Best Way to Affix Tweeters under pillar?
Old May 22, 2005 | 07:11 AM
seventy5impala's Avatar
Hey, i was wondering whats the best method too use too affix some tweeters underneath the a pillar in 2k/5th gen maximas???....ive got the pos clarions out.... and its jsut bare metal under neath.... i thought maybe some double sided tape (says its out door and can hold up too 5 pounds) but the space on the back of the tweeter is so limited too actually gettin a good contact with the tape....anyone elseh ave any other sugestions? or what u used? how about velcro?
Old May 22, 2005 | 11:14 AM
slickrick's Avatar
i used double sided tape and have not had a problem yet.
Old May 22, 2005 | 01:27 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Take the stock tweet brackets out. Line up the new tweets inside the A pillars and use Hot Glue. Been working for me for years now.
Old May 22, 2005 | 02:01 PM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
i just drilled a small hole in the metal and put the bracket provided (smallest one) from the tweeter on that then, placed the tweeter in the bracket. if i ever need to take my a pillar totally off and put it outside of the car, i dont need to disconnect my tweeter.
Old May 22, 2005 | 02:36 PM
thanks for the suggestions... i went with an epoxy and velcro lol, it seems to be good, plus the piller sits pretty snug with them, so i think it should be all fine and dandy!.... now i jsutn eed my box 2marrow, and i can put my amps in.......the inside of the car is done.. wahoooooooooooooo
Old May 23, 2005 | 12:03 PM
unrealii's Avatar
I just duct taped mine to the apillar trim. I added foam weather stripping from home depot to prevent any rattles.
Old May 23, 2005 | 12:20 PM
durckelg's Avatar
Epoxy Putty is best. You can buy it at just about any HW store. It comes in an 1" thick by 6" long plastic tube. It is a much beter all-purpose product than even duct tape (jk). I have not used it for this in my Max, but I have use it in other cars.
Old May 23, 2005 | 02:08 PM
ionpcs's Avatar
All of you decided to attach it on the a-pillar? That's suprising. I was advised by the speaker manufacturers to not move them that far away from the speakers and told that a position in the door would be best. (It's also the easiest install available). I put them right in front of the door handles.
Old May 24, 2005 | 04:28 PM
Maxima112's Avatar
yes that may be the best, but then you already have holes in the apillar, why would you drill a new hole just for slightly, prob not a noticable quality difference compared to the a-pillar....most put it near the door handle when they do not have the tweet in the a pillar.
chisam14
Nov 6, 2018 08:56 PM
Matt93SE
Apr 8, 2018 09:23 AM
95naSTA
Sep 21, 2015 06:50 PM
delerium75
Aug 19, 2015 11:08 AM
MikesChevelle
Aug 9, 2015 11:50 AM
