Eclipse AVN6620?
Old Sep 12, 2008 | 09:15 AM
  #121
Pearl96Max's Avatar
I tend to get a bit irritable
Originally Posted by maxprivate
You guys know if there is a way to have the antenna only power extend when I am listening to the FM/AM radio? I don't like the fact that if Im using a CD, Ipod, or even watching a movie that the antenna is always extended. When I had my Bose radio the Antenna would extend only when listening to FM/AM radio.
Did you connect the right wire to the power antenna lead? Blue is power ant and Blue/White is remote turn on. I know the latter of the two is right, can you confirm the first?
Old Sep 12, 2008 | 09:43 AM
  #122
maxprivate's Avatar
Black Lion
I didn't connect anything my friend. I think parag made the connections at the headunit. but when I get to it ill confirm. I was looking on shaving the anntenna all together and adding an aftermarket. maybe something similar to the audi anntenna or the bmw. I was going to ask your opinion because on a aftermarket anntenna. I hear you lose the am reception (which I listen to occasionally ) when shaving and removing the stock anntenna .
Old Sep 12, 2008 | 09:46 AM
  #123
Pearl96Max's Avatar
I thought you put in the AVN yourself the night you took it home?
Old Sep 12, 2008 | 10:05 AM
  #124
maxprivate's Avatar
Black Lion
aahhh memory refreshener. yeah I did.. parag hooked up the wires for the spd sensor and backup camera. So I don't want the anntenna to power on unless I am using FM or AM. so I guess adding a switch is my only option? or removing the stock antenna all together and adding a roof mount which I hear will have bad reception for AM.
Old Sep 12, 2008 | 10:08 AM
  #125
Pearl96Max's Avatar
No, how would that be your only option? Connect the power antenna wire from the HU to the power antenna lead on the car.
Old Sep 12, 2008 | 10:17 AM
  #126
maxprivate's Avatar
Black Lion
I thought it was like that now. evertime the headunit is powered...the antenna extends. this is what I don't want.
Old Sep 12, 2008 | 10:21 AM
  #127
Pearl96Max's Avatar
And THAT would be using the remote out and Not the power antenna lead.
Old Sep 12, 2008 | 10:25 AM
  #128
maxprivate's Avatar
Black Lion
so if I use the remote antenna lead (this on the headunit?) then the antenna would only extend when I turn on FM AM?
Old Sep 12, 2008 | 10:29 AM
  #129
Pearl96Max's Avatar
That should be correct.
Old Sep 12, 2008 | 10:42 AM
  #130
maxprivate's Avatar
Black Lion
damn I wish I knew that first time. I remember asking Parag about it and he didn't have much to say about it. So power antenna wire makes the antenna power any time the headunit is on... and remote wire only when I turn on FM AM correct? maybe it wasn't parag I asked.... it was someone on the Org and they said that's the way it worked . So great ... I do this switch of the wires and problem solved I hope. So now I can leave my antenna alone.
Old Sep 12, 2008 | 10:51 AM
  #131
Pearl96Max's Avatar
Umm negative. Power antenna wire is for the antenna Only. Remote turn on is for the amps and remains on always while any source is played.
Old Sep 12, 2008 | 11:03 AM
  #132
maxprivate's Avatar
Black Lion
Now im all confused . How is the antenna supposed to function with the AVN? I know with the Bose headunit it would only power when I turne on FM or AM radio. So your saying I may have the antenna wired to the remote power lead which supplies constant power to the amps providing the audio is on?
Old Sep 12, 2008 | 11:16 AM
  #133
Pearl96Max's Avatar
Yes.
Old Nov 1, 2008 | 09:48 PM
  #134
maxprivate's Avatar
Black Lion
6620 problem
My 6620 is not playing any cd's or dvd's when I insert a cd or dvd in the slot I get a check disc display All other functions are working fine. Anyone have any Idea what can be going on here? i tried different cd and dvd and powering the unit off and the problem wont go away. Please help!
Old Nov 4, 2008 | 05:33 AM
  #135
MHLY01's Avatar
I have the older version, works well and great sounding
Old Nov 4, 2008 | 05:39 AM
  #136
maxprivate's Avatar
Black Lion
OK that's Great but how does this help me?
Old Nov 25, 2008 | 03:17 PM
  #137
maxprivate's Avatar
Black Lion
Well Im pleased to say that I was warranted a brand new head unit from Eclipse . Thanks to Don for the fast service and hooking me up. I new he would come through.
Old Jan 6, 2009 | 09:06 AM
  #138
ZzSlOtHzZ's Avatar
Problem with AVN 6620 and 03 Maxima.
Does anyone have a problem with the Nav moving on it's own? The speed sensor is saying I'm moving even though I'm in park. Will resetting the ECU fix the problem? I've tried to reset the ECU following directions from the other forums, but I guess my timing is way off. Is turning key on then pressing accelerator, etc... the only way to reset the ecu? Need help thanks.
Old May 27, 2010 | 02:07 PM
  #139
maxprivate's Avatar
Black Lion
This is old I know, but Im having the same problem. The GPS is not staying on its course at all and I keep loosing the signal.
hawkdog
Apr 22, 2001 04:52 PM
RaYnMeLa
Apr 17, 2001 06:20 PM
wesley
Feb 2, 2001 01:31 PM
QUANSUNG
Dec 7, 2000 01:29 AM
