Sponsored by:
Sponsored by: CARiD
My n/a project
Old Mar 31, 2008 | 06:15 AM
  #201
doublea's Avatar
Does anyone has the spec for the stock " Rod Bolts " for the VQ30DEK. I've ordered a set of ARP VQ35 " Rod Bolts " but when the rep received my ordered he called me back seing the note that I was looking for Rod bolts for VQ30DEK. Basically some are telling me they are the same bolts but the rep is saying it's a no no... Does anyone has the spec of the stock Rod Bolts for the VQ30DEK, he say he can check my spec with what is available and maybe they can find a bolt that has the same spec. Otherwise I found a company that make custom fit rods & bolts but let see first what are the stock spec then I can search for alternative.
Old Mar 31, 2008 | 07:35 AM
  #202
nismology's Avatar
DE-K doesn't use bolts. It's a stud/nut setup.
Who's been telling you they are the "same bolts"?
Old Mar 31, 2008 | 07:51 AM
  #203
DrunkieTheBear's Avatar
Turbo'd Saab
crap I was really hoping for these to work.....
so what this bolt and nut setup mean for us
Old Mar 31, 2008 | 07:55 AM
  #204
nismology's Avatar
The rod fasteners in the 3.0 are as strong as you will ever need them to be.
Old Mar 31, 2008 | 08:32 AM
  #205
doublea's Avatar
That's what I meant, but my Fr-english is playing me some trick sometime... In french we say Bolt & Nuts and this refer to stud/nuts. I'll post some pics of the DEK stud/nut later tonight.
I ordered the ARP from a local shop, he tough they where the same and that's why I didn't ordered directly, I let him took the guess... Now what other option is there available beside custom made ? I can only seem to find stockers stud/nut but that might be good enough.
Old Mar 31, 2008 | 02:35 PM
  #206
Turbo'd Saab
well how high of a rev limit were you planning on ( I was thinking 7200-7500)
Old Mar 31, 2008 | 03:31 PM
  #207
doublea's Avatar
I was thinking between 7200 -7500 rpm. Even if the engine would be capable of 8000 - 8500 rpm I would limit the engine to 7200 -7500 rpm in order to preserve it and make it last longer.
I mean if the engine still produce power at 7200-7500 rpm, I have a doubt that pass that rpm any gain would be made but I might just be plain wrong.
Old Mar 31, 2008 | 09:41 PM
  #208
nismology's Avatar
7200-7500 is nothing as far as the rod fasteners are concerned. Stock is fine.
Old Apr 1, 2008 | 05:36 AM
  #209
MOHFpro90's Avatar
Is this the same with the de too? No rod bolts? (you mentioned dek earlier)
Old Apr 1, 2008 | 05:49 AM
  #210
nismology's Avatar
^Yup. 95-01 VQ's.
Old Apr 1, 2008 | 05:57 AM
  #211
nismology's Avatar
With that said, if you are going through the trouble of taking apart and reassembling the bottom end, I would use new "bolts" and nuts.
Part numbers:
12109-31U00 Rod bolts (studs)
12112-42L00 Nuts
12 of each. Cheap too.
Old Apr 1, 2008 | 06:32 AM
  #212
doublea's Avatar
Thank you guys, I'm ordering a new set of VQ30DEK stocker stud/nuts.
Old Apr 1, 2008 | 07:43 PM
  #213
Turbo'd Saab
I'm looking at a DEK motor with 13k miles on it, I shouldn't have to really worry about just replacing the stud/nuts on this engine right?
Old Apr 1, 2008 | 09:20 PM
  #214
MOHFpro90's Avatar
That would be a no.
Old Apr 2, 2008 | 12:17 AM
  #215
nismology's Avatar
IMHO, torque-to-yield fasteners should never be reused. They're so inexpensive that you might as well replace them.
Old Apr 3, 2008 | 05:42 PM
  #216
MOHFpro90's Avatar
Dave order some.
Old Apr 4, 2008 | 05:12 AM
  #217
doublea's Avatar
I've send an e-mail to Dave Burnett so I'll let you know shortly how much they cost.
Old Apr 5, 2008 | 04:51 AM
  #218
doublea's Avatar
I call Dave B, the studs are 3.40 each and the nuts .86 cents, plain dirt cheap.
Now I guess it would be wise to replace all the crank bearing ( not sure if it's how it is call in english ) do I just order the stocker or is there any better option ?
Old Apr 5, 2008 | 01:31 PM
  #219
MOHFpro90's Avatar
Not sure if they have a crank bearing, but here is a nice site thats got some good stuff.
http://www.importperformanceparts.net/
Old Apr 5, 2008 | 04:08 PM
  #220
MOHFpro90's Avatar
What is the bore size for the piston rings? Dave wants to know cause he is ordering his piston rings
Old Apr 5, 2008 | 05:31 PM
  #221
doublea's Avatar
Thanks for the link.
Old Apr 5, 2008 | 09:57 PM
  #222
Turbo'd Saab
I found it 93mm
So doublea what are you doing for the oil pump? I looked into the vq35 stock oil pump (180) but I don't know if its going to be necessary since I plan to only rev to 7500(but I also don't want to end up like dandymax). I have already started pricing my project and its at $4k now but I will have alot of stuff that I am selling at the same time.
Old Apr 6, 2008 | 06:11 AM
  #223
doublea's Avatar
Hey DaveVQ, I've ordered a Toga oil pump because they are rated up to 800HP, here is the link: http://www.importperformanceparts.ne...mpsnissan.html
I'm like you and wont cut corner, since this engine will have a lots of new expensive parts, I want to make sure I wont re-open it before a long time, that's why this entire project will have taken me like 2+ years to accomplished. At the stage I'am that would be easy to get discourage but my goal was set for spring 2009 and I believe it will be done in time ( ready for my daughter's graduation ) she really want me to bring her with the max once it's ready and honestly I dont want to disappoint her and miss that honor.
Old Apr 6, 2008 | 09:13 AM
  #224
nismology's Avatar
Rating an oil pump in terms of HP makes no sense. Revs, not HP, kill oil pumps. Either by crank harmonic vibration, lack of volume, oil aeration, etc.
Old Apr 6, 2008 | 08:06 PM
  #225
doublea's Avatar
I should have said the Toga oil pump will hold up fine up to 8000 rpm & 800 hp.
Old Apr 7, 2008 | 10:29 PM
  #226
Turbo'd Saab
Hey grey99max, can I get a measurement on the pathy IM? As in how tall is it
I believe if I measured correctly I have 8" to work with from lower IM to hood. If worse comes to worse I will make a hood scoop
Old Apr 8, 2008 | 06:47 AM
  #227
grey99max's Avatar
LandShark has Cosworth
Sure, I can do that tonight - it's raining and storming - again - so no play time on the highways for me.
Are you thinking about trying this manifold ??
Old Apr 8, 2008 | 08:26 AM
  #228
Turbo'd Saab
Oh definetly if your measurements are what i want to see I will be ordering friday probably
Old Apr 8, 2008 | 11:21 AM
  #229
grey99max's Avatar
I don't want mine anymore - too bad you're not in the States, or you could have it...... although, if I had the '01 Pathy 3.5 LIM that matched my Pathy UIM, I wonder if that would fit on my 3.5L ??? Now that could make an interesting intake manifold.
I'll take photos with a ruler included, from all angles. I seem to remember that the UIM bolts don't all match up to the lower 3.0 LIM, but I gotta check - it's been a year or two since I looked at this.
Old Apr 8, 2008 | 01:51 PM
  #230
MOHFpro90's Avatar
He is in Fl...he just wants to be 'cool' and think he is part of top gear...I told him it would confuse people...
Old Apr 8, 2008 | 02:25 PM
  #231
grey99max's Avatar
well, it worked....
Old Apr 8, 2008 | 04:11 PM
  #232
Turbo'd Saab
I own a house in Surrey
I think its time I start my own NA thread
Old Apr 8, 2008 | 05:12 PM
  #233
MOHFpro90's Avatar
well, it worked....
Thats what I told him...see Dave...? haha.
Old Apr 14, 2008 | 04:18 PM
  #234
doublea's Avatar
I took the day off and finished the intake ports on the second heads, it's going much faster with the second head as I now have a mock up but better knowledge on how to do it. I should finish the exhaust port within about a week. The final polishing of the exhaust port will add another week to the work.
A+
Old Apr 16, 2008 | 10:35 AM
  #235
MOHFpro90's Avatar
Hey man,
Just wondering a few things about your pistons. You said they are 9.5:1 right? You got them custom made, how much did you pay Arias? Just doing some research for the fall project.
Old Apr 16, 2008 | 10:43 AM
  #236
doublea's Avatar
Yes the Arias piston are 9.5:1 C/R, I've purchased them from an org member and got it for 450$.
You may want to check with this company: http://www.importperformanceparts.net/
Old Apr 17, 2008 | 05:49 PM
  #237
MOHFpro90's Avatar
Some more questions:
Have you decided on cams yet? Just going to go stock 3.5?
Old Apr 18, 2008 | 08:14 AM
  #238
doublea's Avatar
Now I have the VQ35 cam with stephen's max cam adaptor, but depending on the cash flow when ready to re-assemble I may buy some e-bay or nismo knocker.
Old Apr 18, 2008 | 10:13 AM
  #239
nismology's Avatar
If you do decide to buy a knock-off please please PLEASE check the valve clearance before final assembly. The quality control just isn't there.
Old Apr 18, 2008 | 12:01 PM
  #240
doublea's Avatar
I said knocker but to be honest I've never made any research for cam. I'm not familiar with the available brand, so if I drop the VQ35 cam, I'll go with a brand name...
Nismology: Thanks for the hint about the cam, but which one would you use if you would be in my situation ?
