Schmellyfart's 4th gen
Jun 9, 2013 | 03:47 PM
  #201
Quote: That's awful, especially from an I4! How much do those cars weigh?
Around 2860lbs....E10 really killed the mpg in this car, I lost an easy 3mpg by my long term calculations and the 4spd auto doesn't help.
Plus when I installed the 4.08FD auto, I left the '93 TCM because I would have to have made some kind of conversion harness to plug the 2001 auto TCM into my '93 and I didn't feel like fooling with it so the TC doesn't lockup at highway speeds. It runs about 300rpm higher than a stock 2001 Altima but babying it, we get around 21 mixed. On the plus side, it can spin the tires from a roll in first gear w/the shorter gearing and bolt ons.
FWIW, Fueleconomy.gov has the 2.4 auto Altima rerated (around '07??) at 19/26, down from the original 23/29 rating lol!
Jul 7, 2013 | 10:58 AM
  #202
Took a little road trip up to Sedona for the weekend.
Sep 15, 2013 | 12:08 AM
  #203
About ready to pull the trigger on a 75mm tb.
Here it is compared to the tb inlet on the elbow.
Sep 15, 2013 | 02:07 AM
  #204
In for dyno.
Sep 15, 2013 | 09:46 AM
  #205
Probably won't be renting any dyno time until December.
I was also looking into an 80mm tb but there just isn't enough material on the elbow.
Sep 15, 2013 | 10:09 AM
  #206
Arizona is beautiful
Sep 15, 2013 | 05:47 PM
  #207
Quote: Arizona is beautiful
The auction ended for that large 75mm tb, and everyone else wants $130+ for the same style.
There's a newer, smaller 75mm tb that I can get for $64 shipped. I'll just have to run an external IACV.
Oct 23, 2013 | 08:14 PM
  #208
Meh I guess I'll post this here too.
Quote: Finally got a chance to dyno the swap today. I decided to spring the extra $10 for an AFR reading since my EU is disconnected. Grand total: $30 for two pulls.
Same shop/dyno I used for my previous pulls with the 3.0.
Minor changes that might affect readings:
~New tires 245/50R16.
~Finally had the car aligned after the swap.
Current setup:
+02 VQ35 w/3.0 timing, DE-K Injectors & FPR, return fuel setup
+Stock 5th gen intake w/ bomz cone filter
+PFTB
+NWP BOP
+NWP 5pc spacers
+Altima headers w/ 3" y pipe back
Fuel and timing are bone stock, no adjustments made.
236.96whp/221.51wtq
Nov 15, 2013 | 07:29 PM
  #209
Weighed the car today on the way home from work.
1997 SE, 5MT, VQ35, tan cloth, sunroof, spoiler removed.
3100 lbs w/driver and 1/4 tank of gas.
Filled up the tank 10 miles later with 13.9 gallons. At the tank average of 25.2 mpg, I used 0.39 gallons of fuel driving from the weigh station to the gas station. This leaves me missing 13.5 gallons of fuel at the time of weighing. Assuming 6.25lbs per gallon of gas, that will add 84lbs to this weight with a full tank of gas.
I need to weigh the random extra stuff sitting in my car. This was with the RX7 wheels and same mods as my recent dyno and 1/4 miles pass.
So a couple quick numbers with extra junk in the car:
Car w/ driver, 1/4 tank of gas: 3100lbs
Car w/o driver, 1/4 tank of gas: 2930lbs
Car w/o driver, full tank of gas: 3014lbs
Nov 15, 2013 | 08:51 PM
  #210
Wow your max is pretty light. Mine is 2700lbs curb weight.
Nov 16, 2013 | 08:20 AM
  #211
Not really, I was a little disappointed to be honest. Most sites I've seen state a curb weight of 2800lbs. That's probably for the 95 now that I think about it.
Nov 16, 2013 | 12:10 PM
  #212
Just weighed all the tools and extra crap in my car. 51.6lbs
That comes out to:
Car w/ driver, 1/4 tank of gas: ~3045lbs depending on the last time I took a dump.
Car w/o driver, 1/4 tank of gas: 2878.4lbs
Car w/o driver, full tank of gas: 2962.4lbs
Nov 16, 2013 | 02:36 PM
  #213
For a maxima that seems very light to me, especially with a bigger displacement engine
Nov 16, 2013 | 03:29 PM
  #214
Quote: For a maxima that seems very light to me, especially with a bigger displacement engine
He forgot to mention he has helium compartments on his car.
That's cool to find out weights ya head tapper.
Nov 16, 2013 | 10:50 PM
  #215
That's part of why the 4th gen is so awesome! The 3.5 is actually lighter due to the plastic valve covers among other things.
lololol been spending time on my youtube, eh?
Nov 16, 2013 | 10:58 PM
  #216
Quote: That's part of why the 4th gen is so awesome! The 3.5 is actually lighter due to the plastic valve covers among other things. lololol been spending time on my youtube, eh?
x2
Dec 29, 2013 | 08:10 PM
  #217
Did a little bit of work on the car today after a successful junkyard run.
First up was a neat little EVAP cover I found.
Next up was this
Dropped 19.13lbs when all said and done today. This brings my vehicle weight, full tank of gas, to 2943.27lbs.
Also weighed some lug nuts on my tiny new scale.
OEM Acorn lug nut: 0.074 lbs each
OEM 3rd gen open ended lug nut: 0.060 lbs each
Drag Aluminum lug nut: 0.046 lbs each
Dec 29, 2013 | 09:02 PM
  #218
I've been kicking around the idea of a smaller fuel tank. Checked out a 13.2 gal B14 gas tank.
Hoses line up just fine, though I just realized I forgot to check the access cover once I had the B14 tank 'mounted' on the A32. Oops.
B14 tank bolts to the unibody around the perimeter of the tank.
A32 tank uses two straps running underneath the tank.
The fuel tank strap on the driver side bolted up without much hassle. The passenger side strap wasn't so easy.
A32 FSU has one more sensor than the B14. I'm doing some FSM diving to see what it is. I'm thinking fuel temp. Due to that, the B14 FSU has one less pin on the fuel level sender connector.
The return line on the B14 FSU is connected to a hose whereas the A32 just has a tube going into the tank.
B14 FSU
A32 FSU
B14 top
A32 bottom
Hoses line up
At this point I was just tired of messing with it. The tank was hitting the exhaust heat shields and possibly the evap stuff too. So a custom mounting soultion would be needed to mount the tank level.
Dec 30, 2013 | 05:27 PM
  #219
Dec 31, 2013 | 05:34 PM
  #220
Hmm I'm not a fan of the new front bumper, but I'm assuming you're doing this for MPG purposes?
Good work though
Dec 31, 2013 | 08:47 PM
  #221
Its going to take some getting used to. I am going to reinstall the clear turn signals soon.
MPG is the reason behind the 95-96 bumper. My old bumper was done, peeling clear coat, fading paint, bondo from an accident 15 years ago was cracking. So its time for a change that may help with the sleeper look I'm going for.
Snagged this one up in pretty good condition for only $20 with the grille and AL bumper support.
Dec 31, 2013 | 11:50 PM
  #222
Upper radiator hose just blew out on me
Jan 1, 2014 | 12:30 AM
  #223
Quote: Upper radiator hose just blew out on me
Original equipment?
Didn't leave you stranded, did it?
Jan 1, 2014 | 09:57 AM
  #224
Yes and yes. Pulled over as soon as I saw smoke coming out of my hood. Popped the hood and was greeted with the classic cloud of white smoke and coolant all over the place.
The timing sucks though since I also need to replace the water pipe gaskets on the front and rear heads, but Nissan is closed today so I can't get the gaskets.
Jan 1, 2014 | 02:10 PM
  #225
I blame your brother.
Jan 1, 2014 | 02:39 PM
  #226
Funny you say that. It happened on my way back after dropping him off at his friends house last night.
Jan 2, 2014 | 04:29 PM
  #227
Much better
Jan 4, 2014 | 05:12 PM
  #228
-3.4lbs
Total weight: 2939.87lbs
I also removed the screws holding the timing ring on and put a dab of loctite on them.
Jan 4, 2014 | 05:26 PM
  #229
The front looks much better now. UD Pulley adds a nice touch
Jan 4, 2014 | 05:35 PM
  #230
I tossed on a rear 5.5gen nissan burger on the front as well :3
Will snap some more pics when I get around to washing the car.
Jan 8, 2014 | 10:41 PM
  #231
Rear beam = 74lbs
Progress RSB w/ all mounting hardware = 16lbs
With half of the RSB weight being unsprung, that's quite a bit of weight. Makes me curious as to what the FSB weighs.
Jan 9, 2014 | 01:18 AM
  #232
When's the sunroof delete?
Jan 9, 2014 | 08:33 AM
  #233
Quote: When's the sunroof delete?
This guy
Jan 9, 2014 | 09:06 AM
  #234
After I decide how I'm gonna fill the hole. Was thinking about something like the 2jr b15 sunroof delete, but I don't like how non-OEM it looks. It may blend in better with my dark colored car, though.
Jan 9, 2014 | 09:09 AM
  #235
Quote: This guy
I'm serious.
Jan 9, 2014 | 09:59 AM
  #236
Quote: I'm serious.
Whattt? I didn't know this is possible
Jan 9, 2014 | 11:51 AM
  #237
That sunroof delete looks legit. I'm digging that. Wonder how much weight that drops? Im installing a civic sized battery this weekend. I really need to weigh my car to compare. A lot of cool ideas in this thread. Keep it up.
Jan 9, 2014 | 06:26 PM
  #238
I think its around 60-75lbs for the B15 guys. However I'm only going to guess 30lbs so I'm not disappointed when I weigh mine
I'm running a 17lb, $20 lawn mower battery at the moment. Just be mindful of your accessories/lights when the engine isn't running and you'll be fine.
I am considering swapping it out for a 13lb battery that's in my Harbor Freight Jump pack.
Jan 9, 2014 | 09:09 PM
  #239
ES bushings are 0.308 lbs heavier than the OEMs cut out of the trailing arm.
2940.178lbs
Jan 9, 2014 | 10:53 PM
  #240
^^ I REALLY need to do that as well.
Looks good.
I've been thinking about a sunroof delete.
My buddy has a BMW that he found a kit for that makes it look flush.
I'm going to test fit it on mine just because.
I'll report if that turns up anything.
Make sure you wear shorts, sandals, a wife-beater, and get a hair cut on track day.
