The Poorman's HAI...
Originally posted by costcowholesale
guys I couldn't get this screw out
its like stuck, I can't dettach the airbox with the intake pipe, how do I do this?
heres my filter waiting to be install
Originally posted by maxstyle98
You didn't use a 10mm socket????
http://images.cardomain.com/installs...65_33_full.jpg
its done!
its done!
Finally!-Cyrus
Re: anyone know if this will work on vg?
Originally posted by darrick
thanks
thanks
-Cyrus
whats a intake resonator? I think i have that
The black box which the hoses connect to is the resonator; the accordian section behind it is also probably restrictive.
Here is the "Powered by Home Depot" mod that I'll probably do soon.
The Poor Man's Intake v2.0
but isnt a good part about buying the expensive intake is that it comes w/ a good k&n filter? i wouldnt think that the cheapo filters flow as much air, are as good of quality, etc...example: k&n drop in filters are about 4 times more expensive than regular drop in ones, but "supposedly" flow more air, give u about 1-2 horses....
Well, I cant speak on facts here becase i havent tested the two but...
I have a K&N on the LT1 in our boat and one in our Suburban. If anything the $15 no-name filter I have looks higher quality then the K&N's. As to filtering performance, the actual filter material looks exactly the same except the K&N's are dark red and mine was silver before I oiled it.
Originally posted by Vyrus
I made sure my plate was flat and there was no air leaking, so I didn't need it. It all depends on how careful you are prying the plate off.
-Cyrus
-Cyrus
Originally posted by TylerBorg
do i need to reset the ECU? I did this and it sounds great!
-Cyrus
Originally posted by DerekJ212
Why does everyone say they are making gaskets? What are those, how are they made and is it neccesary?
the brass looking piece doesnt seal completely with the intake cone.... thats why some people use duct tape or something ( gaskets ) to seal it.... i used electrical tape to make sure
Only part I am confused/scared with is the sensor. Ive heard blown MAFS are expensive and I am not sure what to do with it!
I just did this with some 3A Racing generic $29.99 air filter. Brass plate is HARD to get off and I bent it up good...used a hammer to get it back in place as good as i could. Anyways, put it on, had some trouble with the screws, started the car and CEL. I forgot to hook up MAF....reset...battery off, and CEL went off. Test drove, no difference unless youre almost on the floor above 3500 which is nice. However, at around 5500+ sounds almost a little ricey. I taped up the sides so I dont think I have much of an air leak if one at all...not so sure about the sound...performance is the same.
Dave B
Oct 20, 2002 12:59 AM
sickmen
30
Aug 28, 2001 06:23 PM
Dave B
Mar 7, 2001 09:30 PM
Dave B
Mar 5, 2001 10:30 PM
