Subwoofer went out.
Old Jan 27, 2006 | 09:20 PM
MaximaSE2005's Avatar
Subwoofer went out.
Hey guys, I need your help.
I was pumping my music really loud a couple of nights ago and the bass just went kaput. I'm not sure if my subwoofer went bad or if my amp went bad. When I play music now, sometimes the bass will come on just for a couple of seconds and then stops.
Any idea as to what happened? Anything that I can do to test to see what happened?
Your help as always is greatly appreciated.
Thanks!
Scott
Old Jan 27, 2006 | 09:33 PM
AscendantMax's Avatar
sounds like something came loose. check to see if all the connections are still secured.
Old Jan 27, 2006 | 09:41 PM
I opened up the box and check to make sure that the connections were secure and they were (meaning, the wires connecting the subwoofer to the box). I checked my the speaker wires connected to the amp and they were secure. The only thing that I did not check was the PAC adaptor. I want to see if there is anything else I can check before taking the dash apart again. If there are no more suggestions then I guess I'm going to have to take the dash apart and check the RCA connections. I hope that I did not blow my sub or amp. I only set the gain to about 75% and the bass boost to about 15%, plus the I'm pretty sure the 12" L7 can handle more power that I am pushing to it with the Kicker 600W amp.
Thanks again for your help!
Old Jan 27, 2006 | 10:26 PM
hmm....so the bass cuts on and off periodically? is the amp in protect mode when it stops?
Old Jan 27, 2006 | 10:47 PM
Actually, the bass has completely stopped now. I don't hear anything coming from the subwoofer.
I double check my connections tomorrow and let you guys know. I'll try disconnecting the speaker wires completely and then I will try to rewire them again.
Will let you guys know what happened when I find out.
Old Jan 27, 2006 | 11:03 PM
kpr10is's Avatar
+1 on whether or not the amp is going into protect mode?
Do you have a multimeter to test the sub? Could be that the sub is fried and if you hit a bump while driving the sub jump starts and plays shortly since the resistance changes. Could also be as simple as a fuse thats almost blown, but makes contact every once in a while.
Old Jan 27, 2006 | 11:08 PM
about the fuse
had a similar situation where the sub would cut in and out at random, and the fuse looked fine. but when i took the fuse out, one of the end caps came off completely. so it was a faulty fuse...changed it, no more problems afterwards.
Old Jan 27, 2006 | 11:38 PM
PandaXpress's Avatar
Originally Posted by AscendantMax
about the fuse
yep..same problem..fuse looked fine, but wasnt..check on the amp to the sub and also the fuse on the wire from your 12V source that powers the amp.
Old Jan 28, 2006 | 05:21 AM
nismos14's Avatar
§è~® f®ÈÄk
Go with what these guys said but also check amp side of the ground and chassis side of ground, remote wires, connections behind the HU, and connections at the battery. Also I would consider re-tuning the amp a bit, that gain is set pretty high, I a$$ume your also utilizing a remote gain/bass control.
Old Jan 28, 2006 | 09:14 AM
Thanks guys for all the great suggestions. I will definitely check the fuses. And yes I do have a remote gain which is also at 75 - 80%.
Another question, how do I know if the amp is in protect mode?
Thanks again.
Old Jan 28, 2006 | 09:29 AM
look on the amp itself. should be some sort of a LED indicator that the amp is in protect mode.
Old Jan 28, 2006 | 11:28 AM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
for the remote gain at 75-80 what do you have the amp gain at? and does it make a difference if you turn the amp gain up or down with the remote gain all the way up?
Old Jan 28, 2006 | 04:45 PM
i thank god for avatars like yours
Old Jan 28, 2006 | 08:37 PM
Hey guys. I took a look at the amp and the protection mode light was not on. So, I guess that it did not go into protection mode, right? Anyways, the amp seems fine, I'm guessing right now that my sub has blown. I am going to try to connect it to another subwoofer to see if it is in fact the subwoofer. Will keep you guys updated on the situation. It really sucks that I am stuck with the factory bass. It was such a HUGE difference.
Old Feb 23, 2006 | 07:48 PM
Hey guys, thanks again for your help. I just finally found the time to fix the problem. It seems like the problem came from the wiring inside the box.
The first thing I did was change the speaker wire that connected the amp to the box and that did not fix it.
The next thing I did was take out the subwoofer from the box and rewire everything with new wires and now it works. I guess, something must of came loose or a wire went bad (not sure if wires can go bad).
Anyways, I'm glad that I didn't need to take apart the dash to fix the problem. That would of been time consuming.
Thanks again guys for your help. I am so... glad to have my bass back. The factory bass just doesn't sound as good.
Old Feb 23, 2006 | 07:50 PM
nismos14's Avatar
§è~® f®ÈÄk
Congrats man!
Old Feb 23, 2006 | 08:06 PM
djfrestyl's Avatar
Suspension Yoda
Glad it worked out.
For future reference, if taking apart the 6th gen dash is so bad, you can just meter your RCA's (at the amp) to see if you're actually getting signal....
Old Feb 23, 2006 | 08:31 PM
Glad it worked out.
Thanks! Taking apart the dash is not so bad, if I had time and if the weather here was warmer. lol! Thanks again for the heads up on metering the RCA's (at the amp), I will remember that for future references.
Old Feb 23, 2006 | 08:33 PM
djfrestyl's Avatar
Suspension Yoda
The weather is the primary reason I'm not working on many cars.
A meter is your friend, everyone with anything more than a somewhat standard system should have one, or at least access to one for troubleshooting.
TallTom
57
Oct 14, 2025 05:16 PM
mclasser
22
Nov 12, 2020 01:58 PM
howardis
Dec 11, 2019 06:10 PM
mpbclutch33
Dec 26, 2015 11:11 AM
sliptap
Sep 30, 2015 05:57 AM
