NEED HELP RUNNING POWER WIRE THROUGH FIREWALL
Old Apr 9, 2012 | 07:20 PM
jsantoslive's Avatar
I have an 04 maxima manual I need help on where to run the power wire for my amp from the battery. I don't really want to drill bc im not sure where a safe spot to do it would be...I've heard taking the tire off but that's kind of alot of work there has to be an easier way can someone please help me...thanks ...I've also heard running in through the steering collum is that a good/easy place to do it?
Old Apr 10, 2012 | 08:08 AM
installer's Avatar
hi how are you dont run it through the steering column or through the fender do you have a clutch pedal if not there is a plate where the pedal belongs that you can drill through safely that is the best spot
Old Apr 10, 2012 | 01:44 PM
AscendantMax's Avatar
The area near the clutch master cylinder is a common site for 6th gens. Just crawl under the dash and look up, there's a lot of area that you can safely drill through (I recommend using a nice step-bit to do so. It made the task very easy when I drilled through my firewall).
Others have snaked it through the wire grommet.
Old Apr 11, 2012 | 12:27 PM
IDvsEGO's Avatar
I havent checked ont he maxi yet but on my chevelle I actually ran it under the car along with the stock wiring cluster to the trunk, then up through the drain hole. The cable is protected from road debris by the frame. But that was 0 awg so it was too big to go under the carpet.
Old Apr 12, 2012 | 08:42 PM
Andrew's Avatar
Hope this helps. Wrote this up a few years ago.
http://nycmaximas.org/showthread.php?t=53338
vybz05
Dec 10, 2015 07:38 PM
sake1bs
Sep 19, 2015 09:32 PM
conansriver
Sep 3, 2015 06:38 AM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
