr 23, 2006 | 07:52 PM
nismology's Avatar
thanx and thanx..
Yer welcome and ....
Old May 2, 2006 | 08:48 AM
muradk's Avatar
update
damn posted it in a wrong place 8-) ... edited my 1st one
Old May 2, 2006 | 04:39 PM
jcy98maxse's Avatar
Outta curiousity, do we use 4th gen coilpacks or 5th gen coilpacks???
Old May 2, 2006 | 11:46 PM
Ceasars Chariot's Avatar
Old Maxima Legend
let me get this straight, you can swap in the vq30de-k in a 1997 model lets say, and use a TS ecu (like the one i have already in my 97?) or is TS doing an ecu for 00-01 model maximas ?
i ask because in the part of the world im in, i can get the whole vq30de-k for a hair more than 00VI/vafc-2 combo ?
can someone explain ?
Old May 3, 2006 | 12:29 AM
jcy98maxse's Avatar
You would be using your 97 ecu because you have a 97 wiring harness. The 00 ecu may not be compatible with the harness (pin-wise) I would think. My 98 will run the DEk just fine and I dont need the 00 ecu to run the car so you should be able to run your TS just fine.
matts95max
Sep 14, 2006 11:30 AM
915Max
Jul 12, 2006 02:05 PM
mforrest100
Jan 28, 2006 02:52 PM
95maxrider
Dyno Discussion and Slips
25
Dec 21, 2005 02:16 AM
skuccio's max
Sep 15, 2005 06:47 AM
